[U-Boot] [PATCH 1/3] arm: mvebu: Add some SPI CS attributes
These attribute defines may be used to map an area of memory for direct access to the specific SPI devices. See SPI Direct Access Mode for further information.
Signed-off-by: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr --- arch/arm/mach-mvebu/include/mach/cpu.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-mvebu/include/mach/cpu.h b/arch/arm/mach-mvebu/include/mach/cpu.h index 017d55f..dd58b4a 100644 --- a/arch/arm/mach-mvebu/include/mach/cpu.h +++ b/arch/arm/mach-mvebu/include/mach/cpu.h @@ -47,6 +47,9 @@ enum cpu_attrib { CPU_ATTR_DRAM_CS3 = 0x07, CPU_ATTR_NANDFLASH = 0x2f, CPU_ATTR_SPIFLASH = 0x1e, + CPU_ATTR_SPI0_CS0 = 0x1e, + CPU_ATTR_SPI0_CS1 = 0x5e, + CPU_ATTR_SPI1_CS2 = 0x9a, CPU_ATTR_BOOTROM = 0x1d, CPU_ATTR_PCIE_IO = 0xe0, CPU_ATTR_PCIE_MEM = 0xe8,
The direct write config register is needed for SPI direct write mode configuration.
Signed-off-by: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr --- arch/arm/include/asm/arch-mvebu/spi.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/include/asm/arch-mvebu/spi.h b/arch/arm/include/asm/arch-mvebu/spi.h index 4b66499..78869a2 100644 --- a/arch/arm/include/asm/arch-mvebu/spi.h +++ b/arch/arm/include/asm/arch-mvebu/spi.h @@ -19,6 +19,9 @@ struct kwspi_registers { u32 din; /* 0x1060c */ u32 irq_cause; /* 0x10610 */ u32 irq_mask; /* 0x10614 */ + u32 timing1; /* 0x10618 */ + u32 timing2; /* 0x1061c */ + u32 dw_cfg; /* 0x10620 - Direct Write Configuration */ };
/* They are used to define CONFIG_SYS_KW_SPI_MPP
Applied to u-boot-marvell/master.
Thanks, Stefan
This patch adds support for Altera StratixV bitstream programming. 2 FPGAs are connected to the SPI busses. This patch uses board specific write code to program the bitstream via SPI direct write mode.
Signed-off-by: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr --- arch/arm/dts/armada-xp-theadorable.dts | 21 ++++ board/theadorable/Makefile | 1 + board/theadorable/fpga.c | 179 +++++++++++++++++++++++++++++++++ board/theadorable/theadorable.c | 3 + board/theadorable/theadorable.h | 12 +++ configs/theadorable_debug_defconfig | 3 +- configs/theadorable_defconfig | 2 +- include/configs/theadorable.h | 5 + 8 files changed, 224 insertions(+), 2 deletions(-) create mode 100644 board/theadorable/fpga.c create mode 100644 board/theadorable/theadorable.h
diff --git a/arch/arm/dts/armada-xp-theadorable.dts b/arch/arm/dts/armada-xp-theadorable.dts index cf1be2a..7087ccf 100644 --- a/arch/arm/dts/armada-xp-theadorable.dts +++ b/arch/arm/dts/armada-xp-theadorable.dts @@ -69,6 +69,7 @@
aliases { spi0 = &spi0; + spi1 = &spi1; ethernet0 = ð0; };
@@ -137,6 +138,26 @@ reg = <0>; /* Chip select 0 */ spi-max-frequency = <27777777>; }; + + fpga@1 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-generic-device"; + reg = <1>; /* Chip select 1 */ + spi-max-frequency = <27777777>; + }; + }; + + spi1: spi@10680 { + status = "okay"; + + fpga@2 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-generic-device"; + reg = <2>; /* Chip select 2 */ + spi-max-frequency = <27777777>; + }; }; }; }; diff --git a/board/theadorable/Makefile b/board/theadorable/Makefile index 9d5b39e..ef5a519 100644 --- a/board/theadorable/Makefile +++ b/board/theadorable/Makefile @@ -5,3 +5,4 @@ #
obj-y := theadorable.o +obj-y += fpga.o diff --git a/board/theadorable/fpga.c b/board/theadorable/fpga.c new file mode 100644 index 0000000..6f068c3 --- /dev/null +++ b/board/theadorable/fpga.c @@ -0,0 +1,179 @@ +/* + * Copyright (C) 2016 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <altera.h> +#include <errno.