[U-Boot] [PATCH] arm: dra7xx: Update bootloader partition size
The current size of U-Boot is already ~840 KiB.
This patch is to increase bootloader partition size up to 1 MiB and thereby fix flashing error.
Also fix U-Boot environment address on eMMC ("reserved" partition), as it's being shifted by above change.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- include/configs/dra7xx_evm.h | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 549439e8b4..1e67c386a0 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -13,6 +13,7 @@ #define __CONFIG_DRA7XX_EVM_H
#include <environment/ti/dfu.h> +#include <linux/sizes.h>
#define CONFIG_DRA7XX
@@ -28,8 +29,8 @@ /* MMC ENV related defines */ #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ -#define CONFIG_ENV_SIZE (128 << 10) -#define CONFIG_ENV_OFFSET 0xE0000 +#define CONFIG_ENV_SIZE SZ_128K +#define CONFIG_ENV_OFFSET 0x1A0000 /* "reserved" part. */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #endif @@ -56,7 +57,7 @@ "partitions_android=" \ "uuid_disk=${uuid_gpt_disk};" \ "name=xloader,start=128K,size=256K,uuid=${uuid_gpt_xloader};" \ - "name=bootloader,size=768K,uuid=${uuid_gpt_bootloader};" \ + "name=bootloader,size=1M,uuid=${uuid_gpt_bootloader};" \ "name=environment,size=128K,uuid=${uuid_gpt_environment};" \ "name=misc,size=128K,uuid=${uuid_gpt_misc};" \ "name=reserved,size=256K,uuid=${uuid_gpt_reserved};" \
Verified Signed-off-by: Praneeth Bajjuri praneeth@ti.com
- "name=bootloader,size=1M,uuid=${uuid_gpt_bootloader};" \ "name=environment,size=128K,uuid=${uuid_gpt_environment};" \ "name=misc,size=128K,uuid=${uuid_gpt_misc};" \ "name=reserved,size=256K,uuid=${uuid_gpt_reserved};" \
+ jj
There might be lot of side effects with this. Is it verified that this is not overlapping with any other section? Also dfu parameters needs to be updated.
Thanks and regards, Lokesh
On 22/02/2017 06:01, Lokesh Vutla wrote:
- jj
It does overlap with other regions used by DFU. I have patch queued for posting that does change the layout of MMC and eMMC to give more room to u-boot, args (dtb) and fixes the overlaps. I'll post it now.
The problems with the current DFU layout are: MMC: The space allocated for u-boot is too small for the latest u-boot (>750KB). We need to increase it. eMMC uses a much bigger area (2MB). eMMC: region "u-boot.img.raw" overlaps the environment area and the region "spl-os-image.raw". both: region "spl-os-image.raw" is quite small and can't handle android kernels
Fixing this requires growing some regions and moving others. Care has been taken to leave some room for further growth of "spl-os-args.raw". Also the "env" now appears in the dfu so that it's apparent that the region is not free space that can be used to grow "u-boot.img.raw". The total space allocated for those raw binaries is 16MB, of which 13+MB are reserved for the kernel image.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com ---
Sam,
This patch goes a bit further in changing the layout of the MMC than yours. However it doesn't update the GPT partitioning. This would still be needed.
