[U-Boot] HP Jornada 720 flashrom
Greetings,
Trying to get my Flashrom working (previously used blob with it). I get this now : c -Map u-boot.map -o u-boot net/libnet.a(net.o)(.text+0x1cc): In function `ArpRequest': /home/kristoffer/work/projects/u-boot.git/net/net.c:250: undefined reference to `eth_send' net/libnet.a(net.o)(.text+0x29c): In function `NetStartAgain': /home/kristoffer/work/projects/u-boot.git/net/net.c:568: undefined reference to `eth_halt' net/libnet.a(net.o)(.text+0x370): In function `NetSendPacket': /home/kristoffer/work/projects/u-boot.git/net/net.c:623: undefined reference to `eth_send' net/libnet.a(net.o)(.text+0x634): In function `NetSendUDPPacket': /home/kristoffer/work/projects/u-boot.git/net/net.c:668: undefined reference to `eth_send' net/libnet.a(net.o)(.text+0x910): In function `NetReceive': /home/kristoffer/work/projects/u-boot.git/net/net.c:1263: undefined reference to `eth_send' net/libnet.a(net.o)(.text+0x98c):/home/kristoffer/work/projects/u-boot.git/net/net.c:1295: undefined reference to `eth_send' net/libnet.a(net.o)(.text+0xf04): In function `NetLoop': /home/kristoffer/work/projects/u-boot.git/net/net.c:342: undefined reference to `eth_halt' net/libnet.a(net.o)(.text+0xf0c):/home/kristoffer/work/projects/u-boot.git/net/net.c:346: undefined reference to `eth_init' net/libnet.a(net.o)(.text+0x101c):/home/kristoffer/work/projects/u-boot.git/net/net.c:370: undefined reference to `eth_halt' net/libnet.a(net.o)(.text+0x10ac):/home/kristoffer/work/projects/u-boot.git/net/net.c:481: undefined reference to `eth_halt' net/libnet.a(net.o)(.text+0x10cc):/home/kristoffer/work/projects/u-boot.git/net/net.c:475: undefined reference to `eth_rx' net/libnet.a(net.o)(.text+0x11a4):/home/kristoffer/work/projects/u-boot.git/net/net.c:535: undefined reference to `eth_halt' make: *** [u-boot] Fel 1
My device shouldnt be using those at all so its no wonder that they are undefined, but the question is how I should get rid of those messages.
Best wishes Kristoffer
Dear Kristoffer Ericson,
In message 20090902233329.a9b77e68.kristoffer.ericson@gmail.com you wrote:
Greetings,
Don't enable network support in your board configuration? I. e. remove all command selections that require Ethenret to work...
Still having trouble finding exactly what is causing it. See below for my include/configs/jornada.h file.
diff --git a/include/configs/jornada.h b/include/configs/jornada.h new file mode 100644 index 0000000..270b54f --- /dev/null +++ b/include/configs/jornada.h @@ -0,0 +1,166 @@ +/* + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * 2004 (c) MontaVista Software, Inc. + * + * Configuation settings for the Intel Assabet board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + * (easy to change) + */ +#define CONFIG_SA1110 1 /* This is an SA1100 CPU */ +#define CONFIG_JORNADA700 1 /* on an HP Jornada 700 */ + +#undef CONFIG_USE_IRQ +/* we will never enable dcache, because we have to setup MMU first */ +#define CONFIG_SYS_NO_DCACHE + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size rsrvd for initial data */ + +/* + * select serial console configuration + */ +#define CONFIG_SA1100_SERIAL +#define CONFIG_SERIAL1 1 /* we use SERIAL 1 on HP Jornada */ +#define CONFIG_SERIAL3 1 /* needed? */ + +/* allow to overwrite serial and ethaddr */ +//#define CONFIG_ENV_OVERWRITE + +#define CONFIG_BAUDRATE 59600 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +//#define CONFIG_CMD_DHCP + + +/* + * BOOTP options + */ +//#define CONFIG_BOOTP_SUBNETMASK +//#define CONFIG_BOOTP_GATEWAY +//#define CONFIG_BOOTP_HOSTNAME +//#define CONFIG_BOOTP_BOOTPATH + +#define CONFIG_BOOTDELAY 10 +#define CONFIG_BOOTARGS "console=ttySA0,115200n8" +#define CONFIG_BOOTCOMMAND "bootp;tftp;bootm" +//#define CONFIG_SYS_AUTOLOAD "n" /* No autoload */ + +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 59600 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "HP Jornada # " /* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ + +#define CONFIG_SYS_MEMTEST_START 0xc0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xc0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR 0xc0000000 /* default load address */ + +#define CONFIG_SYS_HZ 3686400 /* incrementer freq: 3.6864 MHz */ +#define CONFIG_SYS_CPUSPEED 0x0a /* set core clock to 206MHz */ + + /* valid baudrates */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of SDRAM */ +#define PHYS_SDRAM_1 0xc0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x02000000 /* 32 MB */ + +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define PHYS_FLASH_SIZE 0x02000000 /* 32 MB */ +#define PHYS_FLASH_BANK_SIZE 0x01000000 /* 16 MB Banks */ +#define PHYS_FLASH_SECT_SIZE 0x00040000 /* 256 KB sectors (x2) */ + +#define CONFIG_SYS_MONITOR_BASE TEXT_BASE +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 KB for Monitor */ + +#if CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_RAMSTART +#endif + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ + +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 +#define CONFIG_SYS_FLASH_SIZE PHYS_FLASH_SIZE +#define CONFIG_SYS_FLASH_CFI 1 /* flash is CFI conformant */ +#define CONFIG_FLASH_CFI_DRIVER 1 /* use common cfi driver */ +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max # of memory banks */ +#define CONFIG_SYS_FLASH_INCREMENT 0 /* there is only one bank */ +#define CONFIG_SYS_MAX_FLASH_SECT 128 /* max # of sectors on one chip */ +#undef CONFIG_SYS_FLASH_PROTECTION +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } + +#define CONFIG_ENV_IS_IN_FLASH 1 + +#if defined(CONFIG_ENV_IS_IN_FLASH) +#define CONFIG_ENV_IN_OWN_SECTOR 1 +#define CONFIG_ENV_ADDR (PHYS_FLASH_1 + PHYS_FLASH_SECT_SIZE) +#define CONFIG_ENV_SIZE PHYS_FLASH_SECT_SIZE +#define CONFIG_ENV_SECT_SIZE PHYS_FLASH_SECT_SIZE +#endif + +#endif /* __CONFIG_H */
Greetings,
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Substitute "damn" every time you're inclined to write "very"; your editor will delete it and the writing will be just as it should be. - Mark Twain
- Command line configuration.
This will include the default configuration, which has (among other things)
#define CONFIG_CMD_NET #define CONFIG_CMD_NFS
Try adding (after this #include):
#undef CONFIG_CMD_NET #undef CONFIG_CMD_NFS
Kristoffer Ericson
