[PATCH] Environment: Change reporting "nowhere" as "magic hat" to user
Make string more user-friendly
Signed-off-by: Alicja Michalska alicja.michalska@9elements.com --- doc/arch/sandbox/sandbox.rst | 2 +- doc/board/emulation/qemu-x86.rst | 2 +- doc/board/sophgo/milkv_duo.rst | 2 +- doc/board/starfive/visionfive2.rst | 2 +- doc/develop/uefi/u-boot_on_efi.rst | 2 +- env/nowhere.c | 2 +- test/py/tests/test_env.py | 4 ++-- 7 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/doc/arch/sandbox/sandbox.rst b/doc/arch/sandbox/sandbox.rst index a8b0d7f039..d88f05285e 100644 --- a/doc/arch/sandbox/sandbox.rst +++ b/doc/arch/sandbox/sandbox.rst @@ -469,7 +469,7 @@ Here is an example trace:: Address in environment is 02:00:11:22:33:44 Core: 103 devices, 51 uclasses, devicetree: board MMC: - Loading Environment from nowhere... OK + Loading Environment from a magic hat... OK In: serial,cros-ec-keyb,usbkbd Out: serial,vidconsole Err: serial,vidconsole diff --git a/doc/board/emulation/qemu-x86.rst b/doc/board/emulation/qemu-x86.rst index c604e42990..06e9dcd999 100644 --- a/doc/board/emulation/qemu-x86.rst +++ b/doc/board/emulation/qemu-x86.rst @@ -142,7 +142,7 @@ The output will be something like this:: CPU: QEMU Virtual CPU version 2.5+ DRAM: 8 GiB Core: 20 devices, 13 uclasses, devicetree: separate - Loading Environment from nowhere... OK + Loading Environment from a magic hat... OK Model: QEMU x86 (I440FX) Net: e1000: 52:54:00:12:34:56 eth0: e1000#0 diff --git a/doc/board/sophgo/milkv_duo.rst b/doc/board/sophgo/milkv_duo.rst index cb2ed1ad98..243468bf10 100644 --- a/doc/board/sophgo/milkv_duo.rst +++ b/doc/board/sophgo/milkv_duo.rst @@ -53,7 +53,7 @@ Sample boot log from Milk-V Duo board
DRAM: 63.3 MiB Core: 10 devices, 8 uclasses, devicetree: separate - Loading Environment from nowhere... OK + Loading Environment from a magic hat... OK In: serial@4140000 Out: serial@4140000 Err: serial@4140000 diff --git a/doc/board/starfive/visionfive2.rst b/doc/board/starfive/visionfive2.rst index 2c68df3ce4..7a926dc021 100644 --- a/doc/board/starfive/visionfive2.rst +++ b/doc/board/starfive/visionfive2.rst @@ -209,7 +209,7 @@ Sample boot log from StarFive VisionFive2 board DRAM: 8 GiB Core: 107 devices, 18 uclasses, devicetree: separate MMC: mmc@16010000: 0, mmc@16020000: 1 - Loading Environment from nowhere... OK + Loading Environment from a magic hat... OK In: serial@10000000 Out: serial@10000000 Err: serial@10000000 diff --git a/doc/develop/uefi/u-boot_on_efi.rst b/doc/develop/uefi/u-boot_on_efi.rst index 245b4af1fa..dbc2b74c6e 100644 --- a/doc/develop/uefi/u-boot_on_efi.rst +++ b/doc/develop/uefi/u-boot_on_efi.rst @@ -230,7 +230,7 @@ This shows running with serial enabled (see `include/configs/efi-x86_app.h`):: DRAM: 32 MiB 0: efi_media_0 PciRoot(0x0)/Pci(0x3,0x0)/Sata(0x0,0xFFFF,0x0) 1: <partition> PciRoot(0x0)/Pci(0x3,0x0)/Sata(0x0,0xFFFF,0x0)/HD(1,GPT,0FFD5E61-3B0C-4326-8049-BDCDC910AF72,0x800,0xB000) - Loading Environment from nowhere... OK + Loading Environment from a magic hat... OK Model: EFI x86 Application Hit any key to stop autoboot: 0
