[PATCH 0/3] cadence_qspi driver updates
In this patch series - Change driver to use plat data structure only in of_to_plat() and probe(). In probe, copy plat structure members to priv structure. Replace plat with priv across the driver. - Fix function name issue in flash reset - Add a call to read_setup in cadence_spi_read_id() before STIG read.
Ashok Reddy Soma (3): spi: cadence-qspi: Correct flash reset function name spi: cadence_qspi: Call read_setup for STIG_READ spi: cadence-qspi: Use priv instead of plat across the driver
drivers/spi/cadence_ospi_versal.c | 56 ++++---- drivers/spi/cadence_qspi.c | 104 ++++++++------ drivers/spi/cadence_qspi.h | 56 +++++--- drivers/spi/cadence_qspi_apb.c | 231 +++++++++++++++--------------- 4 files changed, 242 insertions(+), 205 deletions(-)
In cadence_spi_probe, cadence_qspi_versal_flash_reset() is called to reset the flash device. Looks like there is a mistake in previous series of patches where it is defined as cadence_spi_versal_flash_reset() but called as cadence_qspi_versal_flash_reset. Since there is a weak function defined with the same name this issue was not caught.
Fix the issue by renaming cadence_spi_versal_flash_reset as cadence_qspi_versal_flash_reset().
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com ---
drivers/spi/cadence_ospi_versal.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/spi/cadence_ospi_versal.c b/drivers/spi/cadence_ospi_versal.c index 52bcad053f..c756a854bc 100644 --- a/drivers/spi/cadence_ospi_versal.c +++ b/drivers/spi/cadence_ospi_versal.c @@ -128,7 +128,7 @@ int cadence_qspi_apb_wait_for_dma_cmplt(struct cadence_spi_plat *plat) }
#if defined(CONFIG_DM_GPIO) -int cadence_spi_versal_flash_reset(struct udevice *dev) +int cadence_qspi_versal_flash_reset(struct udevice *dev) { struct gpio_desc gpio; u32 reset_gpio; @@ -169,7 +169,7 @@ int cadence_spi_versal_flash_reset(struct udevice *dev) return 0; } #else -int cadence_spi_versal_flash_reset(struct udevice *dev) +int cadence_qspi_versal_flash_reset(struct udevice *dev) { /* CRP WPROT */ writel(0, WPROT_CRP);
In cadence_spi_read_id we are using STIG mode to read flash id's. Call cadence_qspi_apb_command_read_setup() to setup cmd, addr and data bus width properly before cadence_qspi_apb_command_read().
drivers/spi/cadence_qspi.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index 907f5dadc4..6e50b94e14 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -59,12 +59,17 @@ static int cadence_spi_write_speed(struct udevice *bus, uint hz) static int cadence_spi_read_id(struct cadence_spi_plat *plat, u8 len, u8 *idcode) { + int err; struct spi_mem_op op = SPI_MEM_OP(SPI_MEM_OP_CMD(0x9F, 1), SPI_MEM_OP_NO_ADDR, SPI_MEM_OP_NO_DUMMY, SPI_MEM_OP_DATA_IN(len, idcode, 1));
- return cadence_qspi_apb_command_read(plat, &op); + err = cadence_qspi_apb_command_read_setup(plat, &op); + if (!err) + err = cadence_qspi_apb_command_read(plat, &op); + + return err; }
/* Calibration sequence to determine the read data capture delay register */
As per driver model we should enumerate plat structure only in of_to_plat() and should be used only in probe(). Copy required plat structure info into priv structure in probe() and use priv structure across the driver. So replace plat with priv structure across the driver.
drivers/spi/cadence_ospi_versal.c | 52 +++---- drivers/spi/cadence_qspi.c | 101 +++++++------ drivers/spi/cadence_qspi.h | 56 +++++--- drivers/spi/cadence_qspi_apb.c | 231 +++++++++++++++--------------- 4 files changed, 236 insertions(+), 204 deletions(-)
diff --git a/drivers/spi/cadence_ospi_versal.c b/drivers/spi/cadence_ospi_versal.c index c756a854bc..a25c50bc50 100644 --- a/drivers/spi/cadence_ospi_versal.c +++ b/drivers/spi/cadence_ospi_versal.c @@ -21,7 +21,7 @@ #define CMD_4BYTE_READ 0x13 #define CMD_4BYTE_FAST_READ 0x0C
-int cadence_qspi_apb_dma_read(struct cadence_spi_plat *plat, +int cadence_qspi_apb_dma_read(struct cadence_spi_priv *priv, const struct spi_mem_op *op) { u32 reg, ret, rx_rem, n_rx, bytes_to_dma, data; @@ -34,86 +34,86 @@ int cadence_qspi_apb_dma_read(struct cadence_spi_plat *plat,
if (bytes_to_dma) { cadence_qspi_apb_enable_linear_mode(false); - reg = readl(plat->regbase + CQSPI_REG_CONFIG); + reg = readl(priv->regbase + CQSPI_REG_CONFIG); reg |= CQSPI_REG_CONFIG_ENBL_DMA; - writel(reg, plat->regbase + CQSPI_REG_CONFIG); + writel(reg, priv->regbase + CQSPI_REG_CONFIG);
- writel(bytes_to_dma, plat->regbase + CQSPI_REG_INDIRECTRDBYTES); + writel(bytes_to_dma, priv->regbase + CQSPI_REG_INDIRECTRDBYTES);
writel(CQSPI_DFLT_INDIR_TRIG_ADDR_RANGE, - plat->regbase + CQSPI_REG_INDIR_TRIG_ADDR_RANGE); + priv->regbase + CQSPI_REG_INDIR_TRIG_ADDR_RANGE); writel(CQSPI_DFLT_DMA_PERIPH_CFG, - plat->regbase + CQSPI_REG_DMA_PERIPH_CFG); - writel((unsigned long)rxbuf, plat->regbase + + priv->regbase + CQSPI_REG_DMA_PERIPH_CFG); + writel((unsigned long)rxbuf, priv->regbase + CQSPI_DMA_DST_ADDR_REG); - writel(plat->trigger_address, plat->regbase + + writel(priv->trigger_address, priv->regbase + CQSPI_DMA_SRC_RD_ADDR_REG); - writel(bytes_to_dma, plat->regbase + + writel(bytes_to_dma, priv->regbase + CQSPI_DMA_DST_SIZE_REG); flush_dcache_range((unsigned long)rxbuf, (unsigned long)rxbuf + bytes_to_dma); writel(CQSPI_DFLT_DST_CTRL_REG_VAL, - plat->regbase + CQSPI_DMA_DST_CTRL_REG); + priv->regbase + CQSPI_DMA_DST_CTRL_REG);