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> +#include <asm/arch-mvebu/spi.h> +#include "theadorable.h" + +/* + * FPGA programming support + */ +static int fpga_pre_fn(int cookie) +{ + int gpio_config = COOKIE2CONFIG(cookie); + int gpio_done = COOKIE2DONE(cookie); + int ret; + + debug("%s (%d): cookie=%08x gpio_config=%d gpio_done=%d\n", + __func__, __LINE__, cookie, gpio_config, gpio_done); + + /* Configure config pin */ + /* Set to output */ + ret = gpio_request(gpio_config, "CONFIG"); + if (ret < 0) + return ret; + gpio_direction_output(gpio_config, 1); + + /* Configure done pin */ + /* Set to input */ + ret = gpio_request(gpio_done, "DONE"); + if (ret < 0) + return ret; + + gpio_direction_input(gpio_done); + + return 0; +} + +static int fpga_config_fn(int assert, int flush, int cookie) +{ + int gpio_config = COOKIE2CONFIG(cookie); + + debug("%s (%d): cookie=%08x gpio_config=%d\n", + __func__, __LINE__, cookie, gpio_config); + + if (assert) + gpio_set_value(gpio_config, 1); + else + gpio_set_value(gpio_config, 0); + + return 0; +} + +static int fpga_write_fn(const void *buf, size_t len, int flush, int cookie) +{ + int spi_bus = COOKIE2SPI_BUS(cookie); + int spi_dev = COOKIE2SPI_DEV(cookie); + struct kwspi_registers *reg; + u32 control_reg; + u32 config_reg; + void *dst; + + /* + * Write data to FPGA attached to SPI bus via SPI direct write. + * This results in the fastest and easiest way to program the + * bitstream into the FPGA. + */ + debug("%s (%d): cookie=%08x spi_bus=%d spi_dev=%d\n", + __func__, __LINE__, cookie, spi_bus, spi_dev); + + if (spi_bus == 0) { + reg = (struct kwspi_registers *)MVEBU_REGISTER(0x10600); + dst = (void *)SPI_BUS0_DEV1_BASE; + } else { + reg = (struct kwspi_registers *)MVEBU_REGISTER(0x10680); + dst = (void *)SPI_BUS1_DEV2_BASE; + } + + /* Configure SPI controller for direct access mode */ + control_reg = readl(®->ctrl); + config_reg = readl(®->cfg); + writel(0x00000214, ®->cfg); /* 27MHz clock */ + writel(0x00000000, ®->dw_cfg); /* don't de-asset CS */ + writel(KWSPI_CSN_ACT, ®->ctrl); /* activate CS */ + + /* Copy data to the SPI direct mapped window */ + memcpy(dst, buf, len); + + /* Restore original register values */ + writel(control_reg, ®->ctrl); + writel(config_reg, ®->cfg); + + return 0; +} + +/* Returns the state of CONF_DONE Pin */ +static int fpga_done_fn(int cookie) +{ + int gpio_done = COOKIE2DONE(cookie); + unsigned long ts; + + debug("%s (%d): cookie=%08x gpio_done=%d\n", + __func__, __LINE__, cookie, gpio_done); + + ts = get_timer(0); + do { + if (gpio_get_value(gpio_done)) + return 0; + } while (get_timer(ts) < 1000); + + /* timeout so return error */ + return -ENODEV; +} + +static altera_board_specific_func stratixv_fns = { + .pre = fpga_pre_fn, + .config = fpga_config_fn, + .write = fpga_write_fn, + .done = fpga_done_fn, +}; + +static Altera_desc altera_fpga[] = { + { + /* Family */ + Altera_StratixV, + /* Interface type */ + passive_serial, + /* No limitation as additional data will be ignored */ + -1, + /* Device function table */ + (void *)&stratixv_fns, + /* Base interface address specified in driver */ + NULL, + /* Cookie implementation */ + /* + * In this 32bit word the following information is coded: + * Bit 31 ... Bit 0 + * SPI-Bus | SPI-Dev | Config-Pin | Done-Pin + */ + FPGA_COOKIE(0, 1, 26, 7) + }, + { + /* Family */ + Altera_StratixV, + /* Interface type */ + passive_serial, + /* No limitation as additional data will be ignored */ + -1, + /* Device function table */ + (void *)&stratixv_fns, + /* Base interface address specified in driver */ + NULL, + /* Cookie implementation */ + /* + * In this 32bit word the following information is coded: + * Bit 31 ... Bit 0 + * SPI-Bus | SPI-Dev | Config-Pin | Done-Pin + */ + FPGA_COOKIE(1, 2, 29, 9) + }, +}; + +/* Add device descriptor to FPGA device table */ +void board_fpga_add(void) +{ + int i; + + fpga_init(); + for (i = 0; i < ARRAY_SIZE(altera_fpga); i++) + fpga_add(fpga_altera, &altera_fpga[i]); +} diff --git a/board/theadorable/theadorable.c b/board/theadorable/theadorable.c index 0e23265..3c7f15a 100644 --- a/board/theadorable/theadorable.c +++ b/board/theadorable/theadorable.c @@ -11,6 +11,7 @@ #ifdef CONFIG_NET #include <netdev.h> #endif +#include "theadorable.h"
