[U-Boot] [PATCH v2 1/3] dm: spi: Add support for all targets which requires MANUAL_RELOC
It is follow up patch based on "dm: Add support for all targets which requires MANUAL_RELOC" (sha1: 484fdf5ba058b07be5ca82763aa2b72063540ef3) to update function pointers for DM.
Signed-off-by: Michal Simek michal.simek@xilinx.com Acked-by: Simon Glass sjg@chromium.org ---
Changes in v2: None
drivers/spi/spi-uclass.c | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index d666272e39ce..27409fb088ea 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -118,6 +118,26 @@ static int spi_post_probe(struct udevice *bus) spi->max_hz = fdtdec_get_int(gd->fdt_blob, bus->of_offset, "spi-max-frequency", 0);
+#if defined(CONFIG_NEEDS_MANUAL_RELOC) + struct dm_spi_ops *ops = spi_get_ops(bus); + + + if (ops->claim_bus) + ops->claim_bus += gd->reloc_off; + if (ops->release_bus) + ops->release_bus += gd->reloc_off; + if (ops->set_wordlen) + ops->set_wordlen += gd->reloc_off; + if (ops->xfer) + ops->xfer += gd->reloc_off; + if (ops->set_speed) + ops->set_speed += gd->reloc_off; + if (ops->set_mode) + ops->set_mode += gd->reloc_off; + if (ops->cs_info) + ops->cs_info += gd->reloc_off; +#endif + return 0; }
Patches: "dm: core: Add a post_bind method for parents" (sha1: 0118ce79577f9b0881f99a6e4f8a79cd5014cb87) "dm: core: Add a uclass pre_probe() method for devices" (sha1: 02c07b3741f1b825934b1a6eb8f23530532dc426) "dm: core: Allow the uclass to set up a device's child after binding" (sha1: 081f2fcbd9a95ba10677065359791f8fea3f8c58) "dm: core: Allow uclass to set up a device's child before it is probed" (sha1: 83c7e434c9dd3ca81f8b763e23c1881b973bcf2f)
Adds new entries to struct driver and struct uclass_driver without extending code for manual relocation. This patch fixes it for all architectures which requires MANUAL_RELOC.
Changes in v2: None
drivers/core/root.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/core/root.c b/drivers/core/root.c index bdb394a9ae21..e7b1f249682e 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -59,6 +59,8 @@ void fix_drivers(void) entry->unbind += gd->reloc_off; if (entry->ofdata_to_platdata) entry->ofdata_to_platdata += gd->reloc_off; + if (entry->child_post_bind) + entry->child_post_bind += gd->reloc_off; if (entry->child_pre_probe) entry->child_pre_probe += gd->reloc_off; if (entry->child_post_remove) @@ -81,10 +83,16 @@ void fix_uclass(void) entry->post_bind += gd->reloc_off; if (entry->pre_unbind) entry->pre_unbind += gd->reloc_off; + if (entry->pre_probe) + entry->pre_probe += gd->reloc_off; if (entry->post_probe) entry->post_probe += gd->reloc_off; if (entry->pre_remove) entry->pre_remove += gd->reloc_off; + if (entry->child_post_bind) + entry->child_post_bind += gd->reloc_off; + if (entry->child_pre_probe) + entry->child_pre_probe += gd->reloc_off; if (entry->init) entry->init += gd->reloc_off; if (entry->destroy)
Using post_bind is not ideal but it is one on current option what can be used. Variable reloc_done has to be used do not call relocation after every bind. Maybe new core functions should be introduced for this case.
Changes in v2: - Add checking for MANUAL_RELOC code only
drivers/mtd/spi/sf-uclass.c | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/drivers/mtd/spi/sf-uclass.c b/drivers/mtd/spi/sf-uclass.c index 350e21aa7d65..72e0f6b3fb1e 100644 --- a/drivers/mtd/spi/sf-uclass.c +++ b/drivers/mtd/spi/sf-uclass.c @@ -11,6 +11,8 @@ #include <dm/device-internal.h> #include "sf_internal.h"
+DECLARE_GLOBAL_DATA_PTR; + int spi_flash_read_dm(struct udevice *dev, u32 offset, size_t len, void *buf) { return sf_get_ops(dev)->read(dev, offset, len, buf); @@ -72,8 +74,29 @@ int spi_flash_remove(struct udevice *dev) return device_remove(dev); }
+static int spi_flash_post_bind(struct udevice *dev) +{ +#if defined(CONFIG_NEEDS_MANUAL_RELOC) + struct dm_spi_flash_ops *ops = sf_get_ops(dev); + static int reloc_done; + + if (!reloc_done) { + if (ops->read) + ops->read += gd->reloc_off; + if (ops->write) + ops->write += gd->reloc_off; + if (ops->erase) + ops->erase += gd->reloc_off; + + reloc_done++; + } +#endif + return 0; +} + UCLASS_DRIVER(spi_flash) = { .id = UCLASS_SPI_FLASH, .name = "spi_flash", + .post_bind = spi_flash_post_bind, .per_device_auto_alloc_size = sizeof(struct spi_flash), };
Changes in v2:
The ugly continues...
Changes in v2:
:-) When I have time I will look at changing microblaze not to use it. But on the other hand Microblaze is not only one arch which uses this. But probably only one arch which is using DM.
Thanks, Michal
Michal Simek