/* Start the indirect read transfer */ - writel(CQSPI_REG_INDIRECTRD_START, plat->regbase + + writel(CQSPI_REG_INDIRECTRD_START, priv->regbase + CQSPI_REG_INDIRECTRD); /* Wait for dma to complete transfer */ - ret = cadence_qspi_apb_wait_for_dma_cmplt(plat); + ret = cadence_qspi_apb_wait_for_dma_cmplt(priv); if (ret) return ret;
/* Clear indirect completion status */ - writel(CQSPI_REG_INDIRECTRD_DONE, plat->regbase + + writel(CQSPI_REG_INDIRECTRD_DONE, priv->regbase + CQSPI_REG_INDIRECTRD); rxbuf += bytes_to_dma; }
if (rx_rem) { - reg = readl(plat->regbase + CQSPI_REG_CONFIG); + reg = readl(priv->regbase + CQSPI_REG_CONFIG); reg &= ~CQSPI_REG_CONFIG_ENBL_DMA; - writel(reg, plat->regbase + CQSPI_REG_CONFIG); + writel(reg, priv->regbase + CQSPI_REG_CONFIG);
- reg = readl(plat->regbase + CQSPI_REG_INDIRECTRDSTARTADDR); + reg = readl(priv->regbase + CQSPI_REG_INDIRECTRDSTARTADDR); reg += bytes_to_dma; - writel(reg, plat->regbase + CQSPI_REG_CMDADDRESS); + writel(reg, priv->regbase + CQSPI_REG_CMDADDRESS);
- addr_bytes = readl(plat->regbase + CQSPI_REG_SIZE) & + addr_bytes = readl(priv->regbase + CQSPI_REG_SIZE) & CQSPI_REG_SIZE_ADDRESS_MASK;
opcode = CMD_4BYTE_FAST_READ; dummy_cycles = 8; writel((dummy_cycles << CQSPI_REG_RD_INSTR_DUMMY_LSB) | opcode, - plat->regbase + CQSPI_REG_RD_INSTR); + priv->regbase + CQSPI_REG_RD_INSTR);
reg = opcode << CQSPI_REG_CMDCTRL_OPCODE_LSB; reg |= (0x1 << CQSPI_REG_CMDCTRL_RD_EN_LSB); reg |= (addr_bytes & CQSPI_REG_CMDCTRL_ADD_BYTES_MASK) << CQSPI_REG_CMDCTRL_ADD_BYTES_LSB; reg |= (0x1 << CQSPI_REG_CMDCTRL_ADDR_EN_LSB); - dummy_cycles = (readl(plat->regbase + CQSPI_REG_RD_INSTR) >> + dummy_cycles = (readl(priv->regbase + CQSPI_REG_RD_INSTR) >> CQSPI_REG_RD_INSTR_DUMMY_LSB) & CQSPI_REG_RD_INSTR_DUMMY_MASK; reg |= (dummy_cycles & CQSPI_REG_CMDCTRL_DUMMY_MASK) << CQSPI_REG_CMDCTRL_DUMMY_LSB; reg |= (((rx_rem - 1) & CQSPI_REG_CMDCTRL_RD_BYTES_MASK) << CQSPI_REG_CMDCTRL_RD_BYTES_LSB); - ret = cadence_qspi_apb_exec_flash_cmd(plat->regbase, reg); + ret = cadence_qspi_apb_exec_flash_cmd(priv->regbase, reg); if (ret) return ret;
- data = readl(plat->regbase + CQSPI_REG_CMDREADDATALOWER); + data = readl(priv->regbase + CQSPI_REG_CMDREADDATALOWER); memcpy(rxbuf, &data, rx_rem); }
return 0; }
-int cadence_qspi_apb_wait_for_dma_cmplt(struct cadence_spi_plat *plat) +int cadence_qspi_apb_wait_for_dma_cmplt(struct cadence_spi_priv *priv) { u32 timeout = CQSPI_DMA_TIMEOUT;
- while (!(readl(plat->regbase + CQSPI_DMA_DST_I_STS_REG) & + while (!(readl(priv->regbase + CQSPI_DMA_DST_I_STS_REG) & CQSPI_DMA_DST_I_STS_DONE) && timeout--) udelay(1);
@@ -122,8 +122,8 @@ int cadence_qspi_apb_wait_for_dma_cmplt(struct cadence_spi_plat *plat) return -ETIMEDOUT; }
- writel(readl(plat->regbase + CQSPI_DMA_DST_I_STS_REG), - plat->regbase + CQSPI_DMA_DST_I_STS_REG); + writel(readl(priv->regbase + CQSPI_DMA_DST_I_STS_REG), + priv->regbase + CQSPI_DMA_DST_I_STS_REG); return 0; }
diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index 6e50b94e14..ab0a681c83 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -29,7 +29,7 @@ #define CQSPI_READ 2 #define CQSPI_WRITE 3
-__weak int cadence_qspi_apb_dma_read(struct cadence_spi_plat *plat, +__weak int cadence_qspi_apb_dma_read(struct cadence_spi_priv *priv, const struct spi_mem_op *op) { return 0; @@ -42,32 +42,32 @@ __weak int cadence_qspi_versal_flash_reset(struct udevice *dev)
static int cadence_spi_write_speed(struct udevice *bus, uint hz) { - struct cadence_spi_plat *plat = dev_get_plat(bus); struct cadence_spi_priv *priv = dev_get_priv(bus);
cadence_qspi_apb_config_baudrate_div(priv->regbase, - plat->ref_clk_hz, hz); + priv->ref_clk_hz, hz);
/* Reconfigure delay timing if speed is changed. */ - cadence_qspi_apb_delay(priv->regbase, plat->ref_clk_hz, hz, - plat->tshsl_ns, plat->tsd2d_ns, - plat->tchsh_ns, plat->tslch_ns); + cadence_qspi_apb_delay(priv->regbase, priv->ref_clk_hz, hz, + priv->tshsl_ns, priv->tsd2d_ns, + priv->tchsh_ns, priv->tslch_ns);
return 0; }
-static int cadence_spi_read_id(struct cadence_spi_plat *plat, u8 len, +static int cadence_spi_read_id(struct cadence_spi_priv *priv, u8 len, u8 *idcode) { int err; + struct spi_mem_op op = SPI_MEM_OP(SPI_MEM_OP_CMD(0x9F, 1), SPI_MEM_OP_NO_ADDR, SPI_MEM_OP_NO_DUMMY, SPI_MEM_OP_DATA_IN(len, idcode, 1));
- err = cadence_qspi_apb_command_read_setup(plat, &op); + err = cadence_qspi_apb_command_read_setup(priv, &op); if (!err) - err = cadence_qspi_apb_command_read(plat, &op); + err = cadence_qspi_apb_command_read(priv, &op);
