[PATCH 0/4] xilinx: common: Fix fdt/initrd_high and bootm_* variables
this series is removing fdt/initrd_high variables and tune bootm_size run time setup to match needs from Linux kernel.
Thanks, Michal
Michal Simek (4): xilinx: common: Get rid of fdt_high variable xilinx: common: Get rid of initrd_high variable setup xilinx: common: Check return value from variable setup xilinx: common: Change bootm_size variable setting
board/xilinx/common/board.c | 17 ++++++++++------- include/configs/xilinx_versal.h | 1 - include/configs/xilinx_zynqmp.h | 1 - include/configs/zynq-common.h | 1 - 4 files changed, 10 insertions(+), 10 deletions(-)
There is no need to setup this variable if bootm_low and bootm_size variable are properly setup. If fdt_high variable is missing U-Boot is asking LMB to return free memory which is not used.
include/configs/xilinx_versal.h | 1 - include/configs/xilinx_zynqmp.h | 1 - include/configs/zynq-common.h | 1 - 3 files changed, 3 deletions(-)
diff --git a/include/configs/xilinx_versal.h b/include/configs/xilinx_versal.h index 32cd5b21f7b7..d7255a05dff1 100644 --- a/include/configs/xilinx_versal.h +++ b/include/configs/xilinx_versal.h @@ -79,7 +79,6 @@ #define CONFIG_CLOCKS
#define ENV_MEM_LAYOUT_SETTINGS \ - "fdt_high=10000000\0" \ "fdt_addr_r=0x40000000\0" \ "fdt_size_r=0x400000\0" \ "pxefile_addr_r=0x10000000\0" \ diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 7c24bf632e3f..15ad4198a6be 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -101,7 +101,6 @@ #define CONFIG_CLOCKS
#define ENV_MEM_LAYOUT_SETTINGS \ - "fdt_high=10000000\0" \ "fdt_addr_r=0x40000000\0" \ "fdt_size_r=0x400000\0" \ "pxefile_addr_r=0x10000000\0" \ diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 79c75784f2bf..1607a8d06518 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -196,7 +196,6 @@ /* Default environment */ #ifndef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \ - "fdt_high=0x20000000\0" \ "scriptaddr=0x20000\0" \ "script_size_f=0x40000\0" \ "fdt_addr_r=0x1f00000\0" \
When bootm_low/bootm_size are setup properly there is no need to setup any initrd_high address. Location for initrd is determined through LMB.
board/xilinx/common/board.c | 6 ------ 1 file changed, 6 deletions(-)
diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 0782d08ee3fe..901591ba2a85 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -77,14 +77,8 @@ void *board_fdt_blob_setup(void)
int board_late_init_xilinx(void) { - ulong initrd_hi; - env_set_hex("script_offset_f", CONFIG_BOOT_SCRIPT_OFFSET);
- initrd_hi = gd->start_addr_sp - CONFIG_STACK_SIZE; - initrd_hi = round_down(initrd_hi, SZ_16M); - env_set_addr("initrd_high", (void *)initrd_hi); - env_set_addr("bootm_low", (void *)gd->ram_base); env_set_addr("bootm_size", (void *)gd->ram_size);
env_set..() can failed that's why check return status and report it back to make sure that user is aware that's something went wrong.
Change type to u32 to have defined bit operations (mentioned by Marek) Origin patch sent as https://lists.denx.de/pipermail/u-boot/2020-August/422508.html --- board/xilinx/common/board.c | 11 ++++++++--- 1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 901591ba2a85..581c88ad49a4 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -77,10 +77,15 @@ void *board_fdt_blob_setup(void)
int board_late_init_xilinx(void) { - env_set_hex("script_offset_f", CONFIG_BOOT_SCRIPT_OFFSET); + u32 ret = 0;
- env_set_addr("bootm_low", (void *)gd->ram_base); - env_set_addr("bootm_size", (void *)gd->ram_size); + ret |= env_set_hex("script_offset_f", CONFIG_BOOT_SCRIPT_OFFSET); + + ret |= env_set_addr("bootm_low", (void *)gd->ram_base); + ret |= env_set_addr("bootm_size", (void *)gd->ram_size); + + if (ret) + printf("%s: Saving run time variables FAILED\n", __func__);
return 0; }
Linux kernel for arm32 requires dtb and initrd to be placed in low memory to work properly. This requirement is described in chapter 4b) and 5) in Linux documentation (Documentation/arm/booting.rst).
There is an issue on arm32 with 2GB of memory that bootm_size is bigger than Linux lowmem (for example with VMSPLIT_3G). That's why limit bootm size on these systems not to be above 768MB.
board/xilinx/common/board.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 581c88ad49a4..eab389d049f2 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -78,11 +78,15 @@ void *board_fdt_blob_setup(void) int board_late_init_xilinx(void) { u32 ret = 0; + phys_size_t bootm_size = gd->ram_size; + + if (CONFIG_IS_ENABLED(ARCH_ZYNQ)) + bootm_size = min(bootm_size, (phys_size_t)(SZ_512M + SZ_256M));
ret |= env_set_addr("bootm_low", (void *)gd->ram_base); - ret |= env_set_addr("bootm_size", (void *)gd->ram_size); + ret |= env_set_addr("bootm_size", (void *)bootm_size);
if (ret) printf("%s: Saving run time variables FAILED\n", __func__);
st 12. 8. 2020 v 12:42 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
Thanks, Michal
-- 2.28.0
Applied all. M
Michal Simek
Michal Simek
