[U-Boot] [PATCH] ARM: socfpga: remove unneeded NAND config options
CONFIG_NAND_DENALI select's CONFIG_SYS_NAND_SELF_INIT, so the NAND initialization process is driven by the driver itself. CONFIG_SYS_NAND_MAX_CHIPS and CONFIG_SYS_NAND_BASE are unused.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
include/configs/socfpga_common.h | 2 -- 1 file changed, 2 deletions(-)
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 175b01ef84a9..4f64c3281e42 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -144,12 +144,10 @@ */ #ifdef CONFIG_NAND_DENALI #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_MAX_CHIPS 1 #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_NAND_DENALI_ECC_SIZE 512 #define CONFIG_SYS_NAND_REGS_BASE SOCFPGA_NANDREGS_ADDRESS #define CONFIG_SYS_NAND_DATA_BASE SOCFPGA_NANDDATA_ADDRESS -#define CONFIG_SYS_NAND_BASE (CONFIG_SYS_NAND_DATA_BASE + 0x10) #endif
Acked-by: Marek Vasut marex@denx.de
Is this for -master or for -next ?
Hi Marek.
2017-09-02 18:23 GMT+09:00 Marek Vasut marex@denx.de:
It is up to you, but no need to rush for this patch. It will just reduce the source file size.
On 09/02/2017 04:18 PM, Masahiro Yamada wrote:
Hi Marek.
Hello Masahiro,
OK, I doubt anyone really uses the Denali NAND on SoCFPGA now anyway.
Applied, thanks.
Masahiro Yamada
