[U-Boot] [PATCH] Add support for ASIX's AX88783 ethernet chip
for more information about this chip, please check: http://www.asix.com.tw/products.php?op=pItemdetail&PItemID=98;65;86&...
Signed-off-by: Joe Xue lgxue@hotmail.com
--- README | 7 +++++++ drivers/net/Makefile | 1 + include/netdev.h | 1 + 3 files changed, 9 insertions(+), 0 deletions(-)
diff --git a/README b/README index 755d17c..c9657d8 100644 --- a/README +++ b/README @@ -892,6 +892,13 @@ The following options need to be configured: automatically converts one 32 bit word to two 16 bit words you may also try CONFIG_SMC911X_32_BIT.
+ CONFIG_DRIVER_AX88783 + Support for ASIX's AX88783 chip + + CONFIG_AX88783_BASE + Define this to hold the physical address + of the device (I/O space) + - USB Support: At the moment only the UHCI host controller is supported (PIP405, MIP405, MPC5200); define diff --git a/drivers/net/Makefile b/drivers/net/Makefile index fd9d0b4..7cd6e2c 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -30,6 +30,7 @@ COBJS-$(CONFIG_PPC4xx_EMAC) += 4xx_enet.o COBJS-$(CONFIG_ALTERA_TSE) += altera_tse.o COBJS-$(CONFIG_DRIVER_AT91EMAC) += at91_emac.o COBJS-$(CONFIG_DRIVER_AX88180) += ax88180.o +COBJS-$(CONFIG_DRIVER_AX88783) += ax88783.o COBJS-$(CONFIG_BCM570x) += bcm570x.o COBJS-$(CONFIG_BCM570x) += bcm570x_autoneg.o COBJS-$(CONFIG_BCM570x) += 5701rls.o diff --git a/include/netdev.h b/include/netdev.h index 1a542e8..fddc64d 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -44,6 +44,7 @@ int cpu_eth_init(bd_t *bis); int altera_tse_initialize(u8 dev_num, int mac_base, int sgdma_rx_base, int sgdma_tx_base); int ax88180_initialize(bd_t *bis); +int ax88783_initialize(bd_t *bis); int au1x00_enet_initialize(bd_t*); int at91emac_register(bd_t *bis, unsigned long iobase); int bfin_EMAC_initialize(bd_t *bis);
Joe Xue
