[U-Boot-Users] [PATCH 1/3] ppc4xx: PPC405GPr add missing EIRR register
Signed-off-by: Niklaus Giger niklaus.giger@netstal.com --- include/ppc405.h | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/include/ppc405.h b/include/ppc405.h index b5ad38f..fbfb681 100644 --- a/include/ppc405.h +++ b/include/ppc405.h @@ -784,6 +784,10 @@ #define reset (CNTRL_DCR_BASE+0x3) /* reset register */ #define strap (CNTRL_DCR_BASE+0x4) /* strap register */
+#ifdef CONFIG_405GPr +#define eirr (CNTRL_DCR_BASE+0x6) /* external interrupt routing register */ +#endif + #define ecr (0xaa) /* edge conditioner register (405gpr) */
/* Bit definitions */
Avoid errors for make O=../build and ./MAKEALL hcu4 hcu5.
Signed-off-by: Niklaus Giger niklaus.giger@netstal.com --- board/netstal/hcu4/Makefile | 12 ++++-------- board/netstal/hcu5/Makefile | 10 ++++------ 2 files changed, 8 insertions(+), 14 deletions(-)
diff --git a/board/netstal/hcu4/Makefile b/board/netstal/hcu4/Makefile index b13d9d4..3d1d65d 100644 --- a/board/netstal/hcu4/Makefile +++ b/board/netstal/hcu4/Makefile @@ -1,5 +1,5 @@ # -# (C) Copyright 2007 Netstal Maschinen AG +# (C) Copyright 2007-2008 Netstal Maschinen AG # Niklaus Giger (ng@netstal.com) # # This program is free software; you can redistribute it and/or @@ -22,18 +22,14 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).a
-vpath fixed_sdram.c ../common -vpath hcu_flash.c ../common -vpath nm_bsp.c ../common - # NOBJS : Netstal common objects -NOBJS = ../common/fixed_sdram.o ../common/hcu_flash.o ../common/nm_bsp.o +NOBJS = fixed_sdram.o hcu_flash.o nm_bsp.o COBJS = $(BOARD).o SOBJS =
-SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) $(NOBJS:.o=.c) +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) $(addprefix ../common/,$(NOBJS:.o=.c)) OBJS := $(addprefix $(obj),$(COBJS)) -NOBJS := $(addprefix $(obj),$(NOBJS)) +NOBJS := $(addprefix $(obj)../common/,$(NOBJS)) SOBJS := $(addprefix $(obj),$(SOBJS))
$(LIB): $(OBJS) $(SOBJS) $(NOBJS) diff --git a/board/netstal/hcu5/Makefile b/board/netstal/hcu5/Makefile index 9f248a4..349c653 100644 --- a/board/netstal/hcu5/Makefile +++ b/board/netstal/hcu5/Makefile @@ -1,5 +1,5 @@ # -# (C) Copyright 2007 Netstal Maschinen AG +# (C) Copyright 2007-2008 Netstal Maschinen AG # Niklaus Giger (ng@netstal.com) # # This program is free software; you can redistribute it and/or @@ -22,17 +22,15 @@ include $(TOPDIR)/config.mk
# NOBJS : Netstal common objects -NOBJS = ../common/hcu_flash.o ../common/nm_bsp.o +NOBJS = hcu_flash.o nm_bsp.o COBJS = $(BOARD).o sdram.o SOBJS = init.o
- Fix some coding style violations. - Use in/out_u16/32 where appropriate. - Use register names from ppc405.h. - Fix trace useage for Lauterbach. - Fix detection of vxWorks EDR. - Remove obsolete generation HCU2. - Renamed fixed_hcu4_sdram to init_ppc405_sdram.