return err; } @@ -76,7 +76,6 @@ static int cadence_spi_read_id(struct cadence_spi_plat *plat, u8 len, static int spi_calibration(struct udevice *bus, uint hz) { struct cadence_spi_priv *priv = dev_get_priv(bus); - struct cadence_spi_plat *plat = dev_get_plat(bus); void *base = priv->regbase; unsigned int idcode = 0, temp = 0; int err = 0, i, range_lo = -1, range_hi = -1; @@ -91,7 +90,7 @@ static int spi_calibration(struct udevice *bus, uint hz) cadence_qspi_apb_controller_enable(base);
/* read the ID which will be our golden value */ - err = cadence_spi_read_id(plat, 3, (u8 *)&idcode); + err = cadence_spi_read_id(priv, 3, (u8 *)&idcode); if (err) { puts("SF: Calibration failed (read)\n"); return err; @@ -110,7 +109,7 @@ static int spi_calibration(struct udevice *bus, uint hz) cadence_qspi_apb_controller_enable(base);
/* issue a RDID to get the ID value */ - err = cadence_spi_read_id(plat, 3, (u8 *)&temp); + err = cadence_spi_read_id(priv, 3, (u8 *)&temp); if (err) { puts("SF: Calibration failed (read)\n"); return err; @@ -152,13 +151,11 @@ static int spi_calibration(struct udevice *bus, uint hz)
static int cadence_spi_set_speed(struct udevice *bus, uint hz) { - struct cadence_spi_plat *plat = dev_get_plat(bus); struct cadence_spi_priv *priv = dev_get_priv(bus); int err;
- if (!hz || hz > plat->max_hz) - hz = plat->max_hz; - + if (!hz || hz > priv->max_hz) + hz = priv->max_hz; /* Disable QSPI */ cadence_qspi_apb_controller_disable(priv->regbase);
@@ -166,10 +163,10 @@ static int cadence_spi_set_speed(struct udevice *bus, uint hz) * If the device tree already provides a read delay value, use that * instead of calibrating. */ - if (plat->read_delay >= 0) { + if (priv->read_delay >= 0) { cadence_spi_write_speed(bus, hz); cadence_qspi_apb_readdata_capture(priv->regbase, 1, - plat->read_delay); + priv->read_delay); } else if (priv->previous_hz != hz || priv->qspi_calibrated_hz != hz || priv->qspi_calibrated_cs != spi_chip_select(bus)) { @@ -200,29 +197,44 @@ static int cadence_spi_probe(struct udevice *bus) struct clk clk; int ret;
- priv->regbase = plat->regbase; - priv->ahbbase = plat->ahbbase; + priv->regbase = plat->regbase; + priv->ahbbase = plat->ahbbase; + priv->is_dma = plat->is_dma; + priv->is_decoded_cs = plat->is_decoded_cs; + priv->fifo_depth = plat->fifo_depth; + priv->fifo_width = plat->fifo_width; + priv->trigger_address = plat->trigger_address; + priv->read_delay = plat->read_delay; + priv->ahbsize = plat->ahbsize; + priv->max_hz = plat->max_hz; + + priv->page_size = plat->page_size; + priv->block_size = plat->block_size; + priv->tshsl_ns = plat->tshsl_ns; + priv->tsd2d_ns = plat->tsd2d_ns; + priv->tchsh_ns = plat->tchsh_ns; + priv->tslch_ns = plat->tslch_ns;
if (CONFIG_IS_ENABLED(ZYNQMP_FIRMWARE)) xilinx_pm_request(PM_REQUEST_NODE, PM_DEV_OSPI, ZYNQMP_PM_CAPABILITY_ACCESS, ZYNQMP_PM_MAX_QOS, ZYNQMP_PM_REQUEST_ACK_NO, NULL);
- if (plat->ref_clk_hz == 0) { + if (priv->ref_clk_hz == 0) { ret = clk_get_by_index(bus, 0, &clk); if (ret) { #ifdef CONFIG_HAS_CQSPI_REF_CLK - plat->ref_clk_hz = CONFIG_CQSPI_REF_CLK; + priv->ref_clk_hz = CONFIG_CQSPI_REF_CLK; #elif defined(CONFIG_ARCH_SOCFPGA) - plat->ref_clk_hz = cm_get_qspi_controller_clk_hz(); + priv->ref_clk_hz = cm_get_qspi_controller_clk_hz(); #else return ret; #endif } else { - plat->ref_clk_hz = clk_get_rate(&clk); + priv->ref_clk_hz = clk_get_rate(&clk); clk_free(&clk); - if (IS_ERR_VALUE(plat->ref_clk_hz)) - return plat->ref_clk_hz; + if (IS_ERR_VALUE(priv->ref_clk_hz)) + return priv->ref_clk_hz; } }
@@ -231,16 +243,16 @@ static int cadence_spi_probe(struct udevice *bus) reset_deassert_bulk(priv->resets);
if (!priv->qspi_is_init) { - cadence_qspi_apb_controller_init(plat); + cadence_qspi_apb_controller_init(priv); priv->qspi_is_init = 1; }
- plat->wr_delay = 50 * DIV_ROUND_UP(NSEC_PER_SEC, plat->ref_clk_hz); + priv->wr_delay = 50 * DIV_ROUND_UP(NSEC_PER_SEC, priv->ref_clk_hz);
if (CONFIG_IS_ENABLED(ARCH_VERSAL)) { /* Versal platform uses spi calibration to set read delay */ - if (plat->read_delay >= 0) - plat->read_delay = -1; + if (priv->read_delay >= 0) + priv->read_delay = -1; /* Reset ospi flash device */ ret = cadence_qspi_versal_flash_reset(bus); if (ret) @@ -263,7 +275,6 @@ static int cadence_spi_remove(struct udevice *dev)
static int cadence_spi_set_mode(struct udevice *bus, uint mode) { - struct cadence_spi_plat *plat = dev_get_plat(bus); struct cadence_spi_priv *priv = dev_get_priv(bus);
/* Disable QSPI */ @@ -273,7 +284,7 @@ static int cadence_spi_set_mode(struct udevice *bus, uint mode) cadence_qspi_apb_set_clk_mode(priv->regbase, mode);
/* Enable Direct Access Controller */ - if (plat->use_dac_mode) + if (priv->use_dac_mode) cadence_qspi_apb_dac_mode_enable(priv->regbase);
/* Enable QSPI */ @@ -286,7 +297,6 @@ static int cadence_spi_mem_exec_op(struct spi_slave *spi, const struct spi_mem_op *op) { struct udevice *bus = spi->dev->parent; - struct cadence_spi_plat *plat = dev_get_plat(bus); struct cadence_spi_priv *priv = dev_get_priv(bus); void *base = priv->regbase; int err = 0; @@ -294,7 +304,7 @@ static int cadence_spi_mem_exec_op(struct spi_slave *spi,
