[PATCH 1/3][v2] board: freescale: Remove LS2080A_EMU support
Remove LS2080A_EMU as it was pre-silicon board and is no longer Maintained.
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- Changes for v2: Add 2/3 patch in series
arch/arm/Kconfig | 12 ----- arch/arm/cpu/armv8/Kconfig | 2 +- board/freescale/ls2080a/Kconfig | 18 ------- board/freescale/ls2080a/MAINTAINERS | 2 - configs/ls2080a_emu_defconfig | 37 ------------- drivers/i2c/Kconfig | 4 +- include/configs/ls2080a_emu.h | 80 ----------------------------- 7 files changed, 3 insertions(+), 152 deletions(-) delete mode 100644 configs/ls2080a_emu_defconfig delete mode 100644 include/configs/ls2080a_emu.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 1bcf345028..e4b29e92c8 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1134,18 +1134,6 @@ config TARGET_VEXPRESS64_JUNO select ARM64 select PL01X_SERIAL
-config TARGET_LS2080A_EMU - bool "Support ls2080a_emu" - select ARCH_LS2080A - select ARM64 - select ARMV8_MULTIENTRY - select FSL_DDR_SYNC_REFRESH - help - Support for Freescale LS2080A_EMU platform. - The LS2080A Development System (EMULATOR) is a pre-silicon - development platform that supports the QorIQ LS2080A - Layerscape Architecture processor. - config TARGET_LS2080A_SIMU bool "Support ls2080a_simu" select ARCH_LS2080A diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 16c83e8614..006453921e 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -99,7 +99,7 @@ config PSCI_RESET select ARM_SMCCC if OF_CONTROL depends on !ARCH_EXYNOS7 && !ARCH_BCM283X && \ !TARGET_LS2080A_SIMU && !TARGET_LS2080AQDS && \ - !TARGET_LS2080ARDB && !TARGET_LS2080A_EMU && \ + !TARGET_LS2080ARDB && \ !TARGET_LS1088ARDB && !TARGET_LS1088AQDS && \ !TARGET_LS1012ARDB && !TARGET_LS1012AFRDM && \ !TARGET_LS1012A2G5RDB && !TARGET_LS1012AQDS && \ diff --git a/board/freescale/ls2080a/Kconfig b/board/freescale/ls2080a/Kconfig index b5033511b5..6015b8f930 100644 --- a/board/freescale/ls2080a/Kconfig +++ b/board/freescale/ls2080a/Kconfig @@ -1,21 +1,3 @@ -if TARGET_LS2080A_EMU - -config SYS_BOARD - default "ls2080a" - -config SYS_VENDOR - default "freescale" - -config SYS_SOC - default "fsl-layerscape" - -config SYS_CONFIG_NAME - default "ls2080a_emu" - -source "board/freescale/common/Kconfig" - -endif - if TARGET_LS2080A_SIMU
config SYS_BOARD diff --git a/board/freescale/ls2080a/MAINTAINERS b/board/freescale/ls2080a/MAINTAINERS index e0e4e3f83e..3afaab9c77 100644 --- a/board/freescale/ls2080a/MAINTAINERS +++ b/board/freescale/ls2080a/MAINTAINERS @@ -3,7 +3,5 @@ M: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com M: Priyanka Jain priyanka.jain@nxp.com S: Maintained F: board/freescale/ls2080a/ -F: include/configs/ls2080a_emu.h -F: configs/ls2080a_emu_defconfig F: include/configs/ls2080a_simu.h F: configs/ls2080a_simu_defconfig diff --git a/configs/ls2080a_emu_defconfig b/configs/ls2080a_emu_defconfig deleted file mode 100644 index 7927e3838f..0000000000 --- a/configs/ls2080a_emu_defconfig +++ /dev/null @@ -1,37 +0,0 @@ -CONFIG_ARM=y -CONFIG_TARGET_LS2080A_EMU=y -CONFIG_SYS_TEXT_BASE=0x30100000 -CONFIG_ENV_SIZE=0x1000 -CONFIG_NR_DRAM_BANKS=3 -CONFIG_IDENT_STRING=" LS2080A-EMU" -CONFIG_FIT=y -CONFIG_FIT_VERBOSE=y -CONFIG_OF_BOARD_SETUP=y -CONFIG_OF_STDOUT_VIA_ALIAS=y -CONFIG_SYS_EXTRA_OPTIONS="EMU" -CONFIG_BOOTDELAY=10 -CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" -# CONFIG_USE_BOOTCOMMAND is not set -# CONFIG_DISPLAY_BOARDINFO is not set -# CONFIG_CMD_CONSOLE is not set -# CONFIG_CMD_XIMG is not set -# CONFIG_CMD_EDITENV is not set -CONFIG_CMD_GREPENV=y -CONFIG_CMD_I2C=y -# CONFIG_CMD_LOADS is not set -# CONFIG_CMD_ITEST is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set -CONFIG_CMD_CACHE=y -# CONFIG_CMD_MISC is not set -CONFIG_MP=y -# CONFIG_DOS_PARTITION is not set -# CONFIG_ISO_PARTITION is not set -# CONFIG_EFI_PARTITION