[U-Boot] [PATCH 1/2] smc911x: split out useful defines/functions into local header
The smc911x driver has a lot of useful defines/functions which can be used by pieces of code (such as example eeprom programmers). Rather than forcing each place to duplicate these defines/functions, split them out of the smdc911x driver into a local header.
Signed-off-by: Mike Frysinger vapier@gentoo.org CC: Sascha Hauer s.hauer@pengutronix.de CC: Guennadi Liakhovetski lg@denx.de CC: Magnus Lilja lilja.magnus@gmail.com CC: Ben Warren biggerbadderben@gmail.com --- drivers/net/smc911x.c | 452 +--------------------------------------------- drivers/net/smc911x.h | 486 +++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 488 insertions(+), 450 deletions(-) create mode 100644 drivers/net/smc911x.h
diff --git a/drivers/net/smc911x.c b/drivers/net/smc911x.c index 648c94c..192bd96 100644 --- a/drivers/net/smc911x.c +++ b/drivers/net/smc911x.c @@ -27,35 +27,7 @@ #include <net.h> #include <miiphy.h>
-#if defined (CONFIG_DRIVER_SMC911X_32_BIT) && \ - defined (CONFIG_DRIVER_SMC911X_16_BIT) -#error "SMC911X: Only one of CONFIG_DRIVER_SMC911X_32_BIT and \ - CONFIG_DRIVER_SMC911X_16_BIT shall be set" -#endif - -#if defined (CONFIG_DRIVER_SMC911X_32_BIT) -static inline u32 reg_read(u32 addr) -{ - return *(volatile u32*)addr; -} -static inline void reg_write(u32 addr, u32 val) -{ - *(volatile u32*)addr = val; -} -#elif defined (CONFIG_DRIVER_SMC911X_16_BIT) -static inline u32 reg_read(u32 addr) -{ - volatile u16 *addr_16 = (u16 *)addr; - return ((*addr_16 & 0x0000ffff) | (*(addr_16 + 1) << 16)); -} -static inline void reg_write(u32 addr, u32 val) -{ - *(volatile u16*)addr = (u16)val; - *(volatile u16*)(addr + 2) = (u16)(val >> 16); -} -#else -#error "SMC911X: undefined bus width" -#endif /* CONFIG_DRIVER_SMC911X_16_BIT */ +#include "smc911x.h"
u32 pkt_data_pull(u32 addr) \ __attribute__ ((weak, alias ("reg_read"))); @@ -64,368 +36,6 @@ void pkt_data_push(u32 addr, u32 val) \
#define mdelay(n) udelay((n)*1000)
-/* Below are the register offsets and bit definitions - * of the Lan911x memory space - */ -#define RX_DATA_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x00) - -#define TX_DATA_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x20) -#define TX_CMD_A_INT_ON_COMP 0x80000000 -#define TX_CMD_A_INT_BUF_END_ALGN 0x03000000 -#define TX_CMD_A_INT_4_BYTE_ALGN 0x00000000 -#define TX_CMD_A_INT_16_BYTE_ALGN 0x01000000 -#define TX_CMD_A_INT_32_BYTE_ALGN 0x02000000 -#define TX_CMD_A_INT_DATA_OFFSET 0x001F0000 -#define TX_CMD_A_INT_FIRST_SEG 0x00002000 -#define TX_CMD_A_INT_LAST_SEG 0x00001000 -#define TX_CMD_A_BUF_SIZE 0x000007FF -#define TX_CMD_B_PKT_TAG 0xFFFF0000 -#define TX_CMD_B_ADD_CRC_DISABLE 0x00002000 -#define TX_CMD_B_DISABLE_PADDING 0x00001000 -#define TX_CMD_B_PKT_BYTE_LENGTH 0x000007FF - -#define RX_STATUS_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x40) -#define RX_STS_PKT_LEN 0x3FFF0000 -#define RX_STS_ES 0x00008000 -#define RX_STS_BCST 0x00002000 -#define RX_STS_LEN_ERR 0x00001000 -#define RX_STS_RUNT_ERR 0x00000800 -#define RX_STS_MCAST 0x00000400 -#define RX_STS_TOO_LONG 0x00000080 -#define RX_STS_COLL 0x00000040 -#define RX_STS_ETH_TYPE 0x00000020 -#define RX_STS_WDOG_TMT 0x00000010 -#define RX_STS_MII_ERR 0x00000008 -#define RX_STS_DRIBBLING 0x00000004 -#define RX_STS_CRC_ERR 0x00000002 -#define RX_STATUS_FIFO_PEEK (CONFIG_DRIVER_SMC911X_BASE + 0x44) -#define TX_STATUS_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x48) -#define TX_STS_TAG 0xFFFF0000 -#define TX_STS_ES 0x00008000 -#define TX_STS_LOC 0x00000800 -#define TX_STS_NO_CARR 0x00000400 -#define TX_STS_LATE_COLL 0x00000200 -#define TX_STS_MANY_COLL 0x00000100 -#define TX_STS_COLL_CNT 0x00000078 -#define TX_STS_MANY_DEFER 0x00000004 -#define TX_STS_UNDERRUN 0x00000002 -#define TX_STS_DEFERRED 0x00000001 -#define TX_STATUS_FIFO_PEEK (CONFIG_DRIVER_SMC911X_BASE + 0x4C) -#define ID_REV (CONFIG_DRIVER_SMC911X_BASE + 0x50) -#define ID_REV_CHIP_ID 0xFFFF0000 /* RO */ -#define ID_REV_REV_ID 0x0000FFFF /* RO */ - -#define INT_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x54) -#define INT_CFG_INT_DEAS 0xFF000000 /* R/W */ -#define INT_CFG_INT_DEAS_CLR 0x00004000 -#define INT_CFG_INT_DEAS_STS 0x00002000 -#define INT_CFG_IRQ_INT 0x00001000 /* RO */ -#define INT_CFG_IRQ_EN 0x00000100 /* R/W */ -#define INT_CFG_IRQ_POL 0x00000010 /* R/W Not Affected by SW Reset */ -#define INT_CFG_IRQ_TYPE 0x00000001 /* R/W Not Affected by SW Reset */ - -#define INT_STS (CONFIG_DRIVER_SMC911X_BASE + 0x58) -#define INT_STS_SW_INT 0x80000000 /* R/WC */ -#define INT_STS_TXSTOP_INT 0x02000000 /* R/WC */ -#define INT_STS_RXSTOP_INT 0x01000000 /* R/WC */ -#define INT_STS_RXDFH_INT 0x00800000 /* R/WC */ -#define INT_STS_RXDF_INT 0x00400000 /* R/WC */ -#define INT_STS_TX_IOC 0x00200000 /* R/WC */ -#define INT_STS_RXD_INT 0x00100000 /* R/WC */ -#define INT_STS_GPT_INT 0x00080000 /* R/WC */ -#define INT_STS_PHY_INT 0x00040000 /* RO */ -#define INT_STS_PME_INT 0x00020000 /* R/WC */ -#define INT_STS_TXSO 0x00010000 /* R/WC */ -#define INT_STS_RWT 0x00008000 /* R/WC */ -#define INT_STS_RXE 0x00004000 /* R/WC */ -#define INT_STS_TXE 0x00002000 /* R/WC */ -/*#define INT_STS_ERX 0x00001000*/ /* R/WC */ -#define INT_STS_TDFU 0x00000800 /* R/WC */ -#define INT_STS_TDFO 0x00000400 /* R/WC */ -#define INT_STS_TDFA 0x00000200 /* R/WC */ -#define INT_STS_TSFF 0x00000100 /* R/WC */ -#define INT_STS_TSFL 0x00000080 /* R/WC */ -/*#define INT_STS_RXDF 0x00000040*/ /* R/WC */ -#define INT_STS_RDFO 0x00000040 /* R/WC */ -#define INT_STS_RDFL 0x00000020 /* R/WC */ -#define INT_STS_RSFF 0x00000010 /* R/WC */ -#define INT_STS_RSFL 0x00000008 /* R/WC */ -#define INT_STS_GPIO2_INT 0x00000004 /* R/WC */ -#define INT_STS_GPIO1_INT 0x00000002 /* R/WC */ -#define INT_STS_GPIO0_INT 0x00000001 /* R/WC */ -#define INT_EN (CONFIG_DRIVER_SMC911X_BASE + 0x5C) -#define INT_EN_SW_INT_EN 0x80000000 /* R/W */ -#define INT_EN_TXSTOP_INT_EN 0x02000000 /* R/W */ -#define INT_EN_RXSTOP_INT_EN 0x01000000 /* R/W */ -#define INT_EN_RXDFH_INT_EN 0x00800000 /* R/W */ -/*#define INT_EN_RXDF_INT_EN 0x00400000*/ /* R/W */ -#define INT_EN_TIOC_INT_EN 0x00200000 /* R/W */ -#define INT_EN_RXD_INT_EN 0x00100000 /* R/W */ -#define INT_EN_GPT_INT_EN 0x00080000 /* R/W */ -#define INT_EN_PHY_INT_EN 0x00040000 /* R/W */ -#define INT_EN_PME_INT_EN 0x00020000 /* R/W */ -#define INT_EN_TXSO_EN 0x00010000 /* R/W */ -#define INT_EN_RWT_EN 0x00008000 /* R/W */ -#define INT_EN_RXE_EN 0x00004000 /* R/W */ -#define INT_EN_TXE_EN 0x00002000 /* R/W */ -/*#define INT_EN_ERX_EN 0x00001000*/ /* R/W */ -#define INT_EN_TDFU_EN 0x00000800 /* R/W */ -#define INT_EN_TDFO_EN 0x00000400 /* R/W */ -#define INT_EN_TDFA_EN 0x00000200 /* R/W */ -#define INT_EN_TSFF_EN 0x00000100 /* R/W */ -#define INT_EN_TSFL_EN 0x00000080 /* R/W */ -/*#define INT_EN_RXDF_EN 0x00000040*/ /* R/W */ -#define INT_EN_RDFO_EN 0x00000040 /* R/W */ -#define INT_EN_RDFL_EN 0x00000020 /* R/W */ -#define INT_EN_RSFF_EN 0x00000010 /* R/W */ -#define INT_EN_RSFL_EN 0x00000008 /* R/W */ -#define INT_EN_GPIO2_INT 0x00000004 /* R/W */ -#define INT_EN_GPIO1_INT 0x00000002 /* R/W */ -#define INT_EN_GPIO0_INT 0x00000001 /* R/W */ - -#define BYTE_TEST (CONFIG_DRIVER_SMC911X_BASE + 0x64) -#define FIFO_INT (CONFIG_DRIVER_SMC911X_BASE + 0x68) -#define FIFO_INT_TX_AVAIL_LEVEL 0xFF000000 /* R/W */ -#define FIFO_INT_TX_STS_LEVEL 0x00FF0000 /* R/W */ -#define FIFO_INT_RX_AVAIL_LEVEL 0x0000FF00 /* R/W */ -#define FIFO_INT_RX_STS_LEVEL 0x000000FF /* R/W */ - -#define RX_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x6C) -#define RX_CFG_RX_END_ALGN 0xC0000000 /* R/W */ -#define RX_CFG_RX_END_ALGN4 0x00000000 /* R/W */ -#define RX_CFG_RX_END_ALGN16 0x40000000 /* R/W */ -#define RX_CFG_RX_END_ALGN32 0x80000000 /* R/W */ -#define RX_CFG_RX_DMA_CNT 0x0FFF0000 /* R/W */ -#define RX_CFG_RX_DUMP 0x00008000 /* R/W */ -#define RX_CFG_RXDOFF 0x00001F00 /* R/W */ -/*#define RX_CFG_RXBAD 0x00000001*/ /* R/W */ - -#define TX_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x70) -/*#define TX_CFG_TX_DMA_LVL 0xE0000000*/ /* R/W */ -/*#define TX_CFG_TX_DMA_CNT 0x0FFF0000*/ /* R/W Self Clearing */ -#define TX_CFG_TXS_DUMP 0x00008000 /* Self Clearing */ -#define TX_CFG_TXD_DUMP 0x00004000 /* Self Clearing */ -#define TX_CFG_TXSAO 0x00000004 /* R/W */ -#define TX_CFG_TX_ON 0x00000002 /* R/W */ -#define TX_CFG_STOP_TX 0x00000001 /* Self Clearing */ - -#define HW_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x74) -#define HW_CFG_TTM 0x00200000 /* R/W */ -#define HW_CFG_SF 0x00100000 /* R/W */ -#define HW_CFG_TX_FIF_SZ 0x000F0000 /* R/W */ -#define HW_CFG_TR 0x00003000 /* R/W */ -#define HW_CFG_PHY_CLK_SEL 0x00000060 /* R/W */ -#define HW_CFG_PHY_CLK_SEL_INT_PHY 0x00000000 /* R/W */ -#define HW_CFG_PHY_CLK_SEL_EXT_PHY 0x00000020 /* R/W */ -#define HW_CFG_PHY_CLK_SEL_CLK_DIS 0x00000040 /* R/W */ -#define HW_CFG_SMI_SEL 0x00000010 /* R/W */ -#define HW_CFG_EXT_PHY_DET 0x00000008 /* RO */ -#define HW_CFG_EXT_PHY_EN 0x00000004 /* R/W */ -#define HW_CFG_32_16_BIT_MODE 0x00000004 /* RO */ -#define HW_CFG_SRST_TO 0x00000002 /* RO */ -#define HW_CFG_SRST 0x00000001 /* Self Clearing */ - -#define RX_DP_CTRL (CONFIG_DRIVER_SMC911X_BASE + 0x78) -#define RX_DP_CTRL_RX_FFWD 0x80000000 /* R/W */ -#define RX_DP_CTRL_FFWD_BUSY 0x80000000 /* RO */ - -#define RX_FIFO_INF (CONFIG_DRIVER_SMC911X_BASE + 0x7C) -#define RX_FIFO_INF_RXSUSED 0x00FF0000 /* RO */ -#define RX_FIFO_INF_RXDUSED 0x0000FFFF /* RO */ - -#define TX_FIFO_INF (CONFIG_DRIVER_SMC911X_BASE + 0x80) -#define TX_FIFO_INF_TSUSED 0x00FF0000 /* RO */ -#define TX_FIFO_INF_TDFREE 0x0000FFFF /* RO */ - -#define PMT_CTRL (CONFIG_DRIVER_SMC911X_BASE + 0x84) -#define PMT_CTRL_PM_MODE 0x00003000 /* Self Clearing */ -#define PMT_CTRL_PHY_RST 0x00000400 /* Self Clearing */ -#define PMT_CTRL_WOL_EN 0x00000200 /* R/W */ -#define PMT_CTRL_ED_EN 0x00000100 /* R/W */ -#define PMT_CTRL_PME_TYPE 0x00000040 /* R/W Not Affected by SW Reset */ -#define PMT_CTRL_WUPS 0x00000030 /* R/WC */ -#define PMT_CTRL_WUPS_NOWAKE 0x00000000 /* R/WC */ -#define PMT_CTRL_WUPS_ED 0x00000010 /* R/WC */ -#define PMT_CTRL_WUPS_WOL 0x00000020 /* R/WC */ -#define PMT_CTRL_WUPS_MULTI 0x00000030 /* R/WC */ -#define PMT_CTRL_PME_IND 0x00000008 /* R/W */ -#define PMT_CTRL_PME_POL 0x00000004 /* R/W */ -#define PMT_CTRL_PME_EN 0x00000002 /* R/W Not Affected by SW Reset */ -#define PMT_CTRL_READY 0x00000001 /* RO */ - -#define GPIO_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x88) -#define GPIO_CFG_LED3_EN 0x40000000 /* R/W */ -#define GPIO_CFG_LED2_EN 0x20000000 /* R/W */ -#define GPIO_CFG_LED1_EN 0x10000000 /* R/W */ -#define GPIO_CFG_GPIO2_INT_POL 0x04000000 /* R/W */ -#define GPIO_CFG_GPIO1_INT_POL 0x02000000 /* R/W */ -#define GPIO_CFG_GPIO0_INT_POL 0x01000000 /* R/W */ -#define GPIO_CFG_EEPR_EN 0x00700000 /* R/W */ -#define GPIO_CFG_GPIOBUF2 0x00040000 /* R/W */ -#define GPIO_CFG_GPIOBUF1 0x00020000 /* R/W */ -#define GPIO_CFG_GPIOBUF0 0x00010000 /* R/W */ -#define GPIO_CFG_GPIODIR2 0x00000400 /* R/W */ -#define GPIO_CFG_GPIODIR1 0x00000200 /* R/W */ -#define GPIO_CFG_GPIODIR0 0x00000100 /* R/W */ -#define GPIO_CFG_GPIOD4 0x00000010 /* R/W */ -#define GPIO_CFG_GPIOD3 0x00000008 /* R/W */ -#define GPIO_CFG_GPIOD2 0x00000004 /* R/W */ -#define GPIO_CFG_GPIOD1 0x00000002 /* R/W */ -#define GPIO_CFG_GPIOD0 0x00000001 /* R/W */ - -#define GPT_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x8C) -#define GPT_CFG_TIMER_EN 0x20000000 /* R/W */ -#define GPT_CFG_GPT_LOAD 0x0000FFFF /* R/W */ - -#define GPT_CNT (CONFIG_DRIVER_SMC911X_BASE + 0x90) -#define GPT_CNT_GPT_CNT 0x0000FFFF /* RO */ - -#define ENDIAN (CONFIG_DRIVER_SMC911X_BASE + 0x98) -#define