#include "../drivers/ddr/marvell/axp/ddr3_hw_training.h" #include "../arch/arm/mach-mvebu/serdes/axp/high_speed_env_spec.h" @@ -143,6 +144,8 @@ int checkboard(void) { puts("Board: theadorable\n");
+ board_fpga_add(); + return 0; }
diff --git a/board/theadorable/theadorable.h b/board/theadorable/theadorable.h new file mode 100644 index 0000000..89fe117 --- /dev/null +++ b/board/theadorable/theadorable.h @@ -0,0 +1,12 @@ +/* + * Copyright (C) 2016 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* Base addresses for the SPI direct access mode */ +#define SPI_BUS0_DEV1_BASE 0xe0000000 +#define SPI_BUS0_DEV1_SIZE (1 << 20) +#define SPI_BUS1_DEV2_BASE (SPI_BUS0_DEV1_BASE + SPI_BUS0_DEV1_SIZE) + +void board_fpga_add(void); diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index fbed23c..086d220 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MVEBU=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_THEADORABLE=y +CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y @@ -9,7 +10,7 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y CONFIG_CMD_USB=y -# CONFIG_CMD_FPGA is not set +CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y diff --git a/configs/theadorable_defconfig b/configs/theadorable_defconfig index cce4669..7e01495 100644 --- a/configs/theadorable_defconfig +++ b/configs/theadorable_defconfig @@ -2,13 +2,13 @@ CONFIG_ARM=y CONFIG_ARCH_MVEBU=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_THEADORABLE=y +CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y -# CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index cd9d6b6..5a14e84 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -115,6 +115,11 @@ #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_CMD_BMP
+/* FPGA programming support */ +#define CONFIG_FPGA +#define CONFIG_FPGA_ALTERA +#define CONFIG_FPGA_STRATIX_V + /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros
Signed-off-by: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr --- v2: - Add missing mbus mapping for the SPI devices (direct access mode)
arch/arm/dts/armada-xp-theadorable.dts | 21 ++++ board/theadorable/Makefile | 1 + board/theadorable/fpga.c | 179 +++++++++++++++++++++++++++++++++ board/theadorable/theadorable.c | 13 +++ board/theadorable/theadorable.h | 12 +++ configs/theadorable_debug_defconfig | 3 +- configs/theadorable_defconfig | 2 +- include/configs/theadorable.h | 5 + 8 files changed, 234 insertions(+), 2 deletions(-) create mode 100644 board/theadorable/fpga.c create mode 100644 board/theadorable/theadorable.h
obj-y := theadorable.o +obj-y += fpga.o diff --git a/board/theadorable/fpga.c b/board/theadorable/fpga.c new file mode 100644 index 0000000..6f068c3 --- /dev/null +++ b/board/theadorable/fpga.c @@ -0,0 +1,179 @@ +/* + * Copyright (C) 2016 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <altera.h> +#include <errno.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> +#include <asm/arch-mvebu/spi.h> +#include "theadorable.h" + +/* + * FPGA programming support + */ +static int fpga_pre_fn(int cookie) +{ + int gpio_config = COOKIE2CONFIG(cookie); + int gpio_done = COOKIE2DONE(cookie); + int ret; + + debug("%s (%d): cookie=%08x gpio_config=%d gpio_done=%d\n", + __func__, __LINE__, cookie, gpio_config, gpio_done); + + /* Configure config pin */ + /* Set to output */ + ret = gpio_request(gpio_config, "CONFIG"); + if (ret < 0) + return ret; + gpio_direction_output(gpio_config, 1); + + /* Configure done pin */ + /* Set to input */ + ret = gpio_request(gpio_done, "DONE"); + if (ret < 0) + return ret; + + gpio_direction_input(gpio_done); + + return 0; +} + +static int fpga_config_fn(int assert, int flush, int cookie) +{ + int gpio_config = COOKIE2CONFIG(cookie); + + debug("%s (%d): cookie=%08x gpio_config=%d\n", + __func__, __LINE__, cookie, gpio_config); + + if (assert) + gpio_set_value(gpio_config, 1); + else + gpio_set_value(gpio_config, 0); + + return 0; +} + +static int fpga_write_fn(const