[U-Boot-Users] RE: [440GX/JFFS]
I have build a JFFS file system on which I put a busybox filesystem including vmlinuximage
Looking at the docuementation, I am not very clear how to start linux. I use fsload to copy it to memory but starting it fails.
Also in another instance when I had the stripped version of Linux burnt into flash I have not succeeded to autostart Linux (bootdelay was set to 5 seconds). Starting it from the command line works (go ff900000).
In message 45ABD2373C33C4459D42B40EC4F346F2034C97C5@FTWMLVEM03.e2k.ad.ge.com you wrote:
Usually it is much easier to put the Linux kernel image in a separate part of the flash. Loading it from a filesystem just adds to the boot time.
There is no difference with any other boot procedure - load the kernel to RAM, and use "bootm" to start it.
What exactly does "it fails" mean? Is there any error message?
What is a "stripped version"? U-Boot does not know such a thing.
You must be doing something seriously wrong. You NEVER start a Linux kernel using the "go" command, but ONLY using "bootm".
Please RTFM.
Barbier, Renaud (GE Infrastructure)
