[U-Boot] common/cmd_nand.c license terms
Dear Scott,
with commit ea533c2 "cmd_nand: some infrastructure fixes and refactoring" (Mon Aug 02, 2010), you added the following license header to common/cmd_nand.c :
+ * Copyright 2010 Freescale Semiconductor + * The portions of this file whose copyright is held by Freescale and which + * are not considered a derived work of GPL v2-only code may be distributed + * and/or modified under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version.
Looking at this commit, it is totally unclear to me which parts of the newly added code you could be referring to with your "which are not considered a derived work of GPL v2-only code".
Your addition makes the legal situation of the whole file pretty much indeterminable. Could you please be so kind and explain what exactly your intention was, and what exactly yuou were referring to?
On 07/28/2013 07:31:00 AM, Wolfgang Denk wrote:
Dear Scott,
- Copyright 2010 Freescale Semiconductor
- The portions of this file whose copyright is held by Freescale
and which
- are not considered a derived work of GPL v2-only code may be
distributed
- and/or modified under the terms of the GNU General Public License
as
- published by the Free Software Foundation; either version 2 of the
- License, or (at your option) any later version.
The license of the whole file is GPLv2 only. The intent was to preemptively grant relicensing permission for GPLv2 or later, if a similar agreement could be reached from other copyright holders, or if the file eventually changes to the point where none of the original v2-only code remains, and if what is left isn't considered derivative of that older code. Likewise, it could be useful (in conjunction with git history) if code gets moved from one file to another.
As for which parts are considered a derivative, I am not a lawyer and can't answer that. It's not a licensing question, but rather a basic copyright question. The point is that it wouldn't be Freescale raising a copyright complaint[1] if you were to license it as v2 or later.
It was a response to your asking for no more v2-only code in U-Boot. We can remove the above text (except the actual copyright line) and make it clearly v2-only if you'd prefer.
-Scott
[1] If you were to actually relicense U-Boot to v3, we'd have a different sort of complaint, in that we'd probably want to fork, but that's separate from licensing.
Dear Scott,
Is it? Why so? It appears that the first versions of that file did not include any license header at all, which means they were contributed under the project-wide GPLv2+ license.
Only your commit added - 7 years later! - a GPLv2 only license header, and I really wonder what the base for this change would be?
Which "original v2-only code" are you referring to?
I fail to see where your "v2-only" notion is coming from.
On 07/29/2013 03:08:23 PM, Wolfgang Denk wrote:
Dear Scott,
of the
not
much
exactly
Hmm... The same text appears in drivers/mtd/nand/nand_util.c, which does have a pre-existing v2-only header. I probably applied it to cmd_nand.c as well because it was unclear whether the existing code was also v2-only.
The project-wide COPYING did not have the "or later" language until Jan 9 2011 (commit b9347188729992ef8282a2854889d8dcc25175aa), so it's not clear to me that the project-wide license was GPLv2+ at the time that the older cmd_nand.c code was submitted, or even at the time that I added the above text.
-Scott
Scott Wood