FREE_RUN (CONFIG_DRIVER_SMC911X_BASE + 0x9C) -#define RX_DROP (CONFIG_DRIVER_SMC911X_BASE + 0xA0) -#define MAC_CSR_CMD (CONFIG_DRIVER_SMC911X_BASE + 0xA4) -#define MAC_CSR_CMD_CSR_BUSY 0x80000000 /* Self Clearing */ -#define MAC_CSR_CMD_R_NOT_W 0x40000000 /* R/W */ -#define MAC_CSR_CMD_CSR_ADDR 0x000000FF /* R/W */ - -#define MAC_CSR_DATA (CONFIG_DRIVER_SMC911X_BASE + 0xA8) -#define AFC_CFG (CONFIG_DRIVER_SMC911X_BASE + 0xAC) -#define AFC_CFG_AFC_HI 0x00FF0000 /* R/W */ -#define AFC_CFG_AFC_LO 0x0000FF00 /* R/W */ -#define AFC_CFG_BACK_DUR 0x000000F0 /* R/W */ -#define AFC_CFG_FCMULT 0x00000008 /* R/W */ -#define AFC_CFG_FCBRD 0x00000004 /* R/W */ -#define AFC_CFG_FCADD 0x00000002 /* R/W */ -#define AFC_CFG_FCANY 0x00000001 /* R/W */ - -#define E2P_CMD (CONFIG_DRIVER_SMC911X_BASE + 0xB0) -#define E2P_CMD_EPC_BUSY 0x80000000 /* Self Clearing */ -#define E2P_CMD_EPC_CMD 0x70000000 /* R/W */ -#define E2P_CMD_EPC_CMD_READ 0x00000000 /* R/W */ -#define E2P_CMD_EPC_CMD_EWDS 0x10000000 /* R/W */ -#define E2P_CMD_EPC_CMD_EWEN 0x20000000 /* R/W */ -#define E2P_CMD_EPC_CMD_WRITE 0x30000000 /* R/W */ -#define E2P_CMD_EPC_CMD_WRAL 0x40000000 /* R/W */ -#define E2P_CMD_EPC_CMD_ERASE 0x50000000 /* R/W */ -#define E2P_CMD_EPC_CMD_ERAL 0x60000000 /* R/W */ -#define E2P_CMD_EPC_CMD_RELOAD 0x70000000 /* R/W */ -#define E2P_CMD_EPC_TIMEOUT 0x00000200 /* RO */ -#define E2P_CMD_MAC_ADDR_LOADED 0x00000100 /* RO */ -#define E2P_CMD_EPC_ADDR 0x000000FF /* R/W */ - -#define E2P_DATA (CONFIG_DRIVER_SMC911X_BASE + 0xB4) -#define E2P_DATA_EEPROM_DATA 0x000000FF /* R/W */ -/* end of LAN register offsets and bit definitions */ - -/* MAC Control and Status registers */ -#define MAC_CR 0x01 /* R/W */ - -/* MAC_CR - MAC Control Register */ -#define MAC_CR_RXALL 0x80000000 -/* TODO: delete this bit? It is not described in the data sheet. */ -#define MAC_CR_HBDIS 0x10000000 -#define MAC_CR_RCVOWN 0x00800000 -#define MAC_CR_LOOPBK 0x00200000 -#define MAC_CR_FDPX 0x00100000 -#define MAC_CR_MCPAS 0x00080000 -#define MAC_CR_PRMS 0x00040000 -#define MAC_CR_INVFILT 0x00020000 -#define MAC_CR_PASSBAD 0x00010000 -#define MAC_CR_HFILT 0x00008000 -#define MAC_CR_HPFILT 0x00002000 -#define MAC_CR_LCOLL 0x00001000 -#define MAC_CR_BCAST 0x00000800 -#define MAC_CR_DISRTY 0x00000400 -#define MAC_CR_PADSTR 0x00000100 -#define MAC_CR_BOLMT_MASK 0x000000C0 -#define MAC_CR_DFCHK 0x00000020 -#define MAC_CR_TXEN 0x00000008 -#define MAC_CR_RXEN 0x00000004 - -#define ADDRH 0x02 /* R/W mask 0x0000FFFFUL */ -#define ADDRL 0x03 /* R/W mask 0xFFFFFFFFUL */ -#define HASHH 0x04 /* R/W */ -#define HASHL 0x05 /* R/W */ - -#define MII_ACC 0x06 /* R/W */ -#define MII_ACC_PHY_ADDR 0x0000F800 -#define MII_ACC_MIIRINDA 0x000007C0 -#define MII_ACC_MII_WRITE 0x00000002 -#define MII_ACC_MII_BUSY 0x00000001 - -#define MII_DATA 0x07 /* R/W mask 0x0000FFFFUL */ - -#define FLOW 0x08 /* R/W */ -#define FLOW_FCPT 0xFFFF0000 -#define FLOW_FCPASS 0x00000004 -#define FLOW_FCEN 0x00000002 -#define FLOW_FCBSY 0x00000001 - -#define VLAN1 0x09 /* R/W mask 0x0000FFFFUL */ -#define VLAN1_VTI1 0x0000ffff - -#define VLAN2 0x0A /* R/W mask 0x0000FFFFUL */ -#define VLAN2_VTI2 0x0000ffff - -#define WUFF 0x0B /* WO */ - -#define WUCSR 0x0C /* R/W */ -#define WUCSR_GUE 0x00000200 -#define WUCSR_WUFR 0x00000040 -#define WUCSR_MPR 0x00000020 -#define WUCSR_WAKE_EN 0x00000004 -#define WUCSR_MPEN 0x00000002 - -/* Chip ID values */ -#define CHIP_9115 0x115 -#define CHIP_9116 0x116 -#define CHIP_9117 0x117 -#define CHIP_9118 0x118 -#define CHIP_9215 0x115a -#define CHIP_9216 0x116a -#define CHIP_9217 0x117a -#define CHIP_9218 0x118a - -struct chip_id { - u16 id; - char *name; -}; - -static const struct chip_id chip_ids[] = { - { CHIP_9115, "LAN9115" }, - { CHIP_9116, "LAN9116" }, - { CHIP_9117, "LAN9117" }, - { CHIP_9118, "LAN9118" }, - { CHIP_9215, "LAN9215" }, - { CHIP_9216, "LAN9216" }, - { CHIP_9217, "LAN9217" }, - { CHIP_9218, "LAN9218" }, - { 0, NULL }, -}; - -#define DRIVERNAME "smc911x" - -u32 smc911x_get_mac_csr(u8 reg) -{ - while (reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) - ; - reg_write(MAC_CSR_CMD, MAC_CSR_CMD_CSR_BUSY | MAC_CSR_CMD_R_NOT_W | reg); - while (reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) - ; - - return reg_read(MAC_CSR_DATA); -} - -void smc911x_set_mac_csr(u8 reg, u32 data) -{ - while (reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) - ; - reg_write(MAC_CSR_DATA, data); - reg_write(MAC_CSR_CMD, MAC_CSR_CMD_CSR_BUSY | reg); - while (reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) - ; -} - static int smx911x_handle_mac_address(bd_t *bd) { unsigned long addrh, addrl; @@ -536,48 +146,6 @@ err_out: printf(DRIVERNAME ": autonegotiation timed out\n"); }
-static void smc911x_reset(void) -{ - int timeout; - - /* Take out of PM setting first */ - if (reg_read(PMT_CTRL) & PMT_CTRL_READY) { - /* Write to the bytetest will take out of powerdown */ - reg_write(BYTE_TEST, 0x0); - - timeout = 10; - - while (timeout-- && !(reg_read(PMT_CTRL) & PMT_CTRL_READY)) - udelay(10); - if (!timeout) { - printf(DRIVERNAME - ": timeout waiting for PM restore\n"); - return; - } - } - - /* Disable interrupts */ - reg_write(INT_EN, 0); - - reg_write(HW_CFG, HW_CFG_SRST); - - timeout = 1000; - while (timeout-- && reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY) - udelay(10); - - if (!timeout) { - printf(DRIVERNAME ": reset timeout\n"); - return; - } - - /* Reset the FIFO level and flow control settings */ - smc911x_set_mac_csr(FLOW, FLOW_FCPT | FLOW_FCEN); - reg_write(AFC_CFG, 0x0050287F); - - /* Set to LED outputs */ - reg_write(GPIO_CFG, 0x70070000); -} - static void smc911x_enable(void) { /* Enable TX */ @@ -596,26 +164,10 @@ static void smc911x_enable(void)
int eth_init(bd_t *bd) { - unsigned long val, i; - printf(DRIVERNAME ": initializing\n");
- val = reg_read(BYTE_TEST); - if (val != 0x87654321) { - printf(DRIVERNAME ": Invalid chip endian 0x%08lx\n", val); + if (!smc911x_detect_chip()) goto err_out; - } - - val = reg_read(ID_REV) >> 16; - for (i = 0; chip_ids[i].id != 0; i++) { - if (chip_ids[i].id == val) break; - } - if (!chip_ids[i].id) { - printf(DRIVERNAME ": Unknown chip ID %04lx\n", val); - goto err_out; - } - - printf(DRIVERNAME ": detected %s controller\n", chip_ids[i].name);
smc911x_reset();
diff --git a/drivers/net/smc911x.h b/drivers/net/smc911x.h new file mode 100644 index 0000000..24cbaaa --- /dev/null +++ b/drivers/net/smc911x.h @@ -0,0 +1,486 @@ +/* + * SMSC LAN9[12]1[567] Network driver + * + * (c) 2007 Pengutronix, Sascha Hauer s.hauer@pengutronix.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _SMC911X_H_ +#define _SMC911X_H_ + +#if defined (CONFIG_DRIVER_SMC911X_32_BIT) && \ + defined (CONFIG_DRIVER_SMC911X_16_BIT) +#error "SMC911X: Only one of CONFIG_DRIVER_SMC911X_32_BIT and \ + CONFIG_DRIVER_SMC911X_16_BIT shall be set" +#endif + +#if defined (CONFIG_DRIVER_SMC911X_32_BIT) +static inline u32 reg_read(u32 addr) +{ + return *(volatile u32*)addr; +} +static inline void reg_write(u32 addr, u32 val) +{ + *(volatile u32*)addr = val; +} +#elif defined (CONFIG_DRIVER_SMC911X_16_BIT) +static inline u32 reg_read(u32 addr) +{ + volatile u16 *addr_16 = (u16 *)addr; + return ((*addr_16 & 0x0000ffff) | (*(addr_16 + 1) << 16)); +} +static inline void reg_write(u32 addr, u32 val) +{ + *(volatile u16*)addr = (u16)val; + *(volatile u16*)(addr + 2) = (u16)(val >> 16); +} +#else +#error "SMC911X: undefined bus width" +#endif /* CONFIG_DRIVER_SMC911X_16_BIT */ + +/* Below are the register offsets and bit definitions + * of the Lan911x memory space + */ +#define RX_DATA_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x00) + +#define TX_DATA_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x20) +#define TX_CMD_A_INT_ON_COMP 0x80000000 +#define TX_CMD_A_INT_BUF_END_ALGN 0x03000000 +#define TX_CMD_A_INT_4_BYTE_ALGN 0x00000000 +#define TX_CMD_A_INT_16_BYTE_ALGN 0x01000000 +#define TX_CMD_A_INT_32_BYTE_ALGN 0x02000000 +#define TX_CMD_A_INT_DATA_OFFSET 0x001F0000 +#define TX_CMD_A_INT_FIRST_SEG 0x00002000 +#define TX_CMD_A_INT_LAST_SEG 0x00001000 +#define TX_CMD_A_BUF_SIZE 0x000007FF +#define TX_CMD_B_PKT_TAG 0xFFFF0000 +#define TX_CMD_B_ADD_CRC_DISABLE 0x00002000 +#define TX_CMD_B_DISABLE_PADDING 0x00001000 +#define TX_CMD_B_PKT_BYTE_LENGTH 0x000007FF + +#define RX_STATUS_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x40) +#define RX_STS_PKT_LEN 0x3FFF0000 +#define RX_STS_ES 0x00008000 +#define RX_STS_BCST 0x00002000 +#define RX_STS_LEN_ERR 0x00001000 +#define RX_STS_RUNT_ERR 0x00000800 +#define RX_STS_MCAST 0x00000400 +#define RX_STS_TOO_LONG 0x00000080 +#define RX_STS_COLL 0x00000040 +#define RX_STS_ETH_TYPE 0x00000020 +#define RX_STS_WDOG_TMT 0x00000010 +#define RX_STS_MII_ERR 0x00000008 +#define RX_STS_DRIBBLING 0x00000004 +#define RX_STS_CRC_ERR 0x00000002 +#define RX_STATUS_FIFO_PEEK (CONFIG_DRIVER_SMC911X_BASE + 0x44) +#define TX_STATUS_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x48) +#define TX_STS_TAG 0xFFFF0000 +#define TX_STS_ES 0x00008000 +#define TX_STS_LOC 0x00000800 +#define TX_STS_NO_CARR 0x00000400 +#define TX_STS_LATE_COLL 0x00000200 +#define TX_STS_MANY_COLL 0x00000100 +#define TX_STS_COLL_CNT 0x00000078 +#define TX_STS_MANY_DEFER 0x00000004 +#define TX_STS_UNDERRUN 0x00000002 +#define TX_STS_DEFERRED 0x00000001 +#define TX_STATUS_FIFO_PEEK (CONFIG_DRIVER_SMC911X_BASE + 0x4C) +#define ID_REV (CONFIG_DRIVER_SMC911X_BASE + 0x50) +#define ID_REV_CHIP_ID 0xFFFF0000 /* RO */ +#define ID_REV_REV_ID 0x0000FFFF /* RO */ + +#define INT_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x54) +#define INT_CFG_INT_DEAS 0xFF000000 /* R/W */ +#define INT_CFG_INT_DEAS_CLR 0x00004000 +#define INT_CFG_INT_DEAS_STS 0x00002000 +#define INT_CFG_IRQ_INT 0x00001000 /* RO */ +#define INT_CFG_IRQ_EN 0x00000100 /* R/W */ +#define INT_CFG_IRQ_POL 0x00000010 /* R/W Not Affected by SW Reset */ +#define INT_CFG_IRQ_TYPE 0x00000001 /* R/W Not Affected by SW Reset */ + +#define INT_STS (CONFIG_DRIVER_SMC911X_BASE + 0x58) +#define INT_STS_SW_INT 0x80000000 /* R/WC */ +#define INT_STS_TXSTOP_INT 0x02000000 /* R/WC */ +#define INT_STS_RXSTOP_INT 0x01000000 /* R/WC */ +#define INT_STS_RXDFH_INT 0x00800000 /* R/WC */ +#define INT_STS_RXDF_INT 0x00400000 /* R/WC */ +#define INT_STS_TX_IOC 0x00200000 /* R/WC */ +#define INT_STS_RXD_INT 0x00100000 /* R/WC */ +#define INT_STS_GPT_INT 0x00080000 /* R/WC */ +#define INT_STS_PHY_INT 0x00040000 /* RO */ +#define INT_STS_PME_INT 0x00020000 /* R/WC */ +#define INT_STS_TXSO 0x00010000 /* R/WC */ +#define INT_STS_RWT 0x00008000 /* R/WC */ +#define INT_STS_RXE 0x00004000 /* R/WC */ +#define INT_STS_TXE 0x00002000 /* R/WC */ +/*#define INT_STS_ERX 0x00001000*/ /* R/WC */ +#define INT_STS_TDFU 0x00000800 /* R/WC */ +#define INT_STS_TDFO 0x00000400 /* R/WC */ +#define INT_STS_TDFA 0x00000200 /* R/WC */ +#define INT_STS_TSFF 0x00000100 /* R/WC */ +#define INT_STS_TSFL 0x00000080 /* R/WC */ +/*#define INT_STS_RXDF 0x00000040*/ /* R/WC */ +#define INT_STS_RDFO 0x00000040 /* R/WC */ +#define INT_STS_RDFL 0x00000020 /* R/WC */ +#define INT_STS_RSFF 0x00000010 /* R/WC */ +#define INT_STS_RSFL 0x00000008 /* R/WC */ +#define INT_STS_GPIO2_INT 0x00000004 /* R/WC */ +#define INT_STS_GPIO1_INT 0x00000002 /* R/WC */ +#define INT_STS_GPIO0_INT 0x00000001 /* R/WC */ +#define INT_EN (CONFIG_DRIVER_SMC911X_BASE + 0x5C) +#define INT_EN_SW_INT_EN 0x80000000 /* R/W */ +#define INT_EN_TXSTOP_INT_EN 0x02000000 /* R/W */ +#define INT_EN_RXSTOP_INT_EN 0x01000000 /* R/W */ +#define INT_EN_RXDFH_INT_EN 0x00800000 /* R/W */ +/*#define INT_EN_RXDF_INT_EN 0x00400000*/ /* R/W */ +#define INT_EN_TIOC_INT_EN 0x00200000 /* R/W */ +#define INT_EN_RXD_INT_EN 0x00100000 /* R/W */ +#define