void *buf, size_t len, int flush, int cookie) +{ + int spi_bus = COOKIE2SPI_BUS(cookie); + int spi_dev = COOKIE2SPI_DEV(cookie); + struct kwspi_registers *reg; + u32 control_reg; + u32 config_reg; + void *dst; + + /* + * Write data to FPGA attached to SPI bus via SPI direct write. + * This results in the fastest and easiest way to program the + * bitstream into the FPGA. + */ + debug("%s (%d): cookie=%08x spi_bus=%d spi_dev=%d\n", + __func__, __LINE__, cookie, spi_bus, spi_dev); + + if (spi_bus == 0) { + reg = (struct kwspi_registers *)MVEBU_REGISTER(0x10600); + dst = (void *)SPI_BUS0_DEV1_BASE; + } else { + reg = (struct kwspi_registers *)MVEBU_REGISTER(0x10680); + dst = (void *)SPI_BUS1_DEV2_BASE; + } + + /* Configure SPI controller for direct access mode */ + control_reg = readl(®->ctrl); + config_reg = readl(®->cfg); + writel(0x00000214, ®->cfg); /* 27MHz clock */ + writel(0x00000000, ®->dw_cfg); /* don't de-asset CS */ + writel(KWSPI_CSN_ACT, ®->ctrl); /* activate CS */ + + /* Copy data to the SPI direct mapped window */ + memcpy(dst, buf, len); + + /* Restore original register values */ + writel(control_reg, ®->ctrl); + writel(config_reg, ®->cfg); + + return 0; +} + +/* Returns the state of CONF_DONE Pin */ +static int fpga_done_fn(int cookie) +{ + int gpio_done = COOKIE2DONE(cookie); + unsigned long ts; + + debug("%s (%d): cookie=%08x gpio_done=%d\n", + __func__, __LINE__, cookie, gpio_done); + + ts = get_timer(0); + do { + if (gpio_get_value(gpio_done)) + return 0; + } while (get_timer(ts) < 1000); + + /* timeout so return error */ + return -ENODEV; +} + +static altera_board_specific_func stratixv_fns = { + .pre = fpga_pre_fn, + .config = fpga_config_fn, + .write = fpga_write_fn, + .done = fpga_done_fn, +}; + +static Altera_desc altera_fpga[] = { + { + /* Family */ + Altera_StratixV, + /* Interface type */ + passive_serial, + /* No limitation as additional data will be ignored */ + -1, + /* Device function table */ + (void *)&stratixv_fns, + /* Base interface address specified in driver */ + NULL, + /* Cookie implementation */ + /* + * In this 32bit word the following information is coded: + * Bit 31 ... Bit 0 + * SPI-Bus | SPI-Dev | Config-Pin | Done-Pin + */ + FPGA_COOKIE(0, 1, 26, 7) + }, + { + /* Family */ + Altera_StratixV, + /* Interface type */ + passive_serial, + /* No limitation as additional data will be ignored */ + -1, + /* Device function table */ + (void *)&stratixv_fns, + /* Base interface address specified in driver */ + NULL, + /* Cookie implementation */ + /* + * In this 32bit word the following information is coded: + * Bit 31 ... Bit 0 + * SPI-Bus | SPI-Dev | Config-Pin | Done-Pin + */ + FPGA_COOKIE(1, 2, 29, 9) + }, +}; + +/* Add device descriptor to FPGA device table */ +void board_fpga_add(void) +{ + int i; + + fpga_init(); + for (i = 0; i < ARRAY_SIZE(altera_fpga); i++) + fpga_add(fpga_altera, &altera_fpga[i]); +} diff --git a/board/theadorable/theadorable.c b/board/theadorable/theadorable.c index 0e23265..ee88a98 100644 --- a/board/theadorable/theadorable.c +++ b/board/theadorable/theadorable.c @@ -8,9 +8,11 @@ #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> +#include <linux/mbus.h> #ifdef CONFIG_NET #include <netdev.h> #endif +#include "theadorable.h"
#include "../drivers/ddr/marvell/axp/ddr3_hw_training.h" #include "../arch/arm/mach-mvebu/serdes/axp/high_speed_env_spec.h" @@ -136,6 +138,15 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100;
+ /* + * Map SPI devices via MBUS so that they can be accessed via + * the SPI direct access mode + */ + mbus_dt_setup_win(&mbus_state, SPI_BUS0_DEV1_BASE, SPI_BUS0_DEV1_SIZE, + CPU_TARGET_DEVICEBUS_BOOTROM_SPI, CPU_ATTR_SPI0_CS1); + mbus_dt_setup_win(&mbus_state, SPI_BUS1_DEV2_BASE, SPI_BUS0_DEV1_SIZE, + CPU_TARGET_DEVICEBUS_BOOTROM_SPI, CPU_ATTR_SPI1_CS2); + return 0; }
@@ -143,6 +154,8 @@ int checkboard(void) { puts("Board: theadorable\n");
v2:
Thanks, Stefan
Thanks, Stefan
Stefan Roese
