[PATCH v2 0/3] add TCB driver for sama5d2
When booting under OP-TEE, the SYSC is secured which means the PIT is also not accessible by non-secure world. The TCB 0 however is always available for non-secure world and thus can be used. This series add a TCB driver and enables it in sama5d2 configs.
Changes in v2: - Reworked driver to use existing Linux bindings
Clément Léger (3): timer: atmel_tcb_timer: add atmel_tcb driver dts: sama5d2: add TCB node configs: sama5d2: enable option CONFIG_ATMEL_TCB_TIMER
MAINTAINERS | 1 + arch/arm/dts/sama5d2.dtsi | 15 ++ configs/sama5d2_icp_mmc_defconfig | 1 + configs/sama5d2_ptc_ek_mmc_defconfig | 1 + configs/sama5d2_ptc_ek_nandflash_defconfig | 1 + configs/sama5d2_xplained_emmc_defconfig | 1 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d2_xplained_qspiflash_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + drivers/timer/Kconfig | 7 + drivers/timer/Makefile | 1 + drivers/timer/atmel_tcb_timer.c | 160 +++++++++++++++++++ 12 files changed, 191 insertions(+) create mode 100644 drivers/timer/atmel_tcb_timer.c
Add a driver for the timer counter block that can be found on sama5d2. This driver will be used when booting under OP-TEE since the pit timer which is part of the SYSC is secured. Channel 1 & 2 are configured to be chained together which allows to have a 64bits counter.
Signed-off-by: Clément Léger clement.leger@bootlin.com --- MAINTAINERS | 1 + drivers/timer/Kconfig | 7 ++ drivers/timer/Makefile | 1 + drivers/timer/atmel_tcb_timer.c | 160 ++++++++++++++++++++++++++++++++ 4 files changed, 169 insertions(+) create mode 100644 drivers/timer/atmel_tcb_timer.c
diff --git a/MAINTAINERS b/MAINTAINERS index dcdd99e368..6ff95aea39 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -343,6 +343,7 @@ F: arch/arm/mach-at91/ F: board/atmel/ F: drivers/cpu/at91_cpu.c F: drivers/misc/microchip_flexcom.c +F: drivers/timer/atmel_tcb_timer.c F: include/dt-bindings/mfd/atmel-flexcom.h F: drivers/timer/mchp-pit64b-timer.c
diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 8913142654..9b7bbec654 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -96,6 +96,13 @@ config ATMEL_PIT_TIMER it is designed to offer maximum accuracy and efficient management, even for systems with long response time.
+config ATMEL_TCB_TIMER + bool "Atmel timer counter support" + depends on TIMER + help + Select this to enable the use of the timer counter as a monotonic + counter. + config CADENCE_TTC_TIMER bool "Cadence TTC (Triple Timer Counter)" depends on TIMER diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index e2bd530eb0..58da6c1e84 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -10,6 +10,7 @@ obj-$(CONFIG_ARC_TIMER) += arc_timer.o obj-$(CONFIG_AST_TIMER) += ast_timer.o obj-$(CONFIG_ATCPIT100_TIMER) += atcpit100_timer.o obj-$(CONFIG_ATMEL_PIT_TIMER) += atmel_pit_timer.o +obj-$(CONFIG_ATMEL_TCB_TIMER) += atmel_tcb_timer.o obj-$(CONFIG_CADENCE_TTC_TIMER) += cadence-ttc.o obj-$(CONFIG_DESIGNWARE_APB_TIMER) += dw-apb-timer.o obj-$(CONFIG_MPC83XX_TIMER) += mpc83xx_timer.o diff --git a/drivers/timer/atmel_tcb_timer.c