[PATCH 0/2] pci: layerscape: Fix the BARs disable function in RC mode
The Expansion ROM BAR is not disabled by clearing the BAR_EN bit in current code, fix it. Add disabling of BARs of PCIe controller with SRIOV feature.
Hou Zhiqiang (2): pci: layerscape: Fix the disabling of Expansion ROM BAR pci: layerscape: Fix the BARs disable function
drivers/pci/pcie_layerscape.c | 13 +------------ 1 file changed, 1 insertion(+), 12 deletions(-)
The software will still get non-zero Expansion ROM BAR size even when the BAR_EN bit is cleared. The BAR_EN bit of register EXP_ROM_BAR_MASK_RC is not working as expected, so this patch changes to mask all the bits to make it.
Fixes: 80afc63fc342 ("pci: layerscape: add pci driver based on DM") Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- drivers/pci/pcie_layerscape.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pci/pcie_layerscape.c b/drivers/pci/pcie_layerscape.c index 5ad7c28773..96533cb2d9 100644 --- a/drivers/pci/pcie_layerscape.c +++ b/drivers/pci/pcie_layerscape.c @@ -325,7 +325,7 @@ static void ls_pcie_disable_bars(struct ls_pcie *pcie)
dbi_writel(pcie, 0, PCIE_CS2_OFFSET + PCI_BASE_ADDRESS_0); dbi_writel(pcie, 0, PCIE_CS2_OFFSET + PCI_BASE_ADDRESS_1); - dbi_writel(pcie, 0, PCIE_CS2_OFFSET + PCI_ROM_ADDRESS1); + dbi_writel(pcie, 0xfffffffe, PCIE_CS2_OFFSET + PCI_ROM_ADDRESS1); }
static void ls_pcie_setup_ctrl(struct ls_pcie *pcie)
-----Original Message----- From: Z.q. Hou zhiqiang.hou@nxp.com Sent: Tuesday, December 17, 2019 3:41 PM To: u-boot@lists.denx.de; Priyanka Jain priyanka.jain@nxp.com; M.h. Lian minghuan.lian@nxp.com Cc: Z.q. Hou zhiqiang.hou@nxp.com Subject: [PATCH 1/2] pci: layerscape: Fix the disabling of Expansion ROM BAR
series applied in u-boot-fsl-qoriq/master after minor updates in subject of patch 1/2 -priyankajain
There is not any difference for disabling BARs in RC mode between PCIe controllers with and without SRIOV.
Fixes: 80afc63fc342 ("pci: layerscape: add pci driver based on DM") Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- drivers/pci/pcie_layerscape.c | 11 ----------- 1 file changed, 11 deletions(-)
diff --git a/drivers/pci/pcie_layerscape.c b/drivers/pci/pcie_layerscape.c index 96533cb2d9..d8ca7e71f8 100644 --- a/drivers/pci/pcie_layerscape.c +++ b/drivers/pci/pcie_layerscape.c @@ -312,17 +312,6 @@ static void ls_pcie_drop_msg_tlp(struct ls_pcie *pcie) /* Disable all bars in RC mode */ static void ls_pcie_disable_bars(struct ls_pcie *pcie) { - u32 sriov; - - sriov = in_le32(pcie->dbi + PCIE_SRIOV); - - /* - * TODO: For PCIe controller with SRIOV, the method to disable bars - * is different and more complex, so will add later. - */ - if (PCI_EXT_CAP_ID(sriov) == PCI_EXT_CAP_ID_SRIOV) - return; - dbi_writel(pcie, 0, PCIE_CS2_OFFSET + PCI_BASE_ADDRESS_0); dbi_writel(pcie, 0, PCIE_CS2_OFFSET + PCI_BASE_ADDRESS_1); dbi_writel(pcie, 0xfffffffe, PCIE_CS2_OFFSET + PCI_ROM_ADDRESS1);
Priyanka Jain
Z.q. Hou