tested on DRA7. DFU updates ok for MMC and eMMC
Jean-Jacques
include/configs/dra7xx_evm.h | 2 +- include/configs/omap5_uevm.h | 2 +- include/configs/ti_armv7_common.h | 7 ++++--- include/environment/ti/dfu.h | 14 ++++++++------ 4 files changed, 14 insertions(+), 11 deletions(-)
diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index bce2816..a56c224 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -28,7 +28,7 @@ #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ #define CONFIG_ENV_SIZE (128 << 10) -#define CONFIG_ENV_OFFSET 0xE0000 +#define CONFIG_ENV_OFFSET 0x220000 #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #endif diff --git a/include/configs/omap5_uevm.h b/include/configs/omap5_uevm.h index 736d804..127776e 100644 --- a/include/configs/omap5_uevm.h +++ b/include/configs/omap5_uevm.h @@ -38,7 +38,7 @@ #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ #define CONFIG_ENV_SIZE (128 << 10) -#define CONFIG_ENV_OFFSET 0xE0000 +#define CONFIG_ENV_OFFSET 0x220000 #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #define CONFIG_SYS_REDUNDAND_ENVIRONMENT
diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index 905e1ef..4cfa134 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -282,9 +282,10 @@ #define CONFIG_SPL_FS_LOAD_ARGS_NAME "args"
/* RAW SD card / eMMC */ -#define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR 0x900 /* address 0x120000 */ -#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x80 /* address 0x10000 */ -#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0x80 /* 64KiB */ +#define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR 0x1500 /* address 0x2A0000 */ +#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x1300 /* address 0x260000 */ +#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0x100 /* 128KiB */ +
/* spl export command */ #define CONFIG_CMD_SPL diff --git a/include/environment/ti/dfu.h b/include/environment/ti/dfu.h index caf71a3..63e0ab8 100644 --- a/include/environment/ti/dfu.h +++ b/include/environment/ti/dfu.h @@ -12,9 +12,10 @@ "rootfs part 0 2;" \ "MLO fat 0 1;" \ "MLO.raw raw 0x100 0x100;" \ - "u-boot.img.raw raw 0x300 0x400;" \ - "spl-os-args.raw raw 0x80 0x80;" \ - "spl-os-image.raw raw 0x900 0x2000;" \ + "u-boot.img.raw raw 0x300 0xE00;" \ + "u-env.raw raw 0x1100 0x200;" \ + "spl-os-args.raw raw 0x1300 0x100;" \ + "spl-os-image.raw raw 0x1500 0x6B00;" \ "spl-os-args fat 0 1;" \ "spl-os-image fat 0 1;" \ "u-boot.img fat 0 1;" \ @@ -27,9 +28,10 @@ "rootfs part 1 2;" \ "MLO fat 1 1;" \ "MLO.raw raw 0x100 0x100;" \ - "u-boot.img.raw raw 0x300 0x1000;" \ - "spl-os-args.raw raw 0x80 0x80;" \ - "spl-os-image.raw raw 0x900 0x2000;" \ + "u-boot.img.raw raw 0x300 0xE00;" \ + "u-env.raw raw 0x1100 0x200;" \ + "spl-os-args.raw raw 0x1300 0x100;" \ + "spl-os-image.raw raw 0x1500 0x6B00;" \ "spl-os-args fat 1 1;" \ "spl-os-image fat 1 1;" \ "u-boot.img fat 1 1;" \
Sam,
Hi Jean-Jacques,
Got a couple of questions about this change and my patch (changing eMMC partitions table), about how to make them play nice together.
1. How DFU table is connected to eMMC partition table? And why my patch was interfering with DFU table? 2. Can I change CONFIG_ENV_OFFSET? Because my changes is going to move "reserved" partition on eMMC, where U-Boot environment is stored. Or it should be in sync with DFU table somehow? If yes -- we should work together to find solution that works best for both cases. 3. What about my similar patch for AM57x EVM (see [1])? Is it fine, or it affects DFU table as well?
Thanks.
[1] https://patchwork.ozlabs.org/patch/730736/
Jean-Jacques
-- 1.9.1
Sam,
Hi Jean-Jacques,
- How DFU table is connected to eMMC partition table? And why my
AFAIK DFU is not related to GPT. I never used the GPT so I can't for sure how it fits together. My guess is that env_mmc.c has no idea that GPT even exists and uses raw access to the eMMC. In this case CONFIG_ENV_OFFSET must be defined to point at the beginning of your env partition and must be adapted when the GPT is updated. The same goes for the DFU. Ideally GPT and DFU should use the same layout (at least for MLO, u-boot, kernel and args).
- Can I change CONFIG_ENV_OFFSET? Because my changes is going to move
CONFIG_ENV_OFFSET is loosely related to DFU: we don't update the environment through DFU. However we must make sure that the area used to store the env doesn't overlap a another region (MLO, u-boot, kernel, args). The dfu doesn't define those regions, it's done with #defines like CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR. But DFU exposes them for "remote" upgrade.
