[U-Boot-Users] [PATCH 2/2 v2] PPC4xx: Enable Primordial Stack for 40x and Unify ECC Handling
This patch (Part 2 of 2):
* Rolls up a suite of changes to enable correct primordial stack and global data handling when the data cache is used for such a purpose for PPC40x-variants (i.e. CFG_INIT_DCACHE_CS).
* Related to the first, unifies DDR2 SDRAM and ECC initialization by eliminating redundant ECC initialization implementations and moving redundant SDRAM initialization out of board code into shared 4xx code.
* Enables MCSR visibility on the 405EX(r).
* Enables the use of the data cache for initial RAM on both AMCC's Kilauea and Makalu and removes a redundant CFG_POST_MEMORY flag from each board's CONFIG_POST value.
With respect to the 4xx DDR initialization and ECC unification, there is certainly more work that can and should be done (file renaming, etc.). However, that can be handled at a later date on a second or third pass. As it stands, this patch moves things forward in an incremental yet positive way for those platforms that utilize this code and the features associated with it.
Signed-off-by: Grant Erickson gerickson@nuovations.com --- board/amcc/kilauea/init.S | 229 +++++++++++++++++--------------- board/amcc/kilauea/memory.c | 5 + board/amcc/makalu/init.S | 125 +----------------- board/amcc/makalu/memory.c | 118 +---------------- include/configs/kilauea.h | 110 ++++++++++++++-- include/configs/makalu.h | 114 ++++++++++++++-- 6 files
diff --git a/board/amcc/kilauea/init.S b/board/amcc/kilauea/init.S index 053fe19..bf47d6b 100644 --- a/board/amcc/kilauea/init.S +++ b/board/amcc/kilauea/init.S @@ -1,8 +1,11 @@ /* + * Copyright (c) 2008 Nuovation System Designs, LLC + * Grant Erickson gerickson@nuovations.com + * * (C) Copyright 2007-2008 * Stefan Roese, DENX Software Engineering, sr@denx.de. * - * Based on code provided from UDTech and AMCC + * Originally based on code provided from UDTech and AMCC * * See file CREDITS for list of people who contributed to this * project. @@ -29,126 +32,136 @@ #include <ppc_asm.tmpl> #include <ppc_defs.h>
-#define mtsdram_as(reg, value) \ - addi r4,0,reg ; \ - mtdcr memcfga,r4 ; \ - addis r4,0,value@h ; \ - ori r4,r4,value@l ; \ - mtdcr memcfgd,r4 ; +#define mtsdram_as(reg, value) \ + addi r4,0,reg ; \ + mtdcr memcfga,r4 ; \ + addis r4,0,value@h ; \ + ori r4,r4,value@l ; \ + mtdcr memcfgd,r4 ; + +#if defined(CONFIG_DDR_ECC) + .extern ecc_init +#endif /* defined(CONFIG_DDR_ECC) */
.globl ext_bus_cntlr_init ext_bus_cntlr_init: +#if !defined(CFG_INIT_DCACHE_CS) #if !defined(CONFIG_NAND_U_BOOT) || defined(CONFIG_NAND_SPL)
/* - * DDR2 setup + * DDR2 SDRAM Controller Setup */
- /* Following the DDR Core Manual, here is the initialization */ - - /* Step 1 */ - - /* Step 2 */ - - /* Step 3 */ - - /* base=00000000, size=256MByte (6), mode=7 (n*10*8) */ - mtsdram_as(SDRAM_MB0CF, 0x00006701); - - /* SET SDRAM_MB1CF - Not enabled */ - mtsdram_as(SDRAM_MB1CF, 0x00000000); - - /* SET SDRAM_MB2CF - Not enabled */ - mtsdram_as(SDRAM_MB2CF, 0x00000000); - - /* SET SDRAM_MB3CF - Not enabled */ - mtsdram_as(SDRAM_MB3CF, 0x00000000); - - /* SDRAM_CLKTR: Adv Addr clock by 180 deg */ - mtsdram_as(SDRAM_CLKTR, 0x80000000); - - /* Refresh Time register (0x30) Refresh every 7.8125uS */ - mtsdram_as(SDRAM_RTR, 0x06180000); + /* Set Memory Bank Configuration Registers */ + mtsdram_as(SDRAM_MB0CF, CFG_SDRAM0_MB0CF); + mtsdram_as(SDRAM_MB1CF, CFG_SDRAM0_MB1CF); + mtsdram_as(SDRAM_MB2CF, CFG_SDRAM0_MB2CF); + mtsdram_as(SDRAM_MB3CF, CFG_SDRAM0_MB3CF); + + /* Set