[U-Boot] efi: fix memory calculation overflow on 32-bit systems
There are Cubox-i machines out there with nearly 4 GiB of RAM. The RAM starts at 0x10000000 with a size of 0xf0000000. Thus the end of RAM is at 0x100000000. This overflows a 32-bit integer, which should be fine since in the EFI memory code the variables used are all 64-bit with a fixed size. Unfortunately EFI_PAGE_MASK, which is used in the EFI memory code to remove the lower bits, is based on the EFI_PAGE_SIZE macro which, uses 1UL with a shift. This means the resulting mask is UL, which is only 32-bit on ARMv7. Use ULL to make sure that even on 32-bit platforms we use a 64-bit long mask. Without this there will be no memory available in the EFI memory map and bootefi will fail allocating pages.
Best regards, Patrick
diff --git a/include/efi.h b/include/efi.h index d98441ab19d..3c9d20f8c0b 100644 --- a/include/efi.h +++ b/include/efi.h @@ -190,7 +190,7 @@ enum efi_mem_type { #define EFI_MEM_DESC_VERSION 1
#define EFI_PAGE_SHIFT 12 -#define EFI_PAGE_SIZE (1UL << EFI_PAGE_SHIFT) +#define EFI_PAGE_SIZE (1ULL << EFI_PAGE_SHIFT) #define EFI_PAGE_MASK (EFI_PAGE_SIZE - 1)
struct efi_mem_desc {
We are using `& ~EFI_PAGE_MASK` in multiplaces for 64bit operations. So it makes sense to use a 64bit value.
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Hi Patrick,
From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Patrick Wildt
Same issue for stm32mp157c-ev1 board (32bits platform with 1GB at 0xC0000000).
Patched tested on v2019.04 and my issue is solved and it is a better approach that my patch http://patchwork.ozlabs.org/patch/1083262/
So I will abandon my path and
Reviewed-by: Patrick Delaunay patrick.delaunay@st.com
Regards
Patrick
Patrick DELAUNAY
Patrick Wildt
