[PATCH] common: add blkcache init
From: Angelo Durgehello angelo.dureghello@timesys.com
On m68k, block_cache list is relocated, but next and prev list pointers are not adjusted to the relocated struct list_head address, so the first iteration over the block_cache list hangs.
This patch initializes the block_cache list after relocation.
Signed-off-by: Angelo Durgehello angelo.dureghello@timesys.com --- Changes for v2: - call blkcache_init directly --- common/board_r.c | 3 +++ drivers/block/blkcache.c | 9 ++++++++- include/blk.h | 6 ++++++ 3 files changed, 17 insertions(+), 1 deletion(-)
diff --git a/common/board_r.c b/common/board_r.c index 8a0c1114e7..4f56c19fcc 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -864,6 +864,9 @@ static init_fnc_t init_sequence_r[] = { #endif #if defined(CONFIG_PRAM) initr_mem, +#endif +#ifdef CONFIG_BLOCK_CACHE + blkcache_init, #endif run_main_loop, }; diff --git a/drivers/block/blkcache.c b/drivers/block/blkcache.c index 1fa64989d3..f603aa129d 100644 --- a/drivers/block/blkcache.c +++ b/drivers/block/blkcache.c @@ -21,13 +21,20 @@ struct block_cache_node { char *cache; };
-static LIST_HEAD(block_cache); +static struct list_head block_cache;
static struct block_cache_stats _stats = { .max_blocks_per_entry = 8, .max_entries = 32 };
+int blkcache_init(void) +{ + INIT_LIST_HEAD(&block_cache); + + return 0; +} + static struct block_cache_node *cache_find(int iftype, int devnum, lbaint_t start, lbaint_t blkcnt, unsigned long blksz) diff --git a/include/blk.h b/include/blk.h index d0c033aece..65db69f5d9 100644 --- a/include/blk.h +++ b/include/blk.h @@ -113,6 +113,12 @@ struct blk_desc { (PAD_SIZE(size, blk_desc->blksz))
#if CONFIG_IS_ENABLED(BLOCK_CACHE) + +/** + * blkcache_init() - initialize the block cache list pointers + */ +int blkcache_init(void); + /** * blkcache_read() - attempt to read a set of blocks from cache *
Thanks Angelo,
Changes for v2:
- blkcache_init, #endif run_main_loop, };
- INIT_LIST_HEAD(&block_cache);
- static struct block_cache_node *cache_find(int iftype, int devnum, lbaint_t start, lbaint_t blkcnt, unsigned long blksz)
- blkcache_init() - initialize the block cache list pointers
- blkcache_read() - attempt to read a set of blocks from cache
This looks good to me.
Reviewed-by: Eric Nelson eric@nelint.com
Signed-off-by: Angelo Durgehello angelo.dureghello@timesys.com Reviewed-by: Eric Nelson eric@nelint.com
Hi Angelo
Changes for v2:
- blkcache_init,
Unfortunately this one seems to break i.MX 8M Mini booting:
U-Boot SPL 2020.01-00179-g35ac4f216b (Jan 25 2020 - 23:36:35 +0100) Normal Boot Trying to boot from MMC1 NOTICE: Configuring TZASC380 NOTICE: RDC off NOTICE: BL31: v2.0(release):rel_imx_4.14.98_2.3.0-0-g09c5cc994-dirty NOTICE: BL31: Built : 01:11:41, Jan 25 2020 NOTICE: sip svc init
U-Boot 2020.01-00179-g35ac4f216b (Jan 25 2020 - 23:36:35 +0100)
CPU: Freescale i.MX8MMQ rev1.0 at 0 MHz Reset cause: POR DRAM: 2 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 Loading Environment from MMC... "Synchronous Abort" handler, esr 0x96000004 elr: 0000000040226de8 lr : 000000004021e99c (reloc) elr: 00000000bff7fde8 lr : 00000000bff7799c x0 : 0000000002000f00 x1 : 0000000000000000 x2 : 00000000fffffffb x3 : 0000000000000020 x4 : 0000000000000000 x5 : 0000000000000030 x6 : 0000000000000002 x7 : 00000000bdf4ecf0 x8 : 0000000000000000 x9 : 0000000000000008 x10: 00000000ffffffe0 x11: 0000000000000006 x12: 000000000001869f x13: 0000000000005339 x14: 0000000000006694 x15: 00000000ffffffff x16: 0000000000002080 x17: 0000000000004180 x18: 00000000bdf58d70 x19: 01e0000002000f00 x20: 00000000bffec258 x21: 00000000bffcca10 x22: 01e0000002000f00 x23: 0000000000000006 x24: 0000000000000000 x25: 0000000000000000 x26: 0000000000000000 x27: 0000000000000000 x28: 0000000000000000 x29: 00000000bdf4edc0
Code: b9400aa0 51000400 b9000aa0 aa1603f3 (f94002d6) Resetting CPU ...
resetting ...
Reverting just this patch makes it boot fine again.
Cheers
Marcel
Hi Marcel,
thanks for reporting, the fix should be already in master, please let me know if it works on your hardware.
Regards, Angleo
On Mon, Jan 27, 2020 at 8:38 AM Marcel Ziswiler marcel.ziswiler@toradex.com wrote:
Hi Angelo
Changes for v2:
blkcache_init,
resetting ...
Cheers
Marcel
Hi Angelo
On Mon, 2020-01-27 at 08:57 +0100, Angelo Dureghello wrote:
Hi Marcel,
Yes, that works. Thanks!
Regards, Angleo
Cheers
Marcel
Hi Angelo
Changes for v2:
blkcache_init,
U-Boot SPL 2020.01-00179-g35ac4f216b (Jan 25 2020 - 23:36:35 +0100) Normal Boot Trying to boot from MMC1 NOTICE: Configuring TZASC380 NOTICE: RDC off NOTICE: BL31: v2.0(release):rel_imx_4.14.98_2.3.0-0-g09c5cc994- dirty NOTICE: BL31: Built : 01:11:41, Jan 25 2020 NOTICE: sip svc init
resetting ...
Cheers
Marcel
Angelo Dureghello
Eric Nelson
Marcel Ziswiler