Memory Clock Timing Register */ + mtsdram_as(SDRAM_CLKTR, CFG_SDRAM0_CLKTR); + + /* Set Refresh Time Register */ + mtsdram_as(SDRAM_RTR, CFG_SDRAM0_RTR); + + /* Set SDRAM Timing Registers */ + mtsdram_as(SDRAM_SDTR1, CFG_SDRAM0_SDTR1); + mtsdram_as(SDRAM_SDTR2, CFG_SDRAM0_SDTR2); + mtsdram_as(SDRAM_SDTR3, CFG_SDRAM0_SDTR3); + + /* Set Mode and Extended Mode Registers */ + mtsdram_as(SDRAM_MMODE, CFG_SDRAM0_MMODE); + mtsdram_as(SDRAM_MEMODE, CFG_SDRAM0_MEMODE); + + /* Set Memory Controller Options 1 Register */ + mtsdram_as(SDRAM_MCOPT1, CFG_SDRAM0_MCOPT1); + + /* Set Manual Initialization Control Registers */ + mtsdram_as(SDRAM_INITPLR0, CFG_SDRAM0_INITPLR0); + mtsdram_as(SDRAM_INITPLR1, CFG_SDRAM0_INITPLR1); + mtsdram_as(SDRAM_INITPLR2, CFG_SDRAM0_INITPLR2); + mtsdram_as(SDRAM_INITPLR3, CFG_SDRAM0_INITPLR3); + mtsdram_as(SDRAM_INITPLR4, CFG_SDRAM0_INITPLR4); + mtsdram_as(SDRAM_INITPLR5, CFG_SDRAM0_INITPLR5); + mtsdram_as(SDRAM_INITPLR6, CFG_SDRAM0_INITPLR6); + mtsdram_as(SDRAM_INITPLR7, CFG_SDRAM0_INITPLR7); + mtsdram_as(SDRAM_INITPLR8, CFG_SDRAM0_INITPLR8); + mtsdram_as(SDRAM_INITPLR9, CFG_SDRAM0_INITPLR9); + mtsdram_as(SDRAM_INITPLR10, CFG_SDRAM0_INITPLR10); + mtsdram_as(SDRAM_INITPLR11, CFG_SDRAM0_INITPLR11); + mtsdram_as(SDRAM_INITPLR12, CFG_SDRAM0_INITPLR12); + mtsdram_as(SDRAM_INITPLR13, CFG_SDRAM0_INITPLR13); + mtsdram_as(SDRAM_INITPLR14, CFG_SDRAM0_INITPLR14); + mtsdram_as(SDRAM_INITPLR15, CFG_SDRAM0_INITPLR15); + + /* Set On-Die Termination Registers */ + mtsdram_as(SDRAM_CODT, CFG_SDRAM0_CODT); + mtsdram_as(SDRAM_MODT0, CFG_SDRAM0_MODT0); + mtsdram_as(SDRAM_MODT1, CFG_SDRAM0_MODT1); + + /* Set Write Timing Register */ + mtsdram_as(SDRAM_WRDTR, CFG_SDRAM0_WRDTR);
- /* SDRAM_SDTR1 */ - mtsdram_as(SDRAM_SDTR1, 0x80201000); - - /* SDRAM_SDTR2 */ - mtsdram_as(SDRAM_SDTR2, 0x32204232); + /* + * Start Initialization by SDRAM0_MCOPT2[SREN] = 0 and + * SDRAM0_MCOPT2[IPTR] = 1 + */ + mtsdram_as(SDRAM_MCOPT2, SDRAM_MCOPT2_SREN_EXIT | \ + SDRAM_MCOPT2_IPTR_EXECUTE);
- /* SDRAM_SDTR3 */ - mtsdram_as(SDRAM_SDTR3, 0x080b0d1a); + /* + * Poll SDRAM0_MCSTAT[MIC] for assertion to indicate the + * completion of initialization. + * + * do { + * mfsdram(SDRAM_MCSTAT, val); + * } while ((val & SDRAM_MCSTAT_MIC_MASK) != SDRAM_MCSTAT_MIC_COMP); + */ + li r4,SDRAM_MCSTAT + lis r2,SDRAM_MCSTAT_MIC_COMP@h + ori r2,r2,SDRAM_MCSTAT_MIC_COMP@l +0: mtdcr memcfga,r4 + mfdcr r3,memcfgd + clrrwi r3,r3,31 + cmpw cr7,r3,r2 + bne+ cr7,0b + + /* Set Delay Control Registers */ + mtsdram_as(SDRAM_DLCR, CFG_SDRAM0_DLCR); + mtsdram_as(SDRAM_RDCC, CFG_SDRAM0_RDCC); + mtsdram_as(SDRAM_RQDC, CFG_SDRAM0_RQDC); + mtsdram_as(SDRAM_RFDC, CFG_SDRAM0_RFDC);
- mtsdram_as(SDRAM_MMODE, 0x00000442); - mtsdram_as(SDRAM_MEMODE, 0x00000404); + /* + * Enable Controller by SDRAM0_MCOPT2[DCEN] = 1: + * + * mcopt2 = mfsdram(SDRAM_MCOPT2); + */ + li r4,SDRAM_MCOPT2 + mtdcr memcfga,r4 + mfdcr r3,memcfgd
- /* SDRAM0_MCOPT1 (0X20) No ECC Gen */ - mtsdram_as(SDRAM_MCOPT1, 0x04322000); + /* + * mtsdram(SDRAM_MCOPT2, mcopt2 | SDRAM_MCOPT2_DCEN_ENABLE); + */ + mtdcr memcfga,r4 + oris r3,r3,SDRAM_MCOPT2_DCEN_ENABLE@h + ori r3,r3,SDRAM_MCOPT2_DCEN_ENABLE@l + mtdcr memcfgd,r3
