[U-Boot] [PATCH v2] tools: fix Makefile to clean-up fit_info and fit_check_sign
We should avoid the description in Makefile like this
ifdef CONFIG_FIT_SIGNATURE hostprogs-y += fit_info$(SFX) fit_check_sign$(SFX) endif
Otherwise, fit_info and fit_check_sign would never be cleaned by "make clean".
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Heiko Schocher hs@denx.de ---
This patch is against u-boot/next
Changes in v2: - Add Signed-off-by
tools/Makefile | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/tools/Makefile b/tools/Makefile index c5c378c..c34df4f 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -60,9 +60,7 @@ hostprogs-y += mkenvimage$(SFX) mkenvimage$(SFX)-objs := crc32.o mkenvimage.o os_support.o
hostprogs-y += dumpimage$(SFX) mkimage$(SFX) -ifdef CONFIG_FIT_SIGNATURE -hostprogs-y += fit_info$(SFX) fit_check_sign$(SFX) -endif +hostprogs-$(CONFIG_FIT_SIGNATURE) += fit_info$(SFX) fit_check_sign$(SFX)
FIT_SIG_OBJS-$(CONFIG_FIT_SIGNATURE) := image-sig.o # Flattened device tree objects
Masahiro Yamada