/* Set Chip select */ cadence_qspi_apb_chipselect(base, spi_chip_select(spi->dev), - plat->is_decoded_cs); + priv->is_decoded_cs);
if (op->data.dir == SPI_MEM_DATA_IN && op->data.buf.in) { if (!op->addr.nbytes) @@ -310,28 +320,28 @@ static int cadence_spi_mem_exec_op(struct spi_slave *spi,
switch (mode) { case CQSPI_STIG_READ: - err = cadence_qspi_apb_command_read_setup(plat, op); + err = cadence_qspi_apb_command_read_setup(priv, op); if (!err) - err = cadence_qspi_apb_command_read(plat, op); + err = cadence_qspi_apb_command_read(priv, op); break; case CQSPI_STIG_WRITE: - err = cadence_qspi_apb_command_write_setup(plat, op); + err = cadence_qspi_apb_command_write_setup(priv, op); if (!err) - err = cadence_qspi_apb_command_write(plat, op); + err = cadence_qspi_apb_command_write(priv, op); break; case CQSPI_READ: - err = cadence_qspi_apb_read_setup(plat, op); + err = cadence_qspi_apb_read_setup(priv, op); if (!err) { - if (plat->is_dma) - err = cadence_qspi_apb_dma_read(plat, op); + if (priv->is_dma) + err = cadence_qspi_apb_dma_read(priv, op); else - err = cadence_qspi_apb_read_execute(plat, op); + err = cadence_qspi_apb_read_execute(priv, op); } break; case CQSPI_WRITE: - err = cadence_qspi_apb_write_setup(plat, op); + err = cadence_qspi_apb_write_setup(priv, op); if (!err) - err = cadence_qspi_apb_write_execute(plat, op); + err = cadence_qspi_apb_write_execute(priv, op); break; default: err = -1; @@ -364,6 +374,7 @@ static bool cadence_spi_mem_supports_op(struct spi_slave *slave, static int cadence_spi_of_to_plat(struct udevice *bus) { struct cadence_spi_plat *plat = dev_get_plat(bus); + struct cadence_spi_priv *priv = dev_get_priv(bus); ofnode subnode;
plat->regbase = (void *)devfdt_get_addr_index(bus, 0); @@ -377,7 +388,7 @@ static int cadence_spi_of_to_plat(struct udevice *bus) 0); /* Use DAC mode only when MMIO window is at least 8M wide */ if (plat->ahbsize >= SZ_8M) - plat->use_dac_mode = true; + priv->use_dac_mode = true;
plat->is_dma = dev_read_bool(bus, "cdns,is-dma");
diff --git a/drivers/spi/cadence_qspi.h b/drivers/spi/cadence_qspi.h index c8d16bb0e4..1c59d1a9d9 100644 --- a/drivers/spi/cadence_qspi.h +++ b/drivers/spi/cadence_qspi.h @@ -198,7 +198,6 @@ CQSPI_REG_SDRAMLEVEL_WR_LSB) & CQSPI_REG_SDRAMLEVEL_WR_MASK)
struct cadence_spi_plat { - unsigned int ref_clk_hz; unsigned int max_hz; void *regbase; void *ahbbase; @@ -209,7 +208,6 @@ struct cadence_spi_plat { fdt_addr_t ahbsize; bool use_dac_mode; int read_delay; - u32 wr_delay;
/* Flash parameters */ u32 page_size; @@ -219,17 +217,18 @@ struct cadence_spi_plat { u32 tchsh_ns; u32 tslch_ns;
- /* Transaction protocol parameters. */ - u8 inst_width; - u8 addr_width; - u8 data_width; - bool dtr; bool is_dma; };
struct cadence_spi_priv { + unsigned int ref_clk_hz; + unsigned int max_hz; void *regbase; void *ahbbase; + unsigned int fifo_depth; + unsigned int fifo_width; + unsigned int trigger_address; + fdt_addr_t ahbsize; size_t cmd_len; u8 cmd_buf[32]; size_t data_len; @@ -238,32 +237,53 @@ struct cadence_spi_priv { unsigned int qspi_calibrated_hz; unsigned int qspi_calibrated_cs; unsigned int previous_hz; + u32 wr_delay; + int read_delay;
struct reset_ctl_bulk *resets; + u32 page_size; + u32 block_size; + u32 tshsl_ns; + u32 tsd2d_ns; + u32 tchsh_ns; + u32 tslch_ns; + u8 edge_mode; + u8 dll_mode; + bool extra_dummy; + bool ddr_init; + bool is_decoded_cs; + bool use_dac_mode; + bool is_dma; + + /* Transaction protocol parameters. */ + u8 inst_width; + u8 addr_width; + u8 data_width; + bool dtr; };
/* Functions call declaration */ -void cadence_qspi_apb_controller_init(struct cadence_spi_plat *plat); +void cadence_qspi_apb_controller_init(struct cadence_spi_priv *priv); void cadence_qspi_apb_controller_enable(void *reg_base_addr); void cadence_qspi_apb_controller_disable(void *reg_base_addr); void cadence_qspi_apb_dac_mode_enable(void *reg_base);
-int cadence_qspi_apb_command_read_setup(struct cadence_spi_plat *plat, +int cadence_qspi_apb_command_read_setup(struct cadence_spi_priv *priv, const struct spi_mem_op *op); -int cadence_qspi_apb_command_read(struct cadence_spi_plat *plat, +int cadence_qspi_apb_command_read(struct cadence_spi_priv *priv, const struct spi_mem_op *op); -int cadence_qspi_apb_command_write_setup(struct cadence_spi_plat *plat, +int cadence_qspi_apb_command_write_setup(struct cadence_spi_priv *priv, const struct spi_mem_op *op); -int cadence_qspi_apb_command_write(struct cadence_spi_plat *plat, +int cadence_qspi_apb_command_write(struct cadence_spi_priv *priv, const struct spi_mem_op *op);
