[PATCH 1/2] rpi: Update the Raspberry Pi doucmentation URL
The Raspberry Pi Foundation has updated their documentation so update the URL to the latest place to find the HW device revision codes.
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- board/raspberrypi/rpi/rpi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 55afaa54d9..e7bcee3746 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -72,7 +72,7 @@ struct msg_get_clock_rate { #endif
/* - * https://www.raspberrypi.org/documentation/hardware/raspberrypi/revision-code... + * https://www.raspberrypi.com/documentation/computers/raspberry-pi.html#raspbe... */ struct rpi_model { const char *name;
The Raspberry Pi Foundation released the new Zero 2 W which we want to detect, so we can detect the correct device tree file name.
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- board/raspberrypi/rpi/rpi.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index e7bcee3746..ff69607d3c 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -157,6 +157,11 @@ static const struct rpi_model rpi_models_new_scheme[] = { DTB_DIR "bcm2711-rpi-4-b.dtb", true, }, + [0x12] = { + "Zero 2 W", + DTB_DIR "bcm2837-rpi-zero-2.dtb", + false, + }, [0x13] = { "400", DTB_DIR "bcm2711-rpi-400.dtb",
Applied to rpi-next
Thanks!
- [0x12] = {
"Zero 2 W",
false,
- }, [0x13] = { "400", DTB_DIR "bcm2711-rpi-400.dtb",
-- 2.33.1
Applied to rpi-next
Thanks!
struct rpi_model { const char *name; -- 2.33.1
Matthias Brugger
Peter Robinson
