[U-Boot] [PATCH v4] SMDK5250: Enable VBus for USB 2.0 controller
This patch enables Vbus required for USB 2.0 controller.
Signed-off-by: Vivek Gautam gautam.vivek@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com ---
Changes from v3: - Rebased on top of u-boot-samsung/master.
Changes from v2: - Rebased on top of u-boot-usb/next - Enclosed the function definition for board_usb_vbus_init() inside "CONFIG_USB_EHCI_EXYNOS"
Changes from v1: - Using the old school method of setting up gpio instead of using the pinmux method, since the required gpio line here is board specific.
board/samsung/smdk5250/smdk5250.c | 19 +++++++++++++++++++ 1 files changed, 19 insertions(+), 0 deletions(-)
diff --git a/board/samsung/smdk5250/smdk5250.c b/board/samsung/smdk5250/smdk5250.c index 73c3ec0..d80f75d 100644 --- a/board/samsung/smdk5250/smdk5250.c +++ b/board/samsung/smdk5250/smdk5250.c @@ -35,12 +35,31 @@
DECLARE_GLOBAL_DATA_PTR;
+#ifdef CONFIG_USB_EHCI_EXYNOS +int board_usb_vbus_init(void) +{ + struct exynos5_gpio_part1 *gpio1 = (struct exynos5_gpio_part1 *) + samsung_get_base_gpio_part1(); + + /* Enable VBUS power switch */ + s5p_gpio_direction_output(&gpio1->x2, 6, 1); + + /* VBUS turn ON time */ + mdelay(3); + + return 0; +} +#endif + int board_init(void) { gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); #ifdef CONFIG_EXYNOS_SPI spi_init(); #endif +#ifdef CONFIG_USB_EHCI_EXYNOS + board_usb_vbus_init(); +#endif return 0; }
Changes from v3:
Changes from v2:
Changes from v1:
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Minkyu Kang
Vivek Gautam
