[PATCH 0/4] arm: Tidy up debug UART init
The debug UART init should be done early in boot by the architecture. At present ARM leaves boards to fend for themselves, resulting in quite a bit of inconsistency.
This series attempts a small clean-up, so that enabling the debug UART should be just a matter of enabling the CONFIG options for most boards.
Simon Glass (4): arm: Fix some inconsistent debug-UART CONFIG options arm: Init the debug UART arm: qemu: Enable the debug UART rk3399: Don't enable the debug UART if there is no driver
arch/arm/lib/crt0.S | 4 +++ arch/arm/lib/crt0_64.S | 4 +++ arch/arm/mach-rockchip/rk3399/rk3399.c | 34 ++++++++++++++------------ configs/elgin-rv1108_defconfig | 1 + configs/evb-rk3128_defconfig | 1 + configs/evb-rv1108_defconfig | 1 + configs/pm9g45_defconfig | 1 - configs/qemu_arm64_defconfig | 5 ++++ configs/qemu_arm_defconfig | 5 ++++ configs/snow_defconfig | 1 + 10 files changed, 40 insertions(+), 17 deletions(-)
A few boards enable CONFIG_DEBUG_UART_BOARD_INIT but do not define the required init function. Fix this by disabling the debug UART.
With snow the debug UART is enabled but the driver CONFIG is not. Fix this too.
configs/elgin-rv1108_defconfig | 1 + configs/evb-rk3128_defconfig | 1 + configs/evb-rv1108_defconfig | 1 + configs/pm9g45_defconfig | 1 - configs/snow_defconfig | 1 + 5 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/configs/elgin-rv1108_defconfig b/configs/elgin-rv1108_defconfig index ee5bfddc438..ed6557a6a35 100644 --- a/configs/elgin-rv1108_defconfig +++ b/configs/elgin-rv1108_defconfig @@ -6,6 +6,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_DEFAULT_DEVICE_TREE="rv1108-elgin-r1" CONFIG_ROCKCHIP_RV1108=y +# CONFIG_DEBUG_UART_BOARD_INIT is not set CONFIG_ROCKCHIP_BOOT_MODE_REG=0 CONFIG_TARGET_ELGIN_RV1108=y CONFIG_DEBUG_UART_BASE=0x10210000 diff --git a/configs/evb-rk3128_defconfig b/configs/evb-rk3128_defconfig index e446a226415..544d6debd02 100644 --- a/configs/evb-rk3128_defconfig +++ b/configs/evb-rk3128_defconfig @@ -6,6 +6,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_OFFSET=0x0 CONFIG_DEFAULT_DEVICE_TREE="rk3128-evb" CONFIG_ROCKCHIP_RK3128=y +# CONFIG_DEBUG_UART_BOARD_INIT is not set CONFIG_DEBUG_UART_BASE=0x20068000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y diff --git a/configs/evb-rv1108_defconfig b/configs/evb-rv1108_defconfig index 916a6fb8510..b6510b5fca6 100644 --- a/configs/evb-rv1108_defconfig +++ b/configs/evb-rv1108_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x60000000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEFAULT_DEVICE_TREE="rv1108-evb" CONFIG_ROCKCHIP_RV1108=y +# CONFIG_DEBUG_UART_BOARD_INIT is not set CONFIG_DEBUG_UART_BASE=0x10210000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index 9382c389678..96260e05908 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -8,7 +8,6 @@ CONFIG_TARGET_PM9G45=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9m10g45ek" -CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_ENV_OFFSET_REDUND=0x100000 diff --git a/configs/snow_defconfig b/configs/snow_defconfig index e5bac37808e..00181124eca 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL_TEXT_BASE=0x02023400 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0x12c30000 CONFIG_DEBUG_UART_CLOCK=100000000 +CONFIG_DEBUG_UART_S5P=y CONFIG_IDENT_STRING=" for snow" CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y
At present we don't init the debug UART in the generic ARM code, but instead leave it to individual machines to handle. This is not the way it is supposed to work.
Add the required init to the crt files. This ensures that the UART is available as early as possible and that the announcement appears when it should, if enabled.
arch/arm/lib/crt0.S | 4 ++++ arch/arm/lib/crt0_64.S | 4 ++++ 2 files changed, 8 insertions(+)
diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index 956d258c9da..ba312901f33 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -109,6 +109,10 @@ ENTRY(_main) mov r9, r0 bl board_init_f_init_reserve
+#if defined(CONFIG_DEBUG_UART) && CONFIG_IS_ENABLED(SERIAL) + bl debug_uart_init +#endif + #if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_EARLY_BSS) CLEAR_BSS #endif diff --git a/arch/arm/lib/crt0_64.S b/arch/arm/lib/crt0_64.S index 680e674fa33..611affb74ce 100644 --- a/arch/arm/lib/crt0_64.S +++ b/arch/arm/lib/crt0_64.S @@ -91,6 +91,10 @@ ENTRY(_main) mov x18, x0 bl board_init_f_init_reserve
+#if defined(CONFIG_DEBUG_UART) && CONFIG_IS_ENABLED(SERIAL) + bl debug_uart_init +#endif + mov x0, #0 bl board_init_f
Enable this to permit early debugging. Due to the way qmeu works, the input clock can be zero and things still work.
