[U-Boot] [PATCH] doc: fix documentation of output directory
Correct environment variable is KBUILD_OUTPUT.
Signed-off-by: Timo Ketola timo@exertus.fi --- README | 6 +++--- doc/README.kwbimage | 4 ++-- 2 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/README b/README index 7b5538e..c3a9dfc 100644 --- a/README +++ b/README @@ -5012,14 +5012,14 @@ this behavior and build U-Boot to some external directory: make O=/tmp/build NAME_defconfig make O=/tmp/build all
-2. Set environment variable BUILD_DIR to point to the desired location: +2. Set environment variable KBUILD_OUTPUT to point to the desired location:
- export BUILD_DIR=/tmp/build + export KBUILD_OUTPUT=/tmp/build make distclean make NAME_defconfig make all
-Note that the command line "O=" setting overrides the BUILD_DIR environment +Note that the command line "O=" setting overrides the KBUILD_OUTPUT environment variable.
diff --git a/doc/README.kwbimage b/doc/README.kwbimage index 13f6f92..8c02298 100644 --- a/doc/README.kwbimage +++ b/doc/README.kwbimage @@ -30,10 +30,10 @@ kwbimage support available with mkimage utility will generate kirkwood boot image that can be flashed on the board NAND/SPI flash. The make target which uses mkimage to produce such an image is "u-boot.kwb". For example:
- export BUILD_DIR=/tmp/build + export KBUILD_OUTPUT=/tmp/build make distclean make yourboard_config - make $BUILD_DIR/u-boot.kwb + make $KBUILD_OUTPUT/u-boot.kwb
Board specific configuration file specifications:
Hi Timo,
- export KBUILD_OUTPUT=/tmp/build
Correct.
- make $KBUILD_OUTPUT/u-boot.kwb
Should be make yourboard_defconfig make u-boot.kwb
Best Regards Masahiro Yamada
Sounds logical. But that means that the older version was already broken (even when BUILD_DIR was correct variable), doesn't it?
Should I edit the patch that way or leave the file alone?
Timo
Hi Timo,
2014-11-05 17:12 GMT+09:00 Timo Ketola Timo.Ketola@exertus.fi:
Both "make $BUILD_DIR/u-boot.kwb" and "make "$KBUILD_OUTPUT/u-boot.kwb" are wrong.
"make u-boot.kwb" is correct.
Please fix the patch as I suggested.
Correct environment variable for output directory is KBUILD_OUTPUT.
Signed-off-by: Timo Ketola timo@exertus.fi --- v2 changes: - Fixed the example in the doc/README.kwbimage file functionally correct
diff --git a/doc/README.kwbimage b/doc/README.kwbimage index 13f6f92..762b2e3 100644 --- a/doc/README.kwbimage +++ b/doc/README.kwbimage @@ -30,10 +30,10 @@ kwbimage support available with mkimage utility will generate kirkwood boot image that can be flashed on the board NAND/SPI flash. The make target which uses mkimage to produce such an image is "u-boot.kwb". For example:
- export BUILD_DIR=/tmp/build + export KBUILD_OUTPUT=/tmp/build make distclean make yourboard_config - make $BUILD_DIR/u-boot.kwb + make u-boot.kwb
participants (5)
Masahiro YAMADA
Masahiro Yamada
Timo Ketola
Timo Ketola