- /* NOP */ - mtsdram_as(SDRAM_INITPLR0, 0xa8380000); - /* precharge 3 DDR clock cycle */ - mtsdram_as(SDRAM_INITPLR1, 0x81900400); - /* EMR2 twr = 2tck */ - mtsdram_as(SDRAM_INITPLR2, 0x81020000); - /* EMR3 twr = 2tck */ - mtsdram_as(SDRAM_INITPLR3, 0x81030000); - /* EMR DLL ENABLE twr = 2tck */ - mtsdram_as(SDRAM_INITPLR4, 0x81010404); - /* MR w/ DLL reset - * Note: 5 is CL. May need to be changed +#if defined(CONFIG_DDR_ECC) + /* + * ecc_init(CFG_SDRAM_BASE, CFG_MBYTES_SDRAM << 20); */ - mtsdram_as(SDRAM_INITPLR5, 0x81000542); - /* precharge 3 DDR clock cycle */ - mtsdram_as(SDRAM_INITPLR6, 0x81900400); - /* Auto-refresh trfc = 26tck */ - mtsdram_as(SDRAM_INITPLR7, 0x8D080000); - /* Auto-refresh trfc = 26tck */ - mtsdram_as(SDRAM_INITPLR8, 0x8D080000); - /* Auto-refresh */ - mtsdram_as(SDRAM_INITPLR9, 0x8D080000); - /* Auto-refresh */ - mtsdram_as(SDRAM_INITPLR10, 0x8D080000); - /* MRS - normal operation; wait 2 cycle (set wait to tMRD) */ - mtsdram_as(SDRAM_INITPLR11, 0x81000442); - mtsdram_as(SDRAM_INITPLR12, 0x81010780); - mtsdram_as(SDRAM_INITPLR13, 0x81010400); - mtsdram_as(SDRAM_INITPLR14, 0x00000000); - mtsdram_as(SDRAM_INITPLR15, 0x00000000); - - /* SET MCIF0_CODT Die Termination On */ - mtsdram_as(SDRAM_CODT, 0x0080f837); - mtsdram_as(SDRAM_MODT0, 0x01800000); - mtsdram_as(SDRAM_MODT1, 0x00000000); - - mtsdram_as(SDRAM_WRDTR, 0x00000000); - - /* SDRAM0_MCOPT2 (0X21) Start initialization */ - mtsdram_as(SDRAM_MCOPT2, 0x20000000); - - /* Step 5 */ - lis r3,0x1 /* 400000 = wait 100ms */ - mtctr r3 - -pll_wait: - bdnz pll_wait - - /* Step 6 */ - - /* SDRAM_DLCR */ - mtsdram_as(SDRAM_DLCR, 0x030000a5); - - /* SDRAM_RDCC */ - mtsdram_as(SDRAM_RDCC, 0x40000000); - - /* SDRAM_RQDC */ - mtsdram_as(SDRAM_RQDC, 0x80000038); - - /* SDRAM_RFDC */ - mtsdram_as(SDRAM_RFDC, 0x00000209); - - /* Enable memory controller */ - mtsdram_as(SDRAM_MCOPT2, 0x28000000); -#endif /* #ifndef CONFIG_NAND_U_BOOT */ + mflr r13 + lis r3,CFG_SDRAM_BASE@h + ori r3,r3,CFG_SDRAM_BASE@l + lis r4,(CFG_MBYTES_SDRAM << 20)@h + ori r4,r4,(CFG_MBYTES_SDRAM << 20)@l + bl ecc_init + mtlr r13 +#endif /* defined(CONFIG_DDR_ECC) */ +#endif /* !defined(CONFIG_NAND_U_BOOT) || defined(CONFIG_NAND_SPL) */ +#endif /* !defined(CFG_INIT_DCACHE_CS) */
blr diff --git a/board/amcc/kilauea/memory.c b/board/amcc/kilauea/memory.c index 1d7a3fa..b7e2344 100644 --- a/board/amcc/kilauea/memory.c +++ b/board/amcc/kilauea/memory.c @@ -1,4 +1,7 @@ /* + * Copyright (c) 2008 Nuovation System Designs, LLC + * Grant Erickson gerickson@nuovations.com + * * (C) Copyright 2007 * Stefan Roese, DENX Software Engineering, sr@denx.de. * @@ -30,10 +33,12 @@ void sdram_init(void) return; }
+#if defined(CONFIG_NAND_U_BOOT) long int initdram(int board_type) { return (CFG_MBYTES_SDRAM << 20); } +#endif /* defined(CONFIG_NAND_U_BOOT) */
#if defined(CFG_DRAM_TEST) int testdram (void) diff --git a/board/amcc/makalu/init.S b/board/amcc/makalu/init.S index 5e9a5e0..4d0f460 100644 --- a/board/amcc/makalu/init.S +++ b/board/amcc/makalu/init.S @@ -1,8 +1,11 @@ /* + * Copyright (c) 2008 Nuovation System Designs, LLC + * Grant Erickson gerickson@nuovations.com + * * (C) Copyright 2007-2008 * Stefan Roese, DENX Software Engineering, sr@denx.de. * - * Based on code provided from Senao and AMCC + * Originally based on code provided from Senao and AMCC * * See file CREDITS for list of people who contributed to this * project. @@ -23,126 +26,6 @@ * MA 02111-1307 USA */
