[U-Boot] [PATCH v3 0/4] ahci mvebu driver updates
These patches move ahci mvebu driver to drivers/ata directory with bug fixing and scsi supporting.
Changes in v3: - Use the new SPDX tags.
David Sniatkiwicz (1): ata: ahci_mvebu: a8040 a0: remove bad port register offsets workarounds
Ken Ma (3): ata: mvebu: move mvebu sata driver to drivers/ata directory ata: ahci_mvebu: add scsi support arm64: mvebu: defconfig: enable CONFIG_AHCI_MVEBU
MAINTAINERS | 1 + arch/arm/mach-mvebu/Makefile | 1 - configs/mvebu_db-88f3720_defconfig | 1 + configs/mvebu_db_armada8k_defconfig | 1 + configs/mvebu_espressobin-88f3720_defconfig | 1 + configs/mvebu_mcbin-88f8040_defconfig | 1 + drivers/ata/Kconfig | 9 ++++++++ drivers/ata/Makefile | 1 + .../mach-mvebu/sata.c => drivers/ata/ahci_mvebu.c | 24 +++++++++++++--------- 9 files changed, 29 insertions(+), 11 deletions(-) rename arch/arm/mach-mvebu/sata.c => drivers/ata/ahci_mvebu.c (68%)
Currently mvebu sata driver is in arch/arm/mach_mvebu directory, this patch moves it to drivers/ata directory with renaming "sata.c" to "ahci_mvebu.c" which is aligned to Linux. New ahci driver's kconfig option is added as AHCI_MVEBU which selects DM_SCSI.
Signed-off-by: Ken Ma make@marvell.com Reviewed-by: Stefan Roese sr@denx.de Reviewed-by: Simon Glass sjg@chromium.org ---
MAINTAINERS | 1 + arch/arm/mach-mvebu/Makefile | 1 - drivers/ata/Kconfig | 9 +++++++++ drivers/ata/Makefile | 1 + arch/arm/mach-mvebu/sata.c => drivers/ata/ahci_mvebu.c | 5 +---- 5 files changed, 12 insertions(+), 5 deletions(-) rename arch/arm/mach-mvebu/sata.c => drivers/ata/ahci_mvebu.c (93%)
diff --git a/MAINTAINERS b/MAINTAINERS index 077828c..97c0752 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -134,6 +134,7 @@ S: Maintained T: git git://git.denx.de/u-boot-marvell.git F: arch/arm/mach-kirkwood/ F: arch/arm/mach-mvebu/ +F: drivers/ata/ahci_mvebu.c
ARM MARVELL PXA M: Marek Vasut marex@denx.de diff --git a/arch/arm/mach-mvebu/Makefile b/arch/arm/mach-mvebu/Makefile index d4210af..7f0d692 100644 --- a/arch/arm/mach-mvebu/Makefile +++ b/arch/arm/mach-mvebu/Makefile @@ -9,7 +9,6 @@ ifdef CONFIG_ARM64 obj-$(CONFIG_ARMADA_3700) += armada3700/ obj-$(CONFIG_ARMADA_8K) += armada8k/ obj-y += arm64-common.o -obj-y += sata.o
else # CONFIG_ARM64
diff --git a/drivers/ata/Kconfig b/drivers/ata/Kconfig index 86ec628..9ef4589 100644 --- a/drivers/ata/Kconfig +++ b/drivers/ata/Kconfig @@ -99,4 +99,13 @@ config SATA_SIL3114 help Enable this driver to support the SIL3114 SATA controllers.
+config AHCI_MVEBU + bool "Marvell EBU AHCI SATA support" + depends on ARCH_MVEBU + select DM_SCSI + help + This option enables support for the Marvell EBU SoC's + onboard AHCI SATA. + + If unsure, say N. endmenu diff --git a/drivers/ata/Makefile b/drivers/ata/Makefile index a94c804..0254640 100644 --- a/drivers/ata/Makefile +++ b/drivers/ata/Makefile @@ -19,3 +19,4 @@ obj-$(CONFIG_SATA_MV) += sata_mv.o obj-$(CONFIG_SATA_SIL3114) += sata_sil3114.o obj-$(CONFIG_SATA_SIL) += sata_sil.o obj-$(CONFIG_SANDBOX) += sata_sandbox.o +obj-$(CONFIG_AHCI_MVEBU) += ahci_mvebu.o diff --git a/arch/arm/mach-mvebu/sata.c b/drivers/ata/ahci_mvebu.c similarity index 93% rename from arch/arm/mach-mvebu/sata.c rename to drivers/ata/ahci_mvebu.c index 5d8032b..3ae8dae 100644 --- a/arch/arm/mach-mvebu/sata.c +++ b/drivers/ata/ahci_mvebu.c @@ -1,15 +1,12 @@ +// SPDX-License-Identifier: GPL-2.0+ /* * Copyright (C) 2016 Stefan Roese sr@denx.de - * - * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> #include <ahci.h> #include <dm.h>
-DECLARE_GLOBAL_DATA_PTR; - /* * Dummy implementation that can be overwritten by a board * specific function
Changes in v3:
else # CONFIG_ARM64
+config AHCI_MVEBU
- bool "Marvell EBU AHCI SATA support"
- depends on ARCH_MVEBU
- select DM_SCSI
- help
onboard AHCI SATA.
endmenuIf unsure, say N.
