[U-Boot-Users] [PATCH 4/9] NAND update
The following modifications have been made in drivers/nand/nand_bbt.c
Note that the patch-series is broken unless it is seen as one single patch. It is broken up to multiple emails to fit the size limit.
We have set up a git repository were you can pull the complete patch: http://git.tandberg.com/tandberg/u-boot.git
Best regards William
------------------------------------------------- William Juul, Senior Development Engineer Data Respons Norge AS Sandviksveien 26 P.O. Box 489 NO-1323 Høvik, Norway
www.datarespons.no -------------------------------------------------
diff --git a/drivers/nand/nand_bbt.c b/drivers/nand/nand_bbt.c index 19a9bc2..dea9448 100644 --- a/drivers/nand/nand_bbt.c +++ b/drivers/nand/nand_bbt.c @@ -6,7 +6,7 @@ * * Copyright (C) 2004 Thomas Gleixner (tglx@linutronix.de) * - * $Id: nand_bbt.c,v 1.28 2004/11/13 10:19:09 gleixner Exp $ + * $Id: nand_bbt.c,v 1.36 2005/11/07 11:14:30 gleixner Exp $ * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as @@ -48,7 +48,7 @@ * * Following assumptions are made: * - bbts start at a page boundary, if autolocated on a block boundary - * - the space neccecary for a bbt in FLASH does not exceed a block boundary + * - the space necessary for a bbt in FLASH does not exceed a block boundary * */
@@ -63,6 +63,19 @@
#include <asm/errno.h>
+/* XXX U-BOOT XXX */ +#if 0 +#include <linux/slab.h> +#include <linux/types.h> +#include <linux/mtd/mtd.h> +#include <linux/mtd/nand.h> +#include <linux/mtd/nand_ecc.h> +#include <linux/mtd/compatmac.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/vmalloc.h> +#endif + /** * check_pattern - [GENERIC] check if a pattern is in the buffer * @buf: the buffer to search @@ -76,9 +89,9 @@ * pattern area contain 0xff * */ -static int check_pattern (uint8_t *buf, int len, int paglen, struct nand_bbt_descr *td) +static int check_pattern(uint8_t *buf, int len, int paglen, struct nand_bbt_descr *td) { - int i, end; + int i, end = 0; uint8_t *p = buf;
end = paglen + td->offs; @@ -96,9 +109,9 @@ static int check_pattern (uint8_t *buf, int len, int paglen, struct nand_bbt_des return -1; }
- p += td->len; - end += td->len; if (td->options & NAND_BBT_SCANEMPTY) { + p += td->len; + end += td->len; for (i = end; i < len; i++) { if (*p++ != 0xff) return -1; @@ -108,6 +121,29 @@ static int check_pattern (uint8_t *buf, int len, int paglen, struct nand_bbt_des }
/** + * check_short_pattern - [GENERIC] check if a pattern is in the buffer + * @buf: the buffer to search + * @td: search pattern descriptor + * + * Check for a pattern at the given place. Used to search bad block + * tables and good / bad block identifiers. Same as check_pattern, but + * no optional empty check + * +*/ +static int check_short_pattern(uint8_t *buf, struct nand_bbt_descr *td) +{ + int i; + uint8_t *p = buf; + + /* Compare the pattern */ + for (i = 0; i < td->len; i++) { + if (p[td->offs + i] != td->pattern[i]) + return -1; + } + return 0; +} + +/** * read_bbt - [GENERIC] Read the bad block table starting from page * @mtd: MTD device structure * @buf: temporary buffer @@ -120,8 +156,8 @@ static int check_pattern (uint8_t *buf, int len, int paglen, struct nand_bbt_des * Read the bad block table starting from page. * */ -static int read_bbt (struct mtd_info *mtd, uint8_t *buf, int page, int num, - int bits, int offs, int reserved_block_code) +static int read_bbt(struct mtd_info *mtd, uint8_t *buf, int page, int num, + int bits, int offs, int reserved_block_code) { int res, i, j, act = 0; struct nand_chip *this = mtd->priv; @@ -130,17 +166,17 @@ static int read_bbt (struct mtd_info *mtd, uint8_t *buf, int page, int num, uint8_t msk = (uint8_t) ((1 << bits) - 1);
totlen = (num * bits) >> 3; - from = ((loff_t)page) << this->page_shift; + from = ((loff_t) page) << this->page_shift;
while (totlen) { - len = min (totlen, (size_t) (1 << this->bbt_erase_shift)); - res = mtd->read_ecc (mtd, from, len, &retlen, buf, NULL, this->autooob); + len = min(totlen, (size_t) (1 << this->bbt_erase_shift)); + res = mtd->read(mtd, from, len, &retlen, buf); if (res < 0) { if (retlen != len) { - printk (KERN_INFO "nand_bbt: Error reading bad block table\n"); + printk(KERN_INFO "nand_bbt: Error reading bad block table\n"); return res; } - printk (KERN_WARNING "nand_bbt: ECC error while reading bad block table\n"); + printk(KERN_WARNING "nand_bbt: ECC error while reading bad block table\n"); }