- What about my similar patch for AM57x EVM (see [1])? Is it fine, or
I guess it's OK because the env is stored in a FAT partition: CONFIG_ENV_OFFSET is not used
Thanks.
Jean-Jacques
-- 1.9.1
Sam,
Hi Jean-Jacques,
So if I change eMMC GPT partition table, it's ok for me to update CONFIG_ENV_OFFSET as well, right? Because in my case CONFIG_ENV_OFFSET is going to be different from the value your patch sets. In case of eMMC table, we're using "reserved" partition to store U-Boot environment, and I want it to be at 1664 KiB, which gives us CONFIG_ENV_OFFSET=0x1A0000. Is it ok if I change it to that value? Or something else must be changed along with it? If yes, then what exactly?
Thanks.
Thanks.
Jean-Jacques
-- 1.9.1
Sam,
Hi Jean-Jacques,
Yes you need to change it
You need to adapt DFU if you plan to use it. Maybe you can define a new layout for DFU, something like dfu_alt_info_emmc_gpt that will reflect your GPT layout
Anyway IMO it would be good to use the same offset/size for GPT and non-GPT case for the following regions: - MLO - u-boot - env
For MLO we already use the same: offset 128kB / size 256kB For u-boot, you increased the size to 1MB, I suggest that we increase it a bit more (1.5MB or 2MB) just to make sure that we don't have to increase its size again next year. For the env, I suggest that the size is increased to 256kB to take care of redundant env.
Thanks.
Thanks.
Jean-Jacques
-- 1.9.1
Sam,
Hi Jean-Jacques,
- MLO
- u-boot
- env
Thank you for detailed explanation. I'm gonna get back to that task in a few weeks, don't have enough time right now. Once I come up with some particular patch, I will add you to reviewers, to be sure that DFU part is correct.
Thanks.
Thanks.
Jean-Jacques
-- 1.9.1
Sam,
Hi Jean-Jacques,
- MLO
- u-boot
- env
Before you switch to another task maybe we can agree on the offset and sizes for MLO, u-boot and env so that I can do the necessary changes on my side (dfu, #defines).
Thanks.
Thanks.
Jean-Jacques
-- 1.9.1
On Wed, Feb 22, 2017 at 10:27 AM, Jean-Jacques Hiblot jjhiblot@ti.com wrote: > > The problems with the current DFU layout are: > MMC: The space allocated for u-boot is too small for the latest > u-boot > (>750KB). We need to increase it. eMMC uses a much bigger > area > (2MB). > eMMC: region "u-boot.img.raw" overlaps the environment area and the > region > "spl-os-image.raw". > both: region "spl-os-image.raw" is quite small and can't handle > android > kernels > > Fixing this requires growing some regions and moving others. > Care has been taken to leave some room for further growth of > "spl-os-args.raw". > Also the "env" now appears in the dfu so that it's apparent that the > region is not free space that can be used to grow "u-boot.img.raw". > The total space allocated for those raw binaries is 16MB, of which > 13+MB > are reserved for the kernel image. > > Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com > --- > > Sam, > > This patch goes a bit further in changing the layout of the MMC than > yours. However > it doesn't update the GPT partitioning. This would still be needed. > Hi Jean-Jacques,
- MLO
- u-boot
- env
Sure. I agree with you that we should increase U-Boot partition. I'm gonna do next layout for eMMC table:
MLO: start=128K, size=256K U-Boot: size=2M DTB: size=128K misc: size=128K U-Boot environment: size=256K efs: size=16M crypto: size=16K recovery: size=10M boot: size=10M system: size=768M cache: size=256M ipu1: size=1M ipu2: size=1M userdata: size=the rest of eMMC space
Is it ok with you? Also, we should check if it's ok with Praneeth, as he mentioned that some changes to that table may be necessary in the future (from Android side).
Thanks.
Thanks.
