[PATCH] firmware: ti_sci_static_data: Make file board agnostic
Static DMA channel data for R5 SPL is mostly board agnostic so use SOC configs instead of EVM specific config to ease adding new board support.
Drop J7200 EVM specific settings as its same as J721e
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/firmware/ti_sci_static_data.h | 42 +++------------------------ 1 file changed, 4 insertions(+), 38 deletions(-)
diff --git a/drivers/firmware/ti_sci_static_data.h b/drivers/firmware/ti_sci_static_data.h index 8529ef2900..5ae0556a9a 100644 --- a/drivers/firmware/ti_sci_static_data.h +++ b/drivers/firmware/ti_sci_static_data.h @@ -16,7 +16,7 @@ struct ti_sci_resource_static_data {
#if IS_ENABLED(CONFIG_K3_DM_FW)
-#if IS_ENABLED(CONFIG_TARGET_J721E_R5_EVM) +#if IS_ENABLED(CONFIG_SOC_K3_J721E) static struct ti_sci_resource_static_data rm_static_data[] = { /* Free rings */ { @@ -48,43 +48,9 @@ static struct ti_sci_resource_static_data rm_static_data[] = { }, { }, }; -#endif /* CONFIG_TARGET_J721E_R5_EVM */ +#endif /* CONFIG_SOC_K3_J721E */
-#if IS_ENABLED(CONFIG_TARGET_J7200_R5_EVM) -static struct ti_sci_resource_static_data rm_static_data[] = { - /* Free rings */ - { - .dev_id = 235, - .subtype = 1, - .range_start = 124, - .range_num = 32, - }, - /* TX channels */ - { - .dev_id = 236, - .subtype = 13, - .range_start = 6, - .range_num = 2, - }, - /* RX channels */ - { - .dev_id = 236, - .subtype = 10, - .range_start = 6, - .range_num = 2, - }, - /* RX Free flows */ - { - .dev_id = 236, - .subtype = 0, - .range_start = 60, - .range_num = 8, - }, - { }, -}; -#endif /* CONFIG_TARGET_J7200_R5_EVM */ - -#if IS_ENABLED(CONFIG_TARGET_J721S2_R5_EVM) +#if IS_ENABLED(CONFIG_SOC_K3_J721S2) static struct ti_sci_resource_static_data rm_static_data[] = { /* Free rings */ { @@ -116,7 +82,7 @@ static struct ti_sci_resource_static_data rm_static_data[] = { }, { }, }; -#endif /* CONFIG_TARGET_J721S2_R5_EVM */ +#endif /* CONFIG_SOC_K3_J721S2 */
#if IS_ENABLED(CONFIG_SOC_K3_AM625) static struct ti_sci_resource_static_data rm_static_data[] = {
Gee thanks.
Reviewed-by: Nishanth Menon nm@ti.com
- /* Free rings */
.dev_id = 235,
.subtype = 1,
.range_start = 124,
.range_num = 32,
- /* TX channels */
.dev_id = 236,
.subtype = 13,
.range_start = 6,
.range_num = 2,
- /* RX channels */
.dev_id = 236,
.subtype = 10,
.range_start = 6,
.range_num = 2,
.dev_id = 236,
.subtype = 0,
.range_start = 60,
.range_num = 8,
#if IS_ENABLED(CONFIG_SOC_K3_AM625) static struct ti_sci_resource_static_data rm_static_data[] = { -- 2.36.1
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com Reviewed-by: Nishanth Menon nm@ti.com
Nishanth Menon
Vignesh Raghavendra