-int cadence_qspi_apb_read_setup(struct cadence_spi_plat *plat, +int cadence_qspi_apb_read_setup(struct cadence_spi_priv *priv, const struct spi_mem_op *op); -int cadence_qspi_apb_read_execute(struct cadence_spi_plat *plat, +int cadence_qspi_apb_read_execute(struct cadence_spi_priv *priv, const struct spi_mem_op *op); -int cadence_qspi_apb_write_setup(struct cadence_spi_plat *plat, +int cadence_qspi_apb_write_setup(struct cadence_spi_priv *priv, const struct spi_mem_op *op); -int cadence_qspi_apb_write_execute(struct cadence_spi_plat *plat, +int cadence_qspi_apb_write_execute(struct cadence_spi_priv *priv, const struct spi_mem_op *op);
void cadence_qspi_apb_chipselect(void *reg_base, @@ -279,9 +299,9 @@ void cadence_qspi_apb_enter_xip(void *reg_base, char xip_dummy); void cadence_qspi_apb_readdata_capture(void *reg_base, unsigned int bypass, unsigned int delay); unsigned int cm_get_qspi_controller_clk_hz(void); -int cadence_qspi_apb_dma_read(struct cadence_spi_plat *plat, +int cadence_qspi_apb_dma_read(struct cadence_spi_priv *priv, const struct spi_mem_op *op); -int cadence_qspi_apb_wait_for_dma_cmplt(struct cadence_spi_plat *plat); +int cadence_qspi_apb_wait_for_dma_cmplt(struct cadence_spi_priv *priv); int cadence_qspi_apb_exec_flash_cmd(void *reg_base, unsigned int reg); int cadence_qspi_versal_flash_reset(struct udevice *dev); void cadence_qspi_apb_enable_linear_mode(bool enable); diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index c00755050e..cfae5dcbda 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -83,13 +83,13 @@ static unsigned int cadence_qspi_calc_dummy(const struct spi_mem_op *op, return dummy_clk; }
-static u32 cadence_qspi_calc_rdreg(struct cadence_spi_plat *plat) +static u32 cadence_qspi_calc_rdreg(struct cadence_spi_priv *priv) { u32 rdreg = 0;
- rdreg |= plat->inst_width << CQSPI_REG_RD_INSTR_TYPE_INSTR_LSB; - rdreg |= plat->addr_width << CQSPI_REG_RD_INSTR_TYPE_ADDR_LSB; - rdreg |= plat->data_width << CQSPI_REG_RD_INSTR_TYPE_DATA_LSB; + rdreg |= priv->inst_width << CQSPI_REG_RD_INSTR_TYPE_INSTR_LSB; + rdreg |= priv->addr_width << CQSPI_REG_RD_INSTR_TYPE_ADDR_LSB; + rdreg |= priv->data_width << CQSPI_REG_RD_INSTR_TYPE_DATA_LSB;
return rdreg; } @@ -115,27 +115,27 @@ static int cadence_qspi_buswidth_to_inst_type(u8 buswidth) } }
-static int cadence_qspi_set_protocol(struct cadence_spi_plat *plat, +static int cadence_qspi_set_protocol(struct cadence_spi_priv *priv, const struct spi_mem_op *op) { int ret;
- plat->dtr = op->data.dtr && op->cmd.dtr && op->addr.dtr; + priv->dtr = op->data.dtr && op->cmd.dtr && op->addr.dtr;
ret = cadence_qspi_buswidth_to_inst_type(op->cmd.buswidth); if (ret < 0) return ret; - plat->inst_width = ret; + priv->inst_width = ret;
ret = cadence_qspi_buswidth_to_inst_type(op->addr.buswidth); if (ret < 0) return ret; - plat->addr_width = ret; + priv->addr_width = ret;
ret = cadence_qspi_buswidth_to_inst_type(op->data.buswidth); if (ret < 0) return ret; - plat->data_width = ret; + priv->data_width = ret;
return 0; } @@ -314,31 +314,31 @@ void cadence_qspi_apb_delay(void *reg_base, cadence_qspi_apb_controller_enable(reg_base); }
-void cadence_qspi_apb_controller_init(struct cadence_spi_plat *plat) +void cadence_qspi_apb_controller_init(struct cadence_spi_priv *priv) { unsigned reg;
- cadence_qspi_apb_controller_disable(plat->regbase); + cadence_qspi_apb_controller_disable(priv->regbase);
/* Configure the device size and address bytes */ - reg = readl(plat->regbase + CQSPI_REG_SIZE); + reg = readl(priv->regbase + CQSPI_REG_SIZE); /* Clear the previous value */ reg &= ~(CQSPI_REG_SIZE_PAGE_MASK << CQSPI_REG_SIZE_PAGE_LSB); reg &= ~(CQSPI_REG_SIZE_BLOCK_MASK << CQSPI_REG_SIZE_BLOCK_LSB); - reg |= (plat->page_size << CQSPI_REG_SIZE_PAGE_LSB); - reg |= (plat->block_size << CQSPI_REG_SIZE_BLOCK_LSB); - writel(reg, plat->regbase + CQSPI_REG_SIZE); + reg |= (priv->page_size << CQSPI_REG_SIZE_PAGE_LSB); + reg |= (priv->block_size << CQSPI_REG_SIZE_BLOCK_LSB); + writel(reg, priv->regbase + CQSPI_REG_SIZE);
/* Configure the remap address register, no remap */ - writel(0, plat->regbase + CQSPI_REG_REMAP); + writel(0, priv->regbase + CQSPI_REG_REMAP);
/* Indirect mode configurations */ - writel(plat->fifo_depth / 2, plat->regbase + CQSPI_REG_SRAMPARTITION); + writel(priv->fifo_depth / 2, priv->regbase + CQSPI_REG_SRAMPARTITION);
/* Disable all interrupts */ - writel(0, plat->regbase + CQSPI_REG_IRQMASK); + writel(0, priv->regbase + CQSPI_REG_IRQMASK);
- cadence_qspi_apb_controller_enable(plat->regbase); + cadence_qspi_apb_controller_enable(priv->regbase); }
int cadence_qspi_apb_exec_flash_cmd(void *reg_base, unsigned int reg) @@ -370,7 +370,7 @@ int cadence_qspi_apb_exec_flash_cmd(void *reg_base, unsigned int reg) return 0; }
-static int cadence_qspi_setup_opcode_ext(struct cadence_spi_plat *plat, +static int cadence_qspi_setup_opcode_ext(struct cadence_spi_priv *priv, const struct spi_mem_op *op, unsigned int shift) { @@ -383,15 +383,15 @@ static int cadence_qspi_setup_opcode_ext(struct cadence_spi_plat *plat, /* Opcode extension is the LSB. */ ext = op->cmd.opcode & 0xff;
