[U-Boot] [PATCH 13/26] ARM: implement relocation for ARM11
Change the implementation for ARM11 to relocate the code to an arbitrary address in RAM.
Tested on the qong board.
Signed-off-by: Heiko Schocher hs@denx.de --- - changes since v1: - removed converted but not tested boards - add CONFIG_SYS_ARM_WITHOUT_RELOC
arch/arm/cpu/arm1136/start.S | 201 +++++++++++++++++++++++++++++++++++++++ arch/arm/cpu/arm1136/u-boot.lds | 14 +++- board/davedenx/qong/config.mk | 4 +- board/davedenx/qong/qong.c | 87 +++++++++-------- include/configs/qong.h | 10 ++ 5 files changed, 273 insertions(+), 43 deletions(-)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index 1c58abd..8b63192 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -85,12 +85,15 @@ _end_vect: ************************************************************************* */
+.globl _TEXT_BASE _TEXT_BASE: .word TEXT_BASE
+#if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) .globl _armboot_start _armboot_start: .word _start +#endif
/* * These are defined in the board-specific linker script. @@ -103,6 +106,32 @@ _bss_start: _bss_end: .word _end
+#if !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) +.globl _datarel_start +_datarel_start: + .word __datarel_start + +.globl _datarelrolocal_start +_datarelrolocal_start: + .word __datarelrolocal_start + +.globl _datarellocal_start +_datarellocal_start: + .word __datarellocal_start + +.globl _datarelro_start +_datarelro_start: + .word __datarelro_start + +.globl _got_start +_got_start: + .word __got_start + +.globl _got_end +_got_end: + .word __got_end +#endif + #ifdef CONFIG_USE_IRQ /* IRQ stack memory (calculated at run-time) */ .globl IRQ_STACK_START @@ -115,6 +144,164 @@ FIQ_STACK_START: .word 0x0badc0de #endif
+#if !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) +/* IRQ stack memory (calculated at run-time) + 8 bytes */ +.globl IRQ_STACK_START_IN +IRQ_STACK_START_IN: + .word 0x0badc0de +#endif + +#if !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) +/* + * the actual reset code + */ + +reset: + /* + * set the cpu to SVC32 mode + */ + mrs r0,cpsr + bic r0,r0,#0x1f + orr r0,r0,#0xd3 + msr cpsr,r0 + +#ifdef CONFIG_OMAP2420H4 + /* Copy vectors to mask ROM indirect addr */ + adr r0, _start /* r0 <- current position of code */ + add r0, r0, #4 /* skip reset vector */ + mov r2, #64 /* r2 <- size to copy */ + add r2, r0, r2 /* r2 <- source end address */ + mov r1, #SRAM_OFFSET0 /* build vect addr */ + mov r3, #SRAM_OFFSET1 + add r1, r1, r3 + mov r3, #SRAM_OFFSET2 + add r1, r1, r3 +next: + ldmia r0!, {r3-r10} /* copy from source address [r0] */ + stmia r1!, {r3-r10} /* copy to target address [r1] */ + cmp r0, r2 /* until source end address [r2] */ + bne next /* loop until equal */ + bl cpy_clk_code /* put dpll adjust code behind vectors */ +#endif + /* the mask ROM code should have PLL and others stable */ +#ifndef CONFIG_SKIP_LOWLEVEL_INIT + bl cpu_init_crit +#endif + +/* Set stackpointer in internal RAM to call board_init_f */ +call_board_init_f: + ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) + ldr r0,=0x00000000 + +#ifdef CONFIG_NAND_SPL + bl nand_boot +#else +#ifdef