[PATCH v2] bootstage: Fix out-of-bounds read in reloc_bootstage()
bootstage_get_size() returns the total size of the data structure including associated records. When copying from gd->bootstage, only the allocation size of gd->bootstage must be used. Otherwise too much memory is copied.
This bug caused no harm so far because gd->new_bootstage is always large enough and reading beyond the allocation length of gd->bootstage caused no problem due to the U-Boot memory layout.
Fix by using the correct size and perform the initial copy directly in bootstage_relocate() to have the whole relocation process in the same function.
Signed-off-by: Richard Weinberger richard@nod.at --- Changes since v1: - Pass gd->new_bootstage to bootstage_relocate() --- common/board_f.c | 8 +------- common/bootstage.c | 8 ++++++-- include/bootstage.h | 4 ++-- 3 files changed, 9 insertions(+), 11 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 29e185137a..21a8944e2b 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -683,13 +683,7 @@ static int reloc_bootstage(void) if (gd->flags & GD_FLG_SKIP_RELOC) return 0; if (gd->new_bootstage) { - int size = bootstage_get_size(); - - debug("Copying bootstage from %p to %p, size %x\n", - gd->bootstage, gd->new_bootstage, size); - memcpy(gd->new_bootstage, gd->bootstage, size); - gd->bootstage = gd->new_bootstage; - bootstage_relocate(); + bootstage_relocate(gd->new_bootstage); } #endif
diff --git a/common/bootstage.c b/common/bootstage.c index b6c268d9f4..49acc9078a 100644 --- a/common/bootstage.c +++ b/common/bootstage.c @@ -54,12 +54,16 @@ struct bootstage_hdr { u32 next_id; /* Next ID to use for bootstage */ };
-int bootstage_relocate(void) +int bootstage_relocate(void *to) { - struct bootstage_data *data = gd->bootstage; + struct bootstage_data *data; int i; char *ptr;
+ debug("Copying bootstage from %p to %p\n", gd->bootstage, to); + memcpy(to, gd->bootstage, sizeof(struct bootstage_data)); + data = gd->bootstage = to; + /* Figure out where to relocate the strings to */ ptr = (char *)(data + 1);
diff --git a/include/bootstage.h b/include/bootstage.h index f4e77b09d7..57792648c4 100644 --- a/include/bootstage.h +++ b/include/bootstage.h @@ -258,7 +258,7 @@ void show_boot_progress(int val); * relocation, since memory can be overwritten later. * Return: Always returns 0, to indicate success */ -int bootstage_relocate(void); +int bootstage_relocate(void *to);
/** * Add a new bootstage record @@ -395,7 +395,7 @@ static inline ulong bootstage_add_record(enum bootstage_id id, * and won't even do that unless CONFIG_SHOW_BOOT_PROGRESS is defined */
-static inline int bootstage_relocate(void) +static inline int bootstage_relocate(void *to) { return 0; }
Hi Richard,
Changes since v1:
nit below
#endif
should be a separate line (patman/checkpatch complains)
- relocation, since memory can be overwritten later.
- Return: Always returns 0, to indicate success
- Add a new bootstage record
- and won't even do that unless CONFIG_SHOW_BOOT_PROGRESS is defined
-static inline int bootstage_relocate(void) +static inline int bootstage_relocate(void *to) { return 0; } -- 2.35.3
Simon,
Am Donnerstag, 1. August 2024, 16:42:14 CEST schrieb Simon Glass:
I saw the suggestion of checkpatch.pl but ditched it as matter of taste. Do you want a v3?
Thanks, //richard
Hi Richard,
On Thu, 1 Aug 2024 at 08:48, Richard Weinberger richard@sigma-star.at wrote:
Simon,
It's OK I suppose. I used to hate that checkpatch.pl rule too, but have come to get used to it...it avoids hiding the gd-> assignment that my eye is looking for :-)
Thanks, //richard
-- sigma star gmbh | Eduard-Bodem-Gasse 6, 6020 Innsbruck, AUT UID/VAT Nr: ATU 66964118 | FN: 374287y
Richard Weinberger
Richard Weinberger