/* Analyse data */ @@ -150,22 +186,23 @@ static int read_bbt (struct mtd_info *mtd, uint8_t *buf, int page, int num, uint8_t tmp = (dat >> j) & msk; if (tmp == msk) continue; - if (reserved_block_code && - (tmp == reserved_block_code)) { - printk (KERN_DEBUG "nand_read_bbt: Reserved block at 0x%08x\n", - ((offs << 2) + (act >> 1)) << this->bbt_erase_shift); + if (reserved_block_code && (tmp == reserved_block_code)) { + printk(KERN_DEBUG "nand_read_bbt: Reserved block at 0x%08x\n", + ((offs << 2) + (act >> 1)) << this->bbt_erase_shift); this->bbt[offs + (act >> 3)] |= 0x2 << (act & 0x06); + mtd->ecc_stats.bbtblocks++; continue; } /* Leave it for now, if its matured we can move this * message to MTD_DEBUG_LEVEL0 */ - printk (KERN_DEBUG "nand_read_bbt: Bad block at 0x%08x\n", - ((offs << 2) + (act >> 1)) << this->bbt_erase_shift); + printk(KERN_DEBUG "nand_read_bbt: Bad block at 0x%08x\n", + ((offs << 2) + (act >> 1)) << this->bbt_erase_shift); /* Factory marked bad or worn out ? */ if (tmp == 0) this->bbt[offs + (act >> 3)] |= 0x3 << (act & 0x06); else this->bbt[offs + (act >> 3)] |= 0x1 << (act & 0x06); + mtd->ecc_stats.badblocks++; } } totlen -= len; @@ -185,7 +222,7 @@ static int read_bbt (struct mtd_info *mtd, uint8_t *buf, int page, int num, * Read the bad block table for all chips starting at a given page * We assume that the bbt bits are in consecutive order. */ -static int read_abs_bbt (struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_descr *td, int chip) +static int read_abs_bbt(struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_descr *td, int chip) { struct nand_chip *this = mtd->priv; int res = 0, i; @@ -209,6 +246,42 @@ static int read_abs_bbt (struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_des return 0; }
+/* + * Scan read raw data from flash + */ +static int scan_read_raw(struct mtd_info *mtd, uint8_t *buf, loff_t offs, + size_t len) +{ + struct mtd_oob_ops ops; + + ops.mode = MTD_OOB_RAW; + ops.ooboffs = 0; + ops.ooblen = mtd->oobsize; + ops.oobbuf = buf; + ops.datbuf = buf; + ops.len = len; + + return mtd->read_oob(mtd, offs, &ops); +} + +/* + * Scan write data with oob to flash + */ +static int scan_write_bbt(struct mtd_info *mtd, loff_t offs, size_t len, + uint8_t *buf, uint8_t *oob) +{ + struct mtd_oob_ops ops; + + ops.mode = MTD_OOB_PLACE; + ops.ooboffs = 0; + ops.ooblen = mtd->oobsize; + ops.datbuf = buf; + ops.oobbuf = oob; + ops.len = len; + + return mtd->write_oob(mtd, offs, &ops); +} + /** * read_abs_bbts - [GENERIC] Read the bad block table(s) for all chips starting at a given page * @mtd: MTD device structure @@ -220,28 +293,84 @@ static int read_abs_bbt (struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_des * We assume that the bbt bits are in consecutive order. * */ -static int read_abs_bbts (struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_descr *td, - struct nand_bbt_descr *md) +static int read_abs_bbts(struct mtd_info *mtd, uint8_t *buf, + struct nand_bbt_descr *td, struct nand_bbt_descr *md) { struct nand_chip *this = mtd->priv;
/* Read the primary version, if available */ if (td->options & NAND_BBT_VERSION) { - nand_read_raw (mtd, buf, td->pages[0] << this->page_shift, mtd->oobblock, mtd->oobsize); - td->version[0] = buf[mtd->oobblock + td->veroffs]; - printk (KERN_DEBUG "Bad block table at page %d, version 0x%02X\n", td->pages[0], td->version[0]); + scan_read_raw(mtd, buf, td->pages[0] << this->page_shift, + mtd->writesize); + td->version[0] = buf[mtd->writesize + td->veroffs]; + printk(KERN_DEBUG "Bad block table at page %d, version 0x%02X\n", + td->pages[0], td->version[0]); }
/* Read the mirror version, if available */ if (md && (md->options & NAND_BBT_VERSION)) { - nand_read_raw (mtd, buf, md->pages[0] << this->page_shift, mtd->oobblock, mtd->oobsize); - md->version[0] = buf[mtd->oobblock + md->veroffs]; - printk (KERN_DEBUG "Bad block table at page %d, version 0x%02X\n", md->pages[0], md->version[0]); + scan_read_raw(mtd, buf, md->pages[0] << this->page_shift, + mtd->writesize); + md->version[0] = buf[mtd->writesize + md->veroffs]; + printk(KERN_DEBUG "Bad block table at page %d, version 0x%02X\n", + md->pages[0], md->version[0]); } - return 1; }
