[U-Boot] [PATCH v3] arm: dts: Stratix10: Add QSPI node
Add QSPI device tree to Stratix 10. Sync from Linux Stratix 10 dts.
Tested on Stratix 10 SoC devkit. SOCFPGA_STRATIX10 # sf probe 0:0 SF: Detected mt25qu02g with page size 256 Bytes, erase size 64 KiB, total 256 MiB
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com
--- v2->v3: - Change flash compatible to "jedec,spi-nor" - Change spi-max-frequency to 100MHz --- arch/arm/dts/socfpga_stratix10.dtsi | 15 +++++++++++++++ arch/arm/dts/socfpga_stratix10_socdk.dts | 21 +++++++++++++++++++++ 2 files changed, 36 insertions(+)
diff --git a/arch/arm/dts/socfpga_stratix10.dtsi b/arch/arm/dts/socfpga_stratix10.dtsi index ee93725d64..9998bb1ba3 100644 --- a/arch/arm/dts/socfpga_stratix10.dtsi +++ b/arch/arm/dts/socfpga_stratix10.dtsi @@ -391,5 +391,20 @@ resets = <&rst WATCHDOG3_RESET>; status = "disabled"; }; + + qspi: spi@ff8d2000 { + compatible = "cdns,qspi-nor"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0xff8d2000 0x100>, + <0xff900000 0x100000>; + interrupts = <0 3 4>; + cdns,fifo-depth = <128>; + cdns,fifo-width = <4>; + cdns,trigger-address = <0x00000000>; + bus-num = <0>; + status = "disabled"; + u-boot,dm-pre-reloc; + }; }; }; diff --git a/arch/arm/dts/socfpga_stratix10_socdk.dts b/arch/arm/dts/socfpga_stratix10_socdk.dts index c59b77d829..9d7d11ee13 100644 --- a/arch/arm/dts/socfpga_stratix10_socdk.dts +++ b/arch/arm/dts/socfpga_stratix10_socdk.dts @@ -10,6 +10,7 @@
aliases { serial0 = &uart0; + spi0 = &qspi; };
chosen { @@ -87,6 +88,26 @@ smplsel = <0>; };
+&qspi { + status = "okay"; + + flash@0 { + u-boot,dm-pre-reloc; + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + reg = <0>; /* chip select */ + spi-max-frequency = <100000000>; + + page-size = <256>; + block-size = <16>; /* 2^16, 64KB */ + cdns,tshsl-ns = <50>; + cdns,tsd2d-ns = <50>; + cdns,tchsh-ns = <4>; + cdns,tslch-ns = <4>; + }; +}; + &uart0 { status = "okay"; };
Ley Foon Tan