configs/qemu_arm64_defconfig | 5 +++++ configs/qemu_arm_defconfig | 5 +++++ 2 files changed, 10 insertions(+)
diff --git a/configs/qemu_arm64_defconfig b/configs/qemu_arm64_defconfig index 003717efde2..3f205e0f824 100644 --- a/configs/qemu_arm64_defconfig +++ b/configs/qemu_arm64_defconfig @@ -5,6 +5,9 @@ CONFIG_SYS_MALLOC_LEN=0x1000000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_SECT_SIZE=0x40000 +CONFIG_DEBUG_UART_BASE=0x9000000 +CONFIG_DEBUG_UART_CLOCK=0 +CONFIG_DEBUG_UART=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_LOAD_ADDR=0x40200000 @@ -47,6 +50,8 @@ CONFIG_PCI=y CONFIG_PCIE_ECAM_GENERIC=y CONFIG_SCSI=y CONFIG_DM_SCSI=y +CONFIG_DEBUG_UART_PL011=y +CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y CONFIG_SYSRESET_PSCI=y CONFIG_USB=y diff --git a/configs/qemu_arm_defconfig b/configs/qemu_arm_defconfig index 27b0e49f6f8..e64e2be0192 100644 --- a/configs/qemu_arm_defconfig +++ b/configs/qemu_arm_defconfig @@ -6,7 +6,10 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_TARGET_QEMU_ARM_32BIT=y +CONFIG_DEBUG_UART_BASE=0x9000000 +CONFIG_DEBUG_UART_CLOCK=0 CONFIG_ARMV7_LPAE=y +CONFIG_DEBUG_UART=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_LOAD_ADDR=0x40200000 @@ -49,6 +52,8 @@ CONFIG_PCI=y CONFIG_PCIE_ECAM_GENERIC=y CONFIG_SCSI=y CONFIG_DM_SCSI=y +CONFIG_DEBUG_UART_PL011=y +CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y CONFIG_SYSRESET_PSCI=y CONFIG_USB=y
Some boards do not enable SPL_SERIAL so cannot use the debug UART. Add this condition to the code and drop use of the preprocessor while we are here.
arch/arm/mach-rockchip/rk3399/rk3399.c | 34 ++++++++++++++------------ 1 file changed, 18 insertions(+), 16 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index 2bc8e60b99b..d40969c8889 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -118,10 +118,6 @@ void board_debug_uart_init(void) #define GPIO0_BASE 0xff720000 #define PMUGRF_BASE 0xff320000 struct rk3399_grf_regs * const grf = (void *)GRF_BASE; -#ifdef CONFIG_TARGET_CHROMEBOOK_BOB - struct rk3399_pmugrf_regs * const pmugrf = (void *)PMUGRF_BASE; - struct rockchip_gpio_regs * const gpio = (void *)GPIO0_BASE; -#endif
#if defined(CONFIG_DEBUG_UART_BASE) && (CONFIG_DEBUG_UART_BASE == 0xff180000) /* Enable early UART0 on the RK3399 */ @@ -140,19 +136,25 @@ void board_debug_uart_init(void) GRF_GPIO3B7_SEL_MASK, GRF_UART3_SOUT << GRF_GPIO3B7_SEL_SHIFT); #else -# ifdef CONFIG_TARGET_CHROMEBOOK_BOB - rk_setreg(&grf->io_vsel, 1 << 0); - - /* - * Let's enable these power rails here, we are already running the SPI - * Flash based code. - */ - spl_gpio_output(gpio, GPIO(BANK_B, 2), 1); /* PP1500_EN */ - spl_gpio_set_pull(&pmugrf->gpio0_p, GPIO(BANK_B, 2), GPIO_PULL_NORMAL); + struct rk3399_pmugrf_regs * const pmugrf = (void *)PMUGRF_BASE; + struct rockchip_gpio_regs * const gpio = (void *)GPIO0_BASE;
- spl_gpio_output(gpio, GPIO(BANK_B, 4), 1); /* PP3000_EN */ - spl_gpio_set_pull(&pmugrf->gpio0_p, GPIO(BANK_B, 4), GPIO_PULL_NORMAL); -#endif /* CONFIG_TARGET_CHROMEBOOK_BOB */ + if (IS_ENABLED(CONFIG_SPL_BUILD) && + IS_ENABLED(CONFIG_TARGET_CHROMEBOOK_BOB)) { + rk_setreg(&grf->io_vsel, 1 << 0); + + /* + * Let's enable these power rails here, we are already running + * the SPI-Flash-based code. + */ + spl_gpio_output(gpio, GPIO(BANK_B, 2), 1); /* PP1500_EN */ + spl_gpio_set_pull(&pmugrf->gpio0_p, GPIO(BANK_B, 2), + GPIO_PULL_NORMAL); + + spl_gpio_output(gpio, GPIO(BANK_B, 4), 1); /* PP3000_EN */ + spl_gpio_set_pull(&pmugrf->gpio0_p, GPIO(BANK_B, 4), + GPIO_PULL_NORMAL); + }
/* Enable early UART2 channel C on the RK3399 */ rk_clrsetreg(&grf->gpio4c_iomux,
Reviewed-by: Philipp Tomsich philipp.tomsich@vrull.eu
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Philipp Tomsich philipp.tomsich@vrull.eu
Philipp Tomsich