Signed-off-by: Niklaus Giger niklaus.giger@netstal.com --- board/netstal/common/fixed_sdram.c | 2 +- board/netstal/common/hcu_flash.c | 14 ------ board/netstal/common/nm.h | 11 ++++- board/netstal/common/nm_bsp.c | 4 +- board/netstal/hcu4/hcu4.c | 78 ++++++++++++++++-------------------- board/netstal/hcu5/hcu5.c | 8 +-- board/netstal/hcu5/sdram.c | 32 +++++++++------ 7 files changed, 68 insertions(+), 81 deletions(-)
diff --git a/board/netstal/common/fixed_sdram.c b/board/netstal/common/fixed_sdram.c index 8082f60..1df790c 100644 --- a/board/netstal/common/fixed_sdram.c +++ b/board/netstal/common/fixed_sdram.c @@ -44,7 +44,7 @@ void show_sdram_registers(void) } #endif
-long int fixed_hcu4_sdram (unsigned int dram_size) +long int init_ppc405_sdram (unsigned int dram_size) { #ifdef DEBUG printf(__FUNCTION__); diff --git a/board/netstal/common/hcu_flash.c b/board/netstal/common/hcu_flash.c index be2cb37..d0322f2 100644 --- a/board/netstal/common/hcu_flash.c +++ b/board/netstal/common/hcu_flash.c @@ -21,18 +21,6 @@ * MA 02111-1307 USA */
-/* - * Modified 4/5/2001 - * Wait for completion of each sector erase command issued - * 4/5/2001 - * Chris Hallinan - DS4.COM, Inc. - clh@net1plus.com - * - * Modified 6/6/2007 - * Added isync - * Niklaus Giger, Netstal Maschinen, niklaus.giger@netstal.com - * - */ - #include <common.h> #include <ppc4xx.h> #include <asm/processor.h> @@ -387,7 +375,6 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) /* wait at least 80us - let's wait 1 ms */ udelay (1000);
-#if 0 /* * We wait for the last triggered sector */ @@ -396,7 +383,6 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) wait_for_DQ7 (info, l_sect);
DONE: -#endif /* reset to read mode */ addr = (FLASH_WORD_SIZE *) info->start[0]; addr[0] = (FLASH_WORD_SIZE) 0x00F000F0; /* reset bank */ diff --git a/board/netstal/common/nm.h b/board/netstal/common/nm.h index 2801e13..f6acd47 100644 --- a/board/netstal/common/nm.h +++ b/board/netstal/common/nm.h @@ -27,8 +27,7 @@ extern void set_params_for_sw_install(int install_requested, char *board_name ); extern void common_misc_init_r(void);
enum { - /* HW_GENERATION_HCU1 is no longer supported */ - HW_GENERATION_HCU2 = 0x10, + /* HW_GENERATION_HCU1/2 is no longer supported */ HW_GENERATION_HCU3 = 0x10, HW_GENERATION_HCU4 = 0x20, HW_GENERATION_HCU5 = 0x30, @@ -36,3 +35,11 @@ enum { HW_GENERATION_MCU20 = 0x0a, HW_GENERATION_MCU25 = 0x09, }; + +#ifdef CONFIG_405GPr +#if defined(DEBUG) +void show_sdram_registers(void); +#endif +long int init_ppc405_sdram (unsigned int dram_size); +#endif + diff --git a/board/netstal/common/nm_bsp.c b/board/netstal/common/nm_bsp.c index c4265bb..89c697c 100644 --- a/board/netstal/common/nm_bsp.c +++ b/board/netstal/common/nm_bsp.c @@ -29,8 +29,7 @@ DECLARE_GLOBAL_DATA_PTR;
typedef struct {u8 id; char *name;} generation_info;
-generation_info generations[7] = { - {HW_GENERATION_HCU2, "HCU2"}, +generation_info generations[6] = { {HW_GENERATION_HCU3, "HCU3"}, {HW_GENERATION_HCU4, "HCU4"}, {HW_GENERATION_HCU5, "HCU5"}, @@ -134,3 +133,4 @@ void common_misc_init_r(void) saveenv(); } } + diff --git a/board/netstal/hcu4/hcu4.c b/board/netstal/hcu4/hcu4.c index 4fbe701..43057a0 100644 --- a/board/netstal/hcu4/hcu4.c +++ b/board/netstal/hcu4/hcu4.c @@ -1,5 +1,5 @@ /* - *(C) Copyright 2005-2007 Netstal Maschinen AG + *(C) Copyright 2005-2008 Netstal Maschinen AG * Niklaus Giger (Niklaus.Giger@netstal.com) * * This source code is free software; you can redistribute it @@ -28,17 +28,10 @@ DECLARE_GLOBAL_DATA_PTR;