CONFIG_ONENAND_IPL + bl start_oneboot +#else + bl board_init_f +#endif /* CONFIG_ONENAND_IPL */ +#endif /* CONFIG_NAND_SPL */ + +/*------------------------------------------------------------------------------*/ + +/* + * void relocate_code (addr_sp, gd, addr_moni) + * + * This "function" does not return, instead it continues in RAM + * after relocating the monitor code. + * + */ + .globl relocate_code +relocate_code: + mov r4, r0 /* save addr_sp */ + mov r5, r1 /* save addr of gd */ + mov r6, r2 /* save addr of destination */ + mov r7, r2 /* save addr of destination */ + + /* Set up the stack */ +stack_setup: + mov sp, r4 + + adr r0, _start + ldr r2, _TEXT_BASE + ldr r3, _bss_start + sub r2, r3, r2 /* r2 <- size of armboot */ + add r2, r0, r2 /* r2 <- source end address */ + cmp r0, r6 + beq clear_bss + +#ifndef CONFIG_SKIP_RELOCATE_UBOOT +copy_loop: + ldmia r0!, {r9-r10} /* copy from source address [r0] */ + stmia r6!, {r9-r10} /* copy to target address [r1] */ + cmp r0, r2 /* until source end addreee [r2] */ + ble copy_loop + +#ifndef CONFIG_PRELOADER + /* fix got entries */ + ldr r1, _TEXT_BASE + mov r0, r7 /* reloc addr */ + ldr r2, _got_start /* addr in Flash */ + ldr r3, _got_end /* addr in Flash */ + sub r3, r3, r1 + add r3, r3, r0 + sub r2, r2, r1 + add r2, r2, r0 + +fixloop: + ldr r4, [r2] + sub r4, r4, r1 + add r4, r4, r0 + str r4, [r2] + add r2, r2, #4 + cmp r2, r3 + bne fixloop +#endif +#endif /* #ifndef CONFIG_SKIP_RELOCATE_UBOOT */ + +clear_bss: +#ifndef CONFIG_PRELOADER + ldr r0, _bss_start + ldr r1, _bss_end + ldr r3, _TEXT_BASE /* Text base */ + mov r4, r7 /* reloc addr */ + sub r0, r0, r3 + add r0, r0, r4 + sub r1, r1, r3 + add r1, r1, r4 + mov r2, #0x00000000 /* clear */ + +clbss_l:str r2, [r0] /* clear loop... */ + add r0, r0, #4 + cmp r0, r1 + bne clbss_l +#endif /* #ifndef CONFIG_PRELOADER */ + +/* + * We are done. Do not return, instead branch to second part of board + * initialization, now running from RAM. + */ +#ifdef CONFIG_NAND_SPL + ldr pc, _nand_boot + +_nand_boot: .word nand_boot +#else +jump_2_ram: + ldr r0, _TEXT_BASE + ldr r2, _board_init_r + sub r2, r2, r0 + add r2, r2, r7 /* position from board_init_r in RAM */ + /* setup parameters for board_init_r */ + mov r0, r5 /* gd_t */ + mov r1, r7 /* dest_addr */ + /* jump to it ... */ + mov lr, r2 + mov pc, lr + +_board_init_r: .word board_init_r +#endif +#else /* #if !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) */ /* * the actual reset code */ @@ -211,6 +398,8 @@ _start_armboot: .word start_armboot #endif /* CONFIG_ONENAND_IPL */ #endif /* CONFIG_NAND_SPL */
+#endif /* #if !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) */ + /* ************************************************************************* * @@ -295,9 +484,13 @@ cpu_init_crit: sub sp, sp, #S_FRAME_SIZE @ carve out a frame on current user stack stmia sp, {r0 - r12} @ Save user registers (now in svc mode) r0-r12
+#if !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) + ldr r2, IRQ_STACK_START_IN @ set base 2 words into abort stack +#else ldr r2, _armboot_start sub r2, r2, #(CONFIG_SYS_MALLOC_LEN) sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ set base 2 words into abort stack +#endif ldmia r2, {r2 - r3} @ get values for "aborted" pc and cpsr (into parm regs) add r0, sp, #S_FRAME_SIZE @ grab pointer to old stack