-#include <config.h> -#include <ppc4xx.h> - -#include <ppc_asm.tmpl> -#include <ppc_defs.h> - -#define mtsdram_as(reg, value) \ - addi r4,0,reg ; \ - mtdcr memcfga,r4 ; \ - addis r4,0,value@h ; \ - ori r4,r4,value@l ; \ - mtdcr memcfgd,r4 ; - .globl ext_bus_cntlr_init ext_bus_cntlr_init: - - /* - * DDR2 setup - */ - - /* Following the DDR Core Manual, here is the initialization */ - - /* Step 1 */ - - /* Step 2 */ - - /* Step 3 */ - - /* base=00000000, size=128MByte (5), mode=2 (n*10*4) */ - mtsdram_as(SDRAM_MB0CF, 0x00005201); - - /* base=08000000, size=128MByte (5), mode=2 (n*10*4) */ - mtsdram_as(SDRAM_MB1CF, (0x08000000 >> 3) | 0x5201); - - /* SDRAM_CLKTR: Adv Addr clock by 180 deg */ - mtsdram_as(SDRAM_CLKTR,0x80000000); - - /* Refresh Time register (0x30) Refresh every 7.8125uS */ - mtsdram_as(SDRAM_RTR, 0x06180000); - - /* SDRAM_SDTR1 */ - mtsdram_as(SDRAM_SDTR1, 0x80201000); - - /* SDRAM_SDTR2 */ - mtsdram_as(SDRAM_SDTR2, 0x32204232); - - /* SDRAM_SDTR3 */ - mtsdram_as(SDRAM_SDTR3, 0x080b0d1a); - - mtsdram_as(SDRAM_MMODE, 0x00000442); - mtsdram_as(SDRAM_MEMODE, 0x00000404); - - /* SDRAM0_MCOPT1 (0X20) No ECC Gen */ - mtsdram_as(SDRAM_MCOPT1, 0x04322000); - - /* NOP */ - mtsdram_as(SDRAM_INITPLR0, 0xa8380000); - /* precharge 3 DDR clock cycle */ - mtsdram_as(SDRAM_INITPLR1, 0x81900400); - /* EMR2 twr = 2tck */ - mtsdram_as(SDRAM_INITPLR2, 0x81020000); - /* EMR3 twr = 2tck */ - mtsdram_as(SDRAM_INITPLR3, 0x81030000); - /* EMR DLL ENABLE twr = 2tck */ - mtsdram_as(SDRAM_INITPLR4, 0x81010404); - /* MR w/ DLL reset - * Note: 5 is CL. May need to be changed - */ - mtsdram_as(SDRAM_INITPLR5, 0x81000542); - /* precharge 3 DDR clock cycle */ - mtsdram_as(SDRAM_INITPLR6, 0x81900400); - /* Auto-refresh trfc = 26tck */ - mtsdram_as(SDRAM_INITPLR7, 0x8D080000); - /* Auto-refresh trfc = 26tck */ - mtsdram_as(SDRAM_INITPLR8, 0x8D080000); - /* Auto-refresh */ - mtsdram_as(SDRAM_INITPLR9, 0x8D080000); - /* Auto-refresh */ - mtsdram_as(SDRAM_INITPLR10, 0x8D080000); - /* MRS - normal operation; wait 2 cycle (set wait to tMRD) */ - mtsdram_as(SDRAM_INITPLR11, 0x81000442); - mtsdram_as(SDRAM_INITPLR12, 0x81010780); - mtsdram_as(SDRAM_INITPLR13, 0x81010400); - mtsdram_as(SDRAM_INITPLR14, 0x00000000); - mtsdram_as(SDRAM_INITPLR15, 0x00000000); - - /* SET MCIF0_CODT Die Termination On */ - mtsdram_as(SDRAM_CODT, 0x0080f837); - mtsdram_as(SDRAM_MODT0, 0x01800000); -#if 0 /* test-only: not sure if 0 is ok when 2nd bank is used */ - mtsdram_as(SDRAM_MODT1, 0x00000000); -#endif - - mtsdram_as(SDRAM_WRDTR, 0x00000000); - - /* SDRAM0_MCOPT2 (0X21) Start initialization */ - mtsdram_as(SDRAM_MCOPT2, 0x20000000); - - /* Step 5 */ - lis r3,0x1 /* 400000 = wait 100ms */ - mtctr r3 - -pll_wait: - bdnz pll_wait - - /* Step 6 */ - - /* SDRAM_DLCR */ - mtsdram_as(SDRAM_DLCR, 0x030000a5); - - /* SDRAM_RDCC */ - mtsdram_as(SDRAM_RDCC, 0x40000000); - - /* SDRAM_RQDC */ - mtsdram_as(SDRAM_RQDC, 0x80000038); - - /* SDRAM_RFDC */ - mtsdram_as(SDRAM_RFDC, 0x00000209); - - /* Enable memory controller */ - mtsdram_as(SDRAM_MCOPT2, 0x28000000); - blr diff --git a/board/amcc/makalu/memory.c b/board/amcc/makalu/memory.c index b03b60b..326feb7 100644 --- a/board/amcc/makalu/memory.c +++ b/board/amcc/makalu/memory.c @@ -1,4 +1,7 @@ /* + * Copyright (c) 2008 Nuovation System Designs, LLC + * Grant Erickson gerickson@nuovations.com + * * (C) Copyright 2007 * Stefan Roese, DENX Software Engineering, sr@denx.de. * @@ -29,121 +32,6 @@ void sdram_init(void) return; }