+/* + * Scan a given block full + */ +static int scan_block_full(struct mtd_info *mtd, struct nand_bbt_descr *bd, + loff_t offs, uint8_t *buf, size_t readlen, + int scanlen, int len) +{ + int ret, j; + + ret = scan_read_raw(mtd, buf, offs, readlen); + if (ret) + return ret; + + for (j = 0; j < len; j++, buf += scanlen) { + if (check_pattern(buf, scanlen, mtd->writesize, bd)) + return 1; + } + return 0; +} + +/* + * Scan a given block partially + */ +static int scan_block_fast(struct mtd_info *mtd, struct nand_bbt_descr *bd, + loff_t offs, uint8_t *buf, int len) +{ + struct mtd_oob_ops ops; + int j, ret; + + ops.ooblen = mtd->oobsize; + ops.oobbuf = buf; + ops.ooboffs = 0; + ops.datbuf = NULL; + ops.mode = MTD_OOB_PLACE; + + for (j = 0; j < len; j++) { + /* + * Read the full oob until read_oob is fixed to + * handle single byte reads for 16 bit + * buswidth + */ + ret = mtd->read_oob(mtd, offs, &ops); + if (ret) + return ret; + + if (check_short_pattern(buf, bd)) + return 1; + + offs += mtd->writesize; + } + return 0; +} + /** * create_bbt - [GENERIC] Create a bad block table by scanning the device * @mtd: MTD device structure @@ -253,13 +382,16 @@ static int read_abs_bbts (struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_de * Create a bad block table by scanning the device * for the given good/bad block identify pattern */ -static void create_bbt (struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_descr *bd, int chip) +static int create_bbt(struct mtd_info *mtd, uint8_t *buf, + struct nand_bbt_descr *bd, int chip) { struct nand_chip *this = mtd->priv; - int i, j, numblocks, len, scanlen; + int i, numblocks, len, scanlen; int startblock; loff_t from; - size_t readlen, ooblen; + size_t readlen; + + printk(KERN_INFO "Scanning device for bad blocks\n");
if (bd->options & NAND_BBT_SCANALLPAGES) len = 1 << (this->bbt_erase_shift - this->page_shift); @@ -269,21 +401,28 @@ static void create_bbt (struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_desc else len = 1; } - scanlen = mtd->oobblock + mtd->oobsize; - readlen = len * mtd->oobblock; - ooblen = len * mtd->oobsize; + + if (!(bd->options & NAND_BBT_SCANEMPTY)) { + /* We need only read few bytes from the OOB area */ + scanlen = 0; + readlen = bd->len; + } else { + /* Full page content should be read */ + scanlen = mtd->writesize + mtd->oobsize; + readlen = len * mtd->writesize; + }
if (chip == -1) { - /* Note that numblocks is 2 * (real numblocks) here, see i+=2 below as it - * makes shifting and masking less painful */ + /* Note that numblocks is 2 * (real numblocks) here, see i+=2 + * below as it makes shifting and masking less painful */ numblocks = mtd->size >> (this->bbt_erase_shift - 1); startblock = 0; from = 0; } else { if (chip >= this->numchips) { - printk (KERN_WARNING "create_bbt(): chipnr (%d) > available chips (%d)\n", - chip + 1, this->numchips); - return; + printk(KERN_WARNING "create_bbt(): chipnr (%d) > available chips (%d)\n", + chip + 1, this->numchips); + return -EINVAL; } numblocks = this->chipsize >> (this->bbt_erase_shift - 1); startblock = chip * numblocks; @@ -292,16 +431,28 @@ static void create_bbt (struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_desc }
for (i = startblock; i < numblocks;) { - nand_read_raw (mtd, buf, from, readlen, ooblen); - for (j = 0; j < len; j++) { - if (check_pattern (&buf[j * scanlen], scanlen, mtd->oobblock, bd)) { - this->bbt[i >> 3] |= 0x03 << (i & 0x6); - break; - } + int ret; + + if (bd->options & NAND_BBT_SCANALLPAGES) + ret = scan_block_full(mtd, bd, from, buf, readlen, + scanlen, len); + else + ret = scan_block_fast(mtd, bd, from, buf, len); + + if (ret < 0) + return ret; + + if (ret) { + this->bbt[i >> 3] |= 0x03 << (i & 0x6); + printk(KERN_WARNING "Bad eraseblock %d at 0x%08x\n", + i >> 1, (unsigned int)from); + mtd->ecc_stats.badblocks++; } + i += 2; from += (1 << this->bbt_erase_shift); } + return 0; }
