[U-Boot] [PATCH v1] dfu: Avoid declaring unused variables and absent parameters
The compiler is not happy when neither USB nor TFTP transport for DFU defined:
cmd/dfu.c: In function ‘do_dfu’: cmd/dfu.c:31:8: warning: unused variable ‘devstring’ [-Wunused-variable] char *devstring = argv[3]; ^~~~~~~~~ cmd/dfu.c:30:8: warning: unused variable ‘interface’ [-Wunused-variable] char *interface = argv[2]; ^~~~~~~~~
Surround those variables by #ifdef expression.
More serious, that comes under same circumstances, is a compilation error due to absence of macro parameter:
In file included from include/image.h:45, from include/common.h:35, from cmd/dfu.c:13: include/command.h:207:24: error: expected expression before ‘,’ token # define _CMD_HELP(x) x, ^ include/command.h:286:18: note: in expansion of macro ‘_CMD_HELP’ _cmd, _usage, _CMD_HELP(_help) _CMD_COMPLETE(_comp) } ^~~~~~~~~ include/command.h:290:3: note: in expansion of macro ‘U_BOOT_CMD_MKENT_COMPLETE’ U_BOOT_CMD_MKENT_COMPLETE(_name, _maxargs, _rep, _cmd, \ ^~~~~~~~~~~~~~~~~~~~~~~~~ include/command.h:332:2: note: in expansion of macro ‘U_BOOT_CMD_COMPLETE’ U_BOOT_CMD_COMPLETE(_name, _maxargs, _rep, _cmd, _usage, _help, NULL) ^~~~~~~~~~~~~~~~~~~ cmd/dfu.c:70:1: note: in expansion of macro ‘U_BOOT_CMD’ U_BOOT_CMD(dfu, CONFIG_SYS_MAXARGS, 1, do_dfu, ^~~~~~~~~~ make[1]: *** [scripts/Makefile.build:279: cmd/dfu.o] Error 1 make: *** [Makefile:1518: cmd] Error 2
Put empty string unconditionally to have macro parameter present.
Fixes: 0f44d33536a5 ("dfu: Fix up the Kconfig mess") Cc: Marek Vasut marek.vasut@gmail.com Signed-off-by: Andy Shevchenko andriy.shevchenko@linux.intel.com --- cmd/dfu.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/cmd/dfu.c b/cmd/dfu.c index 4adb91c1b0..498a30b33b 100644 --- a/cmd/dfu.c +++ b/cmd/dfu.c @@ -27,8 +27,10 @@ static int do_dfu(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_DFU_OVER_USB char *usb_controller = argv[1]; #endif +#if defined(CONFIG_DFU_OVER_USB) || defined(CONFIG_DFU_OVER_TFTP) char *interface = argv[2]; char *devstring = argv[3]; +#endif
int ret = 0; #ifdef CONFIG_DFU_OVER_TFTP @@ -67,6 +69,7 @@ done:
U_BOOT_CMD(dfu, CONFIG_SYS_MAXARGS, 1, do_dfu, "Device Firmware Upgrade", + "" #ifdef CONFIG_DFU_OVER_USB #ifdef CONFIG_DFU_TIMEOUT "<USB_controller> <interface> <dev> [list|timeout]\n"
Any comments on this?
I don't know who is the right person to push this forward, please, feel free to Cc to the right one, or tell me to resend with proper Cc list.
#ifdef CONFIG_DFU_OVER_USB #ifdef CONFIG_DFU_TIMEOUT "<USB_controller> <interface> <dev> [list|timeout]\n" -- 2.20.1
Lukasz?
-- With Best Regards, Andy Shevchenko
Hi Tom, Andy,
I can only recommend using patman, which shall link the dfu: in topic with my e-mail address,
Lukasz?
Regarding the patch,
Acked-by: Lukasz Majewski lukma@denx.de
If the travis doesn't complain, feel free to apply it.
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
It's pity that different projects based on Kbuild infra are using different type of accessing to maintainers data base. I have used get_maintainer.pl.
Lukasz?
Thanks!
On Fri, 15 Mar 2019 11:23:38 +0200 Andy Shevchenko andy.shevchenko@gmail.com wrote: ...
get_maintainer.pl failed to report e-mail address since the dfu command code entry is not in the data base file. I've just sent a patch to fix it.
-- Anatolij
participants (5)
Anatolij Gustschin
Andy Shevchenko
Andy Shevchenko
Lukasz Majewski
