[U-Boot] [PATCH 2/4] s5p6442: Support onenand driver
This patch is for onenand support of s5p6442 SoC.
Cc: Minkyu Kang mk7.kang@samsung.com Cc: Kyungmin Park kyungmin.park@samsung.com Signed-off-by: Joonyoung Shim jy0922.shim@samsung.com --- drivers/mtd/onenand/samsung.c | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/onenand/samsung.c b/drivers/mtd/onenand/samsung.c index f2be687..cbcf83b 100644 --- a/drivers/mtd/onenand/samsung.c +++ b/drivers/mtd/onenand/samsung.c @@ -67,7 +67,7 @@ do { \ #define MAP_01 (0x1 << 24) #define MAP_10 (0x2 << 24) #define MAP_11 (0x3 << 24) -#elif defined(CONFIG_S5PC1XX) +#elif defined(CONFIG_S5PC1XX) || defined(CONFIG_S5P64XX) #define MAP_00 (0x0 << 26) #define MAP_01 (0x1 << 26) #define MAP_10 (0x2 << 26) @@ -121,7 +121,7 @@ static unsigned int s3c_mem_addr(int fba, int fpa, int fsa) { return (fba << 12) | (fpa << 6) | (fsa << 4); } -#elif defined(CONFIG_S5PC1XX) +#elif defined(CONFIG_S5PC1XX) || defined(CONFIG_S5P64XX) static unsigned int s3c_mem_addr(int fba, int fpa, int fsa) { return (fba << 13) | (fpa << 7) | (fsa << 5); @@ -614,7 +614,7 @@ void s3c_onenand_init(struct mtd_info *mtd) #if defined(CONFIG_S3C64XX) onenand->base = (void *)0x70100000; onenand->ahb_addr = (void *)0x20000000; -#elif defined(CONFIG_S5PC1XX) +#elif defined(CONFIG_S5PC1XX) || defined(CONFIG_S5P64XX) onenand->base = (void *)0xE7100000; onenand->ahb_addr = (void *)0xB0000000; #endif
Acked-by: Scott Wood scottwood@freescale.com
-Scott
I looks like nothing which defines CONFIG_S5P64XX made it in, so I'm going to mark this as Deferred in patchwork.
-Scott
Joonyoung Shim
Scott Wood