/** @@ -316,22 +467,23 @@ static void create_bbt (struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_desc * block. * If the option NAND_BBT_PERCHIP is given, each chip is searched * for a bbt, which contains the bad block information of this chip. - * This is neccecary to provide support for certain DOC devices. + * This is necessary to provide support for certain DOC devices. * * The bbt ident pattern resides in the oob area of the first page * in a block. */ -static int search_bbt (struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_descr *td) +static int search_bbt(struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_descr *td) { struct nand_chip *this = mtd->priv; int i, chips; int bits, startblock, block, dir; - int scanlen = mtd->oobblock + mtd->oobsize; + int scanlen = mtd->writesize + mtd->oobsize; int bbtblocks; + int blocktopage = this->bbt_erase_shift - this->page_shift;
/* Search direction top -> down ? */ if (td->options & NAND_BBT_LASTBLOCK) { - startblock = (mtd->size >> this->bbt_erase_shift) -1; + startblock = (mtd->size >> this->bbt_erase_shift) - 1; dir = -1; } else { startblock = 0; @@ -357,13 +509,16 @@ static int search_bbt (struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_descr td->pages[i] = -1; /* Scan the maximum number of blocks */ for (block = 0; block < td->maxblocks; block++) { + int actblock = startblock + dir * block; + loff_t offs = actblock << this->bbt_erase_shift; + /* Read first page */ - nand_read_raw (mtd, buf, actblock << this->bbt_erase_shift, mtd->oobblock, mtd->oobsize); - if (!check_pattern(buf, scanlen, mtd->oobblock, td)) { - td->pages[i] = actblock << (this->bbt_erase_shift - this->page_shift); + scan_read_raw(mtd, buf, offs, mtd->writesize); + if (!check_pattern(buf, scanlen, mtd->writesize, td)) { + td->pages[i] = actblock << blocktopage; if (td->options & NAND_BBT_VERSION) { - td->version[i] = buf[mtd->oobblock + td->veroffs]; + td->version[i] = buf[mtd->writesize + td->veroffs]; } break; } @@ -373,9 +528,10 @@ static int search_bbt (struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_descr /* Check, if we found a bbt for each requested chip */ for (i = 0; i < chips; i++) { if (td->pages[i] == -1) - printk (KERN_WARNING "Bad block table not found for chip %d\n", i); + printk(KERN_WARNING "Bad block table not found for chip %d\n", i); else - printk (KERN_DEBUG "Bad block table found at page %d, version 0x%02X\n", td->pages[i], td->version[i]); + printk(KERN_DEBUG "Bad block table found at page %d, version 0x%02X\n", td->pages[i], + td->version[i]); } return 0; } @@ -389,21 +545,19 @@ static int search_bbt (struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_descr * * Search and read the bad block table(s) */ -static int search_read_bbts (struct mtd_info *mtd, uint8_t *buf, - struct nand_bbt_descr *td, struct nand_bbt_descr *md) +static int search_read_bbts(struct mtd_info *mtd, uint8_t * buf, struct nand_bbt_descr *td, struct nand_bbt_descr *md) { /* Search the primary table */ - search_bbt (mtd, buf, td); + search_bbt(mtd, buf, td);
/* Search the mirror table */ if (md) - search_bbt (mtd, buf, md); + search_bbt(mtd, buf, md);
/* Force result check */ return 1; }
- /** * write_bbt - [GENERIC] (Re)write the bad block table * @@ -416,25 +570,31 @@ static int search_read_bbts (struct mtd_info *mtd, uint8_t *buf, * (Re)write the bad block table * */ -static int write_bbt (struct mtd_info *mtd, uint8_t *buf, - struct nand_bbt_descr *td, struct nand_bbt_descr *md, int chipsel) +static int write_bbt(struct mtd_info *mtd, uint8_t *buf, + struct nand_bbt_descr *td, struct nand_bbt_descr *md, + int chipsel) { struct nand_chip *this = mtd->priv; - struct nand_oobinfo oobinfo; struct erase_info einfo; int i, j, res, chip = 0; int bits, startblock, dir, page, offs, numblocks, sft, sftmsk; - int nrchips, bbtoffs, pageoffs; + int nrchips, bbtoffs, pageoffs, ooboffs; uint8_t msk[4]; uint8_t rcode = td->reserved_block_code; size_t retlen, len = 0; loff_t to; + struct mtd_oob_ops ops; + + ops.ooblen = mtd->oobsize; + ops.ooboffs = 0; + ops.datbuf = NULL; + ops.mode = MTD_OOB_PLACE;
if (!rcode) rcode = 0xff; /* Write bad block table per chip rather than per device ? */ if (td->options & NAND_BBT_PERCHIP) { - numblocks = (int) (this->chipsize >> this->bbt_erase_shift); + numblocks = (int)(this->chipsize >> this->bbt_erase_shift); /* Full device write or specific chip ? */ if (chipsel == -1) { nrchips = this->numchips; @@ -443,7 +603,7 @@ static int write_bbt (struct mtd_info *mtd, uint8_t *buf, chip = chipsel; } } else { - numblocks = (int) (mtd->size >> this->bbt_erase_shift); + numblocks = (int)(mtd->size >> this->bbt_erase_shift); nrchips = 1; }
