[U-Boot] [PATCH v2] ARM: tegra: increase console buffer size and sys args num
The Linux-for-Tegra kernel uses a very long command line.
The default value of CONFIG_SYS_CBSIZE is too small to printf out the long command line and causes a message like: bootarg overflow 602+0+0+1 > 512 on the console, and the board refuses to boot.
The default value of CONFIG_SYS_MAXARGS is too small to add a long long command line, and the kernel won't boot without the complete bootargs.
Increasing these two config options solves this problem.
Signed-off-by: Bryan Wu pengw@nvidia.com Signed-off-by: Peter Chubb Peter.Chubb@data61.csiro.au Acked-by: Stephen Warren swarren@nvidia.com --- include/configs/tegra-common.h | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 7b0940a..6bfd7b2 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -76,11 +76,12 @@ * Increasing the size of the IO buffer as default nfsargs size is more * than 256 and so it is not possible to edit it */ -#define CONFIG_SYS_CBSIZE (256 * 2) /* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE (1024 * 2) /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_MAXARGS 32 /* max number of command args */ +#define CONFIG_SYS_MAXARGS 64 /* max number of command args */ + /* Boot Argument Buffer Size */ #define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE)