-long int initdram(int board_type) -{ - /* - * Same as on Kilauea, Makalu generates exception 0x200 - * (machine check) after trap_init() in board_init_f, - * when SDRAM is initialized here (late) and d-cache is - * used earlier as INIT_RAM. - * So for now, initialize DDR2 in init.S very early and - * also use it for INIT_RAM. Then this exception doesn't - * occur. - */ -#if 0 - u32 val; - - /* base=00000000, size=128MByte (5), mode=2 (n*10*4) */ - mtsdram(SDRAM_MB0CF, 0x00005201); - - /* SET SDRAM_MB1CF - Not enabled */ - mtsdram(SDRAM_MB1CF, 0x00000000); - - /* SET SDRAM_MB2CF - Not enabled */ - mtsdram(SDRAM_MB2CF, 0x00000000); - - /* SET SDRAM_MB3CF - Not enabled */ - mtsdram(SDRAM_MB3CF, 0x00000000); - - /* SDRAM_CLKTR: Adv Addr clock by 90 deg */ - mtsdram(SDRAM_CLKTR, 0x80000000); - - /* Refresh Time register (0x30) Refresh every 7.8125uS */ - mtsdram(SDRAM_RTR, 0x06180000); - - /* SDRAM_SDTR1 */ - mtsdram(SDRAM_SDTR1, 0x80201000); - - /* SDRAM_SDTR2 */ - mtsdram(SDRAM_SDTR2, 0x32204232); - - /* SDRAM_SDTR3 */ - mtsdram(SDRAM_SDTR3, 0x080b0d1a); - - mtsdram(SDRAM_MMODE, 0x00000442); - mtsdram(SDRAM_MEMODE, 0x00000404); - - /* SDRAM0_MCOPT1 (0X20) No ECC Gen */ - mtsdram(SDRAM_MCOPT1, 0x04322000); - - /* NOP */ - mtsdram(SDRAM_INITPLR0, 0xa8380000); - /* precharge 3 DDR clock cycle */ - mtsdram(SDRAM_INITPLR1, 0x81900400); - /* EMR2 twr = 2tck */ - mtsdram(SDRAM_INITPLR2, 0x81020000); - /* EMR3 twr = 2tck */ - mtsdram(SDRAM_INITPLR3, 0x81030000); - /* EMR DLL ENABLE twr = 2tck */ - mtsdram(SDRAM_INITPLR4, 0x81010404); - /* MR w/ DLL reset - * Note: 5 is CL. May need to be changed - */ - mtsdram(SDRAM_INITPLR5, 0x81000542); - /* precharge 3 DDR clock cycle */ - mtsdram(SDRAM_INITPLR6, 0x81900400); - /* Auto-refresh trfc = 26tck */ - mtsdram(SDRAM_INITPLR7, 0x8D080000); - /* Auto-refresh trfc = 26tck */ - mtsdram(SDRAM_INITPLR8, 0x8D080000); - /* Auto-refresh */ - mtsdram(SDRAM_INITPLR9, 0x8D080000); - /* Auto-refresh */ - mtsdram(SDRAM_INITPLR10, 0x8D080000); - /* MRS - normal operation; wait 2 cycle (set wait to tMRD) */ - mtsdram(SDRAM_INITPLR11, 0x81000442); - mtsdram(SDRAM_INITPLR12, 0x81010780); - mtsdram(SDRAM_INITPLR13, 0x81010400); - mtsdram(SDRAM_INITPLR14, 0x00000000); - mtsdram(SDRAM_INITPLR15, 0x00000000); - - /* SET MCIF0_CODT Die Termination On */ - mtsdram(SDRAM_CODT, 0x0080f837); - mtsdram(SDRAM_MODT0, 0x01800000); - mtsdram(SDRAM_MODT1, 0x00000000); - - mtsdram(SDRAM_WRDTR, 0x00000000); - - /* SDRAM0_MCOPT2 (0X21) Start initialization */ - mtsdram(SDRAM_MCOPT2, 0x20000000); - - /* Step 5 */ - do { - mfsdram(SDRAM_MCSTAT, val); - } while ((val & SDRAM_MCSTAT_MIC_COMP) != SDRAM_MCSTAT_MIC_COMP); - - /* Step 6 */ - - /* SDRAM_DLCR */ - mtsdram(SDRAM_DLCR, 0x030000a5); - - /* SDRAM_RDCC */ - mtsdram(SDRAM_RDCC, 0x40000000); - - /* SDRAM_RQDC */ - mtsdram(SDRAM_RQDC, 0x80000038); - - /* SDRAM_RFDC */ - mtsdram(SDRAM_RFDC, 0x00000209); - - /* Enable memory controller */ - mfsdram(SDRAM_MCOPT2, val); - val |= SDRAM_MCOPT2_DCEN_ENABLE; - mtsdram(SDRAM_MCOPT2, val); -#endif - return (CFG_MBYTES_SDRAM << 20); -} - #if defined(CFG_DRAM_TEST) int testdram (void) { diff --git a/include/configs/kilauea.h b/include/configs/kilauea.h index c7c42a4..035a40e 100644 --- a/include/configs/kilauea.h +++ b/include/configs/kilauea.h @@ -1,4 +1,7 @@ /* + * Copyright (c) 2008 Nuovation System Designs, LLC + * Grant Erickson gerickson@nuovations.com + * * (C) Copyright 2007 * Stefan Roese, DENX Software Engineering, sr@denx.de. * @@ -54,20 +57,56 @@ #define CFG_MONITOR_BASE (TEXT_BASE)