INT_EN_GPT_INT_EN 0x00080000 /* R/W */ +#define INT_EN_PHY_INT_EN 0x00040000 /* R/W */ +#define INT_EN_PME_INT_EN 0x00020000 /* R/W */ +#define INT_EN_TXSO_EN 0x00010000 /* R/W */ +#define INT_EN_RWT_EN 0x00008000 /* R/W */ +#define INT_EN_RXE_EN 0x00004000 /* R/W */ +#define INT_EN_TXE_EN 0x00002000 /* R/W */ +/*#define INT_EN_ERX_EN 0x00001000*/ /* R/W */ +#define INT_EN_TDFU_EN 0x00000800 /* R/W */ +#define INT_EN_TDFO_EN 0x00000400 /* R/W */ +#define INT_EN_TDFA_EN 0x00000200 /* R/W */ +#define INT_EN_TSFF_EN 0x00000100 /* R/W */ +#define INT_EN_TSFL_EN 0x00000080 /* R/W */ +/*#define INT_EN_RXDF_EN 0x00000040*/ /* R/W */ +#define INT_EN_RDFO_EN 0x00000040 /* R/W */ +#define INT_EN_RDFL_EN 0x00000020 /* R/W */ +#define INT_EN_RSFF_EN 0x00000010 /* R/W */ +#define INT_EN_RSFL_EN 0x00000008 /* R/W */ +#define INT_EN_GPIO2_INT 0x00000004 /* R/W */ +#define INT_EN_GPIO1_INT 0x00000002 /* R/W */ +#define INT_EN_GPIO0_INT 0x00000001 /* R/W */ + +#define BYTE_TEST (CONFIG_DRIVER_SMC911X_BASE + 0x64) +#define FIFO_INT (CONFIG_DRIVER_SMC911X_BASE + 0x68) +#define FIFO_INT_TX_AVAIL_LEVEL 0xFF000000 /* R/W */ +#define FIFO_INT_TX_STS_LEVEL 0x00FF0000 /* R/W */ +#define FIFO_INT_RX_AVAIL_LEVEL 0x0000FF00 /* R/W */ +#define FIFO_INT_RX_STS_LEVEL 0x000000FF /* R/W */ + +#define RX_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x6C) +#define RX_CFG_RX_END_ALGN 0xC0000000 /* R/W */ +#define RX_CFG_RX_END_ALGN4 0x00000000 /* R/W */ +#define RX_CFG_RX_END_ALGN16 0x40000000 /* R/W */ +#define RX_CFG_RX_END_ALGN32 0x80000000 /* R/W */ +#define RX_CFG_RX_DMA_CNT 0x0FFF0000 /* R/W */ +#define RX_CFG_RX_DUMP 0x00008000 /* R/W */ +#define RX_CFG_RXDOFF 0x00001F00 /* R/W */ +/*#define RX_CFG_RXBAD 0x00000001*/ /* R/W */ + +#define TX_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x70) +/*#define TX_CFG_TX_DMA_LVL 0xE0000000*/ /* R/W */ +/*#define TX_CFG_TX_DMA_CNT 0x0FFF0000*/ /* R/W Self Clearing */ +#define TX_CFG_TXS_DUMP 0x00008000 /* Self Clearing */ +#define TX_CFG_TXD_DUMP 0x00004000 /* Self Clearing */ +#define TX_CFG_TXSAO 0x00000004 /* R/W */ +#define TX_CFG_TX_ON 0x00000002 /* R/W */ +#define TX_CFG_STOP_TX 0x00000001 /* Self Clearing */ + +#define HW_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x74) +#define HW_CFG_TTM 0x00200000 /* R/W */ +#define HW_CFG_SF 0x00100000 /* R/W */ +#define HW_CFG_TX_FIF_SZ 0x000F0000 /* R/W */ +#define HW_CFG_TR 0x00003000 /* R/W */ +#define HW_CFG_PHY_CLK_SEL 0x00000060 /* R/W */ +#define HW_CFG_PHY_CLK_SEL_INT_PHY 0x00000000 /* R/W */ +#define HW_CFG_PHY_CLK_SEL_EXT_PHY 0x00000020 /* R/W */ +#define HW_CFG_PHY_CLK_SEL_CLK_DIS 0x00000040 /* R/W */ +#define HW_CFG_SMI_SEL 0x00000010 /* R/W */ +#define HW_CFG_EXT_PHY_DET 0x00000008 /* RO */ +#define HW_CFG_EXT_PHY_EN 0x00000004 /* R/W */ +#define HW_CFG_32_16_BIT_MODE 0x00000004 /* RO */ +#define HW_CFG_SRST_TO 0x00000002 /* RO */ +#define HW_CFG_SRST 0x00000001 /* Self Clearing */ + +#define RX_DP_CTRL (CONFIG_DRIVER_SMC911X_BASE + 0x78) +#define RX_DP_CTRL_RX_FFWD 0x80000000 /* R/W */ +#define RX_DP_CTRL_FFWD_BUSY 0x80000000 /* RO */ + +#define RX_FIFO_INF (CONFIG_DRIVER_SMC911X_BASE + 0x7C) +#define RX_FIFO_INF_RXSUSED 0x00FF0000 /* RO */ +#define RX_FIFO_INF_RXDUSED 0x0000FFFF /* RO */ + +#define TX_FIFO_INF (CONFIG_DRIVER_SMC911X_BASE + 0x80) +#define TX_FIFO_INF_TSUSED 0x00FF0000 /* RO */ +#define TX_FIFO_INF_TDFREE 0x0000FFFF /* RO */ + +#define PMT_CTRL (CONFIG_DRIVER_SMC911X_BASE + 0x84) +#define PMT_CTRL_PM_MODE 0x00003000 /* Self Clearing */ +#define PMT_CTRL_PHY_RST 0x00000400 /* Self Clearing */ +#define PMT_CTRL_WOL_EN 0x00000200 /* R/W */ +#define PMT_CTRL_ED_EN 0x00000100 /* R/W */ +#define PMT_CTRL_PME_TYPE 0x00000040 /* R/W Not Affected by SW Reset */ +#define PMT_CTRL_WUPS 0x00000030 /* R/WC */ +#define PMT_CTRL_WUPS_NOWAKE 0x00000000 /* R/WC */ +#define PMT_CTRL_WUPS_ED 0x00000010 /* R/WC */ +#define PMT_CTRL_WUPS_WOL 0x00000020 /* R/WC */ +#define PMT_CTRL_WUPS_MULTI 0x00000030 /* R/WC */ +#define PMT_CTRL_PME_IND 0x00000008 /* R/W */ +#define PMT_CTRL_PME_POL 0x00000004 /* R/W */ +#define PMT_CTRL_PME_EN 0x00000002 /* R/W Not Affected by SW Reset */ +#define PMT_CTRL_READY 0x00000001 /* RO */ + +#define GPIO_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x88) +#define GPIO_CFG_LED3_EN 0x40000000 /* R/W */ +#define GPIO_CFG_LED2_EN 0x20000000 /* R/W */ +#define GPIO_CFG_LED1_EN 0x10000000 /* R/W */ +#define GPIO_CFG_GPIO2_INT_POL 0x04000000 /* R/W */ +#define GPIO_CFG_GPIO1_INT_POL 0x02000000 /* R/W */ +#define GPIO_CFG_GPIO0_INT_POL 0x01000000 /* R/W */ +#define GPIO_CFG_EEPR_EN 0x00700000 /* R/W */ +#define GPIO_CFG_GPIOBUF2 0x00040000 /* R/W */ +#define GPIO_CFG_GPIOBUF1 0x00020000 /* R/W */ +#define GPIO_CFG_GPIOBUF0 0x00010000 /* R/W */ +#define GPIO_CFG_GPIODIR2 0x00000400 /* R/W */ +#define GPIO_CFG_GPIODIR1 0x00000200 /* R/W */ +#define GPIO_CFG_GPIODIR0 0x00000100 /* R/W */ +#define GPIO_CFG_GPIOD4 0x00000010 /* R/W */ +#define GPIO_CFG_GPIOD3 0x00000008 /* R/W */ +#define GPIO_CFG_GPIOD2 0x00000004 /* R/W */ +#define GPIO_CFG_GPIOD1 0x00000002 /* R/W */ +#define GPIO_CFG_GPIOD0 0x00000001 /* R/W */ + +#define GPT_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x8C) +#define GPT_CFG_TIMER_EN 0x20000000 /* R/W */ +#define GPT_CFG_GPT_LOAD 0x0000FFFF /* R/W */ + +#define GPT_CNT (CONFIG_DRIVER_SMC911X_BASE + 0x90) +#define GPT_CNT_GPT_CNT 0x0000FFFF /* RO */ + +#define ENDIAN (CONFIG_DRIVER_SMC911X_BASE + 0x98) +#define FREE_RUN (CONFIG_DRIVER_SMC911X_BASE + 0x9C) +#define RX_DROP (CONFIG_DRIVER_SMC911X_BASE + 0xA0) +#define MAC_CSR_CMD (CONFIG_DRIVER_SMC911X_BASE + 0xA4) +#define MAC_CSR_CMD_CSR_BUSY 0x80000000 /* Self Clearing */ +#define MAC_CSR_CMD_R_NOT_W 0x40000000 /* R/W */ +#define MAC_CSR_CMD_CSR_ADDR 0x000000FF /* R/W */ + +#define MAC_CSR_DATA (CONFIG_DRIVER_SMC911X_BASE + 0xA8) +#define AFC_CFG (CONFIG_DRIVER_SMC911X_BASE + 0xAC) +#define AFC_CFG_AFC_HI 0x00FF0000 /* R/W */ +#define AFC_CFG_AFC_LO 0x0000FF00 /* R/W */ +#define AFC_CFG_BACK_DUR 0x000000F0 /* R/W */ +#define AFC_CFG_FCMULT 0x00000008 /* R/W */ +#define AFC_CFG_FCBRD 0x00000004 /* R/W */ +#define AFC_CFG_FCADD 0x00000002 /* R/W */ +#define AFC_CFG_FCANY 0x00000001 /* R/W */ + +#define E2P_CMD (CONFIG_DRIVER_SMC911X_BASE + 0xB0) +#define E2P_CMD_EPC_BUSY 0x80000000 /* Self Clearing */ +#define E2P_CMD_EPC_CMD 0x70000000 /* R/W */ +#define E2P_CMD_EPC_CMD_READ 0x00000000 /* R/W */ +#define E2P_CMD_EPC_CMD_EWDS 0x10000000 /* R/W */ +#define E2P_CMD_EPC_CMD_EWEN 0x20000000 /* R/W */ +#define E2P_CMD_EPC_CMD_WRITE 0x30000000 /* R/W */ +#define E2P_CMD_EPC_CMD_WRAL 0x40000000 /* R/W */ +#define E2P_CMD_EPC_CMD_ERASE 0x50000000 /* R/W */ +#define E2P_CMD_EPC_CMD_ERAL 0x60000000 /* R/W */ +#define E2P_CMD_EPC_CMD_RELOAD 0x70000000 /* R/W */ +#define E2P_CMD_EPC_TIMEOUT 0x00000200 /* RO */ +#define E2P_CMD_MAC_ADDR_LOADED 0x00000100 /* RO */ +#define E2P_CMD_EPC_ADDR 0x000000FF /* R/W */ + +#define E2P_DATA (CONFIG_DRIVER_SMC911X_BASE + 0xB4) +#define E2P_DATA_EEPROM_DATA 0x000000FF /* R/W */ +/* end of LAN register offsets and bit definitions */ + +/* MAC Control and Status registers */ +#define MAC_CR 0x01 /* R/W */ + +/* MAC_CR - MAC Control Register */ +#define MAC_CR_RXALL 0x80000000 +/* TODO: delete this bit? It is not described in the data sheet. */ +#define MAC_CR_HBDIS 0x10000000 +#define MAC_CR_RCVOWN 0x00800000 +#define MAC_CR_LOOPBK 0x00200000 +#define MAC_CR_FDPX 0x00100000 +#define MAC_CR_MCPAS 0x00080000 +#define MAC_CR_PRMS 0x00040000 +#define MAC_CR_INVFILT 0x00020000 +#define MAC_CR_PASSBAD 0x00010000 +#define MAC_CR_HFILT 0x00008000 +#define MAC_CR_HPFILT 0x00002000 +#define MAC_CR_LCOLL 0x00001000 +#define MAC_CR_BCAST 0x00000800 +#define MAC_CR_DISRTY 0x00000400 +#define MAC_CR_PADSTR 0x00000100 +#define MAC_CR_BOLMT_MASK 0x000000C0 +#define MAC_CR_DFCHK 0x00000020 +#define MAC_CR_TXEN 0x00000008 +#define MAC_CR_RXEN 0x00000004 + +#define ADDRH 0x02 /* R/W mask 0x0000FFFFUL */ +#define ADDRL 0x03 /* R/W mask 0xFFFFFFFFUL */ +#define HASHH 0x04 /* R/W */ +#define HASHL 0x05 /* R/W */ + +#define MII_ACC 0x06 /* R/W */ +#define MII_ACC_PHY_ADDR 0x0000F800 +#define MII_ACC_MIIRINDA 0x000007C0 +#define MII_ACC_MII_WRITE 0x00000002 +#define MII_ACC_MII_BUSY 0x00000001 + +#define MII_DATA 0x07 /* R/W mask 0x0000FFFFUL */ + +#define FLOW 0x08 /* R/W */ +#define FLOW_FCPT 0xFFFF0000 +#define FLOW_FCPASS 0x00000004 +#define FLOW_FCEN 0x00000002 +#define FLOW_FCBSY 0x00000001 + +#define VLAN1 0x09 /* R/W mask 0x0000FFFFUL */ +#define VLAN1_VTI1 0x0000ffff + +#define VLAN2 0x0A /* R/W mask 0x0000FFFFUL */ +#define VLAN2_VTI2 0x0000ffff + +#define WUFF 0x0B /* WO */ + +#define WUCSR 0x0C /* R/W */ +#define WUCSR_GUE 0x00000200 +#define WUCSR_WUFR 0x00000040 +#define WUCSR_MPR 0x00000020 +#define WUCSR_WAKE_EN 0x00000004 +#define WUCSR_MPEN 0x00000002 + +/* Chip ID values */ +#define CHIP_9115 0x115 +#define CHIP_9116 0x116 +#define CHIP_9117 0x117 +#define CHIP_9118 0x118 +#define CHIP_9215 0x115a +#define CHIP_9216 0x116a +#define CHIP_9217 0x117a +#define CHIP_9218 0x118a + +struct chip_id { + u16 id; + char *name; +}; + +static const struct chip_id chip_ids[] = { + { CHIP_9115, "LAN9115" }, + { CHIP_9116, "LAN9116" }, + { CHIP_9117, "LAN9117" }, + { CHIP_9118, "LAN9118" }, + { CHIP_9215, "LAN9215" }, + { CHIP_9216, "LAN9216" }, + { CHIP_9217, "LAN9217" }, + { CHIP_9218, "LAN9218" }, + { 0, NULL }, +}; + +#define DRIVERNAME "smc911x" + +static u32 smc911x_get_mac_csr(u8 reg) +{ + while (reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) + ; + reg_write(MAC_CSR_CMD, MAC_CSR_CMD_CSR_BUSY | MAC_CSR_CMD_R_NOT_W | reg); + while (reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) + ; + + return reg_read(MAC_CSR_DATA); +} + +static void smc911x_set_mac_csr(u8 reg, u32 data) +{ + while (reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) + ; + reg_write(MAC_CSR_DATA, data); + reg_write(MAC_CSR_CMD, MAC_CSR_CMD_CSR_BUSY | reg); + while (reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) + ; +} + +static bool smc911x_detect_chip(void) +{ + unsigned long val, i; + + val = reg_read(BYTE_TEST); + if (val != 0x87654321) { + printf(DRIVERNAME ": Invalid chip endian 0x%08lx\n", val); + return false; + } + + val = reg_read(ID_REV) >> 16; + for (i = 0; chip_ids[i].id != 0; i++) { + if (chip_ids[i].id == val) break; + } + if (!chip_ids[i].id) { + printf(DRIVERNAME ": Unknown chip ID %04lx\n", val); + return false; + } + + printf(DRIVERNAME ": detected %s controller\n", chip_ids[i].name); + + return true; +} + +static void smc911x_reset(void) +{ + int timeout; + + /* Take out of PM setting first */ + if (reg_read(PMT_CTRL) & PMT_CTRL_READY) { + /* Write to the bytetest will take out of powerdown */ + reg_write(BYTE_TEST, 0x0); + + timeout = 10; + + while (timeout-- && !(reg_read(PMT_CTRL) & PMT_CTRL_READY)) + udelay(10); + if (!timeout) { + printf(DRIVERNAME + ": timeout waiting for PM restore\n"); + return; + } + } + + /* Disable interrupts */ + reg_write(INT_EN, 0); + + reg_write(HW_CFG, HW_CFG_SRST); + + timeout = 1000; + while (timeout-- && reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY) + udelay(10); + + if (!timeout) { + printf(DRIVERNAME ": reset timeout\n"); + return; + } + + /* Reset the FIFO level and flow control settings */ + smc911x_set_mac_csr(FLOW, FLOW_FCPT | FLOW_FCEN); + reg_write(AFC_CFG, 0x0050287F); + + /* Set to LED outputs */ + reg_write(GPIO_CFG, 0x70070000); +} + +#endif
A forward port of the last version to work with the newer smc911x driver. I only have a board with a LAN9218 part on it, so that is the only one I've tested. But there isn't anything in this that would make it terribly chip specific afaik.