@@ -472,27 +632,38 @@ static int write_bbt (struct mtd_info *mtd, uint8_t *buf, for (i = 0; i < td->maxblocks; i++) { int block = startblock + dir * i; /* Check, if the block is bad */ - switch ((this->bbt[block >> 2] >> (2 * (block & 0x03))) & 0x03) { + switch ((this->bbt[block >> 2] >> + (2 * (block & 0x03))) & 0x03) { case 0x01: case 0x03: continue; } - page = block << (this->bbt_erase_shift - this->page_shift); + page = block << + (this->bbt_erase_shift - this->page_shift); /* Check, if the block is used by the mirror table */ if (!md || md->pages[chip] != page) goto write; } - printk (KERN_ERR "No space left to write bad block table\n"); + printk(KERN_ERR "No space left to write bad block table\n"); return -ENOSPC; -write: + write:
/* Set up shift count and masks for the flash table */ bits = td->options & NAND_BBT_NRBITS_MSK; + msk[2] = ~rcode; switch (bits) { - case 1: sft = 3; sftmsk = 0x07; msk[0] = 0x00; msk[1] = 0x01; msk[2] = ~rcode; msk[3] = 0x01; break; - case 2: sft = 2; sftmsk = 0x06; msk[0] = 0x00; msk[1] = 0x01; msk[2] = ~rcode; msk[3] = 0x03; break; - case 4: sft = 1; sftmsk = 0x04; msk[0] = 0x00; msk[1] = 0x0C; msk[2] = ~rcode; msk[3] = 0x0f; break; - case 8: sft = 0; sftmsk = 0x00; msk[0] = 0x00; msk[1] = 0x0F; msk[2] = ~rcode; msk[3] = 0xff; break; + case 1: sft = 3; sftmsk = 0x07; msk[0] = 0x00; msk[1] = 0x01; + msk[3] = 0x01; + break; + case 2: sft = 2; sftmsk = 0x06; msk[0] = 0x00; msk[1] = 0x01; + msk[3] = 0x03; + break; + case 4: sft = 1; sftmsk = 0x04; msk[0] = 0x00; msk[1] = 0x0C; + msk[3] = 0x0f; + break; + case 8: sft = 0; sftmsk = 0x00; msk[0] = 0x00; msk[1] = 0x0F; + msk[3] = 0xff; + break; default: return -EINVAL; }
@@ -500,82 +671,92 @@ write:
to = ((loff_t) page) << this->page_shift;
- memcpy (&oobinfo, this->autooob, sizeof(oobinfo)); - oobinfo.useecc = MTD_NANDECC_PLACEONLY; - /* Must we save the block contents ? */ if (td->options & NAND_BBT_SAVECONTENT) { /* Make it block aligned */ to &= ~((loff_t) ((1 << this->bbt_erase_shift) - 1)); len = 1 << this->bbt_erase_shift; - res = mtd->read_ecc (mtd, to, len, &retlen, buf, &buf[len], &oobinfo); + res = mtd->read(mtd, to, len, &retlen, buf); if (res < 0) { if (retlen != len) { - printk (KERN_INFO "nand_bbt: Error reading block for writing the bad block table\n"); + printk(KERN_INFO "nand_bbt: Error " + "reading block for writing " + "the bad block table\n"); return res; } - printk (KERN_WARNING "nand_bbt: ECC error while reading block for writing bad block table\n"); + printk(KERN_WARNING "nand_bbt: ECC error " + "while reading block for writing " + "bad block table\n"); } + /* Read oob data */ + ops.ooblen = (len >> this->page_shift) * mtd->oobsize; + ops.oobbuf = &buf[len]; + res = mtd->read_oob(mtd, to + mtd->writesize, &ops); + if (res < 0 || ops.oobretlen != ops.ooblen) + goto outerr; + /* Calc the byte offset in the buffer */ pageoffs = page - (int)(to >> this->page_shift); offs = pageoffs << this->page_shift; /* Preset the bbt area with 0xff */ - memset (&buf[offs], 0xff, (size_t)(numblocks >> sft)); - /* Preset the bbt's oob area with 0xff */ - memset (&buf[len + pageoffs * mtd->oobsize], 0xff, - ((len >> this->page_shift) - pageoffs) * mtd->oobsize); - if (td->options & NAND_BBT_VERSION) { - buf[len + (pageoffs * mtd->oobsize) + td->veroffs] = td->version[chip]; - } + memset(&buf[offs], 0xff, (size_t) (numblocks >> sft)); + ooboffs = len + (pageoffs * mtd->oobsize); + } else { /* Calc length */ len = (size_t) (numblocks >> sft); /* Make it page aligned ! */ - len = (len + (mtd->oobblock-1)) & ~(mtd->oobblock-1); + len = (len + (mtd->writesize - 1)) & + ~(mtd->writesize - 1); /* Preset the buffer with 0xff */ - memset (buf, 0xff, len + (len >> this->page_shift) * mtd->oobsize); + memset(buf, 0xff, len + + (len >> this->page_shift)* mtd->oobsize); offs = 0; + ooboffs = len; /* Pattern is located in oob area of first page */ - memcpy (&buf[len + td->offs], td->pattern, td->len); - if (td->options & NAND_BBT_VERSION) { - buf[len + td->veroffs] = td->version[chip]; - } + memcpy(&buf[ooboffs + td->offs], td->pattern, td->len); }
+ if (td->options & NAND_BBT_VERSION) + buf[ooboffs + td->veroffs] = td->version[chip]; + /* walk through the memory table */ - for (i = 0; i < numblocks; ) { + for (i = 0; i < numblocks;) { uint8_t dat; dat = this->bbt[bbtoffs + (i >> 2)]; - for (j = 0; j < 4; j++ , i++) { + for (j = 0; j < 4; j++, i++) { int sftcnt = (i << (3 - sft)) & sftmsk; /* Do not store the reserved bbt blocks ! */ - buf[offs + (i >> sft)] &= ~(msk[dat & 0x03] << sftcnt); + buf[offs + (i >> sft)] &= + ~(msk[dat & 0x03] << sftcnt); dat >>= 2; } }