b/drivers/timer/atmel_tcb_timer.c new file mode 100644 index 0000000000..6f2c054629 --- /dev/null +++ b/drivers/timer/atmel_tcb_timer.c @@ -0,0 +1,160 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 Microchip Corporation + * + * Author: Clément Léger clement.leger@bootlin.com + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <timer.h> +#include <asm/io.h> +#include <linux/bitops.h> + +#define TCB_CHAN(chan) ((chan) * 0x40) + +#define TCB_CCR(chan) (0x0 + TCB_CHAN(chan)) +#define TCB_CCR_SWTRG 0x4 +#define TCB_CCR_CLKEN 0x1 + +#define TCB_CMR(chan) (0x4 + TCB_CHAN(chan)) +#define TCB_CMR_WAVE BIT(15) +#define TCB_CMR_TIMER_CLOCK0 0 +#define TCB_CMR_XC1 6 +#define TCB_CMR_ACPA_SET (1 << 16) +#define TCB_CMR_ACPC_CLEAR (2 << 18) + +#define TCB_CV(chan) (0x10 + TCB_CHAN(chan)) + +#define TCB_RA(chan) (0x14 + TCB_CHAN(chan)) +#define TCB_RB(chan) (0x18 + TCB_CHAN(chan)) +#define TCB_RC(chan) (0x1c + TCB_CHAN(chan)) + +#define TCB_IER(chan) (0x24 + TCB_CHAN(chan)) +#define TCB_IER_COVFS 0x1 + +#define TCB_SR(chan) (0x20 + TCB_CHAN(chan)) +#define TCB_SR_COVFS 0x1 + +#define TCB_IDR(chan) (0x28 + TCB_CHAN(chan)) + +#define TCB_BCR 0xc0 +#define TCB_BCR_SYNC 0x1 + +#define TCB_BMR 0xc4 +#define TCB_BMR_TC1XC1S_TIOA0 (2 << 2) + +#define TCB_WPMR 0xe4 +#define TCB_WPMR_WAKEY 0x54494d + +struct atmel_tcb_plat { + void __iomem *base; +}; + +static u64 atmel_tcb_get_count(struct udevice *dev) +{ + struct atmel_tcb_plat *plat = dev_get_plat(dev); + u64 cv0 = 0; + u64 cv1 = 0; + + do { + cv1 = readl(plat->base + TCB_CV(1)); + cv0 = readl(plat->base + TCB_CV(0)); + } while (readl(plat->base + TCB_CV(1)) != cv1); + + cv0 |= cv1 << 32; + + return cv0; +} + +static void atmel_tcb_configure(void __iomem *base) +{ + /* Disable write protection */ + writel(TCB_WPMR_WAKEY, base + TCB_WPMR); + + /* Disable all irqs for both channel 0 & 1 */ + writel(0xff, base + TCB_IDR(0)); + writel(0xff, base + TCB_IDR(1)); + + /* + * In order to avoid wrapping, use a 64 bit counter by chaining + * two channels. + * Channel 0 is configured to generate a clock on TIOA0 which is cleared + * when reaching 0x80000000 and set when reaching 0. + */ + writel(TCB_CMR_TIMER_CLOCK0 | TCB_CMR_WAVE | TCB_CMR_ACPA_SET + | TCB_CMR_ACPC_CLEAR, base + TCB_CMR(0)); + writel(0x80000000, base + TCB_RC(0)); + writel(0x1, base + TCB_RA(0)); + writel(TCB_CCR_CLKEN, base + TCB_CCR(0)); + + /* Channel 1 is configured to use TIOA0 as input */ + writel(TCB_CMR_XC1 | TCB_CMR_WAVE, base + TCB_CMR(1)); + writel(TCB_CCR_CLKEN, base + TCB_CCR(1)); + + /* Set XC1 input to be TIOA0 (ie output of Channel 0) */ + writel(TCB_BMR_TC1XC1S_TIOA0, base + TCB_BMR); + + /* Sync & start all timers */ + writel(TCB_BCR_SYNC, base + TCB_BCR); +} + +static int atmel_tcb_probe(struct udevice *dev) +{ + struct atmel_tcb_plat *plat = dev_get_plat(dev); + struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct clk clk; + ulong clk_rate; + int ret; + + if (!device_is_compatible(dev->parent, "atmel,sama5d2-tcb")) + return -EINVAL; + + /* Currently, we only support channel 0 and 1 to be chained */ + if (dev_read_addr_index(dev, 0) != 0 && + dev_read_addr_index(dev, 1) != 1) + return -EINVAL; + + ret = clk_get_by_name(dev->parent, "gclk", &clk); + if (ret) + return -EINVAL; + + clk_rate = clk_get_rate(&clk); + if (!clk_rate) + return -EINVAL; + + uc_priv->clock_rate = clk_rate; + + atmel_tcb_configure(plat->base); + + return 0; +} + +static int atmel_tcb_of_to_plat(struct udevice *dev) +{ + struct atmel_tcb_plat *plat = dev_get_plat(dev); + + plat->base = dev_read_addr_ptr(dev->parent); + + return 0; +} + +static const struct timer_ops atmel_tcb_ops = { + .get_count = atmel_tcb_get_count, +}; + +static const struct udevice_id atmel_tcb_ids[] = { + { .compatible = "atmel,tcb-timer" }, + { } +}; + +U_BOOT_DRIVER(atmel_tcb) = { + .name = "atmel_tcb", + .id = UCLASS_TIMER, + .of_match = atmel_tcb_ids, + .of_to_plat = atmel_tcb_of_to_plat, + .plat_auto = sizeof(struct atmel_tcb_plat), + .probe = atmel_tcb_probe, + .ops = &atmel_tcb_ops, +};
Hello Clement,
Thank you for your patch.
depends on TIMER
help
counter.
maybe you should specify that this is specific to at91 architecture
- config CADENCE_TTC_TIMER bool "Cadence TTC (Triple Timer Counter)" depends on TIMER
- Copyright (C) 2022 Microchip Corporation
- Author: Clément Léger clement.leger@bootlin.com
Some of these defines are unused. It is better to remove them for simplicity
void __iomem *base;
u64 cv0 = 0;
u64 cv1 = 0;
do {
Are you reading cv1 multiple times without storing the cv1 value ?
And I don't really like this loop. What happens if after reading again CV(1) it's always different from the stored cv1 value ?
cv0 |= cv1 << 32;
return cv0;
* two channels.
struct clk clk;
ulong clk_rate;
int ret;
return -EINVAL;
I find it odd that you check the compatible for a parent of this device when this device is compatible only with 'atmel,tcb-timer' .
I would expect to have a driver specific for atmel,sama5d2-tcb and probe it accordingly.
return -EINVAL;
In here maybe we should at least emit a debug message to log on the console, if we do not support different things.
if (ret)
return -EINVAL;
if (!clk_rate)
return -EINVAL;
It looks like you want to handle the parent in fact. This does not look very straight forward from my perspective.
Added Claudiu to this thread who knows better the timer blocks as they are designed in Linux
.id = UCLASS_TIMER,
2.34.1
Le Thu, 3 Mar 2022 09:31:14 +0000, Eugen.Hristev@microchip.com a écrit :
Hello Clement,
depends on TIMER
help
counter.
Acked.
void __iomem *base;
u64 cv0 = 0;
u64 cv1 = 0;
do {
This loops allows to read a "coherent" 64 bits value from two 32 bits registers that are handled separatly by the hardware. This is just a precaution to avoid reading value while overflowing the 32 bits low value.
Lets say the counter contains the following values: cv1 = 0 cv0 = 0xffffffff
If we read cv1, and then cv0, we might potentially read cv1 = 0 and cv0 = 0 due to counter being incremented instead ov cv1 = 1, cv0 = 0. So actually, this check with cv1 will almost never be true and will potentially just happens if reading at the exact same time cv0 overflows.