> tested on DRA7. DFU updates ok for MMC and eMMC > > Jean-Jacques > > include/configs/dra7xx_evm.h | 2 +- > include/configs/omap5_uevm.h | 2 +- > include/configs/ti_armv7_common.h | 7 ++++--- > include/environment/ti/dfu.h | 14 ++++++++------ > 4 files changed, 14 insertions(+), 11 deletions(-) > > diff --git a/include/configs/dra7xx_evm.h > b/include/configs/dra7xx_evm.h > index bce2816..a56c224 100644 > --- a/include/configs/dra7xx_evm.h > +++ b/include/configs/dra7xx_evm.h > @@ -28,7 +28,7 @@ > #define CONFIG_ENV_IS_IN_MMC > #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) > */ > #define CONFIG_ENV_SIZE (128 << 10) > -#define CONFIG_ENV_OFFSET 0xE0000 > +#define CONFIG_ENV_OFFSET 0x220000 > #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + > CONFIG_ENV_SIZE) > #define CONFIG_SYS_REDUNDAND_ENVIRONMENT > #endif > diff --git a/include/configs/omap5_uevm.h > b/include/configs/omap5_uevm.h > index 736d804..127776e 100644 > --- a/include/configs/omap5_uevm.h > +++ b/include/configs/omap5_uevm.h > @@ -38,7 +38,7 @@ > #define CONFIG_ENV_IS_IN_MMC > #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) > */ > #define CONFIG_ENV_SIZE (128 << 10) > -#define CONFIG_ENV_OFFSET 0xE0000 > +#define CONFIG_ENV_OFFSET 0x220000 > #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + > CONFIG_ENV_SIZE) > #define CONFIG_SYS_REDUNDAND_ENVIRONMENT > > diff --git a/include/configs/ti_armv7_common.h > b/include/configs/ti_armv7_common.h > index 905e1ef..4cfa134 100644 > --- a/include/configs/ti_armv7_common.h > +++ b/include/configs/ti_armv7_common.h > @@ -282,9 +282,10 @@ > #define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" > > /* RAW SD card / eMMC */ > -#define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR 0x900 /* > address 0x120000 */ > -#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x80 /* address > 0x10000 */ > -#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0x80 /* 64KiB */ > +#define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR 0x1500 /* > address 0x2A0000 */ > +#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x1300 /* address > 0x260000 */ > +#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0x100 /* 128KiB */ > + > > /* spl export command */ > #define CONFIG_CMD_SPL > diff --git a/include/environment/ti/dfu.h > b/include/environment/ti/dfu.h > index caf71a3..63e0ab8 100644 > --- a/include/environment/ti/dfu.h > +++ b/include/environment/ti/dfu.h > @@ -12,9 +12,10 @@ > "rootfs part 0 2;" \ > "MLO fat 0 1;" \ > "MLO.raw raw 0x100 0x100;" \ > - "u-boot.img.raw raw 0x300 0x400;" \ > - "spl-os-args.raw raw 0x80 0x80;" \ > - "spl-os-image.raw raw 0x900 0x2000;" \ > + "u-boot.img.raw raw 0x300 0xE00;" \ > + "u-env.raw raw 0x1100 0x200;" \ > + "spl-os-args.raw raw 0x1300 0x100;" \ > + "spl-os-image.raw raw 0x1500 0x6B00;" \ > "spl-os-args fat 0 1;" \ > "spl-os-image fat 0 1;" \ > "u-boot.img fat 0 1;" \ > @@ -27,9 +28,10 @@ > "rootfs part 1 2;" \ > "MLO fat 1 1;" \ > "MLO.raw raw 0x100 0x100;" \ > - "u-boot.img.raw raw 0x300 0x1000;" \ > - "spl-os-args.raw raw 0x80 0x80;" \ > - "spl-os-image.raw raw 0x900 0x2000;" \ > + "u-boot.img.raw raw 0x300 0xE00;" \ > + "u-env.raw raw 0x1100 0x200;" \ > + "spl-os-args.raw raw 0x1300 0x100;" \ > + "spl-os-image.raw raw 0x1500 0x6B00;" \ > "spl-os-args fat 1 1;" \ > "spl-os-image fat 1 1;" \ > "u-boot.img fat 1 1;" \ > -- > 1.9.1 >