#define HCU_MACH_VERSIONS_REGISTER (0x7C000000 + 0xF00000) -#define SYS_SLOT_ADDRESS (0x7C000000 + 0x400000) -#define HCU3_DIGITAL_IO_REGISTER (0x7C000000 + 0x500000) +#define HCU_SLOT_ADDRESS (0x7C000000 + 0x400000) +#define HCU_DIGITAL_IO_REGISTER (0x7C000000 + 0x500000) #define HCU_SW_INSTALL_REQUESTED 0x10
-#undef DEBUG - -#if defined(DEBUG) -void show_sdram_registers(void); -#endif -long int fixed_hcu4_sdram (unsigned int dram_size); - /* * This function is run very early, out of flash, and before devices are * initialized. It is called by lib_ppc/board.c:board_init_f by virtue @@ -49,17 +42,12 @@ long int fixed_hcu4_sdram (unsigned int dram_size); * anything, not even stack. So be careful. */
-#define CPC0_CR0 0xb1 /* Chip control register 0 */ -#define CPC0_CR1 0xb2 /* Chip control register 1 */ /* Attention: If you want 1 microsecs times from the external oscillator - * use 0x00804051. But this causes problems with u-boot and linux! + * 0x00004051 is okay for u-boot/linux, but different from old vxworks values + * 0x00804051 causes problems with u-boot and linux! */ #define CPC0_CR0_VALUE 0x0030103c #define CPC0_CR1_VALUE 0x00004051 -#define CPC0_ECR 0xaa /* Edge condition register */ -#define EBC0_CFG 0x23 /* External Peripheral Control Register */ -#define CPC0_EIRR 0xb6 /* External Interrupt Register */ -
int board_early_init_f (void) { @@ -70,16 +58,16 @@ int board_early_init_f (void) * IRQ 17-24 RESERVED/UNUSED * IRQ 31 (EXT IRQ 6) (unused) */ - mtdcr (uicsr, 0xFFFFFFFF); /* clear all ints */ - mtdcr (uicer, 0x00000000); /* disable all ints */ - mtdcr (uiccr, 0x00000000); /* set all to be non-critical */ - mtdcr (uicpr, 0xFFFFE000); /* set int polarities */ - mtdcr (uictr, 0x00000000); /* set int trigger levels */ - mtdcr (uicsr, 0xFFFFFFFF); /* clear all ints */ + mtdcr(uicsr, 0xFFFFFFFF); /* clear all ints */ + mtdcr(uicer, 0x00000000); /* disable all ints */ + mtdcr(uiccr, 0x00000000); /* set all to be non-critical */ + mtdcr(uicpr, 0xFFFFE000); /* set int polarities */ + mtdcr(uictr, 0x00000000); /* set int trigger levels */ + mtdcr(uicsr, 0xFFFFFFFF); /* clear all ints */
- mtdcr(CPC0_CR1, CPC0_CR1_VALUE); - mtdcr(CPC0_ECR, 0x60606000); - mtdcr(CPC0_EIRR, 0x7c000000); + mtdcr(cntrl1, CPC0_CR1_VALUE); + mtdcr(ecr, 0x60606000); + mtdcr(eirr, 0x7C000000);
return 0; } @@ -93,18 +81,19 @@ int board_pre_init (void)
int sys_install_requested(void) { - u16 *ioValuePtr = (u16 *)HCU3_DIGITAL_IO_REGISTER; - return (in_be16(ioValuePtr) & HCU_SW_INSTALL_REQUESTED) != 0; + u16 ioValue = in_be16((u16 *)HCU_DIGITAL_IO_REGISTER); + return (ioValue & HCU_SW_INSTALL_REQUESTED) != 0; }
int checkboard (void) { - u16 *boardVersReg = (u16 *)HCU_MACH_VERSIONS_REGISTER; - u16 generation = in_be16(boardVersReg) & 0xf0; - u16 index = in_be16(boardVersReg) & 0x0f; + u16 boardVersReg = in_be16((u16 *)HCU_MACH_VERSIONS_REGISTER); + u16 generation = boardVersReg & 0xf0; + u16 index = boardVersReg & 0x0f; + + /* Cannot be done in board_early_init */ + mtdcr(cntrl0, CPC0_CR0_VALUE);
- /* Cannot be done, in board_early_init */ - mtdcr(CPC0_CR0, CPC0_CR0_VALUE); /* Force /RTS to active. The board it not wired quite * correctly to use cts/rtc flow control, so just force the * /RST active and forget about it. @@ -145,8 +134,8 @@ void sdram_init(void) */ u32 hcu_get_slot(void) { - u16 *slot = (u16 *)SYS_SLOT_ADDRESS; - return in_be16(slot) & 0x7f; + u16 slot = in_be16((u16 *)HCU_SLOT_ADDRESS); + return slot & 0x7f; }
/* @@ -154,12 +143,12 @@ u32 hcu_get_slot(void) */ u32 get_serial_number(void) { - u32 *serial = (u32 *)CFG_FLASH_BASE; + u32 serial = in_be32((u32 *)CFG_FLASH_BASE);