I can downgrade to using a 32 bits counter if you want. Please note that the same logic is used in Linux driver.
cv0 |= cv1 << 32;
return cv0;
* two channels.
struct clk clk;
ulong clk_rate;
int ret;
return -EINVAL;
Since we "must" use the Linux bindings, this should be done this way. In linux, it is done the same way:
static const struct of_device_id atmel_tcb_of_match[] = { ... { .compatible = "atmel,sama5d2-tcb", ...}, { /* sentinel */ } };
static int __init tcb_clksrc_init(struct device_node *node) { [...] tc.regs = of_iomap(node->parent, 0); if (!tc.regs) return -ENXIO; [...] match = of_match_node(atmel_tcb_of_match, node->parent); if (!match) return -ENODEV; [...] }
return -EINVAL;
Ok, that would be a good thing indeed.
if (ret)
return -EINVAL;
if (!clk_rate)
return -EINVAL;
The same thing is done in Linux also (see above). This is caused by the specific bindings.
.id = UCLASS_TIMER,
2.34.1
Hello Clement,
depends on TIMER
help
counter.
Acked.
void __iomem *base;
u64 cv0 = 0;
u64 cv1 = 0;
do {
Ok, I understand, the cv1 is the MSB of the timer, thus it won't change so fast
It's fine, keep the 64 bits. If Linux uses the same logic we are fine.
cv0 |= cv1 << 32;
return cv0;
* two channels.
struct clk clk;
ulong clk_rate;
int ret;
return -EINVAL;
Yes, we must, as bindings is ABI and it should reflect the hardware.
return -EINVAL;
if (ret)
return -EINVAL;
if (!clk_rate)
return -EINVAL;
Ok, keep Claudiu in the loop as I would like for him to have the chance to review this driver.
Thanks !
.id = UCLASS_TIMER,
2.34.1
-- Clément Léger, Embedded Linux and Kernel engineer at Bootlin https://bootlin.com
Add the device-tree node to describe the TCB timer.
Signed-off-by: Clément Léger clement.leger@bootlin.com --- arch/arm/dts/sama5d2.dtsi | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/arch/arm/dts/sama5d2.dtsi b/arch/arm/dts/sama5d2.dtsi index 038cd73c03..fc6a4fbe4d 100644 --- a/arch/arm/dts/sama5d2.dtsi +++ b/arch/arm/dts/sama5d2.dtsi @@ -700,6 +700,21 @@ clocks = <&h32ck>; };
+ tcb0: timer@f800c000 { + compatible = "atmel,sama5d2-tcb", "simple-mfd"; + reg = <0xf800c000 0x100>; + + clocks = <&tcb0_clk>, <&tcb0_gclk>, <&clk32k>; + clock-names = "t0_clk", "gclk", "slow_clk"; + #address-cells = <1>; + #size-cells = <0>; + + timer0: timer@0 { + compatible = "atmel,tcb-timer"; + reg = <0>, <1>; + }; + }; + watchdog@f8048040 { compatible = "atmel,sama5d4-wdt"; reg = <0xf8048040 0x10>;
Hello Clement,
Subject should be ARM: dts: [at91:] sama5d2: ...
syscon ?
#size-cells = <0>;
timer0: timer@0 {
reg = <0>, <1>;
I am not happy that the original binding has the interrupts as 'mandatory'. Maybe the binding author did not have more use cases in mind. Anyway I think that it can go to u-boot without this interrupts property as it's surely unused and there is no interrupt controller at the moment in the DT. If nobody has another opinion that is...
Eugen
-- 2.34.1
Le Fri, 4 Feb 2022 07:52:26 +0000, Eugen.Hristev@microchip.com a écrit :
Hello Clement,
syscon ?
Hi Eugen,
Yes I might add it if needed but in my case, there is no need for it.
#size-cells = <0>;
timer0: timer@0 {
reg = <0>, <1>;
I checked the other nodes and indeed, I did not found any 'interrupts' property so i guess it 'could' be left out... But I can add it for sure.