- Copyright (C) 2016 Stefan Roese sr@denx.de
You should have no such changes in your new file, since you are moving the file which already has the new SPDX tags. So please make sure to base your patches on top of the latest mainline git version.
Thanks, Stefan
This workaround was added for A8040/7040 A0. A8040/7040 A0 is no longer supported so this workaround can be removed.
Signed-off-by: David Sniatkiwicz davidsn@marvell.com Signed-off-by: Ken Ma make@marvell.com Reviewed-by: Stefan Roese sr@denx.de Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v3: None
drivers/ata/ahci_mvebu.c | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/drivers/ata/ahci_mvebu.c b/drivers/ata/ahci_mvebu.c index 3ae8dae..c1d215f 100644 --- a/drivers/ata/ahci_mvebu.c +++ b/drivers/ata/ahci_mvebu.c @@ -16,14 +16,6 @@ __weak int board_ahci_enable(void) return 0; }
-#ifdef CONFIG_ARMADA_8K -/* CP110 has different AHCI port addresses */ -void __iomem *ahci_port_base(void __iomem *base, u32 port) -{ - return base + 0x10000 + (port * 0x10000); -} -#endif - static int mvebu_ahci_probe(struct udevice *dev) { /*
Mvebu AHCI is AHCI driver which uses SCSI under the hood. This patch adjusts AHCI setup to support SCSI by creating a SCSI device as a child.
Changes in v3: None
drivers/ata/ahci_mvebu.c | 17 ++++++++++++++++- 1 file changed, 16 insertions(+), 1 deletion(-)
diff --git a/drivers/ata/ahci_mvebu.c b/drivers/ata/ahci_mvebu.c index c1d215f..6e3f17e 100644 --- a/drivers/ata/ahci_mvebu.c +++ b/drivers/ata/ahci_mvebu.c @@ -16,6 +16,20 @@ __weak int board_ahci_enable(void) return 0; }
+static int mvebu_ahci_bind(struct udevice *dev) +{ + struct udevice *scsi_dev; + int ret; + + ret = ahci_bind_scsi(dev, &scsi_dev); + if (ret) { + debug("%s: Failed to bind (err=%d\n)", __func__, ret); + return ret; + } + + return 0; +} + static int mvebu_ahci_probe(struct udevice *dev) { /* @@ -24,7 +38,7 @@ static int mvebu_ahci_probe(struct udevice *dev) */ board_ahci_enable();
- ahci_init(devfdt_get_addr_ptr(dev)); + ahci_probe_scsi(dev, (ulong)devfdt_get_addr_ptr(dev));
return 0; } @@ -39,5 +53,6 @@ U_BOOT_DRIVER(ahci_mvebu_drv) = { .name = "ahci_mvebu", .id = UCLASS_AHCI, .of_match = mvebu_ahci_ids, + .bind = mvebu_ahci_bind, .probe = mvebu_ahci_probe, };
This patch enables the new ahci mvebu driver for marvell arm64 platform SOCs(A3k and A8k).
Changes in v3: None
configs/mvebu_db-88f3720_defconfig | 1 + configs/mvebu_db_armada8k_defconfig | 1 + configs/mvebu_espressobin-88f3720_defconfig | 1 + configs/mvebu_mcbin-88f8040_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/mvebu_db-88f3720_defconfig b/configs/mvebu_db-88f3720_defconfig index 1d6233a..d40dd42 100644 --- a/configs/mvebu_db-88f3720_defconfig +++ b/configs/mvebu_db-88f3720_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_MAC_PARTITION=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SCSI_AHCI=y +CONFIG_AHCI_MVEBU=y CONFIG_BLOCK_CACHE=y CONFIG_DM_GPIO=y # CONFIG_MVEBU_GPIO is not set diff --git a/configs/mvebu_db_armada8k_defconfig b/configs/mvebu_db_armada8k_defconfig index da67aad..72c86f3 100644 --- a/configs/mvebu_db_armada8k_defconfig +++ b/configs/mvebu_db_armada8k_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_MAC_PARTITION=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SCSI_AHCI=y +CONFIG_AHCI_MVEBU=y CONFIG_BLOCK_CACHE=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/mvebu_espressobin-88f3720_defconfig b/configs/mvebu_espressobin-88f3720_defconfig index 314d405..cc41711 100644 --- a/configs/mvebu_espressobin-88f3720_defconfig +++ b/configs/mvebu_espressobin-88f3720_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_MAC_PARTITION=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SCSI_AHCI=y +CONFIG_AHCI_MVEBU=y CONFIG_BLOCK_CACHE=y CONFIG_DM_I2C=y CONFIG_MISC=y diff --git a/configs/mvebu_mcbin-88f8040_defconfig b/configs/mvebu_mcbin-88f8040_defconfig index e16a56e..dea0cd0 100644 --- a/configs/mvebu_mcbin-88f8040_defconfig +++ b/configs/mvebu_mcbin-88f8040_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_MAC_PARTITION=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SCSI_AHCI=y +CONFIG_AHCI_MVEBU=y CONFIG_BLOCK_CACHE=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y
make@marvell.com
Stefan Roese
