[PATCH v5] reset: socfpga: Poll for reset status after deassert reset
In Cyclone 5 SoC platform, the first USB probing is failed but second probing is success. DWC2 USB driver read gsnpsid register right after de-assert reset, but controller is not ready yet and it returns gsnpsid 0. Polling reset status after de-assert reset to solve the issue.
Retry with this fix more than 10 times without issue.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com
--- v5: - Change to use wait_for_bit_le32().
v4: - Change to use get_timer() for timeout. - https://patchwork.ozlabs.org/patch/1219487/
v3: - Remove _status callback and poll reset status after deassert reset - https://patchwork.ozlabs.org/patch/1218026/
v2: - https://patchwork.ozlabs.org/cover/1215174/
v1: - https://patchwork.ozlabs.org/patch/1214841/ --- drivers/reset/reset-socfpga.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/drivers/reset/reset-socfpga.c b/drivers/reset/reset-socfpga.c index 93ec9cfdb6..105ce94c71 100644 --- a/drivers/reset/reset-socfpga.c +++ b/drivers/reset/reset-socfpga.c @@ -18,6 +18,7 @@ #include <dm/of_access.h> #include <env.h> #include <reset-uclass.h> +#include <wait_bit.h> #include <linux/bitops.h> #include <linux/io.h> #include <linux/sizes.h> @@ -80,7 +81,10 @@ static int socfpga_reset_deassert(struct reset_ctl *reset_ctl) int offset = id % (reg_width * BITS_PER_BYTE);
clrbits_le32(data->modrst_base + (bank * BANK_INCREMENT), BIT(offset)); - return 0; + + return wait_for_bit_le32(data->modrst_base + (bank * BANK_INCREMENT), + BIT(offset), + false, 500, false); }
static int socfpga_reset_request(struct reset_ctl *reset_ctl)
Applied, thanks.
Ley Foon Tan
