[PATCH] arm: dts: rk3399-puma: re-add vdd_log for uboot
The rk3399-puma board needs a 950mV vdd_log to work stable. This was already added in commit 77012e79ffc3 ("rockchip: rk3399-puma: Set VDD_LOG to 950 mV") but lost again with commit 167efc2c7a46 ("arm64: dts: rk3399: Sync v5.7-rc1 from Linux")
So to make puma stable again re-add the vdd_log pwm regulator. As it is not part of the mainline Linux dts right now, add it to the -u-boot dtsi for puma.
Fixes: 167efc2c7a46 ("arm64: dts: rk3399: Sync v5.7-rc1 from Linux") Signed-off-by: Heiko Stuebner heiko@sntech.de --- arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi b/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi index 29846c4b00..76eb51d2d7 100644 --- a/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi +++ b/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi @@ -49,6 +49,17 @@ regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; }; + + vdd_log: vdd-log { + compatible = "pwm-regulator"; + pwms = <&pwm2 0 25000 1>; + regulator-name = "vdd_log"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-always-on; + regulator-boot-on; + regulator-init-microvolt = <950000>; + }; };
&gpio1 {
As the history shows here, this keeps getting lost on resync. What's the status on getting this in to the upstream dts itself?
Hi Heiko,
vdd_log: vdd-log {
regulator-boot-on;
&gpio1 {
Is this a spurious patch by any chance?
https://source.denx.de/u-boot/u-boot/-/commit/1621afc84f8a109cfdb98c9e370c35... seems to have more or less the same content, sent (and merged) about a year ago by Christoph.
Moreover, it seems to still be there in master: https://source.denx.de/u-boot/u-boot/-/blob/master/arch/arm/dts/rk3399-puma-...
Cheers, Quentin
Hi Quentin,
Am Montag, 3. Januar 2022, 13:26:09 CET schrieb Quentin Schulz:
Hi Heiko,
vdd_log: vdd-log {
regulator-boot-on;
&gpio1 {
yep, I realized that I was on 2021.01 still. Shortly after that the vdd_log was re-added by Christoph.
Heiko
Cheers, Quentin
Hi Heiko,
Heiko Stuebner heiko@sntech.de 于2021年12月26日周日 20:46写道:
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
vdd_log: vdd-log {
regulator-boot-on;
&gpio1 {
2.30.2
participants (5)
Heiko Stuebner
Heiko Stübner
Kever Yang
Quentin Schulz