- reg = readl(plat->regbase + CQSPI_REG_OP_EXT_LOWER); + reg = readl(priv->regbase + CQSPI_REG_OP_EXT_LOWER); reg &= ~(0xff << shift); reg |= ext << shift; - writel(reg, plat->regbase + CQSPI_REG_OP_EXT_LOWER); + writel(reg, priv->regbase + CQSPI_REG_OP_EXT_LOWER);
return 0; }
-static int cadence_qspi_enable_dtr(struct cadence_spi_plat *plat, +static int cadence_qspi_enable_dtr(struct cadence_spi_priv *priv, const struct spi_mem_op *op, unsigned int shift, bool enable) @@ -399,14 +399,14 @@ static int cadence_qspi_enable_dtr(struct cadence_spi_plat *plat, unsigned int reg; int ret;
if (enable) { reg |= CQSPI_REG_CONFIG_DTR_PROTO; reg |= CQSPI_REG_CONFIG_DUAL_OPCODE;
/* Set up command opcode extension. */ - ret = cadence_qspi_setup_opcode_ext(plat, op, shift); + ret = cadence_qspi_setup_opcode_ext(priv, op, shift); if (ret) return ret; } else { @@ -414,37 +414,37 @@ static int cadence_qspi_enable_dtr(struct cadence_spi_plat *plat, reg &= ~CQSPI_REG_CONFIG_DUAL_OPCODE; }
return 0; }
-int cadence_qspi_apb_command_read_setup(struct cadence_spi_plat *plat, +int cadence_qspi_apb_command_read_setup(struct cadence_spi_priv *priv, const struct spi_mem_op *op) { int ret; unsigned int reg;
- ret = cadence_qspi_set_protocol(plat, op); + ret = cadence_qspi_set_protocol(priv, op); if (ret) return ret;
- ret = cadence_qspi_enable_dtr(plat, op, CQSPI_REG_OP_EXT_STIG_LSB, - plat->dtr); + ret = cadence_qspi_enable_dtr(priv, op, CQSPI_REG_OP_EXT_STIG_LSB, + priv->dtr); if (ret) return ret;
- reg = cadence_qspi_calc_rdreg(plat); - writel(reg, plat->regbase + CQSPI_REG_RD_INSTR); + reg = cadence_qspi_calc_rdreg(priv); + writel(reg, priv->regbase + CQSPI_REG_RD_INSTR);
return 0; }
/* For command RDID, RDSR. */ -int cadence_qspi_apb_command_read(struct cadence_spi_plat *plat, +int cadence_qspi_apb_command_read(struct cadence_spi_priv *priv, const struct spi_mem_op *op) { - void *reg_base = plat->regbase; + void *reg_base = priv->regbase; unsigned int reg; unsigned int read_len; int status; @@ -458,7 +458,7 @@ int cadence_qspi_apb_command_read(struct cadence_spi_plat *plat, return -EINVAL; }
- if (plat->dtr) + if (priv->dtr) opcode = op->cmd.opcode >> 8; else opcode = op->cmd.opcode; @@ -466,7 +466,7 @@ int cadence_qspi_apb_command_read(struct cadence_spi_plat *plat, reg = opcode << CQSPI_REG_CMDCTRL_OPCODE_LSB;
/* Set up dummy cycles. */ - dummy_clk = cadence_qspi_calc_dummy(op, plat->dtr); + dummy_clk = cadence_qspi_calc_dummy(op, priv->dtr); if (dummy_clk > CQSPI_DUMMY_CLKS_MAX) return -ENOTSUPP;
@@ -499,29 +499,29 @@ int cadence_qspi_apb_command_read(struct cadence_spi_plat *plat, return 0; }
-int cadence_qspi_apb_command_write_setup(struct cadence_spi_plat *plat, +int cadence_qspi_apb_command_write_setup(struct cadence_spi_priv *priv, const struct spi_mem_op *op) { int ret; unsigned int reg;
return 0; }
/* For commands: WRSR, WREN, WRDI, CHIP_ERASE, BE, etc. */ -int cadence_qspi_apb_command_write(struct cadence_spi_plat *plat, +int cadence_qspi_apb_command_write(struct cadence_spi_priv *priv, const struct spi_mem_op *op) { unsigned int reg = 0; @@ -529,7 +529,7 @@ int cadence_qspi_apb_command_write(struct cadence_spi_plat *plat, unsigned int wr_len; unsigned int txlen = op->data.nbytes; const void *txbuf = op->data.buf.out; - void *reg_base = plat->regbase; + void *reg_base = priv->regbase; u32 addr; u8 opcode;
@@ -547,7 +547,7 @@ int cadence_qspi_apb_command_write(struct cadence_spi_plat *plat, return -EINVAL; }
- if (plat->dtr) + if (priv->dtr) opcode = op->cmd.opcode >> 8; else opcode = op->cmd.opcode; @@ -579,7 +579,7 @@ int cadence_qspi_apb_command_write(struct cadence_spi_plat *plat, }
/* Opcode + Address (3/4 bytes) + dummy bytes (0-4 bytes) */ -int cadence_qspi_apb_read_setup(struct cadence_spi_plat *plat, +int cadence_qspi_apb_read_setup(struct cadence_spi_priv *priv, const struct spi_mem_op *op) { unsigned int reg; @@ -589,33 +589,33 @@ int cadence_qspi_apb_read_setup(struct cadence_spi_plat *plat, int ret; u8 opcode;
- ret = cadence_qspi_enable_dtr(plat, op, CQSPI_REG_OP_EXT_READ_LSB, - plat->dtr); + ret = cadence_qspi_enable_dtr(priv, op, CQSPI_REG_OP_EXT_READ_LSB, + priv->dtr); if (ret) return ret;
/* Setup the indirect trigger address */ - writel(plat->trigger_address, - plat->regbase + CQSPI_REG_INDIRECTTRIGGER); + writel(priv->trigger_address, + priv->regbase + CQSPI_REG_INDIRECTTRIGGER);
/* Configure the opcode */ - if (plat->dtr) + if (priv->dtr) opcode = op->cmd.opcode >> 8; else opcode = op->cmd.opcode;
rd_reg = opcode << CQSPI_REG_RD_INSTR_OPCODE_LSB; - rd_reg |= cadence_qspi_calc_rdreg(plat); + rd_reg |= cadence_qspi_calc_rdreg(priv);
- writel(op->addr.val, plat->regbase + CQSPI_REG_INDIRECTRDSTARTADDR); + writel(op->addr.val, priv->regbase + CQSPI_REG_INDIRECTRDSTARTADDR);
if (dummy_bytes) { /* Convert to clock cycles. */ - dummy_clk = cadence_qspi_calc_dummy(op, plat->dtr); + dummy_clk = cadence_qspi_calc_dummy(op, priv->dtr);
if (dummy_clk > CQSPI_DUMMY_CLKS_MAX) return -ENOTSUPP; @@ -625,30 +625,30 @@ int cadence_qspi_apb_read_setup(struct cadence_spi_plat *plat, << CQSPI_REG_RD_INSTR_DUMMY_LSB; }
