[PATCH 0/2] fix issues in bootmenu after adding efi entries
This series fixes the issue in bootmenu after adding efi entries.
Masahisa Kojima (2): bootmenu: use utf-8 for menu title bootmenu: U-Boot console is enabled as default
boot/Kconfig | 9 +++++++++ cmd/Kconfig | 10 ---------- cmd/bootmenu.c | 40 +++++++++++++++++++++++----------------- 3 files changed, 32 insertions(+), 27 deletions(-)
The commit a3d0aa87acbe ("bootmenu: update bootmenu_entry structure") changes the bootmenu title type from char to u16(UTF16 string) to support EFI based system. If EFI_LOADER is not enabled, printf("%ls") is not supported, so bootmenu does not appear correctly.
This commit changes the type of menu title from u16(UTF16) to utf-8 string and EFI strings is conveted into utf-8.
Fixes: a3d0aa87acbe ("bootmenu: update bootmenu_entry structure") Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- cmd/bootmenu.c | 36 +++++++++++++++++++++--------------- 1 file changed, 21 insertions(+), 15 deletions(-)
diff --git a/cmd/bootmenu.c b/cmd/bootmenu.c index 8859eebea5..bf88c2127b 100644 --- a/cmd/bootmenu.c +++ b/cmd/bootmenu.c @@ -43,7 +43,7 @@ enum boot_type { struct bootmenu_entry { unsigned short int num; /* unique number 0 .. MAX_COUNT */ char key[3]; /* key identifier of number */ - u16 *title; /* title of entry */ + char *title; /* title of entry */ char *command; /* hush command of entry */ enum boot_type type; /* boot type of entry */ u16 bootorder; /* order for each boot type */ @@ -76,7 +76,7 @@ static void bootmenu_print_entry(void *data) if (reverse) puts(ANSI_COLOR_REVERSE);
- printf("%ls", entry->title); + printf("%s", entry->title);
if (reverse) puts(ANSI_COLOR_RESET); @@ -170,7 +170,7 @@ static int prepare_bootmenu_entry(struct bootmenu_data *menu, struct bootmenu_entry *iter = *current;
while ((option = bootmenu_getoption(i))) { - u16 *buf; + char *buf;
sep = strchr(option, '='); if (!sep) { @@ -183,13 +183,13 @@ static int prepare_bootmenu_entry(struct bootmenu_data *menu, return -ENOMEM;
len = sep-option; - buf = calloc(1, (len + 1) * sizeof(u16)); + buf = calloc(1, (len + 1)); entry->title = buf; if (!entry->title) { free(entry); return -ENOMEM; } - utf8_utf16_strncpy(&buf, option, len); + strncpy(buf, option, len);
len = strlen(sep + 1); entry->command = malloc(len + 1); @@ -227,6 +227,7 @@ static int prepare_bootmenu_entry(struct bootmenu_data *menu, return 1; }
+#if (CONFIG_IS_ENABLED(CMD_BOOTEFI_BOOTMGR)) /** * prepare_uefi_bootorder_entry() - generate the uefi bootmenu entries * @@ -279,13 +280,17 @@ static int prepare_uefi_bootorder_entry(struct bootmenu_data *menu, }
if (lo.attributes & LOAD_OPTION_ACTIVE) { - entry->title = u16_strdup(lo.label); - if (!entry->title) { + char *buf; + + buf = calloc(1, utf16_utf8_strlen(lo.label) + 1); + if (!buf) { free(load_option); free(entry); free(bootorder); return -ENOMEM; } + entry->title = buf; + utf16_utf8_strncpy(&buf, lo.label, u16_strlen(lo.label)); entry->command = strdup("bootefi bootmgr"); sprintf(entry->key, "%d", i); entry->num = i; @@ -315,6 +320,7 @@ static int prepare_uefi_bootorder_entry(struct bootmenu_data *menu,
return 1; } +#endif
static struct bootmenu_data *bootmenu_create(int delay) { @@ -341,13 +347,13 @@ static struct bootmenu_data *bootmenu_create(int delay) if (ret < 0) goto cleanup;
- if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR)) { - if (i < MAX_COUNT - 1) { +#if (CONFIG_IS_ENABLED(CMD_BOOTEFI_BOOTMGR)) + if (i < MAX_COUNT - 1) { ret = prepare_uefi_bootorder_entry(menu, &iter, &i); if (ret < 0 && ret != -ENOENT) goto cleanup; - } } +#endif
/* Add U-Boot console entry at the end */ if (i <= MAX_COUNT - 1) { @@ -357,9 +363,9 @@ static struct bootmenu_data *bootmenu_create(int delay)
/* Add Quit entry if entering U-Boot console is disabled */ if (IS_ENABLED(CONFIG_CMD_BOOTMENU_ENTER_UBOOT_CONSOLE)) - entry->title = u16_strdup(u"U-Boot console"); + entry->title = strdup("U-Boot console"); else - entry->title = u16_strdup(u"Quit"); + entry->title = strdup("Quit");
if (!entry->title) { free(entry); @@ -461,7 +467,7 @@ static enum bootmenu_ret bootmenu_show(int delay) int cmd_ret; int init = 0; void *choice = NULL; - u16 *title = NULL; + char *title = NULL; char *command = NULL; struct menu *menu; struct bootmenu_entry *iter; @@ -517,7 +523,7 @@ static enum bootmenu_ret bootmenu_show(int delay)
if (menu_get_choice(menu, &choice) == 1) { iter = choice; - title = u16_strdup(iter->title); + title = strdup(iter->title); command = strdup(iter->command);
/* last entry is U-Boot console or Quit */ @@ -561,7 +567,7 @@ cleanup: }
if (title && command) { - debug("Starting entry '%ls'\n", title); + debug("Starting entry '%s'\n", title); free(title); if (efi_ret == EFI_SUCCESS) cmd_ret = run_command(command, 0);
The commit 2158b0da220c ("bootmenu: add Kconfig option not to enter U-Boot console") disables to enter U-Boot console from bootmenu as default, this change affects the existing bootmenu users.