@@ -328,9 +521,13 @@ cpu_init_crit: .endm
.macro get_bad_stack +#if !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) + ldr r13, IRQ_STACK_START_IN @ setup our mode stack (enter in banked mode) +#else ldr r13, _armboot_start @ setup our mode stack (enter in banked mode) sub r13, r13, #(CONFIG_SYS_MALLOC_LEN) @ move past malloc pool sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ move to reserved a couple spots for abort stack +#endif
str lr, [r13] @ save caller lr in position 0 of saved stack mrs lr, spsr @ get the spsr @@ -346,9 +543,13 @@ cpu_init_crit: .macro get_bad_stack_swi sub r13, r13, #4 @ space on current stack for scratch reg. str r0, [r13] @ save R0's value. +#if !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) + ldr r0, IRQ_STACK_START_IN @ get data regions start +#else ldr r0, _armboot_start @ get data regions start sub r0, r0, #(CONFIG_SYS_MALLOC_LEN) @ move past malloc pool sub r0, r0, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ move past gbl and a couple spots for abort stack +#endif str lr, [r0] @ save caller lr in position 0 of saved stack mrs r0, spsr @ get the spsr str lr, [r0, #4] @ save spsr in position 1 of saved stack diff --git a/arch/arm/cpu/arm1136/u-boot.lds b/arch/arm/cpu/arm1136/u-boot.lds index e7eefc9..1db4b49 100644 --- a/arch/arm/cpu/arm1136/u-boot.lds +++ b/arch/arm/cpu/arm1136/u-boot.lds @@ -47,11 +47,23 @@ SECTIONS .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) }
. = ALIGN(4); - .data : { *(.data) } + .data : { + *(.data) + __datarel_start = .; + *(.data.rel) + __datarelrolocal_start = .; + *(.data.rel.ro.local) + __datarellocal_start = .; + *(.data.rel.local) + __datarelro_start = .; + *(.data.rel.ro) + }
+ __got_start = .; . = ALIGN(4); .got : { *(.got) }
+ __got_end = .; . = .; __u_boot_cmd_start = .; .u_boot_cmd : { *(.u_boot_cmd) } diff --git a/board/davedenx/qong/config.mk b/board/davedenx/qong/config.mk index d8d0a57..39c1203 100644 --- a/board/davedenx/qong/config.mk +++ b/board/davedenx/qong/config.mk @@ -1 +1,3 @@ -TEXT_BASE = 0x8ff00000 +TEXT_BASE = 0xa0000000 + +# PLATFORM_CPPFLAGS += -DDEBUG diff --git a/board/davedenx/qong/qong.c b/board/davedenx/qong/qong.c index 781333b..e509383 100644 --- a/board/davedenx/qong/qong.c +++ b/board/davedenx/qong/qong.c @@ -33,10 +33,9 @@ DECLARE_GLOBAL_DATA_PTR;
int dram_init (void) { - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = get_ram_size((volatile void *)PHYS_SDRAM_1, - PHYS_SDRAM_1_SIZE); - + /* dram_init must store complete ramsize in gd->ram_size */ + gd->ram_size = get_ram_size((volatile void *)CONFIG_SYS_SDRAM_BASE, + PHYS_SDRAM_1_SIZE); return 0; }
@@ -49,6 +48,49 @@ static void qong_fpga_reset(void) udelay(300); }
