[U-Boot] [PATCH] mpc85xx, mpc86xx: Fix gd->cpu pointer after relocation
The gd->cpu pointer is set to an address located in flash when the probecpu() function is called while U-Boot is executing from flash. This pointer needs to be updated to point to an address in RAM after relocation has occurred otherwise Linux may not be able to boot due to "fdt board" crashing if flash has been erased or changed.
This bug was introduced in commit a0e2066f392782730f0398095e583c87812d97f2.
Signed-off-by: Peter Tyser ptyser@xes-inc.com Reported-by: Ed Swarthout Ed.Swarthout@freescale.com --- Below is the output of Ed's test after applying this patch: U-Boot 2009.11-rc2-00110-g5b75c04-dirty (Dec 15 2009 - 12:05:00)
cpu_numcores gd=e0003f80 cpu=fffd0a60 n=2 CPU0: 8572E, Version: 1.1, (0x80e80011) Core: E500, Version: 3.0, (0x80210030) cpu_numcores gd=e0003f80 cpu=fffd0a60 n=2 cpu_numcores gd=e0003f80 cpu=fffd0a60 n=2 cpu_numcores gd=e0003f80 cpu=fffd0a60 n=2 Clock Configuration:cpu_numcores gd=e0003f80 cpu=fffd0a60 n=2
CPU0:1333.333 MHz, cpu_numcores gd=e0003f80 cpu=fffd0a60 n=2 CPU1:1333.333 MHz, cpu_numcores gd=e0003f80 cpu=fffd0a60 n=2
CCB:533.333 MHz, DDR:333.333 MHz (666.667 MT/s data rate) (Asynchronous), LBC:66.667 MHz L1: D-cache 32 kB enabled I-cache 32 kB enabled Board: X-ES XPedite5370 3U VPX SBC Rev A, Serial# 12345678, Cfg 12345678-1 I2C: ready DRAM: cpu_numcores gd=e0003f80 cpu=fffd0a60 n=2 cpu_numcores gd=e0003f80 cpu=fffd0a60 n=2 cpu_numcores gd=e0003f80 cpu=fffd0a60 n=2 cpu_numcores gd=e0003f80 cpu=fffd0a60 n=2 cpu_numcores gd=e0003f80 cpu=fffd0a60 n=2 cpu_numcores gd=e0003f80 cpu=fffd0a60 n=2 2 GB (DDR2, 64-bit, CL=5, ECC on) DDR Controller Interleaving Mode: bank FLASH: Executed from FLASH1 FLASH: 256 MB L2: 1024 KB enabled cpu_numcores gd=7fe67f78 cpu=7ffc0a60 n=2 cpu_numcores gd=7fe67f78 cpu=7ffc0a60 n=2 cpu_numcores gd=7fe67f78 cpu=7ffc0a60 n=2 cpu_numcores gd=7fe67f78 cpu=7ffc0a60 n=2 NAND: 1024 MiB ...
=> md 7ffc0a60 7ffc0a60: 38353732 00000000 00000000 00000000 8572............ 7ffc0a70: 0080e800 00000002 50313031 31000000 ........P1011... 7ffc0a80: 00000000 00000000 0080e500 00000001 ................ 7ffc0a90: 50313031 31000000 00000000 00000000 P1011........... 7ffc0aa0: 0080ed00 00000001 50313032 30000000 ........P1020... 7ffc0ab0: 00000000 00000000 0080e400 00000002 ................ 7ffc0ac0: 50313032 30000000 00000000 00000000 P1020........... 7ffc0ad0: 0080ec00 00000002 50323031 30000000 ........P2010... 7ffc0ae0: 00000000 00000000 0080e300 00000001 ................ 7ffc0af0: 50323031 30000000 00000000 00000000 P2010........... 7ffc0b00: 0080eb00 00000001 50323032 30000000 ........P2020... 7ffc0b10: 00000000 00000000 0080e200 00000002 ................ 7ffc0b20: 50323032 30000000 00000000 00000000 P2020........... 7ffc0b30: 0080ea00 00000002 50343034 30000000 ........P4040... 7ffc0b40: 00000000 00000000 00820100 00000004 ................ 7ffc0b50: 50343034 30000000 00000000 00000000 P4040........... =>
lib_ppc/board.c | 8 ++++++++ 1 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/lib_ppc/board.c b/lib_ppc/board.c index 765f97a..dd22f99 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -645,6 +645,14 @@ void board_init_r (gd_t *id, ulong dest_addr) /* The Malloc area is immediately below the monitor copy in DRAM */ malloc_start = dest_addr - TOTAL_MALLOC_LEN;
+#if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) + /* + * The gd->cpu pointer is set to an address in flash before relocation. + * We need to update it to point to the same CPU entry in RAM. + */ + gd->cpu += dest_addr - CONFIG_SYS_MONITOR_BASE; +#endif + #ifdef CONFIG_SERIAL_MULTI serial_initialize(); #endif
Tested-by: Kumar Gala galak@kernel.crashing.org
- k
From: Kumar Gala [mailto:galak@kernel.crashing.org]
Tested on MPC8527DS.
Tested by: Ed Swarthout Ed.Swarthout@freescale.com
Dear Peter Tyser,
Applied, thanks.
Kumar Gala
Peter Tyser
Swarthout Edward L-SWARTHOU