/*----------------------------------------------------------------------- - * Initial RAM & stack pointer - *----------------------------------------------------------------------*/ -#define CFG_INIT_RAM_ADDR 0x02000000 /* inside of SDRAM */ -#define CFG_INIT_RAM_END (4 << 10) + * Initial RAM & Stack Pointer Configuration Options + * + * There are traditionally three options for the primordial + * (i.e. initial) stack usage on the 405-series: + * + * 1) On-chip Memory (OCM) (i.e. SRAM) + * 2) Data cache + * 3) SDRAM + * + * For the 405EX(r), there is no OCM, so we are left with (2) or (3) + * the latter of which is less than desireable since it requires + * setting up the SDRAM and ECC in assembly code. + * + * To use (2), define 'CFG_INIT_DCACHE_CS' to be an unused chip + * select on the External Bus Controller (EBC) and then select a + * value for 'CFG_INIT_RAM_ADDR' outside of the range of valid, + * physical SDRAM. Otherwise, undefine 'CFG_INIT_DCACHE_CS' and + * select a value for 'CFG_INIT_RAM_ADDR' within the range of valid, + * physical SDRAM to use (3). + *-----------------------------------------------------------------------*/ + +#define CFG_INIT_DCACHE_CS 4 + +#if defined(CFG_INIT_DCACHE_CS) +#define CFG_INIT_RAM_ADDR (CFG_SDRAM_BASE + ( 1 << 30)) /* 1 GiB */ +#else +#define CFG_INIT_RAM_ADDR (CFG_SDRAM_BASE + (32 << 20)) /* 32 MiB */ +#endif /* defined(CFG_INIT_DCACHE_CS) */ + +#define CFG_INIT_RAM_END (4 << 10) /* 4 KiB */ #define CFG_GBL_DATA_SIZE 256 /* num bytes initial data */ #define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) -/* reserve some memory for POST and BOOT limit info */ -#define CFG_INIT_SP_OFFSET (CFG_GBL_DATA_OFFSET - 16)
-/* extra data in init-ram */ -#define CFG_POST_WORD_ADDR (CFG_GBL_DATA_OFFSET - 4) -#define CFG_POST_MAGIC (CFG_INIT_RAM_ADDR + CFG_GBL_DATA_OFFSET - 8) -#define CFG_POST_VAL (CFG_INIT_RAM_ADDR + CFG_GBL_DATA_OFFSET - 12) -#define CFG_OCM_DATA_ADDR CFG_INIT_RAM_ADDR /* for commproc.c */ +/* + * If the data cache is being used for the primordial stack and global + * data area, the POST word must be placed somewhere else. The General + * Purpose Timer (GPT) is unused by u-boot and the kernel and preserves + * its compare and mask register contents across reset, so it is used + * for the POST word. + */ + +#if defined(CFG_INIT_DCACHE_CS) +# define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET +# define CFG_POST_ALT_WORD_ADDR (CFG_PERIPHERAL_BASE + GPT0_COMP6) +#else +# define CFG_INIT_EXTRA_SIZE 16 +# define CFG_INIT_SP_OFFSET (CFG_GBL_DATA_OFFSET - CFG_INIT_EXTRA_SIZE) +# define CFG_POST_WORD_ADDR (CFG_GBL_DATA_OFFSET - 4) +# define CFG_OCM_DATA_ADDR CFG_INIT_RAM_ADDR +#endif /* defined(CFG_INIT_DCACHE_CS) */
/*----------------------------------------------------------------------- * Serial Port @@ -108,7 +147,7 @@ #define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */
#ifdef CFG_ENV_IS_IN_FLASH -#define CFG_ENV_SECT_SIZE 0x20000 /* size of one complete sector */ +#define CFG_ENV_SECT_SIZE 0x20000 /* size of one complete sector */ #define CFG_ENV_ADDR (CFG_MONITOR_BASE-CFG_ENV_SECT_SIZE) #define CFG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */
@@ -187,6 +226,50 @@ *----------------------------------------------------------------------*/ #define CFG_MBYTES_SDRAM (256) /* 256MB */