- memset (&einfo, 0, sizeof (einfo)); + memset(&einfo, 0, sizeof(einfo)); einfo.mtd = mtd; - einfo.addr = (unsigned long) to; + einfo.addr = (unsigned long)to; einfo.len = 1 << this->bbt_erase_shift; - res = nand_erase_nand (mtd, &einfo, 1); - if (res < 0) { - printk (KERN_WARNING "nand_bbt: Error during block erase: %d\n", res); - return res; - } + res = nand_erase_nand(mtd, &einfo, 1); + if (res < 0) + goto outerr;
- res = mtd->write_ecc (mtd, to, len, &retlen, buf, &buf[len], &oobinfo); - if (res < 0) { - printk (KERN_WARNING "nand_bbt: Error while writing bad block table %d\n", res); - return res; - } - printk (KERN_DEBUG "Bad block table written to 0x%08x, version 0x%02X\n", - (unsigned int) to, td->version[chip]); + res = scan_write_bbt(mtd, to, len, buf, &buf[len]); + if (res < 0) + goto outerr; + + printk(KERN_DEBUG "Bad block table written to 0x%08x, version " + "0x%02X\n", (unsigned int)to, td->version[chip]);
/* Mark it as used */ td->pages[chip] = page; } return 0; + + outerr: + printk(KERN_WARNING + "nand_bbt: Error while writing bad block table %d\n", res); + return res; }
/** @@ -586,29 +767,27 @@ write: * The function creates a memory based bbt by scanning the device * for manufacturer / software marked good / bad blocks */ -static int nand_memory_bbt (struct mtd_info *mtd, struct nand_bbt_descr *bd) +static inline int nand_memory_bbt(struct mtd_info *mtd, struct nand_bbt_descr *bd) { struct nand_chip *this = mtd->priv;
- /* Ensure that we only scan for the pattern and nothing else */ - bd->options = 0; - create_bbt (mtd, this->data_buf, bd, -1); - return 0; + bd->options &= ~NAND_BBT_SCANEMPTY; + return create_bbt(mtd, this->buffers->databuf, bd, -1); }
/** - * check_create - [GENERIC] create and write bbt(s) if neccecary + * check_create - [GENERIC] create and write bbt(s) if necessary * @mtd: MTD device structure * @buf: temporary buffer * @bd: descriptor for the good/bad block search pattern * * The function checks the results of the previous call to read_bbt - * and creates / updates the bbt(s) if neccecary - * Creation is neccecary if no bbt was found for the chip/device - * Update is neccecary if one of the tables is missing or the + * and creates / updates the bbt(s) if necessary + * Creation is necessary if no bbt was found for the chip/device + * Update is necessary if one of the tables is missing or the * version nr. of one table is less than the other */ -static int check_create (struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_descr *bd) +static int check_create(struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_descr *bd) { int i, chips, writeops, chipsel, res; struct nand_chip *this = mtd->priv; @@ -676,35 +855,35 @@ static int check_create (struct mtd_info *mtd, uint8_t *buf, struct nand_bbt_des rd = td; goto writecheck; } -create: + create: /* Create the bad block table by scanning the device ? */ if (!(td->options & NAND_BBT_CREATE)) continue;
/* Create the table in memory by scanning the chip(s) */ - create_bbt (mtd, buf, bd, chipsel); + create_bbt(mtd, buf, bd, chipsel);
td->version[i] = 1; if (md) md->version[i] = 1; -writecheck: + writecheck: /* read back first ? */ if (rd) - read_abs_bbt (mtd, buf, rd, chipsel); + read_abs_bbt(mtd, buf, rd, chipsel); /* If they weren't versioned, read both. */ if (rd2) - read_abs_bbt (mtd, buf, rd2, chipsel); + read_abs_bbt(mtd, buf, rd2, chipsel);
/* Write the bad block table to the device ? */ if ((writeops & 0x01) && (td->options & NAND_BBT_WRITE)) { - res = write_bbt (mtd, buf, td, md, chipsel); + res = write_bbt(mtd, buf, td, md, chipsel); if (res < 0) return res; }