- if (in_be32(serial) == 0xffffffff) + if (serial == 0xffffffff) return 0;
- return in_be32(serial); + return serial; }
@@ -177,12 +166,13 @@ int misc_init_r(void) long int initdram(int board_type) { long dram_size = 0; - u16 *boardVersReg = (u16 *) HCU_MACH_VERSIONS_REGISTER; - u16 generation = in_be16(boardVersReg) & 0xf0; - if (generation == HW_GENERATION_HCU3) - dram_size = 32*1024*1024; - else dram_size = 64*1024*1024; - fixed_hcu4_sdram(dram_size); + u16 boardVersReg = in_be16((u16 *)HCU_MACH_VERSIONS_REGISTER); + u16 generation = boardVersReg & 0xf0; + u16 index = boardVersReg & 0x0f; + if (generation == HW_GENERATION_HCU3 && index < 0xf) + dram_size = 32 << 20; /* 32 MB - RAM */ + else dram_size = 64 << 20; /* 64 MB - RAM */ + init_ppc405_sdram(dram_size);
#ifdef DEBUG show_sdram_registers(); diff --git a/board/netstal/hcu5/hcu5.c b/board/netstal/hcu5/hcu5.c index 2c7afe2..c494e93 100644 --- a/board/netstal/hcu5/hcu5.c +++ b/board/netstal/hcu5/hcu5.c @@ -309,15 +309,13 @@ int misc_init_r(void) */ if (mfspr(dbcr0) & 0x80000000) { /* External debugger alive - * enable trace facilty for Lauterback - * CCR0[DAPUIB]=0 Enable broadcast of instruction data - * to auxiliary processor interface + * enable trace facilty for Lauterbach * CCR0[DTB]=0 Enable broadcast of trace information * SDR0_PFC0[TRE] Trace signals are enabled instead of * GPIO49-63 */ - mtspr(ccr0, mfspr(ccr0) &~ 0x00108000); - mtsdr(SDR0_PFC0, sdr0_pfc1 | 0x00000100); + mtspr(ccr0, mfspr(ccr0) &~ (CCR0_DTB)); + mtsdr(SDR0_PFC0, sdr0_pfc1 | SDR0_PFC0_TRE_ENABLE); } return 0; } diff --git a/board/netstal/hcu5/sdram.c b/board/netstal/hcu5/sdram.c index 5435de1..be9a4cb 100644 --- a/board/netstal/hcu5/sdram.c +++ b/board/netstal/hcu5/sdram.c @@ -165,19 +165,25 @@ static void program_ecc(unsigned long start_address, unsigned long num_bytes) u32 val; char str[] = "ECC generation -"; #if defined(CONFIG_PRAM) - u32 *magic; - - /* Check whether vxWorks is using EDR logging, if yes zero */ - /* also PostMortem and user reserved memory */ - magic = (u32 *)in_be32((u32 *)(start_address + num_bytes - - (CONFIG_PRAM*1024) + sizeof(u32))); - - debug("\n%s: CONFIG_PRAM %d kB magic 0x%x 0x%p -> 0x%x\n", __FUNCTION__, - CONFIG_PRAM, - start_address + num_bytes - (CONFIG_PRAM*1024) + sizeof(u32), - magic, in_be32(magic)); - if (in_be32(magic) == 0xbeefbabe) - num_bytes -= (CONFIG_PRAM*1024) - PM_RESERVED_MEM; + u32 *magicPtr; + u32 magic; + + if ((mfspr(dbcr0) & 0x80000000) == 0) { + /* only if no external debugger is alive! + * Check whether vxWorks is using EDR logging, if yes zero + * also PostMortem and user reserved memory + */ + magicPtr = (u32 *)(start_address + num_bytes - + (CONFIG_PRAM*1024) + sizeof(u32)); + magic = in_be32(magicPtr); + debug("%s: CONFIG_PRAM %d kB magic 0x%x 0x%p\n", + __FUNCTION__, CONFIG_PRAM, + magicPtr, magic); + if (magic == 0xbeefbabe) { + printf("%s: preserving at %p\n", __FUNCTION__, magicPtr); + num_bytes -= (CONFIG_PRAM*1024) - PM_RESERVED_MEM; + } + } #endif
sync(); -- 1.5.2.5
Hi Niklaus,
Thanks. Look really good now. Just a few nitpicking comments below.
- MA 02111-1307 USA
- Modified 4/5/2001
- Wait for completion of each sector erase command issued
- 4/5/2001
- Chris Hallinan - DS4.COM, Inc. - clh@net1plus.com
- Modified 6/6/2007
- Added isync
- Niklaus Giger, Netstal Maschinen, niklaus.giger@netstal.com
enum {
- /* HW_GENERATION_HCU1/2 is no longer supported */ HW_GENERATION_HCU3 = 0x10, HW_GENERATION_HCU4 = 0x20, HW_GENERATION_HCU5 = 0x30,
Why this check here? You should never need 405GPr. CONFIG_405GP should be enough since they are nearly compatible.