diff --git a/env/nowhere.c b/env/nowhere.c index 6b9b6e2fe0..63fc4647f6 100644 --- a/env/nowhere.c +++ b/env/nowhere.c @@ -45,5 +45,5 @@ U_BOOT_ENV_LOCATION(nowhere) = { .location = ENVL_NOWHERE, .init = env_nowhere_init, .load = env_nowhere_load, - ENV_NAME("nowhere") + ENV_NAME("a magic hat") }; diff --git a/test/py/tests/test_env.py b/test/py/tests/test_env.py index 4471db7d9c..3cd06c5c90 100644 --- a/test/py/tests/test_env.py +++ b/test/py/tests/test_env.py @@ -527,10 +527,10 @@ def test_env_ext4(state_test_env):
# restore env location: NOWHERE (prio 0 in sandbox) response = c.run_command('env select nowhere') - assert 'Select Environment on nowhere: OK' in response + assert 'Select Environment from a magic hat: OK' in response
response = c.run_command('env load') - assert 'Loading Environment from nowhere... OK' in response + assert 'Loading Environment from a magic hat... OK' in response
response = c.run_command('env info') assert 'env_valid = invalid' in response
On Thu, 28 Nov 2024 at 08:12, Alicja Michalska alicja.michalska@9elements.com wrote:
A little more whimsy in U-Boot would be nice!
BTW it would be helpful mention these environment drivers in doc/usage/environment.rst
I disagree. I can make a guess as to what 'Loading Environment from nowhere' means. To me it suggests that it has not found anywhere additional to load an environment from. It is a bit awkwardly phrased but it can be understood and it at least sticks to reality. As for 'Loading Environment from a magic hat' - I have no idea what that is trying to convey and that lack of meaning is not, IMO, user-friendly.
Andrew
- Loading Environment from a magic hat... OK In: serial,cros-ec-keyb,usbkbd Out: serial,vidconsole Err: serial,vidconsole
- Loading Environment from a magic hat... OK Model: QEMU x86 (I440FX) Net: e1000: 52:54:00:12:34:56 eth0: e1000#0
- Loading Environment from a magic hat... OK In: serial@4140000 Out: serial@4140000 Err: serial@4140000
- Loading Environment from a magic hat... OK In: serial@10000000 Out: serial@10000000 Err: serial@10000000
- Loading Environment from a magic hat... OK Model: EFI x86 Application Hit any key to stop autoboot: 0
- ENV_NAME("a magic hat") };
assert 'Select Environment from a magic hat: OK' in response response = c.run_command('env load')
assert 'Loading Environment from a magic hat... OK' in response response = c.run_command('env info') assert 'env_valid = invalid' in response
On Fri, Nov 29, 2024 at 7:35 AM Andrew Goodbody andrew.goodbody@linaro.org wrote:
I have the same opinion as Andrew.
It is easy to associate "Loading Environment from nowhere... OK" with CONFIG_ENV_IS_NOWHERE=y.
Changing it to 'Loading Environment from a magic hat' will not make things better or clearer, IMHO.
Seconded. Or rather thirded [*].
If anything, the message could be changed to say "from default", "from built-in", "from build-time default" or something along those lines else that conveys the message that the environment comes from something defined at compile time.
Rasmus
[*] I was pleasantly surprised to see that that actually exists: https://en.wiktionary.org/wiki/third#Verb
Yes. As I mentioned on IRC, there's one match for "nowhere in the sources and it's in env/nowhere.c so it's easy to see where that line comes from.
participants (6)
Alicja Michalska
Andrew Goodbody
Fabio Estevam
Rasmus Villemoes