/* Write the mirror bad block table to the device ? */ if ((writeops & 0x02) && md && (md->options & NAND_BBT_WRITE)) { - res = write_bbt (mtd, buf, md, td, chipsel); + res = write_bbt(mtd, buf, md, td, chipsel); if (res < 0) return res; } @@ -721,7 +900,7 @@ writecheck: * accidental erasures / writes. The regions are identified by * the mark 0x02. */ -static void mark_bbt_region (struct mtd_info *mtd, struct nand_bbt_descr *td) +static void mark_bbt_region(struct mtd_info *mtd, struct nand_bbt_descr *td) { struct nand_chip *this = mtd->priv; int i, j, chips, block, nrblocks, update; @@ -739,7 +918,8 @@ static void mark_bbt_region (struct mtd_info *mtd, struct nand_bbt_descr *td) for (i = 0; i < chips; i++) { if ((td->options & NAND_BBT_ABSPAGE) || !(td->options & NAND_BBT_WRITE)) { - if (td->pages[i] == -1) continue; + if (td->pages[i] == -1) + continue; block = td->pages[i] >> (this->bbt_erase_shift - this->page_shift); block <<= 1; oldval = this->bbt[(block >> 3)]; @@ -759,7 +939,8 @@ static void mark_bbt_region (struct mtd_info *mtd, struct nand_bbt_descr *td) oldval = this->bbt[(block >> 3)]; newval = oldval | (0x2 << (block & 0x06)); this->bbt[(block >> 3)] = newval; - if (oldval != newval) update = 1; + if (oldval != newval) + update = 1; block += 2; } /* If we want reserved blocks to be recorded to flash, and some @@ -784,7 +965,7 @@ static void mark_bbt_region (struct mtd_info *mtd, struct nand_bbt_descr *td) * by calling the nand_free_bbt function. * */ -int nand_scan_bbt (struct mtd_info *mtd, struct nand_bbt_descr *bd) +int nand_scan_bbt(struct mtd_info *mtd, struct nand_bbt_descr *bd) { struct nand_chip *this = mtd->priv; int len, res = 0; @@ -793,53 +974,56 @@ int nand_scan_bbt (struct mtd_info *mtd, struct nand_bbt_descr *bd) struct nand_bbt_descr *md = this->bbt_md;
len = mtd->size >> (this->bbt_erase_shift + 2); - /* Allocate memory (2bit per block) */ - this->bbt = kmalloc (len, GFP_KERNEL); + /* Allocate memory (2bit per block) and clear the memory bad block table */ + this->bbt = kzalloc(len, GFP_KERNEL); if (!this->bbt) { - printk (KERN_ERR "nand_scan_bbt: Out of memory\n"); + printk(KERN_ERR "nand_scan_bbt: Out of memory\n"); return -ENOMEM; } - /* Clear the memory bad block table */ - memset (this->bbt, 0x00, len);
/* If no primary table decriptor is given, scan the device * to build a memory based bad block table */ - if (!td) - return nand_memory_bbt(mtd, bd); + if (!td) { + if ((res = nand_memory_bbt(mtd, bd))) { + printk(KERN_ERR "nand_bbt: Can't scan flash and build the RAM-based BBT\n"); + kfree(this->bbt); + this->bbt = NULL; + } + return res; + }
/* Allocate a temporary buffer for one eraseblock incl. oob */ len = (1 << this->bbt_erase_shift); len += (len >> this->page_shift) * mtd->oobsize; - buf = kmalloc (len, GFP_KERNEL); + buf = vmalloc(len); if (!buf) { - printk (KERN_ERR "nand_bbt: Out of memory\n"); - kfree (this->bbt); + printk(KERN_ERR "nand_bbt: Out of memory\n"); + kfree(this->bbt); this->bbt = NULL; return -ENOMEM; }
/* Is the bbt at a given page ? */ if (td->options & NAND_BBT_ABSPAGE) { - res = read_abs_bbts (mtd, buf, td, md); + res = read_abs_bbts(mtd, buf, td, md); } else { /* Search the bad block table using a pattern in oob */ - res = search_read_bbts (mtd, buf, td, md); + res = search_read_bbts(mtd, buf, td, md); }
if (res) - res = check_create (mtd, buf, bd); + res = check_create(mtd, buf, bd);
/* Prevent the bbt regions from erasing / writing */ - mark_bbt_region (mtd, td); + mark_bbt_region(mtd, td); if (md) - mark_bbt_region (mtd, md); + mark_bbt_region(mtd, md);
- kfree (buf); + vfree(buf); return res; }
- /** * nand_update_bbt - [NAND Interface] update bad block table(s) * @mtd: MTD device structure @@ -847,7 +1031,7 @@ int nand_scan_bbt (struct mtd_info *mtd, struct nand_bbt_descr *bd) * * The function updates the bad block table(s) */ -int nand_update_bbt (struct mtd_info *mtd, loff_t offs) +int nand_update_bbt(struct mtd_info *mtd, loff_t offs) { struct nand_chip *this = mtd->priv; int len, res = 0, writeops = 0; @@ -863,9 +1047,9 @@ int nand_update_bbt (struct mtd_info *mtd, loff_t offs) /* Allocate a temporary buffer for one eraseblock incl. oob */ len = (1 << this->bbt_erase_shift); len += (len >> this->page_shift) * mtd->oobsize; - buf = kmalloc (len, GFP_KERNEL); + buf = kmalloc(len, GFP_KERNEL); if (!buf) { - printk (KERN_ERR "nand_update_bbt: Out of memory\n"); + printk(KERN_ERR "nand_update_bbt: Out of memory\n"); return -ENOMEM; }
@@ -873,7 +1057,7 @@ int nand_update_bbt (struct mtd_info *mtd, loff_t offs)
/* Do we have a bbt per chip ? */ if (td->options & NAND_BBT_PERCHIP) { - chip = (int) (offs >> this->chip_shift); + chip = (int)(offs >> this->chip_shift); chipsel = chip; } else { chip = 0; @@ -886,29 +1070,26 @@ int nand_update_bbt (struct mtd_info *mtd, loff_t offs)
