[U-Boot] [RFC] gpio: omap_gpio: Convert to auto-alloc feature when DT is supported
The omap_gpio driver has a TODO that says when every board is converted to DM and DT, the omap_gpio_bind can stop using calloc and switch to auto-alloc.
This patch converts this driver to auto-calloc when DT is enabled.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/drivers/gpio/omap_gpio.c b/drivers/gpio/omap_gpio.c index d128f942a0..4d54df284d 100644 --- a/drivers/gpio/omap_gpio.c +++ b/drivers/gpio/omap_gpio.c @@ -296,6 +296,7 @@ static int omap_gpio_probe(struct udevice *dev) return 0; }
+#if !CONFIG_IS_ENABLED(OF_CONTROL) static int omap_gpio_bind(struct udevice *dev) { struct omap_gpio_platdata *plat = dev_get_platdata(dev); @@ -328,6 +329,7 @@ static int omap_gpio_bind(struct udevice *dev)
return 0; } +#endif
static const struct udevice_id omap_gpio_ids[] = { { .compatible = "ti,omap3-gpio" }, @@ -336,12 +338,33 @@ static const struct udevice_id omap_gpio_ids[] = { { } };
+#if CONFIG_IS_ENABLED(OF_CONTROL) +static int omap_gpio_ofdata_to_platdata(struct udevice *dev) +{ + struct omap_gpio_platdata *plat = dev_get_platdata(dev); + fdt_addr_t addr; + + addr = devfdt_get_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + plat->base = addr; + return 0; +} +#endif + U_BOOT_DRIVER(gpio_omap) = { .name = "gpio_omap", .id = UCLASS_GPIO, +#if CONFIG_IS_ENABLED(OF_CONTROL) + .ofdata_to_platdata = of_match_ptr(omap_gpio_ofdata_to_platdata), + .bind = dm_scan_fdt_dev, + .platdata_auto_alloc_size = sizeof(struct omap_gpio_platdata), +#else + .bind = omap_gpio_bind, +#endif .ops = &gpio_omap_ops, .of_match = omap_gpio_ids, - .bind = omap_gpio_bind, .probe = omap_gpio_probe, .priv_auto_alloc_size = sizeof(struct gpio_bank), .flags = DM_FLAG_PRE_RELOC,
Adam Ford