+#define CFG_SDRAM0_MB0CF_BASE (( 0 << 20) + CFG_SDRAM_BASE) + +/* DDR1/2 SDRAM Device Control Register Data Values */ +#define CFG_SDRAM0_MB0CF ((CFG_SDRAM0_MB0CF_BASE >> 3) | \ + SDRAM_RXBAS_SDSZ_256MB | \ + SDRAM_RXBAS_SDAM_MODE7 | \ + SDRAM_RXBAS_SDBE_ENABLE) +#define CFG_SDRAM0_MB1CF SDRAM_RXBAS_SDBE_DISABLE +#define CFG_SDRAM0_MB2CF SDRAM_RXBAS_SDBE_DISABLE +#define CFG_SDRAM0_MB3CF SDRAM_RXBAS_SDBE_DISABLE +#define CFG_SDRAM0_MCOPT1 0x04322000 +#define CFG_SDRAM0_MCOPT2 0x00000000 +#define CFG_SDRAM0_MODT0 0x01800000 +#define CFG_SDRAM0_MODT1 0x00000000 +#define CFG_SDRAM0_CODT 0x0080f837 +#define CFG_SDRAM0_RTR 0x06180000 +#define CFG_SDRAM0_INITPLR0 0xa8380000 +#define CFG_SDRAM0_INITPLR1 0x81900400 +#define CFG_SDRAM0_INITPLR2 0x81020000 +#define CFG_SDRAM0_INITPLR3 0x81030000 +#define CFG_SDRAM0_INITPLR4 0x81010404 +#define CFG_SDRAM0_INITPLR5 0x81000542 +#define CFG_SDRAM0_INITPLR6 0x81900400 +#define CFG_SDRAM0_INITPLR7 0x8D080000 +#define CFG_SDRAM0_INITPLR8 0x8D080000 +#define CFG_SDRAM0_INITPLR9 0x8D080000 +#define CFG_SDRAM0_INITPLR10 0x8D080000 +#define CFG_SDRAM0_INITPLR11 0x81000442 +#define CFG_SDRAM0_INITPLR12 0x81010780 +#define CFG_SDRAM0_INITPLR13 0x81010400 +#define CFG_SDRAM0_INITPLR14 0x00000000 +#define CFG_SDRAM0_INITPLR15 0x00000000 +#define CFG_SDRAM0_RQDC 0x80000038 +#define CFG_SDRAM0_RFDC 0x00000209 +#define CFG_SDRAM0_RDCC 0x40000000 +#define CFG_SDRAM0_DLCR 0x030000a5 +#define CFG_SDRAM0_CLKTR 0x80000000 +#define CFG_SDRAM0_WRDTR 0x00000000 +#define CFG_SDRAM0_SDTR1 0x80201000 +#define CFG_SDRAM0_SDTR2 0x32204232 +#define CFG_SDRAM0_SDTR3 0x080b0d1a +#define CFG_SDRAM0_MMODE 0x00000442 +#define CFG_SDRAM0_MEMODE 0x00000404 + /*----------------------------------------------------------------------- * I2C *----------------------------------------------------------------------*/ @@ -319,8 +402,7 @@ #define CONFIG_CMD_SNTP
/* POST support */ -#define CONFIG_POST (CFG_POST_MEMORY | \ - CFG_POST_CACHE | \ +#define CONFIG_POST (CFG_POST_CACHE | \ CFG_POST_CPU | \ CFG_POST_ETHER | \ CFG_POST_I2C | \ diff --git a/include/configs/makalu.h b/include/configs/makalu.h index 67243d4..c4af2a2 100644 --- a/include/configs/makalu.h +++ b/include/configs/makalu.h @@ -1,4 +1,7 @@ /* + * Copyright (c) 2008 Nuovation System Designs, LLC + * Grant Erickson gerickson@nuovations.com + * * (C) Copyright 2007-2008 * Stefan Roese, DENX Software Engineering, sr@denx.de. * @@ -52,20 +55,56 @@ #define CFG_MONITOR_BASE (TEXT_BASE)
/*----------------------------------------------------------------------- * Serial Port @@ -113,7 +152,55 @@ /*----------------------------------------------------------------------- * DDR SDRAM *----------------------------------------------------------------------*/ -#define CFG_MBYTES_SDRAM 256 +#define CFG_MBYTES_SDRAM (256) /* 256MB */ + +#define CFG_SDRAM0_MB0CF_BASE (( 0 << 20) + CFG_SDRAM_BASE) +#define CFG_SDRAM0_MB1CF_BASE ((128 << 20) + CFG_SDRAM_BASE) + +/* DDR1/2 SDRAM Device Control Register Data Values */ +#define CFG_SDRAM0_MB0CF ((CFG_SDRAM0_MB0CF_BASE >> 3) | \ + SDRAM_RXBAS_SDSZ_128MB | \ + SDRAM_RXBAS_SDAM_MODE2 | \ + SDRAM_RXBAS_SDBE_ENABLE) +#define CFG_SDRAM0_MB1CF ((CFG_SDRAM0_MB1CF_BASE >> 3) | \ + SDRAM_RXBAS_SDSZ_128MB | \ + SDRAM_RXBAS_SDAM_MODE2 | \ + SDRAM_RXBAS_SDBE_ENABLE) +#define CFG_SDRAM0_MB2CF SDRAM_RXBAS_SDBE_DISABLE +#define CFG_SDRAM0_MB3CF SDRAM_RXBAS_SDBE_DISABLE +#define CFG_SDRAM0_MCOPT1 0x04322000 +#define CFG_SDRAM0_MCOPT2 0x00000000 +#define CFG_SDRAM0_MODT0 0x01800000 +#define CFG_SDRAM0_MODT1 0x00000000 +#define CFG_SDRAM0_CODT 0x0080f837 +#define CFG_SDRAM0_RTR 