/* Write the bad block table to the device ? */ if ((writeops & 0x01) && (td->options & NAND_BBT_WRITE)) { - res = write_bbt (mtd, buf, td, md, chipsel); + res = write_bbt(mtd, buf, td, md, chipsel); if (res < 0) goto out; } /* Write the mirror bad block table to the device ? */ if ((writeops & 0x02) && md && (md->options & NAND_BBT_WRITE)) { - res = write_bbt (mtd, buf, md, td, chipsel); + res = write_bbt(mtd, buf, md, td, chipsel); }
-out: - kfree (buf); + out: + kfree(buf); return res; }
/* Define some generic bad / good block scan pattern which are used - * while scanning a device for factory marked good / bad blocks - * - * The memory based patterns just - */ + * while scanning a device for factory marked good / bad blocks. */ static uint8_t scan_ff_pattern[] = { 0xff, 0xff };
static struct nand_bbt_descr smallpage_memorybased = { - .options = 0, + .options = NAND_BBT_SCAN2NDPAGE, .offs = 5, .len = 1, .pattern = scan_ff_pattern @@ -922,14 +1103,14 @@ static struct nand_bbt_descr largepage_memorybased = { };
static struct nand_bbt_descr smallpage_flashbased = { - .options = NAND_BBT_SCANEMPTY | NAND_BBT_SCANALLPAGES, + .options = NAND_BBT_SCAN2NDPAGE, .offs = 5, .len = 1, .pattern = scan_ff_pattern };
static struct nand_bbt_descr largepage_flashbased = { - .options = NAND_BBT_SCANEMPTY | NAND_BBT_SCANALLPAGES, + .options = NAND_BBT_SCAN2NDPAGE, .offs = 0, .len = 2, .pattern = scan_ff_pattern @@ -977,7 +1158,7 @@ static struct nand_bbt_descr bbt_mirror_descr = { * support for the device and calls the nand_scan_bbt function * */ -int nand_default_bbt (struct mtd_info *mtd) +int nand_default_bbt(struct mtd_info *mtd) { struct nand_chip *this = mtd->priv;
@@ -987,7 +1168,7 @@ int nand_default_bbt (struct mtd_info *mtd) * of the good / bad information, so we _must_ store * this information in a good / bad table during * startup - */ + */ if (this->options & NAND_IS_AND) { /* Use the default pattern descriptors */ if (!this->bbt_td) { @@ -995,10 +1176,9 @@ int nand_default_bbt (struct mtd_info *mtd) this->bbt_md = &bbt_mirror_descr; } this->options |= NAND_USE_FLASH_BBT; - return nand_scan_bbt (mtd, &agand_flashbased); + return nand_scan_bbt(mtd, &agand_flashbased); }
- /* Is a flash based bad block table requested ? */ if (this->options & NAND_USE_FLASH_BBT) { /* Use the default pattern descriptors */ @@ -1007,18 +1187,17 @@ int nand_default_bbt (struct mtd_info *mtd) this->bbt_md = &bbt_mirror_descr; } if (!this->badblock_pattern) { - this->badblock_pattern = (mtd->oobblock > 512) ? - &largepage_flashbased : &smallpage_flashbased; + this->badblock_pattern = (mtd->writesize > 512) ? &largepage_flashbased : &smallpage_flashbased; } } else { this->bbt_td = NULL; this->bbt_md = NULL; if (!this->badblock_pattern) { - this->badblock_pattern = (mtd->oobblock > 512) ? - &largepage_memorybased : &smallpage_memorybased; + this->badblock_pattern = (mtd->writesize > 512) ? + &largepage_memorybased : &smallpage_memorybased; } } - return nand_scan_bbt (mtd, this->badblock_pattern); + return nand_scan_bbt(mtd, this->badblock_pattern); }
/** @@ -1027,26 +1206,35 @@ int nand_default_bbt (struct mtd_info *mtd) * @offs: offset in the device * @allowbbt: allow access to bad block table region * - */ -int nand_isbad_bbt (struct mtd_info *mtd, loff_t offs, int allowbbt) +*/ +int nand_isbad_bbt(struct mtd_info *mtd, loff_t offs, int allowbbt) { struct nand_chip *this = mtd->priv; int block; - uint8_t res; + uint8_t res;
/* Get block number * 2 */ - block = (int) (offs >> (this->bbt_erase_shift - 1)); + block = (int)(offs >> (this->bbt_erase_shift - 1)); res = (this->bbt[block >> 3] >> (block & 0x06)) & 0x03;
- DEBUG (MTD_DEBUG_LEVEL2, "nand_isbad_bbt(): bbt info for offs 0x%08x: (block %d) 0x%02x\n", - (unsigned int)offs, res, block >> 1); + DEBUG(MTD_DEBUG_LEVEL2, "nand_isbad_bbt(): bbt info for offs 0x%08x: (block %d) 0x%02x\n", + (unsigned int)offs, block >> 1, res);
switch ((int)res) { - case 0x00: return 0; - case 0x01: return 1; - case 0x02: return allowbbt ? 0 : 1; + case 0x00: + return 0; + case 0x01: + return 1; + case 0x02: + return allowbbt ? 0 : 1; } return 1; }
+/* XXX U-BOOT XXX */ +#if 0 +EXPORT_SYMBOL(nand_scan_bbt); +EXPORT_SYMBOL(nand_default_bbt); +#endif + #endif
William Juul
