[U-Boot] [PATCH 8/8] Migrate generic bootcount to Kconfig
Make generate boot counter selected in the same way as other boot count drivers
Signed-off-by: Alex Kiernan alex.kiernan@gmail.com ---
drivers/bootcount/Kconfig | 11 +++++++++++ drivers/bootcount/Makefile | 2 +- 2 files changed, 12 insertions(+), 1 deletion(-)
diff --git a/drivers/bootcount/Kconfig b/drivers/bootcount/Kconfig index e0d1fc2..9fde2f2 100644 --- a/drivers/bootcount/Kconfig +++ b/drivers/bootcount/Kconfig @@ -14,6 +14,16 @@ choice prompt "Boot count device" default BOOTCOUNT_AM33XX if AM33XX || SOC_DA8XX default BOOTCOUNT_AT91 if AT91SAM9XE + default BOOTCOUNT_GENERIC + +config BOOTCOUNT_GENERIC + bool "Generic default boot counter" + help + Generic bootcount stored at SYS_BOOTCOUNT_ADDR. + + SYS_BOOTCOUNT_ADDR: + Set to the address where the bootcount and bootcount magic + will be stored.
config BOOTCOUNT_EXT bool "Boot counter on EXT filesystem" @@ -64,6 +74,7 @@ endchoice
config SYS_BOOTCOUNT_SINGLEWORD bool "Use single word to pack boot count and magic value" + depends on BOOTCOUNT_GENERIC help This option enables packing boot count magic value and boot count into single word (32 bits). diff --git a/drivers/bootcount/Makefile b/drivers/bootcount/Makefile index a3658c1..3e1ae8c 100644 --- a/drivers/bootcount/Makefile +++ b/drivers/bootcount/Makefile @@ -2,7 +2,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += bootcount.o +obj-$(CONFIG_BOOTCOUNT_GENERIC) += bootcount.o obj-$(CONFIG_BOOTCOUNT_AT91) += bootcount_at91.o obj-$(CONFIG_BOOTCOUNT_AM33XX) += bootcount_davinci.o obj-$(CONFIG_BOOTCOUNT_RAM) += bootcount_ram.o
Hi Alex,
- default BOOTCOUNT_GENERIC
- bool "Generic default boot counter"
- help
SYS_BOOTCOUNT_ADDR:
magic
will be stored.
- depends on BOOTCOUNT_GENERIC help This option enables packing boot count magic value and
Reviewed-by: Lukasz Majewski lukma@denx.de
I had to put attached patch (one liner) to make it working on my setup (this allows re-using the SYS_BOOTCOUNT_ADDR on non EXT setup).
Could you squash this patch to your work and send v2?
Thanks in advance,
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
On Sun, Feb 11, 2018 at 7:36 PM, Lukasz Majewski lukma@denx.de wrote:
Hi Alex,
help
SYS_BOOTCOUNT_ADDR:
magic
will be stored.
I'm not really sure what the right thing to do with SYS_BOOTCOUNT_ADDR is...
The default is only right for BOOTCOUNT_EXT (and then only on a specific board?) and elsewhere it's mostly set in board configs. In my case I actually want it to be defined based on a other bits of memory map . Maybe it's been overloaded too much and really wants to be a variable per driver?
That said, squashing in that change doesn't obviously break anything for me, and is probably a step in the right direction.
I'll see what Travis thinks.
On Sun, 11 Feb 2018 21:04:46 +0000 Alex Kiernan alex.kiernan@gmail.com wrote:
Hi Alex,
help
SYS_BOOTCOUNT_ADDR:
magic
will be stored.
It is defined in a few places though:
git grep -n "SYS_BOOTCOUNT_ADDR" [1]
However, for my builds I did not observed the build breaks (build definately breaks when this value is "") - but in my patch I do also use BOOTCOUNT, which is not defined in [1] boards.
Hence, (when BOOTCOUNT is not defined) boards [1] use SYS_BOOTCOUNT_ADDR from their ./include/configs/<board>.h.
When, I do define BOOTCOUNT on my board, then I _must_ also define correct SYS_BOOTCOUNT_ADDR in my ./configs/<board>_defconfig.
Please look into following patchset: http://patchwork.ozlabs.org/cover/871655/
We will probably receive build breaks...
Lukasz Majewski
Yup... https://travis-ci.org/akiernan/u-boot/jobs/340344489
Just tried again on one of those failures (x600) with the the default removed and just set the on board that uses CONFIG_EXT, but that then fails at config time.