- writel(rd_reg, plat->regbase + CQSPI_REG_RD_INSTR); + writel(rd_reg, priv->regbase + CQSPI_REG_RD_INSTR);
/* set device size */ - reg = readl(plat->regbase + CQSPI_REG_SIZE); + reg = readl(priv->regbase + CQSPI_REG_SIZE); reg &= ~CQSPI_REG_SIZE_ADDRESS_MASK; reg |= (op->addr.nbytes - 1); - writel(reg, plat->regbase + CQSPI_REG_SIZE); + writel(reg, priv->regbase + CQSPI_REG_SIZE); return 0; }
-static u32 cadence_qspi_get_rd_sram_level(struct cadence_spi_plat *plat) +static u32 cadence_qspi_get_rd_sram_level(struct cadence_spi_priv *priv) { - u32 reg = readl(plat->regbase + CQSPI_REG_SDRAMLEVEL); + u32 reg = readl(priv->regbase + CQSPI_REG_SDRAMLEVEL); reg >>= CQSPI_REG_SDRAMLEVEL_RD_LSB; return reg & CQSPI_REG_SDRAMLEVEL_RD_MASK; }
-static int cadence_qspi_wait_for_data(struct cadence_spi_plat *plat) +static int cadence_qspi_wait_for_data(struct cadence_spi_priv *priv) { unsigned int timeout = 10000; u32 reg;
while (timeout--) { - reg = cadence_qspi_get_rd_sram_level(plat); + reg = cadence_qspi_get_rd_sram_level(priv); if (reg) return reg; udelay(1); @@ -658,21 +658,21 @@ static int cadence_qspi_wait_for_data(struct cadence_spi_plat *plat) }
static int -cadence_qspi_apb_indirect_read_execute(struct cadence_spi_plat *plat, +cadence_qspi_apb_indirect_read_execute(struct cadence_spi_priv *priv, unsigned int n_rx, u8 *rxbuf) { unsigned int remaining = n_rx; unsigned int bytes_to_read = 0; int ret;
- writel(n_rx, plat->regbase + CQSPI_REG_INDIRECTRDBYTES); + writel(n_rx, priv->regbase + CQSPI_REG_INDIRECTRDBYTES);
/* Start the indirect read transfer */ writel(CQSPI_REG_INDIRECTRD_START, - plat->regbase + CQSPI_REG_INDIRECTRD); + priv->regbase + CQSPI_REG_INDIRECTRD);
while (remaining > 0) { - ret = cadence_qspi_wait_for_data(plat); + ret = cadence_qspi_wait_for_data(priv); if (ret < 0) { printf("Indirect write timed out (%i)\n", ret); goto failrd; @@ -681,7 +681,7 @@ cadence_qspi_apb_indirect_read_execute(struct cadence_spi_plat *plat, bytes_to_read = ret;
while (bytes_to_read != 0) { - bytes_to_read *= plat->fifo_width; + bytes_to_read *= priv->fifo_width; bytes_to_read = bytes_to_read > remaining ? remaining : bytes_to_read; /* @@ -689,18 +689,18 @@ cadence_qspi_apb_indirect_read_execute(struct cadence_spi_plat *plat, * data abort. */ if (((uintptr_t)rxbuf % 4) || (bytes_to_read % 4)) - readsb(plat->ahbbase, rxbuf, bytes_to_read); + readsb(priv->ahbbase, rxbuf, bytes_to_read); else - readsl(plat->ahbbase, rxbuf, + readsl(priv->ahbbase, rxbuf, bytes_to_read >> 2); rxbuf += bytes_to_read; remaining -= bytes_to_read; - bytes_to_read = cadence_qspi_get_rd_sram_level(plat); + bytes_to_read = cadence_qspi_get_rd_sram_level(priv); } }
/* Check indirect done status */ - ret = wait_for_bit_le32(plat->regbase + CQSPI_REG_INDIRECTRD, + ret = wait_for_bit_le32(priv->regbase + CQSPI_REG_INDIRECTRD, CQSPI_REG_INDIRECTRD_DONE, 1, 10, 0); if (ret) { printf("Indirect read completion error (%i)\n", ret); @@ -709,10 +709,10 @@ cadence_qspi_apb_indirect_read_execute(struct cadence_spi_plat *plat,
/* Clear indirect completion status */ writel(CQSPI_REG_INDIRECTRD_DONE, - plat->regbase + CQSPI_REG_INDIRECTRD); + priv->regbase + CQSPI_REG_INDIRECTRD);
/* Check indirect done status */ - ret = wait_for_bit_le32(plat->regbase + CQSPI_REG_INDIRECTRD, + ret = wait_for_bit_le32(priv->regbase + CQSPI_REG_INDIRECTRD, CQSPI_REG_INDIRECTRD_DONE, 0, 10, 0); if (ret) { printf("Indirect read clear completion error (%i)\n", ret); @@ -724,11 +724,11 @@ cadence_qspi_apb_indirect_read_execute(struct cadence_spi_plat *plat, failrd: /* Cancel the indirect read */ writel(CQSPI_REG_INDIRECTRD_CANCEL, - plat->regbase + CQSPI_REG_INDIRECTRD); + priv->regbase + CQSPI_REG_INDIRECTRD); return ret; }
-int cadence_qspi_apb_read_execute(struct cadence_spi_plat *plat, +int cadence_qspi_apb_read_execute(struct cadence_spi_priv *priv, const struct spi_mem_op *op) { u64 from = op->addr.val; @@ -738,57 +738,57 @@ int cadence_qspi_apb_read_execute(struct cadence_spi_plat *plat, if (CONFIG_IS_ENABLED(ARCH_VERSAL)) cadence_qspi_apb_enable_linear_mode(true);
- if (plat->use_dac_mode && (from + len < plat->ahbsize)) { + if (priv->use_dac_mode && (from + len < priv->ahbsize)) { if (len < 256 || - dma_memcpy(buf, plat->ahbbase + from, len) < 0) { - memcpy_fromio(buf, plat->ahbbase + from, len); + dma_memcpy(buf, priv->ahbbase + from, len) < 0) { + memcpy_fromio(buf, priv->ahbbase + from, len); } - if (!cadence_qspi_wait_idle(plat->regbase)) + if (!cadence_qspi_wait_idle(priv->regbase)) return -EIO; return 0; }
- return cadence_qspi_apb_indirect_read_execute(plat, len, buf); + return cadence_qspi_apb_indirect_read_execute(priv, len, buf); }
/* Opcode + Address (3/4 bytes) */ -int cadence_qspi_apb_write_setup(struct cadence_spi_plat *plat, +int cadence_qspi_apb_write_setup(struct cadence_spi_priv *priv, const struct spi_mem_op *op) { unsigned int reg; int ret; u8 opcode;