This commit reverts the default behavior, the bootmenu can enter U-Boot console same as before. CMD_BOOTMENU_ENTER_UBOOT_CONSOLE is renamed BOOTMENU_DISABLE_UBOOT_CONSOLE and depends on AUTOBOOT_MENU_SHOW.
Fixes: 2158b0da220c ("bootmenu: add Kconfig option not to enter U-Boot console") Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- boot/Kconfig | 9 +++++++++ cmd/Kconfig | 10 ---------- cmd/bootmenu.c | 4 ++-- 3 files changed, 11 insertions(+), 12 deletions(-)
diff --git a/boot/Kconfig b/boot/Kconfig index dff4d23b88..2eae3d5c6b 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -1143,6 +1143,15 @@ config AUTOBOOT_MENU_SHOW environmnent variable (if enabled) and before handling the boot delay. See README.bootmenu for more details.
+config BOOTMENU_DISABLE_UBOOT_CONSOLE + bool "Disallow bootmenu to enter the U-Boot console" + depends on AUTOBOOT_MENU_SHOW + default n + help + If this option is enabled, user can not enter + the U-Boot console from bootmenu. It increases + the system security. + config BOOT_RETRY bool "Boot retry feature" help diff --git a/cmd/Kconfig b/cmd/Kconfig index 69c1814d24..09193b61b9 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -357,16 +357,6 @@ config CMD_BOOTMENU help Add an ANSI terminal boot menu command.
-config CMD_BOOTMENU_ENTER_UBOOT_CONSOLE - bool "Allow Bootmenu to enter the U-Boot console" - depends on CMD_BOOTMENU - default n - help - Add an entry to enter U-Boot console in bootmenu. - If this option is disabled, user can not enter - the U-Boot console from bootmenu. It increases - the system security. - config CMD_ADTIMG bool "adtimg" help diff --git a/cmd/bootmenu.c b/cmd/bootmenu.c index bf88c2127b..1002c6b20a 100644 --- a/cmd/bootmenu.c +++ b/cmd/bootmenu.c @@ -362,7 +362,7 @@ static struct bootmenu_data *bootmenu_create(int delay) goto cleanup;
/* Add Quit entry if entering U-Boot console is disabled */ - if (IS_ENABLED(CONFIG_CMD_BOOTMENU_ENTER_UBOOT_CONSOLE)) + if (!IS_ENABLED(CONFIG_BOOTMENU_DISABLE_UBOOT_CONSOLE)) entry->title = strdup("U-Boot console"); else entry->title = strdup("Quit"); @@ -595,7 +595,7 @@ int menu_show(int bootdelay) if (ret == BOOTMENU_RET_UPDATED) continue;
- if (!IS_ENABLED(CONFIG_CMD_BOOTMENU_ENTER_UBOOT_CONSOLE)) { + if (IS_ENABLED(CONFIG_BOOTMENU_DISABLE_UBOOT_CONSOLE)) { if (ret == BOOTMENU_RET_QUIT) { /* default boot process */ if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR))
On 5/25/22 10:18, Masahisa Kojima wrote:
[CAUTION: External Email]
default n
Remove this line. It is default option anyway.
help
you have 80 chars limit that's why please use it.
- config BOOT_RETRY bool "Boot retry feature" help
default n
help
-- 2.17.1
M
default n
OK.
help
OK, I will use 80 chars for one line.
Thanks, Masahisa Kojima
default n
help
-- 2.17.1
M
-- 2.17.1
I have tested these two patches and bootmenu is working on n900 again!
Tested-by: Pali Rohár pali@kernel.org
Hi Pali,
-- 2.17.1
Thank you very much for your testing.
Regards, Masahisa Kojima
Masahisa Kojima
Michal Simek
Pali Rohar