TBH I'd actually like to take it out of Kconfig (which I realise is the wrong direction) as it just feels fundamentally wrong the way it is. I don't know what the U-Boot approach configuration like this is... struggling to find prior art.
Hi Alex,
Ok. I see
To finish moving SYS_BOOTCOUNT_ADDR to Kconfig we would need to add its definition to each eligible ./configs/<board>_defconfig file.
Then we would have the previous behaviour preserved.
Let's ask Tom for his opinion as he did much such work before.
Lukasz Majewski
On Mon, 12 Feb 2018 09:48:13 +0100 Lukasz Majewski lukma@denx.de wrote:
Hi Alex,
Ok. I see
I had similar issue with HW_WATCHDOG conversion:
http://patchwork.ozlabs.org/cover/871576/ especially:
http://patchwork.ozlabs.org/patch/871579/
Lukasz Majewski
Lukasz Majewski
On Mon, Feb 12, 2018 at 8:48 AM, Lukasz Majewski lukma@denx.de wrote:
Hi Alex,
Ok. I see
Thoughts:
- Do nothing, leave CONFIG_SYS_BOOTCOUNT_ADDR as a purely CONFIG_EXT piece of Kconfig - Rename CONFIG_SYS_BOOTCOUNT_ADDR to something like CONFIG_SYS_BOOTCOUNT_ADDR_EXT for just CONFIG_EXT - Remove CONFIG_SYS_BOOTCOUNT_ADDR from Kconfig altogether (and rename to say SYS_BOOTCOUNT_ADDR) - Pick through every config building defaults - okay for some boards, but lots have it defined based on other memory offsets
I think the only real options are the last two.
Whatever we do, I think CONFIG_SYS_BOOTCOUNT_ADDR wants splitting into at least two:
- I2C - an offset from an I2C base for the bootcounter - Others - an actual address used for storing the bootcounter
I'm struggling to see why EXT is the way it is - AFAICS the location it uses to access/return the bootcounter is basically local to the two functions in bootcount_ext and could just be a local variable.
Hi Alex,
Hi Alex,
Ok. I see
Thoughts:
piece of Kconfig
I would go for third option - Remove the SYS_BOOTCOUNT_ADDR from Kconfig (also for EXT).
- RAM/SoC memory - location of special register to store bootcounter
Maybe we can replace it with local, static variable then?
As said above - I would remove the (wrongly?) used BOOTCOUNT_ADDR in Kconfig.
Then, for next merge window we can play around with moving CONFIG_SYS_BOOTCOUNT_ADDR per boards if needed.
I just do have a feeling that -rc2 is too late for it....
Also, wrong SYS_BOOTCOUNT_ADDR will not be caught in build testing and may cause boards to silency break.
Lukasz Majewski
On Tue, Feb 13, 2018 at 2:41 PM, Lukasz Majewski lukma@denx.de wrote:
Hi Alex,
Hi Alex,
Ok. I see
Thoughts:
piece of Kconfig
I agree.
Just removing SYS_BOOTCOUNT_ADDR from Kconfig and putting the default back into bootcount_ext seems like the simplest correct change. I'll add that onto the series and throw it at Travis.
Yeah...
Hi Alex,
Hi Alex,
Hi Alex,
> > That said, squashing in that change doesn't obviously break > anything for me, and is probably a step in the right > direction. > > I'll see what Travis thinks. >
Ok. I see
Thoughts:
I agree.
bootcounter
Great. I'm looking forward for next verison of the code - as I do have some code to be put on top of it.
Thanks for help.
Yeah...
Lukasz Majewski
bootcounter
So the super-trivial approach doesn't work, because CONFIG_SYS_BOOTCOUNT_ADDR isn't in the whitelist anymore (7af2e3648f3f6d726f6476745c2eec5de709a702) and I think the only reason it was getting through before is because scripts/check-config.sh doesn't parse conditionals in Kconfig so thought it was allowed :(
I expect reintroducing CONFIG_SYS_BOOTCOUNT_ADDR to config_whitelist.txt would "fix" the problem, but that's not going to make it in.
Which I think means I have to do the work to migrate it out of CONFIG_ land properly.
Hi Alex,
bootcounter
Ok. I see.
Lukasz Majewski
On Wed, Feb 14, 2018 at 7:13 PM, Lukasz Majewski lukma@denx.de wrote:
Hi Alex,
bootcounter
Ok. I see.
'tis done. Only I've fallen foul of the recipient limit on the mailing list :( Will see if the two pieces get pushed out, if not I'll go and trim the list and try again.
As you say, this isn't a patch for -rc2
Alex Kiernan
Lukasz Majewski