On 23/02/2017 14:46, Sam Protsenko wrote: > On Wed, Feb 22, 2017 at 10:27 AM, Jean-Jacques Hiblot > jjhiblot@ti.com > wrote: >> The problems with the current DFU layout are: >> MMC: The space allocated for u-boot is too small for the latest >> u-boot >> (>750KB). We need to increase it. eMMC uses a much bigger >> area >> (2MB). >> eMMC: region "u-boot.img.raw" overlaps the environment area and the >> region >> "spl-os-image.raw". >> both: region "spl-os-image.raw" is quite small and can't handle >> android >> kernels >> >> Fixing this requires growing some regions and moving others. >> Care has been taken to leave some room for further growth of >> "spl-os-args.raw". >> Also the "env" now appears in the dfu so that it's apparent that the >> region is not free space that can be used to grow "u-boot.img.raw". >> The total space allocated for those raw binaries is 16MB, of which >> 13+MB >> are reserved for the kernel image. >> >> Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com >> --- >> >> Sam, >> >> This patch goes a bit further in changing the layout of the MMC than >> yours. However >> it doesn't update the GPT partitioning. This would still be needed. >> > Hi Jean-Jacques, > > Got a couple of questions about this change and my patch (changing > eMMC partitions table), about how to make them play nice together. > > 1. How DFU table is connected to eMMC partition table? And why my > patch was interfering with DFU table? AFAIK DFU is not related to GPT. I never used the GPT so I can't for sure how it fits together. My guess is that env_mmc.c has no idea that GPT even exists and uses raw access to the eMMC. In this case CONFIG_ENV_OFFSET must be defined to point at the beginning of your env partition and must be adapted when the GPT is updated. The same goes for the DFU. Ideally GPT and DFU should use the same layout (at least for MLO, u-boot, kernel and args).
> 2. Can I change CONFIG_ENV_OFFSET? Because my changes is going to move > "reserved" partition on eMMC, where U-Boot environment is stored. Or > it should be in sync with DFU table somehow? If yes -- we should work > together to find solution that works best for both cases. CONFIG_ENV_OFFSET is loosely related to DFU: we don't update the environment through DFU. However we must make sure that the area used to store the env doesn't overlap a another region (MLO, u-boot, kernel, args). The dfu doesn't define those regions, it's done with #defines like CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR. But DFU exposes them for "remote" upgrade.
- MLO
- u-boot
- env
Sorry I took so long to reply. I'd re-arrange the following 3 elements and make the dtb area bigger. At the moment DTBs are around 100k but they keep growing.
U-Boot environment: size=256K DTB: size=256K misc: size=128K
JJ
Thanks.
> 3. What about my similar patch for AM57x EVM (see [1])? Is it fine, or > it affects DFU table as well? I guess it's OK because the env is stored in a FAT partition: CONFIG_ENV_OFFSET is not used
> Thanks. > > [1] https://patchwork.ozlabs.org/patch/730736/ > >> tested on DRA7. DFU updates ok for MMC and eMMC >> >> Jean-Jacques >> >> include/configs/dra7xx_evm.h | 2 +- >> include/configs/omap5_uevm.h | 2 +- >> include/configs/ti_armv7_common.h | 7 ++++--- >> include/environment/ti/dfu.h | 14 ++++++++------ >> 4 files changed, 14 insertions(+), 11 deletions(-) >> >> diff --git a/include/configs/dra7xx_evm.h >> b/include/configs/dra7xx_evm.h >> index bce2816..a56c224 100644 >> --- a/include/configs/dra7xx_evm.h >> +++ b/include/configs/dra7xx_evm.h >> @@ -28,7 +28,7 @@ >> #define CONFIG_ENV_IS_IN_MMC >> #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) >> */ >> #define CONFIG_ENV_SIZE (128 << 10) >> -#define CONFIG_ENV_OFFSET 0xE0000 >> +#define CONFIG_ENV_OFFSET 0x220000 >> #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + >> CONFIG_ENV_SIZE) >> #define CONFIG_SYS_REDUNDAND_ENVIRONMENT >> #endif >> diff --git a/include/configs/omap5_uevm.h >> b/include/configs/omap5_uevm.h >> index 736d804..127776e 100644 >> --- a/include/configs/omap5_uevm.h >> +++ b/include/configs/omap5_uevm.h >> @@ -38,7 +38,7 @@ >> #define CONFIG_ENV_IS_IN_MMC >> #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) >> */ >> #define CONFIG_ENV_SIZE (128 << 10) >> -#define CONFIG_ENV_OFFSET 0xE0000 >> +#define CONFIG_ENV_OFFSET 0x220000 >> #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + >> CONFIG_ENV_SIZE) >> #define CONFIG_SYS_REDUNDAND_ENVIRONMENT >> >> diff --git a/include/configs/ti_armv7_common.h >> b/include/configs/ti_armv7_common.h >> index 905e1ef..4cfa134 100644 >> --- a/include/configs/ti_armv7_common.h >> +++ b/include/configs/ti_armv7_common.h >> @@ -282,9 +282,10 @@ >> #define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" >> >> /* RAW SD card / eMMC */ >> -#define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR 0x900 /* >> address 0x120000 */ >> -#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x80 /* address >> 0x10000 */ >> -#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0x80 /* 64KiB */ >> +#define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR 0x1500 /* >> address 0x2A0000 */ >> +#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x1300 /* address >> 0x260000 */ >> +#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0x100 /* 128KiB */ >> + >> >> /* spl export command */ >> #define CONFIG_CMD_SPL >> diff --git a/include/environment/ti/dfu.h >> b/include/environment/ti/dfu.h >> index caf71a3..63e0ab8 100644 >> --- a/include/environment/ti/dfu.h >> +++ b/include/environment/ti/dfu.h >> @@ -12,9 +12,10 @@ >> "rootfs part 0 2;" \ >> "MLO fat 0 1;" \ >> "MLO.raw raw 0x100 0x100;" \ >> - "u-boot.img.raw raw 0x300 0x400;" \ >> - "spl-os-args.raw raw 0x80 0x80;" \ >> - "spl-os-image.raw raw 0x900 0x2000;" \ >> + "u-boot.img.raw raw 0x300 0xE00;" \ >> + "u-env.raw raw 0x1100 0x200;" \ >> + "spl-os-args.raw raw 0x1300 0x100;" \ >> + "spl-os-image.raw raw 0x1500 0x6B00;" \ >> "spl-os-args fat 0 1;" \ >> "spl-os-image fat 0 1;" \ >> "u-boot.img fat 0 1;" \ >> @@ -27,9 +28,10 @@ >> "rootfs part 1 2;" \ >> "MLO fat 1 1;" \ >> "MLO.raw raw 0x100 0x100;" \ >> - "u-boot.img.raw raw 0x300 0x1000;" \ >> - "spl-os-args.raw raw 0x80 0x80;" \ >> - "spl-os-image.raw raw 0x900 0x2000;" \ >> + "u-boot.img.raw raw 0x300 0xE00;" \ >> + "u-env.raw raw 0x1100 0x200;" \ >> + "spl-os-args.raw raw 0x1300 0x100;" \ >> + "spl-os-image.raw raw 0x1500 0x6B00;" \ >> "spl-os-args fat 1 1;" \ >> "spl-os-image fat 1 1;" \ >> "u-boot.img fat 1 1;" \ >> -- >> 1.9.1 >>
I know I'm late chiming in here, but I want to now, all the same. First, we need to explain _why_ things are getting so huge. The answer is that we're including so many (complete, from Linux) device trees. So we should probably update the comments around this area to note why the bootloader partition is so large, and then pick a good, large, and aligned with the underlying erase block size partition.
Tom,
Your comment is absolutely correct, I was just in a little bit hurry when sending this patch. Please don't merge it yet, I'm gonna get back to it after Linaro Connect. Things you mentioned will be added to commit message, and we are probably going to change that partition size one more time. So let's hold on on this change for now.
Thanks.
-- Tom
participants (5)
Bajjuri, Praneeth
Jean-Jacques Hiblot
Lokesh Vutla
Sam Protsenko