Signed-off-by: Mike Frysinger vapier@gentoo.org CC: Sascha Hauer s.hauer@pengutronix.de CC: Guennadi Liakhovetski lg@denx.de CC: Magnus Lilja lilja.magnus@gmail.com CC: Ben Warren biggerbadderben@gmail.com --- examples/.gitignore | 1 + examples/Makefile | 7 +- examples/smc911x_eeprom.c | 381 +++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 386 insertions(+), 3 deletions(-) create mode 100644 examples/smc911x_eeprom.c
diff --git a/examples/.gitignore b/examples/.gitignore index 806425f..0d1864c 100644 --- a/examples/.gitignore +++ b/examples/.gitignore @@ -6,5 +6,6 @@ /timer /sched /smc91111_eeprom +/smc911x_eeprom *.bin *.srec diff --git a/examples/Makefile b/examples/Makefile index b0a8853..962ca8a 100644 --- a/examples/Makefile +++ b/examples/Makefile @@ -101,9 +101,10 @@ BIN += sched.bin endif
ifeq ($(ARCH),blackfin) -ELF += smc91111_eeprom -SREC += smc91111_eeprom.srec -BIN += smc91111_eeprom.bin +BFIN_BIN = smc91111_eeprom smc911x_eeprom +ELF += $(BFIN_BIN) +SREC += $(addsuffix .srec,$(BFIN_BIN)) +BIN += $(addsuffix .bin,$(BFIN_BIN)) endif
# The following example is pretty 8xx specific... diff --git a/examples/smc911x_eeprom.c b/examples/smc911x_eeprom.c new file mode 100644 index 0000000..3dac4d3 --- /dev/null +++ b/examples/smc911x_eeprom.c @@ -0,0 +1,381 @@ +/* + * smc911x_eeprom.c - EEPROM interface to SMC911x parts. + * Only tested on SMSC9118 though ... + * + * Copyright 2004-2008 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + * + * Based on smc91111_eeprom.c which: + * Heavily borrowed from the following peoples GPL'ed software: + * - Wolfgang Denk, DENX Software Engineering, wd@denx.de + * Das U-boot + * - Ladislav Michl ladis@linux-mips.org + * A rejected patch on the U-Boot mailing list + */ + +#include <common.h> +#include <exports.h> + +#ifdef CONFIG_DRIVER_SMC911X + +#include "../drivers/net/smc911x.h" + +/** + * smsc_ctrlc - detect press of CTRL+C (common ctrlc() isnt exported!?) + */ +static int smsc_ctrlc(void) +{ + return (tstc() && getc() == 0x03); +} + +/** + * usage - dump usage information + */ +static void usage(void) +{ + puts( + "MAC/EEPROM Commands:\n" + " P : Print the MAC addresses\n" + " D : Dump the EEPROM contents\n" + " M : Dump the MAC contents\n" + " C : Copy the MAC address from the EEPROM to the MAC\n" + " W : Write a register in the EEPROM or in the MAC\n" + " Q : Quit\n" + "\n" + "Some commands take arguments:\n" + " W <E|M> <register> <value>\n" + " E: EEPROM M: MAC\n" + ); +} + +/** + * dump_regs - dump the MAC registers + * + * Registers 0x00 - 0x50 are FIFOs. The 0x50+ are the control registers + * and they're all 32bits long. 0xB8+ are reserved, so don't bother. + */ +static void dump_regs(void) +{ + u8 i, j = 0; + for (i = 0x50; i < 0xB8; i += sizeof(u32)) + printf("%02x: 0x%08x %c", i, reg_read(CONFIG_DRIVER_SMC911X_BASE + i), + (j++ % 2 ? '\n' : ' ')); +} + +/** + * do_eeprom_cmd - handle eeprom communication + */ +static int do_eeprom_cmd(int cmd, u8 reg) +{ + if (reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY) { + printf("eeprom_cmd: busy at start (E2P_CMD = 0x%08x)\n", + reg_read(E2P_CMD)); + return -1; + } + + reg_write(E2P_CMD, E2P_CMD_EPC_BUSY | cmd | reg); + + while (reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY) + if (smsc_ctrlc()) { + printf("eeprom_cmd: timeout (E2P_CMD = 0x%08x)\n", + reg_read(E2P_CMD)); + return -1; + } + + return 0; +} + +/** + * read_eeprom_reg - read specified register in EEPROM + */ +static u8 read_eeprom_reg(u8 reg) +{ + int ret = do_eeprom_cmd(E2P_CMD_EPC_CMD_READ, reg); + return (ret ? : reg_read(E2P_DATA)); +} + +/** + * write_eeprom_reg - write specified value into specified register in EEPROM + */ +static int write_eeprom_reg(u8 value, u8 reg) +{ + int ret; + + /* enable erasing/writing */ + ret = do_eeprom_cmd(E2P_CMD_EPC_CMD_EWEN, reg); + if (ret) + goto done; + + /* erase the eeprom reg */ + ret = do_eeprom_cmd(E2P_CMD_EPC_CMD_ERASE, reg); + if (ret) + goto done; + + /* write the eeprom reg */ + reg_write(E2P_DATA, value); + ret = do_eeprom_cmd(E2P_CMD_EPC_CMD_WRITE, reg); + if (ret) + goto done; + + /* disable erasing/writing */ + ret = do_eeprom_cmd(E2P_CMD_EPC_CMD_EWDS, reg); + + done: + return ret; +} + +/** + * skip_space - find first non-whitespace in given pointer + */ +static char *skip_space(char *buf) +{ + while (buf[0] == ' ' || buf[0] == '\t') + ++buf; + return buf; +} + +/** + * write_stuff - handle writing of MAC registers / eeprom + */ +static void write_stuff(char *line) +{ + char dest; + char *endp; + u8 reg; + u32 value; + + /* Skip over the "W " part of the command */ + line = skip_space(line + 1); + + /* Figure out destination */ + switch (line[0]) { + case 'E': + case 'M': + dest = line[0]; + break; + default: + invalid_usage: + printf("ERROR: Invalid write usage\n"); + usage(); + return; + } + + /* Get the register to write */ + line = skip_space(line + 1); + reg = simple_strtoul(line, &endp, 16); + if (line == endp) + goto invalid_usage; + + /* Get the value to write */ + line = skip_space(endp); + value = simple_strtoul(line, &endp, 16); + if (line == endp) + goto invalid_usage; + + /* Check for trailing cruft */ + line = skip_space(endp); + if (line[0]) + goto invalid_usage; + + /* Finally, execute the command */ + if (dest == 'E') { + printf("Writing EEPROM register %02x with %02x\n", reg, value); + write_eeprom_reg(value, reg); + } else { + printf("Writing MAC register %02x with %08x\n", reg, value); + reg_write(CONFIG_DRIVER_SMC911X_BASE + reg, value); + } +} + +/** + * copy_from_eeprom - copy MAC address in eeprom to address registers + */ +static void copy_from_eeprom(void) +{ + ulong addrl = + read_eeprom_reg(0x01) | + read_eeprom_reg(0x02) << 8 | + read_eeprom_reg(0x03) << 16 | + read_eeprom_reg(0x04) << 24; + ulong addrh = + read_eeprom_reg(0x05) | + read_eeprom_reg(0x06) << 8; + smc911x_set_mac_csr(ADDRL, addrl); + smc911x_set_mac_csr(ADDRH, addrh); + puts("EEPROM contents copied to MAC\n"); +} + +/** + * print_macaddr - print MAC address registers and MAC address in eeprom + */ +static void print_macaddr(void) +{ + puts("Current MAC Address in MAC: "); + ulong addrl = smc911x_get_mac_csr(ADDRL); + ulong addrh = smc911x_get_mac_csr(ADDRH); + printf("%02x:%02x:%02x:%02x:%02x:%02x\n", + (u8)(addrl), (u8)(addrl >> 8), (u8)(addrl >> 16), + (u8)(addrl >> 24), (u8)(addrh), (u8)(addrh >> 8)); + + puts("Current MAC Address in EEPROM: "); + int i; + for (i = 1; i < 6; ++i) + printf("%02x:", read_eeprom_reg(i)); + printf("%02x\n", read_eeprom_reg(i)); +} + +/** + * dump_eeprom - dump the whole content of the EEPROM + */ +static void dump_eeprom(void) +{ + int i; + puts("EEPROM:\n"); + for (i = 0; i < 7; ++i) + printf("%02x: 0x%02x\n", i, read_eeprom_reg(i)); +} + +/** + * smc911x_init - get the MAC/EEPROM up and ready for use + */ +static int smc911x_init(void) +{ + /* See if there is anything there */ + if (!smc911x_detect_chip()) + return 1; + + smc911x_reset(); + + /* Make sure we set EEDIO/EECLK to the EEPROM */ + if (reg_read(GPIO_CFG) & GPIO_CFG_EEPR_EN) { + while (reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY) + if (smsc_ctrlc()) { + printf("init: timeout (E2P_CMD = 0x%08x)\n", reg_read(E2P_CMD)); + return 1; + } + reg_write(GPIO_CFG, reg_read(GPIO_CFG) & ~GPIO_CFG_EEPR_EN); + } + + return 0; +} + +/** + * getline - consume a line of input and handle some escape sequences + */ +static char *getline(void) +{ + static char buffer[100]; + char c; + size_t i; + + i = 0; + while (1) { + buffer[i] = '\0'; + while (!tstc()) + continue; + + c = getc(); + /* Convert to uppercase */ + if (c >= 'a' && c <= 'z') + c -= ('a' - 'A'); + + switch (c) { + case '\r': /* Enter/Return key */ + case '\n': + puts("\n"); + return buffer; + + case 0x03: /* ^C - break */ + return NULL; + + case 0x5F: + case 0x08: /* ^H - backspace */ + case 0x7F: /* DEL - backspace */ + if (i) { + puts("\b \b"); + i--; + } + break; + + default: + /* Ignore control characters */ + if (c < 0x20) + break; + /* Queue up all other characters */ + buffer[i++] = c; + printf("%c", c); + break; + } + } +} + +/** + * smc911x_eeprom - our application's main() function + */ +int smc911x_eeprom(int argc, char *argv[]) +{ + /* Print the ABI version */ + app_startup(argv); + if (XF_VERSION != get_version()) { + printf("Expects ABI version %d\n", XF_VERSION); + printf("Actual U-Boot ABI version %lu\n", get_version()); + printf("Can't run\n\n"); + return 1; + } + + /* Initialize the MAC/EEPROM somewhat */ + puts("\n"); + if (smc911x_init()) + return 1; + + /* Dump helpful usage information */ + puts("\n"); + usage(); + puts("\n"); + + while (1) { + char *line; + + /* Send the prompt and wait for a line */ + puts("eeprom> "); + line = getline(); + + /* Got a ctrl+c */ + if (!line) + return 0; + + /* Eat leading space */ + line = skip_space(line); + + /* Empty line, try again */ + if (!line[0]) + continue; + + /* Only accept 1 letter commands */ + if (line[0] && line[1] && line[1] != ' ' && line[1] != '\t') + goto unknown_cmd; + + /* Now parse the command */ + switch (line[0]) { + case 'W': write_stuff(line); break; + case 'D': dump_eeprom(); break; + case 'M': dump_regs(); break; + case 'C': copy_from_eeprom(); break; + case 'P': print_macaddr(); break; + unknown_cmd: + default: puts("ERROR: Unknown command!\n\n"); + case '?': + case 'H': usage(); break; + case 'Q': return 0; + } + } +} + +#else +int smc911x_eeprom(int argc, char *argv[]) +{ + puts("Not supported for this board\n"); + return 1; +} +#endif
Hi
2008/12/22 Mike Frysinger vapier@gentoo.org:
smc911x_eeprom.c can atleast also read from the LAN9217 device on the i.MX31 PDK board. Haven't tried modifiying the MAC address though.
Regards, Magnus
Hi
I forgot to include some comments on the code, sorry about the noise.
examples/.gitignore | 1 + examples/Makefile | 7 +- examples/smc911x_eeprom.c | 381 +++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 386 insertions(+), 3 deletions(-) diff --git a/examples/smc911x_eeprom.c b/examples/smc911x_eeprom.c new file mode 100644 index 0000000..3dac4d3 --- /dev/null +++ b/examples/smc911x_eeprom.c
int i;
The above function declares new variables in the middle of the code. Is this OK w.r.t. the coding standard? I haven't seen such code in U-boot (or Linux) before.
/Magnus
Dear Ben,
In message 1229932567-10682-2-git-send-email-vapier@gentoo.org Mike Frysinger wrote:
What's the state of this patch?
Hi
<snip>
- SMSC LAN9[12]1[567] Network driver
- (c) 2007 Pengutronix, Sascha Hauer s.hauer@pengutronix.de
- project.
- MA 02111-1307 USA
I had to add an #include <stdbool.h> when cross-compiling to an ARM target using GCC 4.1.2, otherwise I get compilation error further down in the file (static bool smc911x_detect_chip(void)).
Regards, Magnus
Signed-off-by: Mike Frysinger vapier@gentoo.org CC: Sascha Hauer s.hauer@pengutronix.de CC: Guennadi Liakhovetski lg@denx.de CC: Magnus Lilja lilja.magnus@gmail.com CC: Ben Warren biggerbadderben@gmail.com --- v2 - add includes for types utilized in smc911x.h
drivers/net/smc911x.c | 452 +--------------------------------------------- drivers/net/smc911x.h | 489 +++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 491 insertions(+), 450 deletions(-) create mode 100644 drivers/net/smc911x.h
smc911x_reset();
diff --git a/drivers/net/smc911x.h b/drivers/net/smc911x.h new file mode 100644 index 0000000..1c6794f --- /dev/null +++ b/drivers/net/smc911x.h @@ -0,0 +1,489 @@ +/* + * SMSC LAN9[12]1[567] Network driver + * + * (c) 2007 Pengutronix, Sascha Hauer s.hauer@pengutronix.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _SMC911X_H_ +#define _SMC911X_H_ + +#include <linux/types.h> +#include <stdbool.h> + +#if defined (CONFIG_DRIVER_SMC911X_32_BIT) && \ + defined (CONFIG_DRIVER_SMC911X_16_BIT) +#error "SMC911X: Only one of CONFIG_DRIVER_SMC911X_32_BIT and \ + CONFIG_DRIVER_SMC911X_16_BIT shall be set" +#endif + +#if defined (CONFIG_DRIVER_SMC911X_32_BIT) +static inline u32 reg_read(u32 addr) +{ + return *(volatile u32*)addr; +} +static inline void reg_write(u32 addr, u32 val) +{ + *(volatile u32*)addr = val; +} +#elif defined (CONFIG_DRIVER_SMC911X_16_BIT) +static inline u32 reg_read(u32 addr) +{ + volatile u16 *addr_16 = (u16 *)addr; + return ((*addr_16 & 0x0000ffff) | (*(addr_16 + 1) << 16)); +} +static inline void reg_write(u32 addr, u32 val) +{ + *(volatile u16*)addr = (u16)val; + *(volatile u16*)(addr + 2) = (u16)(val >> 16); +} +#else +#error "SMC911X: undefined bus width" +#endif /* CONFIG_DRIVER_SMC911X_16_BIT */ + +/* Below are the register offsets and bit definitions + * of the Lan911x memory space + */ +#define RX_DATA_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x00) + +#define TX_DATA_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x20) +#define TX_CMD_A_INT_ON_COMP 0x80000000 +#define TX_CMD_A_INT_BUF_END_ALGN 0x03000000 +#define TX_CMD_A_INT_4_BYTE_ALGN 0x00000000 +#define TX_CMD_A_INT_16_BYTE_ALGN 0x01000000 +#define TX_CMD_A_INT_32_BYTE_ALGN 0x02000000 +#define TX_CMD_A_INT_DATA_OFFSET 0x001F0000 +#define TX_CMD_A_INT_FIRST_SEG 0x00002000 +#define TX_CMD_A_INT_LAST_SEG 0x00001000 +#define TX_CMD_A_BUF_SIZE 0x000007FF +#define TX_CMD_B_PKT_TAG 0xFFFF0000 +#define TX_CMD_B_ADD_CRC_DISABLE 0x00002000 +#define TX_CMD_B_DISABLE_PADDING 0x00001000 +#define TX_CMD_B_PKT_BYTE_LENGTH 0x000007FF + +#define RX_STATUS_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x40) +#define RX_STS_PKT_LEN 0x3FFF0000 +#define RX_STS_ES 0x00008000 +#define RX_STS_BCST 0x00002000 +#define RX_STS_LEN_ERR 0x00001000 +#define RX_STS_RUNT_ERR 0x00000800 +#define RX_STS_MCAST 0x00000400 +#define RX_STS_TOO_LONG 0x00000080 +#define RX_STS_COLL 0x00000040 +#define RX_STS_ETH_TYPE 0x00000020 +#define RX_STS_WDOG_TMT 0x00000010 +#define RX_STS_MII_ERR 0x00000008 +#define RX_STS_DRIBBLING 0x00000004 +#define RX_STS_CRC_ERR 0x00000002 +#define RX_STATUS_FIFO_PEEK (CONFIG_DRIVER_SMC911X_BASE + 0x44) +#define TX_STATUS_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x48) +#define TX_STS_TAG 0xFFFF0000 +#define TX_STS_ES 0x00008000 +#define TX_STS_LOC 0x00000800 +#define TX_STS_NO_CARR 0x00000400 +#define TX_STS_LATE_COLL 0x00000200 +#define TX_STS_MANY_COLL 0x00000100 +#define TX_STS_COLL_CNT 0x00000078 +#define TX_STS_MANY_DEFER 0x00000004 +#define