Wolfgang,
The following changes since commit 8f86a3636ef88427f880610638e80991adc41896: Wolfgang Denk (1): Merge branch 'master' of git://git.denx.de/u-boot-mpc85xx
git://git.denx.de/u-boot-net.git master
Ben Warren (2): Fix compile error in building MBX860T. Merge git://git.denx.de/u-boot into u-boot
Gary Jennejohn (1): mgcoge make ether_scc.c work with CONFIG_NET_MULTI
Gunnar Rangoy (1): AVR32: macb - Search for PHY id
Heiko Schocher (1): powerpc: net: support for the SMSC LAN8700 PHY
Michal Simek (1): net: Sort Makefile labels
Mike Frysinger (1): Move is_valid_ether_addr() to include/net.h
Nobuhiro Iwamatsu (2): sh: sh_eth: Change new network API sh: sh7763rdp: Update sh7763rdp config
Olav Morken (1): Fix IP alignment problem
Ron Madrid (1): Marvell 88E1118 interrupt fix
Stefan Roese (2): net: smc911x: Make register read/write functions weak net: smc911x.c: Add LAN9211 to chip_ids[] array
board/bf537-stamp/bf537-stamp.c | 16 -- cpu/mpc8260/Makefile | 8 +- cpu/mpc8260/cpu.c | 3 + cpu/mpc8260/ether_scc.c | 50 +++++- cpu/sh4/cpu.c | 8 + drivers/net/Makefile | 4 +- drivers/net/macb.c | 31 ++++ drivers/net/sh_eth.c | 355 +++++++++++++++++++++++++-------------- drivers/net/sh_eth.h | 10 +- drivers/net/smc911x.c | 79 +++++---- drivers/net/tsec.c | 4 + drivers/qe/uec_phy.c | 59 +++++++ include/configs/sh7763rdp.h | 1 + include/net.h | 16 ++ include/netdev.h | 2 + net/net.c | 2 +- 16 files changed, 446 insertions(+), 202 deletions(-)
regards, Ben
Dear Ben Warren,
In message 49852782.8040304@gmail.com you wrote:
Wolfgang,
Applied, thanks.
Ben Warren
