[U-Boot] [PATCH] arc: get rid of running_on_hw
ISS is obsolete now and nSIM is used for simulation instead. In its turn nSIM properly handles baud-rate settings so get rid of now useless check.
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com --- arch/arc/include/asm/global_data.h | 1 - arch/arc/lib/cpu.c | 6 ------ drivers/serial/serial_arc.c | 16 ---------------- 3 files changed, 23 deletions(-)
diff --git a/arch/arc/include/asm/global_data.h b/arch/arc/include/asm/global_data.h index d644e80..e25b966 100644 --- a/arch/arc/include/asm/global_data.h +++ b/arch/arc/include/asm/global_data.h @@ -9,7 +9,6 @@
/* Architecture-specific global data */ struct arch_global_data { - int running_on_hw; };
#include <asm-generic/global_data.h> diff --git a/arch/arc/lib/cpu.c b/arch/arc/lib/cpu.c index 4e4dd74..d1f10ab 100644 --- a/arch/arc/lib/cpu.c +++ b/arch/arc/lib/cpu.c @@ -14,12 +14,6 @@ int arch_cpu_init(void) { timer_init();
-/* In simulation (ISS) "CHIPID" and "ARCNUM" are all "ff" */ - if ((read_aux_reg(ARC_AUX_IDENTITY) & 0xffffff00) == 0xffffff00) - gd->arch.running_on_hw = 0; - else - gd->arch.running_on_hw = 1; - gd->cpu_clk = CONFIG_SYS_CLK_FREQ; gd->ram_size = CONFIG_SYS_SDRAM_SIZE;
diff --git a/drivers/serial/serial_arc.c b/drivers/serial/serial_arc.c index 7dbb49f..36d6404 100644 --- a/drivers/serial/serial_arc.c +++ b/drivers/serial/serial_arc.c @@ -42,23 +42,7 @@ static int arc_serial_setbrg(struct udevice *dev, int baudrate) int arc_console_baud = gd->cpu_clk / (baudrate * 4) - 1;
writeb(arc_console_baud & 0xff, ®s->baudl); - -#ifdef CONFIG_ARC - /* - * UART ISS(Instruction Set simulator) emulation has a subtle bug: - * A existing value of Baudh = 0 is used as a indication to startup - * it's internal state machine. - * Thus if baudh is set to 0, 2 times, it chokes. - * This happens with BAUD=115200 and the formaula above - * Until that is fixed, when running on ISS, we will set baudh to !0 - */ - if (gd->arch.running_on_hw) - writeb((arc_console_baud & 0xff00) >> 8, ®s->baudh); - else - writeb(1, ®s->baudh); -#else writeb((arc_console_baud & 0xff00) >> 8, ®s->baudh); -#endif
return 0; }
Applied to u-boot-arc, thanks.
-Alexey
Alexey Brodkin