TX_STS_UNDERRUN 0x00000002 +#define TX_STS_DEFERRED 0x00000001 +#define TX_STATUS_FIFO_PEEK (CONFIG_DRIVER_SMC911X_BASE + 0x4C) +#define ID_REV (CONFIG_DRIVER_SMC911X_BASE + 0x50) +#define ID_REV_CHIP_ID 0xFFFF0000 /* RO */ +#define ID_REV_REV_ID 0x0000FFFF /* RO */ + +#define INT_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x54) +#define INT_CFG_INT_DEAS 0xFF000000 /* R/W */ +#define INT_CFG_INT_DEAS_CLR 0x00004000 +#define INT_CFG_INT_DEAS_STS 0x00002000 +#define INT_CFG_IRQ_INT 0x00001000 /* RO */ +#define INT_CFG_IRQ_EN 0x00000100 /* R/W */ +#define INT_CFG_IRQ_POL 0x00000010 /* R/W Not Affected by SW Reset */ +#define INT_CFG_IRQ_TYPE 0x00000001 /* R/W Not Affected by SW Reset */ + +#define INT_STS (CONFIG_DRIVER_SMC911X_BASE + 0x58) +#define INT_STS_SW_INT 0x80000000 /* R/WC */ +#define INT_STS_TXSTOP_INT 0x02000000 /* R/WC */ +#define INT_STS_RXSTOP_INT 0x01000000 /* R/WC */ +#define INT_STS_RXDFH_INT 0x00800000 /* R/WC */ +#define INT_STS_RXDF_INT 0x00400000 /* R/WC */ +#define INT_STS_TX_IOC 0x00200000 /* R/WC */ +#define INT_STS_RXD_INT 0x00100000 /* R/WC */ +#define INT_STS_GPT_INT 0x00080000 /* R/WC */ +#define INT_STS_PHY_INT 0x00040000 /* RO */ +#define INT_STS_PME_INT 0x00020000 /* R/WC */ +#define INT_STS_TXSO 0x00010000 /* R/WC */ +#define INT_STS_RWT 0x00008000 /* R/WC */ +#define INT_STS_RXE 0x00004000 /* R/WC */ +#define INT_STS_TXE 0x00002000 /* R/WC */ +/*#define INT_STS_ERX 0x00001000*/ /* R/WC */ +#define INT_STS_TDFU 0x00000800 /* R/WC */ +#define INT_STS_TDFO 0x00000400 /* R/WC */ +#define INT_STS_TDFA 0x00000200 /* R/WC */ +#define INT_STS_TSFF 0x00000100 /* R/WC */ +#define INT_STS_TSFL 0x00000080 /* R/WC */ +/*#define INT_STS_RXDF 0x00000040*/ /* R/WC */ +#define INT_STS_RDFO 0x00000040 /* R/WC */ +#define INT_STS_RDFL 0x00000020 /* R/WC */ +#define INT_STS_RSFF 0x00000010 /* R/WC */ +#define INT_STS_RSFL 0x00000008 /* R/WC */ +#define INT_STS_GPIO2_INT 0x00000004 /* R/WC */ +#define INT_STS_GPIO1_INT 0x00000002 /* R/WC */ +#define INT_STS_GPIO0_INT 0x00000001 /* R/WC */ +#define INT_EN (CONFIG_DRIVER_SMC911X_BASE + 0x5C) +#define INT_EN_SW_INT_EN 0x80000000 /* R/W */ +#define INT_EN_TXSTOP_INT_EN 0x02000000 /* R/W */ +#define INT_EN_RXSTOP_INT_EN 0x01000000 /* R/W */ +#define INT_EN_RXDFH_INT_EN 0x00800000 /* R/W */ +/*#define INT_EN_RXDF_INT_EN 0x00400000*/ /* R/W */ +#define INT_EN_TIOC_INT_EN 0x00200000 /* R/W */ +#define INT_EN_RXD_INT_EN 0x00100000 /* R/W */ +#define INT_EN_GPT_INT_EN 0x00080000 /* R/W */ +#define INT_EN_PHY_INT_EN 0x00040000 /* R/W */ +#define INT_EN_PME_INT_EN 0x00020000 /* R/W */ +#define INT_EN_TXSO_EN 0x00010000 /* R/W */ +#define INT_EN_RWT_EN 0x00008000 /* R/W */ +#define INT_EN_RXE_EN 0x00004000 /* R/W */ +#define INT_EN_TXE_EN 0x00002000 /* R/W */ +/*#define INT_EN_ERX_EN 0x00001000*/ /* R/W */ +#define INT_EN_TDFU_EN 0x00000800 /* R/W */ +#define INT_EN_TDFO_EN 0x00000400 /* R/W */ +#define INT_EN_TDFA_EN 0x00000200 /* R/W */ +#define INT_EN_TSFF_EN 0x00000100 /* R/W */ +#define INT_EN_TSFL_EN 0x00000080 /* R/W */ +/*#define INT_EN_RXDF_EN 0x00000040*/ /* R/W */ +#define INT_EN_RDFO_EN 0x00000040 /* R/W */ +#define INT_EN_RDFL_EN 0x00000020 /* R/W */ +#define INT_EN_RSFF_EN 0x00000010 /* R/W */ +#define INT_EN_RSFL_EN 0x00000008 /* R/W */ +#define INT_EN_GPIO2_INT 0x00000004 /* R/W */ +#define INT_EN_GPIO1_INT 0x00000002 /* R/W */ +#define INT_EN_GPIO0_INT 0x00000001 /* R/W */ + +#define BYTE_TEST (CONFIG_DRIVER_SMC911X_BASE + 0x64) +#define FIFO_INT (CONFIG_DRIVER_SMC911X_BASE + 0x68) +#define FIFO_INT_TX_AVAIL_LEVEL 0xFF000000 /* R/W */ +#define FIFO_INT_TX_STS_LEVEL 0x00FF0000 /* R/W */ +#define FIFO_INT_RX_AVAIL_LEVEL 0x0000FF00 /* R/W */ +#define FIFO_INT_RX_STS_LEVEL 0x000000FF /* R/W */ + +#define RX_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x6C) +#define RX_CFG_RX_END_ALGN 0xC0000000 /* R/W */ +#define RX_CFG_RX_END_ALGN4 0x00000000 /* R/W */ +#define RX_CFG_RX_END_ALGN16 0x40000000 /* R/W */ +#define RX_CFG_RX_END_ALGN32 0x80000000 /* R/W */ +#define RX_CFG_RX_DMA_CNT 0x0FFF0000 /* R/W */ +#define RX_CFG_RX_DUMP 0x00008000 /* R/W */ +#define RX_CFG_RXDOFF 0x00001F00 /* R/W */ +/*#define RX_CFG_RXBAD 0x00000001*/ /* R/W */ + +#define TX_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x70) +/*#define TX_CFG_TX_DMA_LVL 0xE0000000*/ /* R/W */ +/*#define TX_CFG_TX_DMA_CNT 0x0FFF0000*/ /* R/W Self Clearing */ +#define TX_CFG_TXS_DUMP 0x00008000 /* Self Clearing */ +#define TX_CFG_TXD_DUMP 0x00004000 /* Self Clearing */ +#define TX_CFG_TXSAO 0x00000004 /* R/W */ +#define TX_CFG_TX_ON 0x00000002 /* R/W */ +#define TX_CFG_STOP_TX 0x00000001 /* Self Clearing */ + +#define HW_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x74) +#define HW_CFG_TTM 0x00200000 /* R/W */ +#define HW_CFG_SF 0x00100000 /* R/W */ +#define HW_CFG_TX_FIF_SZ 0x000F0000 /* R/W */ +#define HW_CFG_TR 0x00003000 /* R/W */ +#define HW_CFG_PHY_CLK_SEL 0x00000060 /* R/W */ +#define HW_CFG_PHY_CLK_SEL_INT_PHY 0x00000000 /* R/W */ +#define HW_CFG_PHY_CLK_SEL_EXT_PHY 0x00000020 /* R/W */ +#define HW_CFG_PHY_CLK_SEL_CLK_DIS 0x00000040 /* R/W */ +#define HW_CFG_SMI_SEL 0x00000010 /* R/W */ +#define HW_CFG_EXT_PHY_DET 0x00000008 /* RO */ +#define HW_CFG_EXT_PHY_EN 0x00000004 /* R/W */ +#define HW_CFG_32_16_BIT_MODE 0x00000004 /* RO */ +#define HW_CFG_SRST_TO 0x00000002 /* RO */ +#define HW_CFG_SRST 0x00000001 /* Self Clearing */ + +#define RX_DP_CTRL (CONFIG_DRIVER_SMC911X_BASE + 0x78) +#define RX_DP_CTRL_RX_FFWD 0x80000000 /* R/W */ +#define RX_DP_CTRL_FFWD_BUSY 0x80000000 /* RO */ + +#define RX_FIFO_INF (CONFIG_DRIVER_SMC911X_BASE + 0x7C) +#define RX_FIFO_INF_RXSUSED 0x00FF0000 /* RO */ +#define RX_FIFO_INF_RXDUSED 0x0000FFFF /* RO */ + +#define TX_FIFO_INF (CONFIG_DRIVER_SMC911X_BASE + 0x80) +#define TX_FIFO_INF_TSUSED 0x00FF0000 /* RO */ +#define TX_FIFO_INF_TDFREE 0x0000FFFF /* RO */ + +#define PMT_CTRL (CONFIG_DRIVER_SMC911X_BASE + 0x84) +#define PMT_CTRL_PM_MODE 0x00003000 /* Self Clearing */ +#define PMT_CTRL_PHY_RST 0x00000400 /* Self Clearing */ +#define PMT_CTRL_WOL_EN 0x00000200 /* R/W */ +#define PMT_CTRL_ED_EN 0x00000100 /* R/W */ +#define PMT_CTRL_PME_TYPE 0x00000040 /* R/W Not Affected by SW Reset */ +#define PMT_CTRL_WUPS 0x00000030 /* R/WC */ +#define PMT_CTRL_WUPS_NOWAKE 0x00000000 /* R/WC */ +#define PMT_CTRL_WUPS_ED 0x00000010 /* R/WC */ +#define PMT_CTRL_WUPS_WOL 0x00000020 /* R/WC */ +#define PMT_CTRL_WUPS_MULTI 0x00000030 /* R/WC */ +#define PMT_CTRL_PME_IND 0x00000008 /* R/W */ +#define PMT_CTRL_PME_POL 0x00000004 /* R/W */ +#define PMT_CTRL_PME_EN 0x00000002 /* R/W Not Affected by SW Reset */ +#define PMT_CTRL_READY 0x00000001 /* RO */ + +#define GPIO_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x88) +#define GPIO_CFG_LED3_EN 0x40000000 /* R/W */ +#define GPIO_CFG_LED2_EN 0x20000000 /* R/W */ +#define GPIO_CFG_LED1_EN 0x10000000 /* R/W */ +#define GPIO_CFG_GPIO2_INT_POL 0x04000000 /* R/W */ +#define GPIO_CFG_GPIO1_INT_POL 0x02000000 /* R/W */ +#define GPIO_CFG_GPIO0_INT_POL 0x01000000 /* R/W */ +#define GPIO_CFG_EEPR_EN 0x00700000 /* R/W */ +#define GPIO_CFG_GPIOBUF2 0x00040000 /* R/W */ +#define GPIO_CFG_GPIOBUF1 0x00020000 /* R/W */ +#define GPIO_CFG_GPIOBUF0 0x00010000 /* R/W */ +#define GPIO_CFG_GPIODIR2 0x00000400 /* R/W */ +#define GPIO_CFG_GPIODIR1 0x00000200 /* R/W */ +#define GPIO_CFG_GPIODIR0 0x00000100 /* R/W */ +#define GPIO_CFG_GPIOD4 0x00000010 /* R/W */ +#define GPIO_CFG_GPIOD3 0x00000008 /* R/W */ +#define GPIO_CFG_GPIOD2 0x00000004 /* R/W */ +#define GPIO_CFG_GPIOD1 0x00000002 /* R/W */ +#define GPIO_CFG_GPIOD0 0x00000001 /* R/W */ + +#define GPT_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x8C) +#define GPT_CFG_TIMER_EN 0x20000000 /* R/W */ +#define GPT_CFG_GPT_LOAD 0x0000FFFF /* R/W */ + +#define GPT_CNT (CONFIG_DRIVER_SMC911X_BASE + 0x90) +#define GPT_CNT_GPT_CNT 0x0000FFFF /* RO */ + +#define ENDIAN (CONFIG_DRIVER_SMC911X_BASE + 0x98) +#define FREE_RUN (CONFIG_DRIVER_SMC911X_BASE + 0x9C) +#define RX_DROP (CONFIG_DRIVER_SMC911X_BASE + 0xA0) +#define MAC_CSR_CMD (CONFIG_DRIVER_SMC911X_BASE + 0xA4) +#define MAC_CSR_CMD_CSR_BUSY 0x80000000 /* Self Clearing */ +#define MAC_CSR_CMD_R_NOT_W 0x40000000 /* R/W */ +#define MAC_CSR_CMD_CSR_ADDR 0x000000FF /* R/W */ + +#define MAC_CSR_DATA (CONFIG_DRIVER_SMC911X_BASE + 0xA8) +#define AFC_CFG (CONFIG_DRIVER_SMC911X_BASE + 0xAC) +#define AFC_CFG_AFC_HI 0x00FF0000 /* R/W */ +#define AFC_CFG_AFC_LO 0x0000FF00 /* R/W */ +#define AFC_CFG_BACK_DUR 0x000000F0 /* R/W */ +#define AFC_CFG_FCMULT 0x00000008 /* R/W */ +#define AFC_CFG_FCBRD 0x00000004 /* R/W */ +#define AFC_CFG_FCADD 0x00000002 /* R/W */ +#define AFC_CFG_FCANY 0x00000001 /* R/W */ + +#define E2P_CMD (CONFIG_DRIVER_SMC911X_BASE + 0xB0) +#define E2P_CMD_EPC_BUSY 0x80000000 /* Self Clearing */ +#define E2P_CMD_EPC_CMD 0x70000000 /* R/W */ +#define E2P_CMD_EPC_CMD_READ 0x00000000 /* R/W */ +#define E2P_CMD_EPC_CMD_EWDS 0x10000000 /* R/W */ +#define E2P_CMD_EPC_CMD_EWEN 0x20000000 /* R/W */ +#define E2P_CMD_EPC_CMD_WRITE 0x30000000 /* R/W */ +#define E2P_CMD_EPC_CMD_WRAL 0x40000000 /* R/W */ +#define E2P_CMD_EPC_CMD_ERASE 0x50000000 /* R/W */ +#define E2P_CMD_EPC_CMD_ERAL 0x60000000 /* R/W */ +#define E2P_CMD_EPC_CMD_RELOAD 0x70000000 /* R/W */ +#define E2P_CMD_EPC_TIMEOUT 0x00000200 /* RO */ +#define E2P_CMD_MAC_ADDR_LOADED 0x00000100 /* RO */ +#define E2P_CMD_EPC_ADDR 0x000000FF /* R/W */ + +#define E2P_DATA (CONFIG_DRIVER_SMC911X_BASE + 0xB4) +#define E2P_DATA_EEPROM_DATA 0x000000FF /* R/W */ +/* end of LAN register offsets and bit definitions */ + +/* MAC Control and Status registers */ +#define MAC_CR 0x01 /* R/W */ + +/* MAC_CR - MAC Control Register */ +#define MAC_CR_RXALL 0x80000000 +/* TODO: delete this bit? It is not described in the data sheet. */ +#define MAC_CR_HBDIS 0x10000000 +#define MAC_CR_RCVOWN 0x00800000 +#define MAC_CR_LOOPBK 0x00200000 +#define MAC_CR_FDPX 0x00100000 +#define MAC_CR_MCPAS 0x00080000 +#define MAC_CR_PRMS 0x00040000 +#define MAC_CR_INVFILT 0x00020000 +#define MAC_CR_PASSBAD 0x00010000 +#define MAC_CR_HFILT 0x00008000 +#define MAC_CR_HPFILT 0x00002000 +#define MAC_CR_LCOLL 0x00001000 +#define MAC_CR_BCAST 0x00000800 +#define MAC_CR_DISRTY 0x00000400 +#define MAC_CR_PADSTR 0x00000100 +#define MAC_CR_BOLMT_MASK 0x000000C0 +#define MAC_CR_DFCHK 0x00000020 +#define MAC_CR_TXEN 0x00000008 +#define MAC_CR_RXEN 0x00000004 + +#define ADDRH 0x02 /* R/W mask 0x0000FFFFUL */ +#define ADDRL 0x03 /* R/W mask 0xFFFFFFFFUL */ +#define HASHH 0x04 /* R/W */ +#define HASHL 0x05 /* R/W */ + +#define MII_ACC 0x06 /* R/W */ +#define MII_ACC_PHY_ADDR 0x0000F800 +#define MII_ACC_MIIRINDA 0x000007C0 +#define MII_ACC_MII_WRITE 0x00000002 +#define MII_ACC_MII_BUSY 0x00000001 + +#define MII_DATA 0x07 /* R/W mask 0x0000FFFFUL */ + +#define FLOW 0x08 /* R/W */ +#define FLOW_FCPT 0xFFFF0000 +#define FLOW_FCPASS 0x00000004 +#define FLOW_FCEN 0x00000002 +#define FLOW_FCBSY 0x00000001 + +#define VLAN1 0x09 /* R/W mask 0x0000FFFFUL */ +#define VLAN1_VTI1 0x0000ffff + +#define VLAN2 0x0A /* R/W mask 0x0000FFFFUL */ +#define VLAN2_VTI2 0x0000ffff + +#define WUFF 0x0B /* WO */ + +#define WUCSR 0x0C /* R/W */ +#define WUCSR_GUE 0x00000200 +#define WUCSR_WUFR 0x00000040 +#define WUCSR_MPR 0x00000020 +#define WUCSR_WAKE_EN 0x00000004 +#define WUCSR_MPEN 0x00000002 + +/* Chip ID values */ +#define CHIP_9115 0x115 +#define CHIP_9116 0x116 +#define CHIP_9117 0x117 +#define CHIP_9118 0x118 +#define CHIP_9215 0x115a +#define CHIP_9216 0x116a +#define CHIP_9217 0x117a +#define CHIP_9218 0x118a + +struct chip_id { + u16 id; + char *name; +}; + +static const struct chip_id chip_ids[] = { + { CHIP_9115, "LAN9115" }, + { CHIP_9116, "LAN9116" }, + { CHIP_9117, "LAN9117" }, + { CHIP_9118, "LAN9118" }, + { CHIP_9215, "LAN9215" }, + { CHIP_9216, "LAN9216" }, + { CHIP_9217, "LAN9217" }, + { CHIP_9218, "LAN9218" }, + { 0, NULL }, +}; + +#define DRIVERNAME "smc911x" + +static u32 smc911x_get_mac_csr(u8 reg) +{ + while (reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) + ; + reg_write(MAC_CSR_CMD, MAC_CSR_CMD_CSR_BUSY | MAC_CSR_CMD_R_NOT_W | reg); + while (reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) + ; + + return reg_read(MAC_CSR_DATA); +} + +static void smc911x_set_mac_csr(u8 reg, u32 data) +{ + while (reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) + ; + reg_write(MAC_CSR_DATA, data); + reg_write(MAC_CSR_CMD, MAC_CSR_CMD_CSR_BUSY | reg); + while (reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) + ; +} + +static bool smc911x_detect_chip(void) +{ + unsigned long val, i; + + val = reg_read(BYTE_TEST); + if (val != 0x87654321) { + printf(DRIVERNAME ": Invalid chip endian 0x%08lx\n", val); + return false; + } + + val = reg_read(ID_REV) >> 16; + for (i = 0; chip_ids[i].id != 0; i++) { + if (chip_ids[i].id == val) break; + } + if (!chip_ids[i].id) { + printf(DRIVERNAME ": Unknown chip ID %04lx\n", val); + return false; + } + + printf(DRIVERNAME ": detected %s controller\n", chip_ids[i].name); + + return true; +} + +static void smc911x_reset(void) +{ + int timeout; + + /* Take out of PM setting first */ + if (reg_read(PMT_CTRL) & PMT_CTRL_READY) { + /* Write to the bytetest will take out of powerdown */ + reg_write(BYTE_TEST, 0x0); + + timeout = 10; + + while (timeout-- && !(reg_read(PMT_CTRL) & PMT_CTRL_READY)) + udelay(10); + if (!timeout) { + printf(DRIVERNAME + ": timeout waiting for PM restore\n"); + return; + } + } + + /* Disable interrupts */ + reg_write(INT_EN, 0); + + reg_write(HW_CFG, HW_CFG_SRST); + + timeout = 1000; + while (timeout-- && reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY) + udelay(10); + + if (!timeout) { + printf(DRIVERNAME ": reset timeout\n"); + return; + } + + /* Reset the FIFO level and flow control settings */ + smc911x_set_mac_csr(FLOW, FLOW_FCPT | FLOW_FCEN); + reg_write(AFC_CFG, 0x0050287F); + + /* Set to LED outputs */ + reg_write(GPIO_CFG, 0x70070000); +} + +#endif
Dear Ben,
In message 1231259684-22134-1-git-send-email-vapier@gentoo.org Mike Frysinger wrote:
The smc911x driver has a lot of useful defines/functions which can be used by pieces of code (such as example eeprom programmers). Rather than forcing each place to duplicate these defines/functions, split them out of the smdc911x driver into a local header.
v2
What happened to that patch?