- ret = cadence_qspi_enable_dtr(plat, op, CQSPI_REG_OP_EXT_WRITE_LSB, - plat->dtr); + ret = cadence_qspi_enable_dtr(priv, op, CQSPI_REG_OP_EXT_WRITE_LSB, + priv->dtr); if (ret) return ret;
reg = opcode << CQSPI_REG_WR_INSTR_OPCODE_LSB; - reg |= plat->data_width << CQSPI_REG_WR_INSTR_TYPE_DATA_LSB; - reg |= plat->addr_width << CQSPI_REG_WR_INSTR_TYPE_ADDR_LSB; - writel(reg, plat->regbase + CQSPI_REG_WR_INSTR); + reg |= priv->data_width << CQSPI_REG_WR_INSTR_TYPE_DATA_LSB; + reg |= priv->addr_width << CQSPI_REG_WR_INSTR_TYPE_ADDR_LSB; + writel(reg, priv->regbase + CQSPI_REG_WR_INSTR);
- writel(op->addr.val, plat->regbase + CQSPI_REG_INDIRECTWRSTARTADDR); + writel(op->addr.val, priv->regbase + CQSPI_REG_INDIRECTWRSTARTADDR);
- if (plat->dtr) { + if (priv->dtr) { /* * Some flashes like the cypress Semper flash expect a 4-byte * dummy address with the Read SR command in DTR mode, but this @@ -797,23 +797,23 @@ int cadence_qspi_apb_write_setup(struct cadence_spi_plat *plat, * controller's side. spi-nor will take care of polling the * status register. */ - reg = readl(plat->regbase + CQSPI_REG_WR_COMPLETION_CTRL); + reg = readl(priv->regbase + CQSPI_REG_WR_COMPLETION_CTRL); reg |= CQSPI_REG_WR_DISABLE_AUTO_POLL; - writel(reg, plat->regbase + CQSPI_REG_WR_COMPLETION_CTRL); + writel(reg, priv->regbase + CQSPI_REG_WR_COMPLETION_CTRL); }
static int -cadence_qspi_apb_indirect_write_execute(struct cadence_spi_plat *plat, +cadence_qspi_apb_indirect_write_execute(struct cadence_spi_priv *priv, unsigned int n_tx, const u8 *txbuf) { - unsigned int page_size = plat->page_size; + unsigned int page_size = priv->page_size; unsigned int remaining = n_tx; const u8 *bb_txbuf = txbuf; void *bounce_buf = NULL; @@ -833,27 +833,27 @@ cadence_qspi_apb_indirect_write_execute(struct cadence_spi_plat *plat, }
/* Configure the indirect read transfer bytes */ - writel(n_tx, plat->regbase + CQSPI_REG_INDIRECTWRBYTES); + writel(n_tx, priv->regbase + CQSPI_REG_INDIRECTWRBYTES);
/* Start the indirect write transfer */ writel(CQSPI_REG_INDIRECTWR_START, - plat->regbase + CQSPI_REG_INDIRECTWR); + priv->regbase + CQSPI_REG_INDIRECTWR);
/* * Some delay is required for the above bit to be internally * synchronized by the QSPI module. */ - ndelay(plat->wr_delay); + ndelay(priv->wr_delay);
while (remaining > 0) { write_bytes = remaining > page_size ? page_size : remaining; - writesl(plat->ahbbase, bb_txbuf, write_bytes >> 2); + writesl(priv->ahbbase, bb_txbuf, write_bytes >> 2); if (write_bytes % 4) - writesb(plat->ahbbase, + writesb(priv->ahbbase, bb_txbuf + rounddown(write_bytes, 4), write_bytes % 4);
- ret = wait_for_bit_le32(plat->regbase + CQSPI_REG_SDRAMLEVEL, + ret = wait_for_bit_le32(priv->regbase + CQSPI_REG_SDRAMLEVEL, CQSPI_REG_SDRAMLEVEL_WR_MASK << CQSPI_REG_SDRAMLEVEL_WR_LSB, 0, 10, 0); if (ret) { @@ -866,7 +866,7 @@ cadence_qspi_apb_indirect_write_execute(struct cadence_spi_plat *plat, }
/* Check indirect done status */ - ret = wait_for_bit_le32(plat->regbase + CQSPI_REG_INDIRECTWR, + ret = wait_for_bit_le32(priv->regbase + CQSPI_REG_INDIRECTWR, CQSPI_REG_INDIRECTWR_DONE, 1, 10, 0); if (ret) { printf("Indirect write completion error (%i)\n", ret); @@ -875,10 +875,10 @@ cadence_qspi_apb_indirect_write_execute(struct cadence_spi_plat *plat,
/* Clear indirect completion status */ writel(CQSPI_REG_INDIRECTWR_DONE, - plat->regbase + CQSPI_REG_INDIRECTWR); + priv->regbase + CQSPI_REG_INDIRECTWR);
/* Check indirect done status */ - ret = wait_for_bit_le32(plat->regbase + CQSPI_REG_INDIRECTWR, + ret = wait_for_bit_le32(priv->regbase + CQSPI_REG_INDIRECTWR, CQSPI_REG_INDIRECTWR_DONE, 0, 10, 0); if (ret) { printf("Indirect write clear completion error (%i)\n", ret); @@ -892,13 +892,13 @@ cadence_qspi_apb_indirect_write_execute(struct cadence_spi_plat *plat, failwr: /* Cancel the indirect write */ writel(CQSPI_REG_INDIRECTWR_CANCEL, - plat->regbase + CQSPI_REG_INDIRECTWR); + priv->regbase + CQSPI_REG_INDIRECTWR); if (bounce_buf) free(bounce_buf); return ret; }
-int cadence_qspi_apb_write_execute(struct cadence_spi_plat *plat, +int cadence_qspi_apb_write_execute(struct cadence_spi_priv *priv, const struct spi_mem_op *op) { u32 to = op->addr.val; @@ -916,14 +916,15 @@ int cadence_qspi_apb_write_execute(struct cadence_spi_plat *plat, * mode. So, we can not use direct mode when in DTR mode for writing * data. */ - if (!plat->dtr && plat->use_dac_mode && (to + len < plat->ahbsize)) { - memcpy_toio(plat->ahbbase + to, buf, len); - if (!cadence_qspi_wait_idle(plat->regbase)) + cadence_qspi_apb_enable_linear_mode(true); + if (!priv->dtr && priv->use_dac_mode && (to + len < priv->ahbsize)) { + memcpy_toio(priv->ahbbase + to, buf, len); + if (!cadence_qspi_wait_idle(priv->regbase)) return -EIO; return 0; }
- return cadence_qspi_apb_indirect_write_execute(plat, len, buf); + return cadence_qspi_apb_indirect_write_execute(priv, len, buf); }
Applied. M
Ashok Reddy Soma
Michal Simek
