[U-Boot] imx28 secure boot
28 Feb
2013
28 Feb
'13
4:21 p.m.
Hi everyone,
This issue is more imx28 / ltib related, but here it goes:
If I build the u-boot from the ltib package and want to flash an SD-card with the boot stream, I have the choice between imx28_uboot.sb and imx28_ivt_uboot.sd (a HAB secured one). For the mx28evk, it only works if I use the _ivt_ one, since HAB is per default enabled.
But now I take the mainline (u-boot-imx.git). The only bootstream output is the uboot.sb, which is (I assume) not secured. So I tried to add this code security without success, but then it appears that this bootstream just works on the mx28evk.
This is not a real problem if things work, but can anyone explain to me how this works?
Ruud Commandeur
4458
Ruud Commandeur