Eugen
-- 2.34.1
Hello Clement,
syscon ?
Hi Eugen,
True, but the binding says that the compatible *must* be the three stated... so we must comply to that, regardless if it's a need for it or not in U-boot.
#size-cells = <0>;
timer0: timer@0 {
reg = <0>, <1>;
I sent a patch in Linux to remove interrupts from mandatory. Let's have the node without it for now.
Your series will have to wait a little bit anyway for the next merge window, and a review on the driver.
Thanks again for your patches,
Eugen
Eugen
-- 2.34.1
Hello Clement,
syscon ?
Hi Eugen,
#size-cells = <0>;
timer0: timer@0 {
reg = <0>, <1>;
Hello Clement,
According to this :
https://lore.kernel.org/linux-arm-kernel/Yf0Bkh4pXKORmNkG@piout.net/
... the interrupt is mandatory.
Eugen
Eugen
Eugen
-- 2.34.1
Hello Clement,
According to this :
Hi Eugen,
No worries, I'll add it in a V3 but I will wait for the driver review to do so.
Eugen
This will allow using the TCB timer instead of the PIT one when running under OP-TEE.
Signed-off-by: Clément Léger clement.leger@bootlin.com --- configs/sama5d2_icp_mmc_defconfig | 1 + configs/sama5d2_ptc_ek_mmc_defconfig | 1 + configs/sama5d2_ptc_ek_nandflash_defconfig | 1 + configs/sama5d2_xplained_emmc_defconfig | 1 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d2_xplained_qspiflash_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + 7 files changed, 7 insertions(+)
diff --git a/configs/sama5d2_icp_mmc_defconfig b/configs/sama5d2_icp_mmc_defconfig index 7761a57e0c..2eb2e92110 100644 --- a/configs/sama5d2_icp_mmc_defconfig +++ b/configs/sama5d2_icp_mmc_defconfig @@ -83,5 +83,6 @@ CONFIG_ATMEL_USART=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y +CONFIG_ATMEL_TCB_TIMER=y CONFIG_OF_LIBFDT_OVERLAY=y # CONFIG_EFI_LOADER_HII is not set diff --git a/configs/sama5d2_ptc_ek_mmc_defconfig b/configs/sama5d2_ptc_ek_mmc_defconfig index 9f458e100b..2a77f72734 100644 --- a/configs/sama5d2_ptc_ek_mmc_defconfig +++ b/configs/sama5d2_ptc_ek_mmc_defconfig @@ -72,6 +72,7 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y +CONFIG_ATMEL_TCB_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/sama5d2_ptc_ek_nandflash_defconfig b/configs/sama5d2_ptc_ek_nandflash_defconfig index 6460ff3dad..790e79019c 100644 --- a/configs/sama5d2_ptc_ek_nandflash_defconfig +++ b/configs/sama5d2_ptc_ek_nandflash_defconfig @@ -72,6 +72,7 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y +CONFIG_ATMEL_TCB_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index 844a9cde64..dfe120051f 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -91,6 +91,7 @@ CONFIG_ATMEL_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y +CONFIG_ATMEL_TCB_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index 0de0636587..910ff5c141 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -93,6 +93,7 @@ CONFIG_ATMEL_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y +CONFIG_ATMEL_TCB_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/sama5d2_xplained_qspiflash_defconfig b/configs/sama5d2_xplained_qspiflash_defconfig index a6e002e59e..158ec4c70e 100644 --- a/configs/sama5d2_xplained_qspiflash_defconfig +++ b/configs/sama5d2_xplained_qspiflash_defconfig @@ -92,6 +92,7 @@ CONFIG_ATMEL_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y +CONFIG_ATMEL_TCB_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index 676385fe55..5d946d06cf 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -96,6 +96,7 @@ CONFIG_ATMEL_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y +CONFIG_ATMEL_TCB_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y
Clément Léger
