[U-Boot] [PATCH] arm64: versal: Remove one level of indentation in board_early_init_r()
Simplify code indentation.
board/xilinx/versal/board.c | 73 +++++++++++++++++++++++---------------------- 1 file changed, 37 insertions(+), 36 deletions(-)
diff --git a/board/xilinx/versal/board.c b/board/xilinx/versal/board.c index 2b3a40b73a5f..fe61125d92a8 100644 --- a/board/xilinx/versal/board.c +++ b/board/xilinx/versal/board.c @@ -21,42 +21,43 @@ int board_init(void)
int board_early_init_r(void) { - if (current_el() == 3) { - u32 val; - - writel(IOU_SWITCH_CTRL_CLKACT_BIT | - (0x20 << IOU_SWITCH_CTRL_DIVISOR0_SHIFT), - &crlapb_base->iou_switch_ctrl); - - /* Global timer init - Program time stamp reference clk */ - val = readl(&crlapb_base->timestamp_ref_ctrl); - val |= CRL_APB_TIMESTAMP_REF_CTRL_CLKACT_BIT; - writel(val, &crlapb_base->timestamp_ref_ctrl); - - debug("ref ctrl 0x%x\n", - readl(&crlapb_base->timestamp_ref_ctrl)); - - /* Clear reset of timestamp reg */ - writel(0, &crlapb_base->rst_timestamp); - - /* - * Program freq register in System counter and - * enable system counter. - */ - writel(COUNTER_FREQUENCY, - &iou_scntr_secure->base_frequency_id_register); - - debug("counter val 0x%x\n", - readl(&iou_scntr_secure->base_frequency_id_register)); - - writel(IOU_SCNTRS_CONTROL_EN, - &iou_scntr_secure->counter_control_register); - - debug("scntrs control 0x%x\n", - readl(&iou_scntr_secure->counter_control_register)); - debug("timer 0x%llx\n", get_ticks()); - debug("timer 0x%llx\n", get_ticks()); - } + u32 val; + + if (current_el() != 3) + return 0; + + writel(IOU_SWITCH_CTRL_CLKACT_BIT | + (0x20 << IOU_SWITCH_CTRL_DIVISOR0_SHIFT), + &crlapb_base->iou_switch_ctrl); + + /* Global timer init - Program time stamp reference clk */ + val = readl(&crlapb_base->timestamp_ref_ctrl); + val |= CRL_APB_TIMESTAMP_REF_CTRL_CLKACT_BIT; + writel(val, &crlapb_base->timestamp_ref_ctrl); + + debug("ref ctrl 0x%x\n", + readl(&crlapb_base->timestamp_ref_ctrl)); + + /* Clear reset of timestamp reg */ + writel(0, &crlapb_base->rst_timestamp); + + /* + * Program freq register in System counter and + * enable system counter. + */ + writel(COUNTER_FREQUENCY, + &iou_scntr_secure->base_frequency_id_register); + + debug("counter val 0x%x\n", + readl(&iou_scntr_secure->base_frequency_id_register)); + + writel(IOU_SCNTRS_CONTROL_EN, + &iou_scntr_secure->counter_control_register); + + debug("scntrs control 0x%x\n", + readl(&iou_scntr_secure->counter_control_register)); + debug("timer 0x%llx\n", get_ticks()); + debug("timer 0x%llx\n", get_ticks());
return 0; }
Michal Simek