Hi Mike,
Sorry I didn't address this earlier.
v2
diff --git a/drivers/net/smc911x.c b/drivers/net/smc911x.c index 648c94c..192bd96 100644 --- a/drivers/net/smc911x.c +++ b/drivers/net/smc911x.c @@ -27,35 +27,7 @@ #include <net.h> #include <miiphy.h>
-#if defined (CONFIG_DRIVER_SMC911X_32_BIT) && \
- defined (CONFIG_DRIVER_SMC911X_16_BIT)
-#error "SMC911X: Only one of CONFIG_DRIVER_SMC911X_32_BIT and \
- CONFIG_DRIVER_SMC911X_16_BIT shall be set"
-#endif
-#if defined (CONFIG_DRIVER_SMC911X_32_BIT) -static inline u32 reg_read(u32 addr) -{
- return *(volatile u32*)addr;
-} -static inline void reg_write(u32 addr, u32 val) -{
- *(volatile u32*)addr = val;
-} -#elif defined (CONFIG_DRIVER_SMC911X_16_BIT) -static inline u32 reg_read(u32 addr) -{
- volatile u16 *addr_16 = (u16 *)addr;
- return ((*addr_16 & 0x0000ffff) | (*(addr_16 + 1) << 16));
- *(volatile u16*)addr = (u16)val;
- *(volatile u16*)(addr + 2) = (u16)(val >> 16);
-} -#else -#error "SMC911X: undefined bus width" -#endif /* CONFIG_DRIVER_SMC911X_16_BIT */ +#include "smc911x.h"
This hunk doesn't apply any more. Commit 890a02e8ee6b8c26a6e3e505e1a2d29cd73aa6f6 in late November changed several of these functions to weak.
<snip>
regards, Ben
Signed-off-by: Mike Frysinger vapier@gentoo.org CC: Sascha Hauer s.hauer@pengutronix.de CC: Guennadi Liakhovetski lg@denx.de CC: Magnus Lilja lilja.magnus@gmail.com CC: Ben Warren biggerbadderben@gmail.com --- v3 - rebased against master
this applies against master and next of u-boot.git
drivers/net/smc911x.c | 457 +--------------------------------------------- drivers/net/smc911x.h | 494 +++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 496 insertions(+), 455 deletions(-) create mode 100644 drivers/net/smc911x.h
diff --git a/drivers/net/smc911x.c b/drivers/net/smc911x.c index 9cc4fce..1ded8f0 100644 --- a/drivers/net/smc911x.c +++ b/drivers/net/smc911x.c @@ -27,38 +27,7 @@ #include <net.h> #include <miiphy.h>
-#if defined (CONFIG_DRIVER_SMC911X_32_BIT) && \ - defined (CONFIG_DRIVER_SMC911X_16_BIT) -#error "SMC911X: Only one of CONFIG_DRIVER_SMC911X_32_BIT and \ - CONFIG_DRIVER_SMC911X_16_BIT shall be set" -#endif - -#if defined (CONFIG_DRIVER_SMC911X_32_BIT) -static inline u32 __smc911x_reg_read(u32 addr) -{ - return *(volatile u32*)addr; -} -u32 smc911x_reg_read(u32 addr) __attribute__((weak, alias("__smc911x_reg_read"))); - -static inline void __smc911x_reg_write(u32 addr, u32 val) -{ - *(volatile u32*)addr = val; -} -void smc911x_reg_write(u32 addr, u32 val) __attribute__((weak, alias("__smc911x_reg_write"))); -#elif defined (CONFIG_DRIVER_SMC911X_16_BIT) -static inline u32 smc911x_reg_read(u32 addr) -{ - volatile u16 *addr_16 = (u16 *)addr; - return ((*addr_16 & 0x0000ffff) | (*(addr_16 + 1) << 16)); -} -static inline void smc911x_reg_write(u32 addr, u32 val) -{ - *(volatile u16*)addr = (u16)val; - *(volatile u16*)(addr + 2) = (u16)(val >> 16); -} -#else -#error "SMC911X: undefined bus width" -#endif /* CONFIG_DRIVER_SMC911X_16_BIT */ +#include "smc911x.h"
u32 pkt_data_pull(u32 addr) \ __attribute__ ((weak, alias ("smc911x_reg_read"))); @@ -67,370 +36,6 @@ void pkt_data_push(u32 addr, u32 val) \
#define mdelay(n) udelay((n)*1000)
-/* Below are the register offsets and bit definitions - * of the Lan911x memory space - */ -#define RX_DATA_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x00) - -#define TX_DATA_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x20) -#define TX_CMD_A_INT_ON_COMP 0x80000000 -#define TX_CMD_A_INT_BUF_END_ALGN 0x03000000 -#define TX_CMD_A_INT_4_BYTE_ALGN 0x00000000 -#define TX_CMD_A_INT_16_BYTE_ALGN 0x01000000 -#define TX_CMD_A_INT_32_BYTE_ALGN 0x02000000 -#define TX_CMD_A_INT_DATA_OFFSET 0x001F0000 -#define TX_CMD_A_INT_FIRST_SEG 0x00002000 -#define TX_CMD_A_INT_LAST_SEG 0x00001000 -#define TX_CMD_A_BUF_SIZE 0x000007FF -#define TX_CMD_B_PKT_TAG 0xFFFF0000 -#define TX_CMD_B_ADD_CRC_DISABLE 0x00002000 -#define TX_CMD_B_DISABLE_PADDING 0x00001000 -#define TX_CMD_B_PKT_BYTE_LENGTH 0x000007FF - -#define RX_STATUS_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x40) -#define RX_STS_PKT_LEN 0x3FFF0000 -#define RX_STS_ES 0x00008000 -#define RX_STS_BCST 0x00002000 -#define RX_STS_LEN_ERR 0x00001000 -#define RX_STS_RUNT_ERR 0x00000800 -#define RX_STS_MCAST 0x00000400 -#define RX_STS_TOO_LONG 0x00000080 -#define RX_STS_COLL 0x00000040 -#define RX_STS_ETH_TYPE 0x00000020 -#define RX_STS_WDOG_TMT 0x00000010 -#define RX_STS_MII_ERR 0x00000008 -#define RX_STS_DRIBBLING 0x00000004 -#define RX_STS_CRC_ERR 0x00000002 -#define RX_STATUS_FIFO_PEEK (CONFIG_DRIVER_SMC911X_BASE + 0x44) -#define TX_STATUS_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x48) -#define TX_STS_TAG 0xFFFF0000 -#define TX_STS_ES 0x00008000 -#define TX_STS_LOC 0x00000800 -#define TX_STS_NO_CARR 0x00000400 -#define TX_STS_LATE_COLL 0x00000200 -#define TX_STS_MANY_COLL 0x00000100 -#define TX_STS_COLL_CNT 0x00000078 -#define TX_STS_MANY_DEFER 0x00000004 -#define TX_STS_UNDERRUN 0x00000002 -#define TX_STS_DEFERRED 0x00000001 -#define TX_STATUS_FIFO_PEEK (CONFIG_DRIVER_SMC911X_BASE + 0x4C) -#define ID_REV (CONFIG_DRIVER_SMC911X_BASE + 0x50) -#define ID_REV_CHIP_ID 0xFFFF0000 /* RO */ -#define ID_REV_REV_ID 0x0000FFFF /* RO */ - -#define INT_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x54) -#define INT_CFG_INT_DEAS 0xFF000000 /* R/W */ -#define INT_CFG_INT_DEAS_CLR 0x00004000 -#define INT_CFG_INT_DEAS_STS 0x00002000 -#define INT_CFG_IRQ_INT 0x00001000 /* RO */ -#define INT_CFG_IRQ_EN 0x00000100 /* R/W */ -#define INT_CFG_IRQ_POL 0x00000010 /* R/W Not Affected by SW Reset */ -#define INT_CFG_IRQ_TYPE 0x00000001 /* R/W Not Affected by SW Reset */ - -#define INT_STS (CONFIG_DRIVER_SMC911X_BASE + 0x58) -#define INT_STS_SW_INT 0x80000000 /* R/WC */ -#define INT_STS_TXSTOP_INT 0x02000000 /* R/WC */ -#define INT_STS_RXSTOP_INT 0x01000000 /* R/WC */ -#define INT_STS_RXDFH_INT 0x00800000 /* R/WC */ -#define INT_STS_RXDF_INT 0x00400000 /* R/WC */ -#define INT_STS_TX_IOC 0x00200000 /* R/WC */ -#define INT_STS_RXD_INT 0x00100000 /* R/WC */ -#define INT_STS_GPT_INT 0x00080000 /* R/WC */ -#define INT_STS_PHY_INT 0x00040000 /* RO */ -#define INT_STS_PME_INT 0x00020000 /* R/WC */ -#define INT_STS_TXSO 0x00010000 /* R/WC */ -#define INT_STS_RWT 0x00008000 /* R/WC */ -#define INT_STS_RXE 0x00004000 /* R/WC */ -#define INT_STS_TXE 0x00002000 /* R/WC */ -/*#define INT_STS_ERX 0x00001000*/ /* R/WC */ -#define INT_STS_TDFU 0x00000800 /* R/WC */ -#define INT_STS_TDFO 0x00000400 /* R/WC */ -#define INT_STS_TDFA 0x00000200 /* R/WC */ -#define INT_STS_TSFF 0x00000100 /* R/WC */ -#define INT_STS_TSFL 0x00000080 /* R/WC */ -/*#define INT_STS_RXDF 0x00000040*/ /* R/WC */ -#define INT_STS_RDFO 0x00000040 /* R/WC */ -#define INT_STS_RDFL 0x00000020 /* R/WC */ -#define INT_STS_RSFF 0x00000010 /* R/WC */ -#define INT_STS_RSFL 0x00000008 /* R/WC */ -#define INT_STS_GPIO2_INT 0x00000004 /* R/WC */ -#define INT_STS_GPIO1_INT 0x00000002 /* R/WC */ -#define INT_STS_GPIO0_INT 0x00000001 /* R/WC */ -#define INT_EN (CONFIG_DRIVER_SMC911X_BASE + 0x5C) -#define INT_EN_SW_INT_EN 0x80000000 /* R/W */ -#define INT_EN_TXSTOP_INT_EN 0x02000000 /* R/W */ -#define INT_EN_RXSTOP_INT_EN 0x01000000 /* R/W */ -#define INT_EN_RXDFH_INT_EN 0x00800000 /* R/W */ -/*#define INT_EN_RXDF_INT_EN 0x00400000*/ /* R/W */ -#define INT_EN_TIOC_INT_EN 0x00200000 /* R/W */ -#define INT_EN_RXD_INT_EN 0x00100000 /* R/W */ -#define INT_EN_GPT_INT_EN 0x00080000 /* R/W */ -#define INT_EN_PHY_INT_EN 0x00040000 /* R/W */ -#define INT_EN_PME_INT_EN 0x00020000 /* R/W */ -#define INT_EN_TXSO_EN 0x00010000 /* R/W */ -#define INT_EN_RWT_EN 0x00008000 /* R/W */ -#define INT_EN_RXE_EN 0x00004000 /* R/W */ -#define INT_EN_TXE_EN 0x00002000 /* R/W */ -/*#define INT_EN_ERX_EN 0x00001000*/ /* R/W */ -#define INT_EN_TDFU_EN 0x00000800 /* R/W */ -#define INT_EN_TDFO_EN 0x00000400 /* R/W */ -#define INT_EN_TDFA_EN 0x00000200 /* R/W */ -#define INT_EN_TSFF_EN 0x00000100 /* R/W */ -#define INT_EN_TSFL_EN 0x00000080 /* R/W */ -/*#define INT_EN_RXDF_EN 0x00000040*/ /* R/W */ -#define INT_EN_RDFO_EN 0x00000040 /* R/W */ -#define INT_EN_RDFL_EN 0x00000020 /* R/W */ -#define INT_EN_RSFF_EN 0x00000010 /* R/W */ -#define INT_EN_RSFL_EN 0x00000008 /* R/W */ -#define INT_EN_GPIO2_INT 0x00000004 /* R/W */ -#define INT_EN_GPIO1_INT 0x00000002 /* R/W */ -#define INT_EN_GPIO0_INT 0x00000001 /* R/W */ - -#define BYTE_TEST (CONFIG_DRIVER_SMC911X_BASE + 0x64) -#define FIFO_INT (CONFIG_DRIVER_SMC911X_BASE + 0x68) -#define FIFO_INT_TX_AVAIL_LEVEL 0xFF000000 /* R/W */ -#define FIFO_INT_TX_STS_LEVEL 0x00FF0000 /* R/W */ -#define FIFO_INT_RX_AVAIL_LEVEL 0x0000FF00 /* R/W */ -#define FIFO_INT_RX_STS_LEVEL 0x000000FF /* R/W */ - -#define RX_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x6C) -#define RX_CFG_RX_END_ALGN 0xC0000000 /* R/W */ -#define RX_CFG_RX_END_ALGN4 0x00000000 /* R/W */ -#define RX_CFG_RX_END_ALGN16 0x40000000 /* R/W */ -#define RX_CFG_RX_END_ALGN32 0x80000000 /* R/W */ -#define RX_CFG_RX_DMA_CNT 0x0FFF0000 /* R/W */ -#define RX_CFG_RX_DUMP 0x00008000 /* R/W */ -#define RX_CFG_RXDOFF 0x00001F00 /* R/W */ -/*#define RX_CFG_RXBAD 0x00000001*/ /* R/W */ - -#define TX_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x70) -/*#define TX_CFG_TX_DMA_LVL 0xE0000000*/ /* R/W */ -/*#define TX_CFG_TX_DMA_CNT 0x0FFF0000*/ /* R/W Self Clearing */ -#define TX_CFG_TXS_DUMP 0x00008000 /* Self Clearing */ -#define TX_CFG_TXD_DUMP 0x00004000 /* Self Clearing */ -#define TX_CFG_TXSAO 0x00000004 /* R/W */ -#define TX_CFG_TX_ON 0x00000002 /* R/W */ -#define TX_CFG_STOP_TX 0x00000001 /* Self Clearing */ - -#define HW_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x74) -#define HW_CFG_TTM 0x00200000 /* R/W */ -#define HW_CFG_SF 0x00100000 /* R/W */ -#define HW_CFG_TX_FIF_SZ 0x000F0000 /* R/W */ -#define HW_CFG_TR 0x00003000 /* R/W */ -#define HW_CFG_PHY_CLK_SEL 0x00000060 /* R/W */ -#define HW_CFG_PHY_CLK_SEL_INT_PHY 0x00000000 /* R/W */ -#define HW_CFG_PHY_CLK_SEL_EXT_PHY 0x00000020 /* R/W */ -#define HW_CFG_PHY_CLK_SEL_CLK_DIS 0x00000040 /* R/W */ -#define HW_CFG_SMI_SEL 0x00000010 /* R/W */ -#define HW_CFG_EXT_PHY_DET 0x00000008 /* RO */ -#define HW_CFG_EXT_PHY_EN 0x00000004 /* R/W */ -#define HW_CFG_32_16_BIT_MODE 0x00000004 /* RO */ -#define HW_CFG_SRST_TO 0x00000002 /* RO */ -#define HW_CFG_SRST 0x00000001 /* Self Clearing */ - -#define RX_DP_CTRL (CONFIG_DRIVER_SMC911X_BASE + 0x78) -#define RX_DP_CTRL_RX_FFWD 0x80000000 /* R/W */ -#define RX_DP_CTRL_FFWD_BUSY 0x80000000 /* RO */ - -#define RX_FIFO_INF (CONFIG_DRIVER_SMC911X_BASE + 0x7C) -#define RX_FIFO_INF_RXSUSED 0x00FF0000 /* RO */ -#define RX_FIFO_INF_RXDUSED 0x0000FFFF /* RO */ - -#define TX_FIFO_INF (CONFIG_DRIVER_SMC911X_BASE + 0x80) -#define TX_FIFO_INF_TSUSED 0x00FF0000 /* RO */ -#define TX_FIFO_INF_TDFREE 0x0000FFFF /* RO */ - -#define PMT_CTRL (CONFIG_DRIVER_SMC911X_BASE + 0x84) -#define PMT_CTRL_PM_MODE 0x00003000 /* Self Clearing */ -#define PMT_CTRL_PHY_RST 0x00000400 /* Self Clearing */ -#define PMT_CTRL_WOL_EN 0x00000200 /* R/W */ -#define PMT_CTRL_ED_EN 0x00000100 /* R/W */ -#define PMT_CTRL_PME_TYPE 0x00000040 /* R/W Not Affected by SW Reset */ -#define PMT_CTRL_WUPS 0x00000030 /* R/WC */ -#define PMT_CTRL_WUPS_NOWAKE 0x00000000 /* R/WC */ -#define PMT_CTRL_WUPS_ED 0x00000010 /* R/WC */ -#define PMT_CTRL_WUPS_WOL 0x00000020 /* R/WC */ -#define PMT_CTRL_WUPS_MULTI 0x00000030 /* R/WC */ -#define PMT_CTRL_PME_IND 0x00000008 /* R/W */ -#define PMT_CTRL_PME_POL 0x00000004 /* R/W */ -#define PMT_CTRL_PME_EN 0x00000002 /* R/W Not Affected by SW Reset */ -#define PMT_CTRL_READY 0x00000001 /* RO */ - -#define GPIO_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x88) -#define GPIO_CFG_LED3_EN 0x40000000 /* R/W */ -#define GPIO_CFG_LED2_EN 0x20000000 /* R/W */ -#define GPIO_CFG_LED1_EN 0x10000000 /* R/W */ -#define GPIO_CFG_GPIO2_INT_POL 0x04000000 /* R/W */ -#define GPIO_CFG_GPIO1_INT_POL 0x02000000 /* R/W */ -#define GPIO_CFG_GPIO0_INT_POL 0x01000000 /* R/W */ -#define GPIO_CFG_EEPR_EN 0x00700000 /* R/W */ -#define GPIO_CFG_GPIOBUF2 0x00040000 /* R/W */ -#define GPIO_CFG_GPIOBUF1 0x00020000 /* R/W */ -#define GPIO_CFG_GPIOBUF0 0x00010000 /* R/W */ -#define GPIO_CFG_GPIODIR2 0x00000400 /* R/W */ -#define GPIO_CFG_GPIODIR1 0x00000200 /* R/W */ -#define GPIO_CFG_GPIODIR0 0x00000100 /* R/W */ -#define GPIO_CFG_GPIOD4 0x00000010 /* R/W */ -#define GPIO_CFG_GPIOD3 0x00000008 /* R/W */ -#define GPIO_CFG_GPIOD2 0x00000004 /* R/W */ -#define GPIO_CFG_GPIOD1 0x00000002 /* R/W */ -#define GPIO_CFG_GPIOD0 0x00000001 /* R/W */ - -#define