0x06180000 +#define CFG_SDRAM0_INITPLR0 0xa8380000 +#define CFG_SDRAM0_INITPLR1 0x81900400 +#define CFG_SDRAM0_INITPLR2 0x81020000 +#define CFG_SDRAM0_INITPLR3 0x81030000 +#define CFG_SDRAM0_INITPLR4 0x81010404 +#define CFG_SDRAM0_INITPLR5 0x81000542 +#define CFG_SDRAM0_INITPLR6 0x81900400 +#define CFG_SDRAM0_INITPLR7 0x8D080000 +#define CFG_SDRAM0_INITPLR8 0x8D080000 +#define CFG_SDRAM0_INITPLR9 0x8D080000 +#define CFG_SDRAM0_INITPLR10 0x8D080000 +#define CFG_SDRAM0_INITPLR11 0x81000442 +#define CFG_SDRAM0_INITPLR12 0x81010780 +#define CFG_SDRAM0_INITPLR13 0x81010400 +#define CFG_SDRAM0_INITPLR14 0x00000000 +#define CFG_SDRAM0_INITPLR15 0x00000000 +#define CFG_SDRAM0_RQDC 0x80000038 +#define CFG_SDRAM0_RFDC 0x00000209 +#define CFG_SDRAM0_RDCC 0x40000000 +#define CFG_SDRAM0_DLCR 0x030000a5 +#define CFG_SDRAM0_CLKTR 0x80000000 +#define CFG_SDRAM0_WRDTR 0x00000000 +#define CFG_SDRAM0_SDTR1 0x80201000 +#define CFG_SDRAM0_SDTR2 0x32204232 +#define CFG_SDRAM0_SDTR3 0x080b0d1a +#define CFG_SDRAM0_MMODE 0x00000442 +#define CFG_SDRAM0_MEMODE 0x00000404
/*----------------------------------------------------------------------- * I2C @@ -244,8 +331,7 @@ #define CONFIG_CMD_SNTP
Grant,
Thanks a lot for all this work. Please find some comments below.
- Copyright (c) 2008 Nuovation System Designs, LLC
- Grant Erickson gerickson@nuovations.com
- (C) Copyright 2007-2008
- Stefan Roese, DENX Software Engineering, sr@denx.de.
- Based on code provided from UDTech and AMCC
- Originally based on code provided from UDTech and AMCC
- project.
- addi r4,0,reg ; \
- addi r4,0,reg ; \
- .extern ecc_init
* DDR2 setup
*/* DDR2 SDRAM Controller Setup
- /* Step 1 */
- /* Step 2 */
- /* Step 3 */
- /* Set Memory Bank Configuration Registers */
- mtsdram_as(SDRAM_MB0CF, CFG_SDRAM0_MB0CF);
Why do we now still have the SDRAM setup for Kilauea included in assembler? Is it because of the NAND booting support? If yes, then leave it as is and I'll clean this up later.
<snip>
- Based on code provided from Senao and AMCC
- Originally based on code provided from Senao and AMCC
- project.
@@ -23,126 +26,6 @@
- MA 02111-1307 USA
- addi r4,0,reg ; \
ext_bus_cntlr_init:
* DDR2 setup
- /* Step 1 */
- /* Step 2 */
- /* Step 3 */
- /* SDRAM_SDTR1 */
- /* SDRAM_SDTR2 */
- /* SDRAM_SDTR3 */
- /* NOP */
-#endif
- /* Step 5 */
- mtctr r3
-pll_wait:
- bdnz pll_wait
- /* Step 6 */
- /* SDRAM_DLCR */
- /* SDRAM_RDCC */
- /* SDRAM_RQDC */
- /* SDRAM_RFDC */
- blr
Please remove this file completely. It's not needed anymore, since we now use the common DDR2 controller init code you introduced with this patch. Please remove the testdram() function completely and move the sdram_init() to makalu.c.
Please fix if needed and resubmit. Thanks.
Best regards, Stefan
And thank you for your helpful pointers along the way.
Precisely. You have better exposure and visibility to the subtle nuances of NAND booting on Kilauea, so wrapping up that particular issue is best left to your experience.
For both Kilauea and Makalu or just Makalu and you'll address Kilauea in the course of handling init.S?
Regards,
Grant
OK. I'll take care of this.
Just do Makalu. I need to tackle Kilauea anyway, so I'll clean this up in a later patch in this merge window.
And please base you new patches against the TOT of Wolfgangs master branch. He has already pushed his "Big white-space cleanup" and there could be merge problems with your work.
Thanks.
Grant Erickson
Stefan Roese
