[U-Boot] [PATCH] ARM: uniphier: support some more DRAM use cases on PH1-Pro4
Some of PH1-Pro4 boards are equipped with larger amount of DRAM than the reference board. Add UMC settings to support them.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/dram/umc-ph1-pro4.c | 80 ++++++++++++++++++++---------- 1 file changed, 53 insertions(+), 27 deletions(-)
diff --git a/arch/arm/mach-uniphier/dram/umc-ph1-pro4.c b/arch/arm/mach-uniphier/dram/umc-ph1-pro4.c index 4d976e3..261f7cf 100644 --- a/arch/arm/mach-uniphier/dram/umc-ph1-pro4.c +++ b/arch/arm/mach-uniphier/dram/umc-ph1-pro4.c @@ -13,6 +13,16 @@ #include "ddrphy-regs.h" #include "umc-regs.h"
+enum dram_size { + DRAM_SZ_128M, + DRAM_SZ_256M, + DRAM_SZ_512M, + DRAM_SZ_NR, +}; + +static u32 umc_initctlb[DRAM_SZ_NR] = {0x43030d3f, 0x43030d3f, 0x7b030d3f}; +static u32 umc_spcctla[DRAM_SZ_NR] = {0x002b0617, 0x003f0617, 0x00770617}; + static void umc_start_ssif(void __iomem *ssif_base) { writel(0x00000001, ssif_base + 0x0000b004); @@ -56,19 +66,36 @@ static void umc_start_ssif(void __iomem *ssif_base) writel(0x00000001, ssif_base + UMC_DMDRST); }
-static void umc_dramcont_init(void __iomem *dramcont, void __iomem *ca_base, - int size, int freq) +static int umc_dramcont_init(void __iomem *dramcont, void __iomem *ca_base, + int size, int width) { + enum dram_size dram_size; + + switch (size / (width / 16)) { + case SZ_128M: + dram_size = DRAM_SZ_128M; + break; + case SZ_256M: + dram_size = DRAM_SZ_256M; + break; + case SZ_512M: + dram_size = DRAM_SZ_512M; + break; + default: + printf("unsupported DRAM size\n"); + return -EINVAL; + } + writel(0x66bb0f17, dramcont + UMC_CMDCTLA); writel(0x18c6aa44, dramcont + UMC_CMDCTLB); writel(0x5101387f, dramcont + UMC_INITCTLA); - writel(0x43030d3f, dramcont + UMC_INITCTLB); + writel(umc_initctlb[dram_size], dramcont + UMC_INITCTLB); writel(0x00ff00ff, dramcont + UMC_INITCTLC); writel(0x00000d71, dramcont + UMC_DRMMR0); writel(0x00000006, dramcont + UMC_DRMMR1); writel(0x00000298, dramcont + UMC_DRMMR2); writel(0x00000000, dramcont + UMC_DRMMR3); - writel(0x003f0617, dramcont + UMC_SPCCTLA); + writel(umc_spcctla[dram_size], dramcont + UMC_SPCCTLA); writel(0x00ff0008, dramcont + UMC_SPCCTLB); writel(0x000c00ae, dramcont + UMC_RDATACTL_D0); writel(0x000c00ae, dramcont + UMC_RDATACTL_D1); @@ -90,9 +117,11 @@ static void umc_dramcont_init(void __iomem *dramcont, void __iomem *ca_base, writel(0x200a0a00, dramcont + UMC_SPCSETB); writel(0x00010000, dramcont + UMC_SPCSETD); writel(0x80000020, dramcont + UMC_DFICUPDCTLA); + + return 0; }
-static int umc_init_sub(int freq, int size_ch0, int size_ch1) +int ph1_pro4_umc_init(const struct uniphier_board_data *bd) { void __iomem *ssif_base = (void __iomem *)UMC_SSIF_BASE; void __iomem *ca_base0 = (void __iomem *)UMC_CA_BASE(0); @@ -103,6 +132,12 @@ static int umc_init_sub(int freq, int size_ch0, int size_ch1) void __iomem *phy0_1 = (void __iomem *)DDRPHY_BASE(0, 1); void __iomem *phy1_0 = (void __iomem *)DDRPHY_BASE(1, 0); void __iomem *phy1_1 = (void __iomem *)DDRPHY_BASE(1, 1); + int ret; + + if (bd->dram_freq != 1600) { + pr_err("Unsupported DDR configuration\n"); + return -EINVAL; + }
umc_dram_init_start(dramcont0); umc_dram_init_start(dramcont1); @@ -111,52 +146,43 @@ static int umc_init_sub(int freq, int size_ch0, int size_ch1)
writel(0x00000101, dramcont0 + UMC_DIOCTLA);
- ph1_pro4_ddrphy_init(phy0_0, freq, size_ch0); + ph1_pro4_ddrphy_init(phy0_0, bd->dram_freq, bd->dram_ch0_size);
ddrphy_prepare_training(phy0_0, 0); ddrphy_training(phy0_0);
writel(0x00000103, dramcont0 + UMC_DIOCTLA);
- ph1_pro4_ddrphy_init(phy0_1, freq, size_ch0); + ph1_pro4_ddrphy_init(phy0_1, bd->dram_freq, bd->dram_ch0_size);
ddrphy_prepare_training(phy0_1, 1); ddrphy_training(phy0_1);
writel(0x00000101, dramcont1 + UMC_DIOCTLA);
- ph1_pro4_ddrphy_init(phy1_0, freq, size_ch1); + ph1_pro4_ddrphy_init(phy1_0, bd->dram_freq, bd->dram_ch1_size);
ddrphy_prepare_training(phy1_0, 0); ddrphy_training(phy1_0);
writel(0x00000103, dramcont1 + UMC_DIOCTLA);
- ph1_pro4_ddrphy_init(phy1_1, freq, size_ch1); + ph1_pro4_ddrphy_init(phy1_1, bd->dram_freq, bd->dram_ch1_size);
ddrphy_prepare_training(phy1_1, 1); ddrphy_training(phy1_1);
- umc_dramcont_init(dramcont0, ca_base0, size_ch0, freq); - umc_dramcont_init(dramcont1, ca_base1, size_ch1, freq); + ret = umc_dramcont_init(dramcont0, ca_base0, bd->dram_ch0_size, + bd->dram_ch0_width); + if (ret) + return ret; + + ret = umc_dramcont_init(dramcont1, ca_base1, bd->dram_ch1_size, + bd->dram_ch1_width); + if (ret) + return ret;
umc_start_ssif(ssif_base);
return 0; } - -int ph1_pro4_umc_init(const struct uniphier_board_data *bd) -{ - if (((bd->dram_ch0_size == SZ_512M && bd->dram_ch0_width == 32) || - (bd->dram_ch0_size == SZ_256M && bd->dram_ch0_width == 16)) && - ((bd->dram_ch1_size == SZ_512M && bd->dram_ch1_width == 32) || - (bd->dram_ch1_size == SZ_256M && bd->dram_ch1_width == 16)) && - bd->dram_freq == 1600) { - return umc_init_sub(bd->dram_freq, - bd->dram_ch0_size / SZ_128M, - bd->dram_ch1_size / SZ_128M); - } else { - pr_err("Unsupported DDR configuration\n"); - return -EINVAL; - } -}
2016-01-21 14:57 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier/master.
Masahiro Yamada