+int board_early_init_f (void) +{ +#ifdef CONFIG_QONG_FPGA + /* CS1: FPGA/Network Controller/GPIO */ + /* 16-bit, no DTACK */ + __REG(CSCR_U(1)) = 0x00000A01; + __REG(CSCR_L(1)) = 0x20040501; + __REG(CSCR_A(1)) = 0x04020C00; + + /* setup pins for FPGA */ + mx31_gpio_mux(IOMUX_MODE(0x76, MUX_CTL_GPIO)); + mx31_gpio_mux(IOMUX_MODE(0x7e, MUX_CTL_GPIO)); + mx31_gpio_mux(IOMUX_MODE(0x91, MUX_CTL_OUT_FUNC | MUX_CTL_IN_GPIO)); + mx31_gpio_mux(IOMUX_MODE(0x92, MUX_CTL_GPIO)); + mx31_gpio_mux(IOMUX_MODE(0x93, MUX_CTL_GPIO)); + + /* FPGA reset Pin */ + /* rstn = 0 */ + mx31_gpio_set(QONG_FPGA_RST_PIN, 0); + mx31_gpio_direction(QONG_FPGA_RST_PIN, MX31_GPIO_DIRECTION_OUT); + + /* set interrupt pin as input */ + mx31_gpio_direction(QONG_FPGA_IRQ_PIN, MX31_GPIO_DIRECTION_IN); + +#endif + + /* setup pins for UART1 */ + mx31_gpio_mux(MUX_RXD1__UART1_RXD_MUX); + mx31_gpio_mux(MUX_TXD1__UART1_TXD_MUX); + mx31_gpio_mux(MUX_RTS1__UART1_RTS_B); + mx31_gpio_mux(MUX_CTS1__UART1_CTS_B); + + /* setup pins for SPI (pmic) */ + mx31_gpio_mux(MUX_CSPI2_SS0__CSPI2_SS0_B); + mx31_gpio_mux(MUX_CSPI2_MOSI__CSPI2_MOSI); + mx31_gpio_mux(MUX_CSPI2_MISO__CSPI2_MISO); + mx31_gpio_mux(MUX_CSPI2_SCLK__CSPI2_CLK); + mx31_gpio_mux(MUX_CSPI2_SPI_RDY__CSPI2_DATAREADY_B); + + return 0; + +} + int board_init (void) { /* Chip selects */ @@ -99,43 +141,6 @@ int board_init (void) (0 << 0) /* FCE */ );
-#ifdef CONFIG_QONG_FPGA - /* CS1: FPGA/Network Controller/GPIO */ - /* 16-bit, no DTACK */ - __REG(CSCR_U(1)) = 0x00000A01; - __REG(CSCR_L(1)) = 0x20040501; - __REG(CSCR_A(1)) = 0x04020C00; - - /* setup pins for FPGA */ - mx31_gpio_mux(IOMUX_MODE(0x76, MUX_CTL_GPIO)); - mx31_gpio_mux(IOMUX_MODE(0x7e, MUX_CTL_GPIO)); - mx31_gpio_mux(IOMUX_MODE(0x91, MUX_CTL_OUT_FUNC | MUX_CTL_IN_GPIO)); - mx31_gpio_mux(IOMUX_MODE(0x92, MUX_CTL_GPIO)); - mx31_gpio_mux(IOMUX_MODE(0x93, MUX_CTL_GPIO)); - - /* FPGA reset Pin */ - /* rstn = 0 */ - mx31_gpio_set(QONG_FPGA_RST_PIN, 0); - mx31_gpio_direction(QONG_FPGA_RST_PIN, MX31_GPIO_DIRECTION_OUT); - - /* set interrupt pin as input */ - mx31_gpio_direction(QONG_FPGA_IRQ_PIN, MX31_GPIO_DIRECTION_IN); - -#endif - - /* setup pins for UART1 */ - mx31_gpio_mux(MUX_RXD1__UART1_RXD_MUX); - mx31_gpio_mux(MUX_TXD1__UART1_TXD_MUX); - mx31_gpio_mux(MUX_RTS1__UART1_RTS_B); - mx31_gpio_mux(MUX_CTS1__UART1_CTS_B); - - /* setup pins for SPI (pmic) */ - mx31_gpio_mux(MUX_CSPI2_SS0__CSPI2_SS0_B); - mx31_gpio_mux(MUX_CSPI2_MOSI__CSPI2_MOSI); - mx31_gpio_mux(MUX_CSPI2_MISO__CSPI2_MISO); - mx31_gpio_mux(MUX_CSPI2_SCLK__CSPI2_CLK); - mx31_gpio_mux(MUX_CSPI2_SPI_RDY__CSPI2_DATAREADY_B); - /* board id for linux */ gd->bd->bi_arch_number = MACH_TYPE_QONG; gd->bd->bi_boot_params = (0x80000100); /* adress of boot parameters */ diff --git a/include/configs/qong.h b/include/configs/qong.h index 4735b5e..7a68b7b 100644 --- a/include/configs/qong.h +++ b/include/configs/qong.h @@ -282,4 +282,14 @@ extern int qong_nand_rdy(void *chip); "mtdparts=physmap-flash.0:384k(U-Boot),128k(env1)," \ "128k(env2),2432k(kernel),13m(ramdisk),-(user)"
+/* additions for new relocation code, must added to all boards */ +#undef CONFIG_SYS_ARM_WITHOUT_RELOC /* This board is tested with relocation support */ +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_END IRAM_SIZE +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET) + +#define CONFIG_BOARD_EARLY_INIT_F 1 + #endif /* __CONFIG_H */
Heiko Schocher