Again you are mixing here coding styles: func() and func ().
I think you can remove the "6" here.
- *(C) Copyright 2005-2008 Netstal Maschinen AG
- Niklaus Giger (Niklaus.Giger@netstal.com)
- This source code is free software; you can redistribute it
-#undef DEBUG
- This function is run very early, out of flash, and before devices are
- initialized. It is called by lib_ppc/board.c:board_init_f by virtue
- anything, not even stack. So be careful.
- use 0x00804051. But this causes problems with u-boot and linux!
- 0x00004051 is okay for u-boot/linux, but different from old vxworks
- mtdcr(uicsr, 0xFFFFFFFF); /* clear all ints */
- mtdcr(uicer, 0x00000000); /* disable all ints */
- mtdcr(uiccr, 0x00000000); /* set all to be non-critical */
- mtdcr(uicpr, 0xFFFFE000); /* set int polarities */
- mtdcr(uictr, 0x00000000); /* set int trigger levels */
- u16 ioValue = in_be16((u16 *)HCU_DIGITAL_IO_REGISTER);
- return (ioValue & HCU_SW_INSTALL_REQUESTED) != 0;
- u16 boardVersReg = in_be16((u16 *)HCU_MACH_VERSIONS_REGISTER);
- u16 generation = boardVersReg & 0xf0;
- u16 index = boardVersReg & 0x0f;
- /* Cannot be done in board_early_init */
- mtdcr(cntrl0, CPC0_CR0_VALUE);
- correctly to use cts/rtc flow control, so just force the
- /RST active and forget about it.
- u16 slot = in_be16((u16 *)HCU_SLOT_ADDRESS);
- return slot & 0x7f;
- u32 serial = in_be32((u32 *)CFG_FLASH_BASE);
- if (serial == 0xffffffff) return 0;
- return serial;
- if (generation == HW_GENERATION_HCU3 && index < 0xf)
- else dram_size = 64 << 20; /* 64 MB - RAM */
if (generation == HW_GENERATION_HCU3 && index < 0xf) dram_size = 32 << 20; /* 32 MB - RAM */ else dram_size = 64 << 20; /* 64 MB - RAM */
please.
- init_ppc405_sdram(dram_size);
- CCR0[DTB]=0 Enable broadcast of trace information
- SDR0_PFC0[TRE] Trace signals are enabled instead of
GPIO49-63
} return 0;mtsdr(SDR0_PFC0, sdr0_pfc1 | SDR0_PFC0_TRE_ENABLE);
- u32 *magic;
CONFIG_PRAM,
- u32 *magicPtr;
- u32 magic;
- if ((mfspr(dbcr0) & 0x80000000) == 0) {
One space too much after the "=".
magicPtr, magic);
#endif
sync();
Looks good otherwise. Please clean up and resubmit.
Thanks.
Best regards, Stefan
And one more note regarding the 405GPr:
Could you remove the CONFIG_405GPr from your hcu4.h board config file? Please give it a try and if it works (which I don't doubt) then please add this to this patch.
Thanks.
Hi Niklaus,
Thanks for splitting this out. But still I have a question. See below.
Why is 405GPr needed here? Is this register not available in 405GP?
Thanks.
Stefan Roese wrote:
Hi Niklaus,
I found the following comments in the Migration guide for the PPC405GP -> PPC405GPr (PPC405GP_AN2023_405GPrMigration__v1_01.pdf).
The 405GPr provides the ability to add six external interrupts to the seven already available on the 405GP. This is accomplished by logic that allows routing any of the 24 GPIOs to six previously unused Universal Interrupt Controller (UIC) inputs. For those GPIOs that are shared with other functions, the corresponding I/O must first be configured via CPC0_CR0 to be a GPIO. Table 14 shows how the new GPIO to UIC External Interrupt Routing Register (CPC0_EIRR) logically routes GPIO inputs used as interrupts to the UIC.
Therefore I concluded that it is very PPC405GPr specific. But I did not check all other PPC405 variants.
Best regards
Niklaus
Yes, you seem to be right here. This *is* 405GPr specific. But I don't think it is worth adding this CONFIG_405GPr. Right now by setting CONFIG_405GP in your board config file, it should work correctly on boards with 405GP *and* 405GPr. We shouldn't loose this "feature". So please add this define if CONFIG_405GP is defined. And add a comment that it is only valid for 405GPr.
Thanks.
And please use the upper case name from the users manual: CPC0_EIRR. I know this is not done consistently but I we should use these names for newer definitions since it makes it easier to match those defines with the manuals.
Thanks.
Niklaus Giger
Niklaus Giger
Stefan Roese