GPT_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x8C) -#define GPT_CFG_TIMER_EN 0x20000000 /* R/W */ -#define GPT_CFG_GPT_LOAD 0x0000FFFF /* R/W */ - -#define GPT_CNT (CONFIG_DRIVER_SMC911X_BASE + 0x90) -#define GPT_CNT_GPT_CNT 0x0000FFFF /* RO */ - -#define ENDIAN (CONFIG_DRIVER_SMC911X_BASE + 0x98) -#define FREE_RUN (CONFIG_DRIVER_SMC911X_BASE + 0x9C) -#define RX_DROP (CONFIG_DRIVER_SMC911X_BASE + 0xA0) -#define MAC_CSR_CMD (CONFIG_DRIVER_SMC911X_BASE + 0xA4) -#define MAC_CSR_CMD_CSR_BUSY 0x80000000 /* Self Clearing */ -#define MAC_CSR_CMD_R_NOT_W 0x40000000 /* R/W */ -#define MAC_CSR_CMD_CSR_ADDR 0x000000FF /* R/W */ - -#define MAC_CSR_DATA (CONFIG_DRIVER_SMC911X_BASE + 0xA8) -#define AFC_CFG (CONFIG_DRIVER_SMC911X_BASE + 0xAC) -#define AFC_CFG_AFC_HI 0x00FF0000 /* R/W */ -#define AFC_CFG_AFC_LO 0x0000FF00 /* R/W */ -#define AFC_CFG_BACK_DUR 0x000000F0 /* R/W */ -#define AFC_CFG_FCMULT 0x00000008 /* R/W */ -#define AFC_CFG_FCBRD 0x00000004 /* R/W */ -#define AFC_CFG_FCADD 0x00000002 /* R/W */ -#define AFC_CFG_FCANY 0x00000001 /* R/W */ - -#define E2P_CMD (CONFIG_DRIVER_SMC911X_BASE + 0xB0) -#define E2P_CMD_EPC_BUSY 0x80000000 /* Self Clearing */ -#define E2P_CMD_EPC_CMD 0x70000000 /* R/W */ -#define E2P_CMD_EPC_CMD_READ 0x00000000 /* R/W */ -#define E2P_CMD_EPC_CMD_EWDS 0x10000000 /* R/W */ -#define E2P_CMD_EPC_CMD_EWEN 0x20000000 /* R/W */ -#define E2P_CMD_EPC_CMD_WRITE 0x30000000 /* R/W */ -#define E2P_CMD_EPC_CMD_WRAL 0x40000000 /* R/W */ -#define E2P_CMD_EPC_CMD_ERASE 0x50000000 /* R/W */ -#define E2P_CMD_EPC_CMD_ERAL 0x60000000 /* R/W */ -#define E2P_CMD_EPC_CMD_RELOAD 0x70000000 /* R/W */ -#define E2P_CMD_EPC_TIMEOUT 0x00000200 /* RO */ -#define E2P_CMD_MAC_ADDR_LOADED 0x00000100 /* RO */ -#define E2P_CMD_EPC_ADDR 0x000000FF /* R/W */ - -#define E2P_DATA (CONFIG_DRIVER_SMC911X_BASE + 0xB4) -#define E2P_DATA_EEPROM_DATA 0x000000FF /* R/W */ -/* end of LAN register offsets and bit definitions */ - -/* MAC Control and Status registers */ -#define MAC_CR 0x01 /* R/W */ - -/* MAC_CR - MAC Control Register */ -#define MAC_CR_RXALL 0x80000000 -/* TODO: delete this bit? It is not described in the data sheet. */ -#define MAC_CR_HBDIS 0x10000000 -#define MAC_CR_RCVOWN 0x00800000 -#define MAC_CR_LOOPBK 0x00200000 -#define MAC_CR_FDPX 0x00100000 -#define MAC_CR_MCPAS 0x00080000 -#define MAC_CR_PRMS 0x00040000 -#define MAC_CR_INVFILT 0x00020000 -#define MAC_CR_PASSBAD 0x00010000 -#define MAC_CR_HFILT 0x00008000 -#define MAC_CR_HPFILT 0x00002000 -#define MAC_CR_LCOLL 0x00001000 -#define MAC_CR_BCAST 0x00000800 -#define MAC_CR_DISRTY 0x00000400 -#define MAC_CR_PADSTR 0x00000100 -#define MAC_CR_BOLMT_MASK 0x000000C0 -#define MAC_CR_DFCHK 0x00000020 -#define MAC_CR_TXEN 0x00000008 -#define MAC_CR_RXEN 0x00000004 - -#define ADDRH 0x02 /* R/W mask 0x0000FFFFUL */ -#define ADDRL 0x03 /* R/W mask 0xFFFFFFFFUL */ -#define HASHH 0x04 /* R/W */ -#define HASHL 0x05 /* R/W */ - -#define MII_ACC 0x06 /* R/W */ -#define MII_ACC_PHY_ADDR 0x0000F800 -#define MII_ACC_MIIRINDA 0x000007C0 -#define MII_ACC_MII_WRITE 0x00000002 -#define MII_ACC_MII_BUSY 0x00000001 - -#define MII_DATA 0x07 /* R/W mask 0x0000FFFFUL */ - -#define FLOW 0x08 /* R/W */ -#define FLOW_FCPT 0xFFFF0000 -#define FLOW_FCPASS 0x00000004 -#define FLOW_FCEN 0x00000002 -#define FLOW_FCBSY 0x00000001 - -#define VLAN1 0x09 /* R/W mask 0x0000FFFFUL */ -#define VLAN1_VTI1 0x0000ffff - -#define VLAN2 0x0A /* R/W mask 0x0000FFFFUL */ -#define VLAN2_VTI2 0x0000ffff - -#define WUFF 0x0B /* WO */ - -#define WUCSR 0x0C /* R/W */ -#define WUCSR_GUE 0x00000200 -#define WUCSR_WUFR 0x00000040 -#define WUCSR_MPR 0x00000020 -#define WUCSR_WAKE_EN 0x00000004 -#define WUCSR_MPEN 0x00000002 - -/* Chip ID values */ -#define CHIP_9115 0x115 -#define CHIP_9116 0x116 -#define CHIP_9117 0x117 -#define CHIP_9118 0x118 -#define CHIP_9211 0x9211 -#define CHIP_9215 0x115a -#define CHIP_9216 0x116a -#define CHIP_9217 0x117a -#define CHIP_9218 0x118a - -struct chip_id { - u16 id; - char *name; -}; - -static const struct chip_id chip_ids[] = { - { CHIP_9115, "LAN9115" }, - { CHIP_9116, "LAN9116" }, - { CHIP_9117, "LAN9117" }, - { CHIP_9118, "LAN9118" }, - { CHIP_9211, "LAN9211" }, - { CHIP_9215, "LAN9215" }, - { CHIP_9216, "LAN9216" }, - { CHIP_9217, "LAN9217" }, - { CHIP_9218, "LAN9218" }, - { 0, NULL }, -}; - -#define DRIVERNAME "smc911x" - -u32 smc911x_get_mac_csr(u8 reg) -{ - while (smc911x_reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) - ; - smc911x_reg_write(MAC_CSR_CMD, MAC_CSR_CMD_CSR_BUSY | MAC_CSR_CMD_R_NOT_W | reg); - while (smc911x_reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) - ; - - return smc911x_reg_read(MAC_CSR_DATA); -} - -void smc911x_set_mac_csr(u8 reg, u32 data) -{ - while (smc911x_reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) - ; - smc911x_reg_write(MAC_CSR_DATA, data); - smc911x_reg_write(MAC_CSR_CMD, MAC_CSR_CMD_CSR_BUSY | reg); - while (smc911x_reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) - ; -} - static int smx911x_handle_mac_address(bd_t *bd) { unsigned long addrh, addrl; @@ -541,48 +146,6 @@ err_out: printf(DRIVERNAME ": autonegotiation timed out\n"); }
-static void smc911x_reset(void) -{ - int timeout; - - /* Take out of PM setting first */ - if (smc911x_reg_read(PMT_CTRL) & PMT_CTRL_READY) { - /* Write to the bytetest will take out of powerdown */ - smc911x_reg_write(BYTE_TEST, 0x0); - - timeout = 10; - - while (timeout-- && !(smc911x_reg_read(PMT_CTRL) & PMT_CTRL_READY)) - udelay(10); - if (!timeout) { - printf(DRIVERNAME - ": timeout waiting for PM restore\n"); - return; - } - } - - /* Disable interrupts */ - smc911x_reg_write(INT_EN, 0); - - smc911x_reg_write(HW_CFG, HW_CFG_SRST); - - timeout = 1000; - while (timeout-- && smc911x_reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY) - udelay(10); - - if (!timeout) { - printf(DRIVERNAME ": reset timeout\n"); - return; - } - - /* Reset the FIFO level and flow control settings */ - smc911x_set_mac_csr(FLOW, FLOW_FCPT | FLOW_FCEN); - smc911x_reg_write(AFC_CFG, 0x0050287F); - - /* Set to LED outputs */ - smc911x_reg_write(GPIO_CFG, 0x70070000); -} - static void smc911x_enable(void) { /* Enable TX */ @@ -601,26 +164,10 @@ static void smc911x_enable(void)
int eth_init(bd_t *bd) { - unsigned long val, i; - printf(DRIVERNAME ": initializing\n");
- val = smc911x_reg_read(BYTE_TEST); - if (val != 0x87654321) { - printf(DRIVERNAME ": Invalid chip endian 0x%08lx\n", val); + if (smc911x_detect_chip()) goto err_out; - } - - val = smc911x_reg_read(ID_REV) >> 16; - for (i = 0; chip_ids[i].id != 0; i++) { - if (chip_ids[i].id == val) break; - } - if (!chip_ids[i].id) { - printf(DRIVERNAME ": Unknown chip ID %04lx\n", val); - goto err_out; - } - - printf(DRIVERNAME ": detected %s controller\n", chip_ids[i].name);
smc911x_reset();
diff --git a/drivers/net/smc911x.h b/drivers/net/smc911x.h new file mode 100644 index 0000000..80d2ce0 --- /dev/null +++ b/drivers/net/smc911x.h @@ -0,0 +1,494 @@ +/* + * SMSC LAN9[12]1[567] Network driver + * + * (c) 2007 Pengutronix, Sascha Hauer s.hauer@pengutronix.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _SMC911X_H_ +#define _SMC911X_H_ + +#include <linux/types.h> + +#if defined (CONFIG_DRIVER_SMC911X_32_BIT) && \ + defined (CONFIG_DRIVER_SMC911X_16_BIT) +#error "SMC911X: Only one of CONFIG_DRIVER_SMC911X_32_BIT and \ + CONFIG_DRIVER_SMC911X_16_BIT shall be set" +#endif + +#if defined (CONFIG_DRIVER_SMC911X_32_BIT) +static inline u32 __smc911x_reg_read(u32 addr) +{ + return *(volatile u32*)addr; +} +u32 smc911x_reg_read(u32 addr) __attribute__((weak, alias("__smc911x_reg_read"))); + +static inline void __smc911x_reg_write(u32 addr, u32 val) +{ + *(volatile u32*)addr = val; +} +void smc911x_reg_write(u32 addr, u32 val) __attribute__((weak, alias("__smc911x_reg_write"))); +#elif defined (CONFIG_DRIVER_SMC911X_16_BIT) +static inline u32 smc911x_reg_read(u32 addr) +{ + volatile u16 *addr_16 = (u16 *)addr; + return ((*addr_16 & 0x0000ffff) | (*(addr_16 + 1) << 16)); +} +static inline void smc911x_reg_write(u32 addr, u32 val) +{ + *(volatile u16*)addr = (u16)val; + *(volatile u16*)(addr + 2) = (u16)(val >> 16); +} +#else +#error "SMC911X: undefined bus width" +#endif /* CONFIG_DRIVER_SMC911X_16_BIT */ + +/* Below are the register offsets and bit definitions + * of the Lan911x memory space + */ +#define RX_DATA_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x00) + +#define TX_DATA_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x20) +#define TX_CMD_A_INT_ON_COMP 0x80000000 +#define TX_CMD_A_INT_BUF_END_ALGN 0x03000000 +#define TX_CMD_A_INT_4_BYTE_ALGN 0x00000000 +#define TX_CMD_A_INT_16_BYTE_ALGN 0x01000000 +#define TX_CMD_A_INT_32_BYTE_ALGN 0x02000000 +#define TX_CMD_A_INT_DATA_OFFSET 0x001F0000 +#define TX_CMD_A_INT_FIRST_SEG 0x00002000 +#define TX_CMD_A_INT_LAST_SEG 0x00001000 +#define TX_CMD_A_BUF_SIZE 0x000007FF +#define TX_CMD_B_PKT_TAG 0xFFFF0000 +#define TX_CMD_B_ADD_CRC_DISABLE 0x00002000 +#define TX_CMD_B_DISABLE_PADDING 0x00001000 +#define TX_CMD_B_PKT_BYTE_LENGTH 0x000007FF + +#define RX_STATUS_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x40) +#define RX_STS_PKT_LEN 0x3FFF0000 +#define RX_STS_ES 0x00008000 +#define RX_STS_BCST 0x00002000 +#define RX_STS_LEN_ERR 0x00001000 +#define RX_STS_RUNT_ERR 0x00000800 +#define RX_STS_MCAST 0x00000400 +#define RX_STS_TOO_LONG 0x00000080 +#define RX_STS_COLL 0x00000040 +#define RX_STS_ETH_TYPE 0x00000020 +#define RX_STS_WDOG_TMT 0x00000010 +#define RX_STS_MII_ERR 0x00000008 +#define RX_STS_DRIBBLING 0x00000004 +#define RX_STS_CRC_ERR 0x00000002 +#define RX_STATUS_FIFO_PEEK (CONFIG_DRIVER_SMC911X_BASE + 0x44) +#define TX_STATUS_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x48) +#define TX_STS_TAG 0xFFFF0000 +#define TX_STS_ES 0x00008000 +#define TX_STS_LOC 0x00000800 +#define TX_STS_NO_CARR 0x00000400 +#define TX_STS_LATE_COLL 0x00000200 +#define TX_STS_MANY_COLL 0x00000100 +#define TX_STS_COLL_CNT 0x00000078 +#define TX_STS_MANY_DEFER 0x00000004 +#define TX_STS_UNDERRUN 0x00000002 +#define TX_STS_DEFERRED 0x00000001 +#define TX_STATUS_FIFO_PEEK (CONFIG_DRIVER_SMC911X_BASE + 0x4C) +#define ID_REV (CONFIG_DRIVER_SMC911X_BASE + 0x50) +#define ID_REV_CHIP_ID 0xFFFF0000 /* RO */ +#define ID_REV_REV_ID 0x0000FFFF /* RO */ + +#define INT_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x54) +#define INT_CFG_INT_DEAS 0xFF000000 /* R/W */ +#define INT_CFG_INT_DEAS_CLR 0x00004000 +#define INT_CFG_INT_DEAS_STS 0x00002000 +#define INT_CFG_IRQ_INT 0x00001000 /* RO */ +#define INT_CFG_IRQ_EN 0x00000100 /* R/W */ +#define INT_CFG_IRQ_POL 0x00000010 /* R/W Not Affected by SW Reset */ +#define INT_CFG_IRQ_TYPE 0x00000001 /* R/W Not Affected by SW Reset */ + +#define INT_STS (CONFIG_DRIVER_SMC911X_BASE + 0x58) +#define INT_STS_SW_INT 0x80000000 /* R/WC */ +#define INT_STS_TXSTOP_INT 0x02000000 /* R/WC */ +#define INT_STS_RXSTOP_INT 0x01000000 /* R/WC */ +#define INT_STS_RXDFH_INT 0x00800000 /* R/WC */ +#define INT_STS_RXDF_INT 0x00400000 /* R/WC */ +#define INT_STS_TX_IOC 0x00200000 /* R/WC */ +#define INT_STS_RXD_INT 0x00100000 /* R/WC */ +#define INT_STS_GPT_INT 0x00080000 /* R/WC */ +#define INT_STS_PHY_INT 0x00040000 /* RO */ +#define INT_STS_PME_INT 0x00020000 /* R/WC */ +#define INT_STS_TXSO 0x00010000 /* R/WC */ +#define INT_STS_RWT 0x00008000 /* R/WC */ +#define INT_STS_RXE 0x00004000 /* R/WC */ +#define INT_STS_TXE 0x00002000 /* R/WC */ +/*#define INT_STS_ERX 0x00001000*/ /* R/WC */ +#define INT_STS_TDFU 0x00000800 /* R/WC */ +#define INT_STS_TDFO 0x00000400 /* R/WC */ +#define INT_STS_TDFA 0x00000200 /* R/WC */ +#define INT_STS_TSFF 0x00000100 /* R/WC */ +#define INT_STS_TSFL 0x00000080 /* R/WC */ +/*#define INT_STS_RXDF 0x00000040*/ /* R/WC */ +#define INT_STS_RDFO 0x00000040 /* R/WC */ +#define INT_STS_RDFL 0x00000020 /* R/WC */ +#define INT_STS_RSFF 0x00000010 /* R/WC */ +#define INT_STS_RSFL 0x00000008 /* R/WC */ +#define INT_STS_GPIO2_INT 0x00000004 /* R/WC */ +#define INT_STS_GPIO1_INT 0x00000002 /* R/WC */ +#define INT_STS_GPIO0_INT 0x00000001 /* R/WC */ +#define INT_EN (CONFIG_DRIVER_SMC911X_BASE + 0x5C) +#define INT_EN_SW_INT_EN 0x80000000 /* R/W */ +#define INT_EN_TXSTOP_INT_EN 0x02000000 /* R/W */ +#define INT_EN_RXSTOP_INT_EN 0x01000000 /* R/W */ +#define INT_EN_RXDFH_INT_EN 0x00800000 /* R/W */ +/*#define INT_EN_RXDF_INT_EN 0x00400000*/ /* R/W */ +#define INT_EN_TIOC_INT_EN 0x00200000 /* R/W */ +#define INT_EN_RXD_INT_EN 0x00100000 /* R/W */ +#define INT_EN_GPT_INT_EN 0x00080000 /* R/W */ +#define INT_EN_PHY_INT_EN 0x00040000 /* R/W */ +#define INT_EN_PME_INT_EN 0x00020000 /* R/W */ +#define INT_EN_TXSO_EN 0x00010000 /* R/W */ +#define INT_EN_RWT_EN 0x00008000 /* R/W */ +#define INT_EN_RXE_EN 0x00004000 /* R/W */ +#define INT_EN_TXE_EN 0x00002000 /* R/W */ +/*#define INT_EN_ERX_EN 0x00001000*/ /* R/W */ +#define INT_EN_TDFU_EN 0x00000800 /* R/W */ +#define INT_EN_TDFO_EN 0x00000400 /* R/W */ +#define INT_EN_TDFA_EN 0x00000200 /* R/W */ +#define INT_EN_TSFF_EN 0x00000100 /* R/W */ +#define INT_EN_TSFL_EN 0x00000080 /* R/W */ +/*#define INT_EN_RXDF_EN 0x00000040*/ /* R/W */ +#define INT_EN_RDFO_EN 0x00000040 /* R/W */ +#define INT_EN_RDFL_EN 0x00000020 /* R/W */ +#define INT_EN_RSFF_EN 0x00000010 /* R/W */ +#define INT_EN_RSFL_EN 0x00000008 /* R/W */ +#define INT_EN_GPIO2_INT 0x00000004 /* R/W */ +#define INT_EN_GPIO1_INT 0x00000002 /* R/W */ +#define INT_EN_GPIO0_INT 0x00000001 /* R/W */ + +#define BYTE_TEST (CONFIG_DRIVER_SMC911X_BASE + 0x64) +#define FIFO_INT (CONFIG_DRIVER_SMC911X_BASE + 0x68) +#define FIFO_INT_TX_AVAIL_LEVEL 0xFF000000 /* R/W */ +#define FIFO_INT_TX_STS_LEVEL 0x00FF0000 /* R/W */ +#define FIFO_INT_RX_AVAIL_LEVEL 0x0000FF00 /* R/W */ +#define FIFO_INT_RX_STS_LEVEL 0x000000FF /* R/W */ + +#define RX_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x6C) +#define RX_CFG_RX_END_ALGN 0xC0000000 /* R/W */ +#define RX_CFG_RX_END_ALGN4 0x00000000 /* R/W */ +#define RX_CFG_RX_END_ALGN16 0x40000000 /* R/W */ +#define RX_CFG_RX_END_ALGN32 0x80000000 /* R/W */ +#define RX_CFG_RX_DMA_CNT 0x0FFF0000 /* R/W */ +#define RX_CFG_RX_DUMP 0x00008000 /* R/W */ +#define RX_CFG_RXDOFF 0x00001F00 /* R/W */ +/*#define RX_CFG_RXBAD 0x00000001*/ /* R/W */ + +#define TX_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x70) +/*#define TX_CFG_TX_DMA_LVL 0xE0000000*/ /* R/W */ +/*#define TX_CFG_TX_DMA_CNT 0x0FFF0000*/ /* R/W Self Clearing */ +#define TX_CFG_TXS_DUMP 0x00008000 /* Self Clearing */ +#define TX_CFG_TXD_DUMP 0x00004000 /* Self Clearing */ +#define TX_CFG_TXSAO 0x00000004 /* R/W */ +#define TX_CFG_TX_ON 0x00000002 /* R/W */ +#define TX_CFG_STOP_TX 0x00000001 /* Self Clearing */ + +#define HW_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x74) +#define HW_CFG_TTM 0x00200000 /* R/W */ +#define HW_CFG_SF 0x00100000 /* R/W */ +#define HW_CFG_TX_FIF_SZ 0x000F0000 /* R/W */ +#define HW_CFG_TR 0x00003000 /* R/W */ +#define HW_CFG_PHY_CLK_SEL 0x00000060 /* R/W */ +#define HW_CFG_PHY_CLK_SEL_INT_PHY 0x00000000 /* R/W */ +#define HW_CFG_PHY_CLK_SEL_EXT_PHY 0x00000020 /* R/W */ +#define HW_CFG_PHY_CLK_SEL_CLK_DIS 0x00000040 /* R/W */ +#define HW_CFG_SMI_SEL 0x00000010 /* R/W */ +#define HW_CFG_EXT_PHY_DET 0x00000008 /* RO */ +#define HW_CFG_EXT_PHY_EN 0x00000004 /* R/W */ +#define HW_CFG_32_16_BIT_MODE 0x00000004 /* RO */ +#define HW_CFG_SRST_TO 0x00000002 /* RO */ +#define HW_CFG_SRST 0x00000001 /* Self Clearing */ + +#define RX_DP_CTRL (CONFIG_DRIVER_SMC911X_BASE + 0x78) +#define RX_DP_CTRL_RX_FFWD 0x80000000 /* R/W */ +#define RX_DP_CTRL_FFWD_BUSY 0x80000000 /* RO */ + +#define RX_FIFO_INF (CONFIG_DRIVER_SMC911X_BASE + 0x7C) +#define RX_FIFO_INF_RXSUSED 0x00FF0000 /* RO */ +#define RX_FIFO_INF_RXDUSED 0x0000FFFF /* RO */ + +#define TX_FIFO_INF (CONFIG_DRIVER_SMC911X_BASE + 0x80) +#define TX_FIFO_INF_TSUSED 0x00FF0000 /* RO */ +#define TX_FIFO_INF_TDFREE 0x0000FFFF /* RO */ + +#define PMT_CTRL (CONFIG_DRIVER_SMC911X_BASE + 0x84) +#define PMT_CTRL_PM_MODE 0x00003000 /* Self Clearing */ +#define PMT_CTRL_PHY_RST 0x00000400 /* Self Clearing */ +#define PMT_CTRL_WOL_EN 0x00000200 /* R/W */ +#define PMT_CTRL_ED_EN 0x00000100 /* R/W */ +#define PMT_CTRL_PME_TYPE 0x00000040 /* R/W Not Affected by SW Reset */ +#define PMT_CTRL_WUPS 0x00000030 /* R/WC */ +#define PMT_CTRL_WUPS_NOWAKE 0x00000000 /* R/WC */ +#define PMT_CTRL_WUPS_ED 0x00000010 /* R/WC */ +#define PMT_CTRL_WUPS_WOL 0x00000020 /* R/WC */ +#define PMT_CTRL_WUPS_MULTI 0x00000030 /* R/WC */ +#define PMT_CTRL_PME_IND 0x00000008 /* R/W */ +#define PMT_CTRL_PME_POL 0x00000004 /* R/W */ +#define PMT_CTRL_PME_EN 0x00000002 /* R/W Not Affected by SW Reset */ +#define PMT_CTRL_READY 0x00000001 /* RO */ + +#define GPIO_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x88) +#define GPIO_CFG_LED3_EN 0x40000000 /* R/W */ +#define GPIO_CFG_LED2_EN 0x20000000 /* R/W */ +#define GPIO_CFG_LED1_EN 0x10000000 /* R/W */ +#define GPIO_CFG_GPIO2_INT_POL 0x04000000 /* R/W */ +#define GPIO_CFG_GPIO1_INT_POL 0x02000000 /* R/W */ +#define GPIO_CFG_GPIO0_INT_POL 0x01000000 /* R/W */ +#define GPIO_CFG_EEPR_EN 0x00700000 /* R/W */ +#define GPIO_CFG_GPIOBUF2 0x00040000 /* R/W */ +#define GPIO_CFG_GPIOBUF1 0x00020000 /* R/W */ +#define GPIO_CFG_GPIOBUF0 0x00010000 /* R/W */ +#define GPIO_CFG_GPIODIR2 0x00000400 /* R/W */ +#define GPIO_CFG_GPIODIR1 0x00000200 /* R/W */ +#define GPIO_CFG_GPIODIR0 0x00000100 /* R/W */ +#define GPIO_CFG_GPIOD4 0x00000010 /* R/W */ +#define GPIO_CFG_GPIOD3 0x00000008 /* R/W */ +#define GPIO_CFG_GPIOD2 0x00000004 /* R/W */ +#define GPIO_CFG_GPIOD1 0x00000002 /* R/W */ +#define GPIO_CFG_GPIOD0 0x00000001 /* R/W */ + +#define GPT_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x8C) +#define GPT_CFG_TIMER_EN 0x20000000 /* R/W */ +#define GPT_CFG_GPT_LOAD 0x0000FFFF /* R/W */ + +#define GPT_CNT (CONFIG_DRIVER_SMC911X_BASE + 0x90) +#define GPT_CNT_GPT_CNT 0x0000FFFF /* RO */ + +#define ENDIAN (CONFIG_DRIVER_SMC911X_BASE + 0x98) +#define FREE_RUN (CONFIG_DRIVER_SMC911X_BASE + 0x9C) +#define RX_DROP (CONFIG_DRIVER_SMC911X_BASE + 0xA0) +#define MAC_CSR_CMD (CONFIG_DRIVER_SMC911X_BASE + 0xA4) +#define MAC_CSR_CMD_CSR_BUSY 0x80000000 /* Self Clearing */ +#define MAC_CSR_CMD_R_NOT_W 0x40000000 /* R/W */ +#define MAC_CSR_CMD_CSR_ADDR 0x000000FF /* R/W */ + +#define MAC_CSR_DATA (CONFIG_DRIVER_SMC911X_BASE + 0xA8) +#define AFC_CFG (CONFIG_DRIVER_SMC911X_BASE + 0xAC) +#define AFC_CFG_AFC_HI 0x00FF0000 /* R/W */ +#define AFC_CFG_AFC_LO 0x0000FF00 /* R/W */ +#define AFC_CFG_BACK_DUR 0x000000F0 /* R/W */ +#define AFC_CFG_FCMULT 0x00000008 /* R/W */ +#define AFC_CFG_FCBRD 0x00000004 /* R/W */ +#define AFC_CFG_FCADD 0x00000002 /* R/W */ +#define AFC_CFG_FCANY 0x00000001 /* R/W */ + +#define E2P_CMD (CONFIG_DRIVER_SMC911X_BASE + 0xB0) +#define E2P_CMD_EPC_BUSY 0x80000000 /* Self Clearing */ +#define E2P_CMD_EPC_CMD 0x70000000 /* R/W */ +#define E2P_CMD_EPC_CMD_READ 0x00000000 /* R/W */ +#define E2P_CMD_EPC_CMD_EWDS 0x10000000 /* R/W */ +#define E2P_CMD_EPC_CMD_EWEN 0x20000000 /* R/W */ +#define E2P_CMD_EPC_CMD_WRITE 0x30000000 /* R/W */ +#define E2P_CMD_EPC_CMD_WRAL 0x40000000 /* R/W */ +#define E2P_CMD_EPC_CMD_ERASE 0x50000000 /* R/W */ +#define E2P_CMD_EPC_CMD_ERAL 0x60000000 /* R/W */ +#define E2P_CMD_EPC_CMD_RELOAD 0x70000000 /* R/W */ +#define E2P_CMD_EPC_TIMEOUT 0x00000200 /* RO */ +#define E2P_CMD_MAC_ADDR_LOADED 0x00000100 /* RO */ +#define E2P_CMD_EPC_ADDR 0x000000FF /* R/W */ + +#define E2P_DATA (CONFIG_DRIVER_SMC911X_BASE + 0xB4) +#define E2P_DATA_EEPROM_DATA 0x000000FF /* R/W */ +/* end of LAN register offsets and bit definitions */ + +/* MAC Control and Status registers */ +#define MAC_CR 0x01 /* R/W */ + +/* MAC_CR - MAC Control Register */ +#define MAC_CR_RXALL 0x80000000 +/* TODO: delete this bit? It is not described in the data sheet. */ +#define MAC_CR_HBDIS 0x10000000 +#define MAC_CR_RCVOWN 0x00800000 +#define MAC_CR_LOOPBK 0x00200000 +#define MAC_CR_FDPX 0x00100000 +#define MAC_CR_MCPAS 0x00080000 +#define MAC_CR_PRMS 0x00040000 +#define MAC_CR_INVFILT 0x00020000 +#define MAC_CR_PASSBAD 0x00010000 +#define MAC_CR_HFILT 0x00008000 +#define MAC_CR_HPFILT 0x00002000 +#define MAC_CR_LCOLL 0x00001000 +#define MAC_CR_BCAST 0x00000800 +#define MAC_CR_DISRTY 0x00000400 +#define MAC_CR_PADSTR 0x00000100 +#define MAC_CR_BOLMT_MASK 0x000000C0 +#define MAC_CR_DFCHK 0x00000020 +#define MAC_CR_TXEN 0x00000008 +#define MAC_CR_RXEN 0x00000004 + +#define ADDRH 0x02 /* R/W mask 0x0000FFFFUL */ +#define ADDRL 0x03 /* R/W mask 0xFFFFFFFFUL */ +#define HASHH 0x04 /* R/W */ +#define HASHL 0x05 /* R/W */ + +#define MII_ACC 0x06 /* R/W */ +#define MII_ACC_PHY_ADDR 0x0000F800 +#define MII_ACC_MIIRINDA 0x000007C0 +#define MII_ACC_MII_WRITE 0x00000002 +#define MII_ACC_MII_BUSY 0x00000001 + +#define MII_DATA 0x07 /* R/W mask 0x0000FFFFUL */ + +#define FLOW 0x08 /* R/W */ +#define FLOW_FCPT 0xFFFF0000 +#define FLOW_FCPASS 0x00000004 +#define FLOW_FCEN 0x00000002 +#define FLOW_FCBSY 0x00000001 + +#define VLAN1 0x09 /* R/W mask 0x0000FFFFUL */ +#define VLAN1_VTI1 0x0000ffff + +#define VLAN2 0x0A /* R/W mask 0x0000FFFFUL */ +#define VLAN2_VTI2 0x0000ffff + +#define WUFF 0x0B /* WO */ + +#define WUCSR 0x0C /* R/W */ +#define WUCSR_GUE 0x00000200 +#define WUCSR_WUFR 0x00000040 +#define WUCSR_MPR 0x00000020 +#define WUCSR_WAKE_EN 0x00000004 +#define WUCSR_MPEN 0x00000002 + +/* Chip ID values */ +#define CHIP_9115 0x115 +#define CHIP_9116 0x116 +#define CHIP_9117 0x117 +#define CHIP_9118 0x118 +#define CHIP_9211 0x9211 +#define CHIP_9215 0x115a +#define CHIP_9216 0x116a +#define CHIP_9217 0x117a +#define CHIP_9218 0x118a + +struct chip_id { + u16 id; + char *name; +}; + +static const struct chip_id chip_ids[] = { + { CHIP_9115, "LAN9115" }, + { CHIP_9116, "LAN9116" }, + { CHIP_9117, "LAN9117" }, + { CHIP_9118, "LAN9118" }, + { CHIP_9211, "LAN9211" }, + { CHIP_9215, "LAN9215" }, + { CHIP_9216, "LAN9216" }, + { CHIP_9217, "LAN9217" }, + { CHIP_9218, "LAN9218" }, + { 0, NULL }, +}; + + +#define DRIVERNAME "smc911x" + +static u32 smc911x_get_mac_csr(u8 reg) +{ + while (smc911x_reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) + ; + smc911x_reg_write(MAC_CSR_CMD, MAC_CSR_CMD_CSR_BUSY | MAC_CSR_CMD_R_NOT_W | reg); + while (smc911x_reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) + ; + + return smc911x_reg_read(MAC_CSR_DATA); +} + +static void smc911x_set_mac_csr(u8 reg, u32 data) +{ + while (smc911x_reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) + ; + smc911x_reg_write(MAC_CSR_DATA, data); + smc911x_reg_write(MAC_CSR_CMD, MAC_CSR_CMD_CSR_BUSY | reg); + while (smc911x_reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) + ; +} + +static int smc911x_detect_chip(void) +{ + unsigned long val, i; + + val = smc911x_reg_read(BYTE_TEST); + if (val != 0x87654321) { + printf(DRIVERNAME ": Invalid chip endian 0x%08lx\n", val); + return -1; + } + + val = smc911x_reg_read(ID_REV) >> 16; + for (i = 0; chip_ids[i].id != 0; i++) { + if (chip_ids[i].id == val) break; + } + if (!chip_ids[i].id) { + printf(DRIVERNAME ": Unknown chip ID %04lx\n", val); + return -1; + } + + printf(DRIVERNAME ": detected %s controller\n", chip_ids[i].name); + + return 0; +} + +static void smc911x_reset(void) +{ + int timeout; + + /* Take out of PM setting first */ + if (smc911x_reg_read(PMT_CTRL) & PMT_CTRL_READY) { + /* Write to the bytetest will take out of powerdown */ + smc911x_reg_write(BYTE_TEST, 0x0); + + timeout = 10; + + while (timeout-- && !(smc911x_reg_read(PMT_CTRL) & PMT_CTRL_READY)) + udelay(10); + if (!timeout) { + printf(DRIVERNAME + ": timeout waiting for PM restore\n"); + return; + } + } + + /* Disable interrupts */ + smc911x_reg_write(INT_EN, 0); + + smc911x_reg_write(HW_CFG, HW_CFG_SRST); + + timeout = 1000; + while (timeout-- && smc911x_reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY) + udelay(10); + + if (!timeout) { + printf(DRIVERNAME ": reset timeout\n"); + return; + } + + /* Reset the FIFO level and flow control settings */ + smc911x_set_mac_csr(FLOW, FLOW_FCPT | FLOW_FCEN); + smc911x_reg_write(AFC_CFG, 0x0050287F); + + /* Set to LED outputs */ + smc911x_reg_write(GPIO_CFG, 0x70070000); +} + +#endif
Hm, sorry, have any of those other "pieces of code" been posted to the list? I'd like to have a look at them to see what they need all those register definitions for.
v3
Thanks Guennadi --- Guennadi Liakhovetski, Ph.D.
DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
it's already been posted in this thread (and Ben has merged it). but to answer your question, external code doesnt generally need most of those register definitions. they're moved because they belong in a header file and because it doesnt make sense to move just a few. -mike
Ok, you mean these patches
[PATCH] smc911x_eeprom: new example app for managing newer SMC parts
Yep, agree, as long as some register definitions are used, it is better to move all to a header.
Thanks Mike, you're a machine.
Acked-by: Ben Warren biggerbadderben@gmail.com
Wolfgang - please pick up directly.
regards, Ben
Dear Ben Warren,
Done, thanks.
Dear Mike Frysinger,
v3
Applied, thanks.
participants (5)
Ben Warren
Magnus Lilja
Mike Frysinger