is not set -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_FSL_CAAM=y -# CONFIG_MMC is not set -CONFIG_SYS_NS16550=y -CONFIG_OF_LIBFDT=y -CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index e42b6516bf..02a74eb136 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -214,7 +214,7 @@ endif if SYS_I2C_MXC_I2C1 config SYS_MXC_I2C1_SPEED int "I2C Channel 1 speed" - default 40000000 if TARGET_LS2080A_SIMU || TARGET_LS2080A_EMU + default 40000000 if TARGET_LS2080A_SIMU default 100000 help MXC I2C Channel 1 speed @@ -229,7 +229,7 @@ endif if SYS_I2C_MXC_I2C2 config SYS_MXC_I2C2_SPEED int "I2C Channel 2 speed" - default 40000000 if TARGET_LS2080A_SIMU || TARGET_LS2080A_EMU + default 40000000 if TARGET_LS2080A_SIMU default 100000 help MXC I2C Channel 2 speed diff --git a/include/configs/ls2080a_emu.h b/include/configs/ls2080a_emu.h deleted file mode 100644 index 3e0ad48dda..0000000000 --- a/include/configs/ls2080a_emu.h +++ /dev/null @@ -1,80 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright 2014 Freescale Semiconductor - */ - -#ifndef __LS2_EMU_H -#define __LS2_EMU_H - -#include "ls2080a_common.h" - -#define CONFIG_SYS_CLK_FREQ 100000000 -#define CONFIG_DDR_CLK_FREQ 133333333 - -#define CONFIG_DDR_SPD -#define CONFIG_SYS_FSL_DDR_EMU /* Support emulator */ -#define SPD_EEPROM_ADDRESS1 0x51 -#define SPD_EEPROM_ADDRESS2 0x52 -#define SPD_EEPROM_ADDRESS3 0x53 -#define SPD_EEPROM_ADDRESS SPD_EEPROM_ADDRESS1 -#define CONFIG_SYS_SPD_BUS_NUM 1 /* SPD on I2C bus 1 */ -#define CONFIG_DIMM_SLOTS_PER_CTLR 1 -#define CONFIG_CHIP_SELECTS_PER_CTRL 4 -#ifdef CONFIG_SYS_FSL_HAS_DP_DDR -#define CONFIG_DP_DDR_DIMM_SLOTS_PER_CTLR 1 -#endif - -#define CONFIG_SYS_NOR0_CSPR_EXT (0x0) -#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) -/* - * NOR Flash Timing Params - */ -#define CONFIG_SYS_NOR0_CSPR \ - (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ - CSPR_PORT_SIZE_16 | \ - CSPR_MSEL_NOR | \ - CSPR_V) -#define CONFIG_SYS_NOR0_CSPR_EARLY \ - (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS_EARLY) | \ - CSPR_PORT_SIZE_16 | \ - CSPR_MSEL_NOR | \ - CSPR_V) -#define CONFIG_SYS_NOR_CSOR CSOR_NOR_ADM_SHIFT(12) -#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x1) | \ - FTIM0_NOR_TEADC(0x1) | \ - FTIM0_NOR_TEAHC(0x1)) -#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x1) | \ - FTIM1_NOR_TRAD_NOR(0x1)) -#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x0) | \ - FTIM2_NOR_TCH(0x0) | \ - FTIM2_NOR_TWP(0x1)) -#define CONFIG_SYS_NOR_FTIM3 0x04000000 -#define CONFIG_SYS_IFC_CCR 0x01000000 - -#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT -#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR_EARLY -#define CONFIG_SYS_CSPR0_FINAL CONFIG_SYS_NOR0_CSPR -#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK -#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR -#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 -#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 -#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 -#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 - -/* Debug Server firmware */ -#define CONFIG_SYS_DEBUG_SERVER_FW_IN_NOR -#define CONFIG_SYS_DEBUG_SERVER_FW_ADDR 0x580C00000ULL - -/* - * This trick allows users to load MC images into DDR directly without - * copying from NOR flash. It dramatically improves speed. - */ -#define CONFIG_SYS_LS_MC_FW_IN_DDR -#define CONFIG_SYS_LS_MC_DPL_IN_DDR -#define CONFIG_SYS_LS_MC_DPC_IN_DDR - -#define CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS 200000 - -/* Store environment at top of flash */ - -#endif /* __LS2_EMU_H */
Add config TARGET_LS2080ARDB in Kconfig
board/freescale/ls2080a/Kconfig | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/board/freescale/ls2080a/Kconfig b/board/freescale/ls2080a/Kconfig index 6015b8f930..f85c547b61 100644 --- a/board/freescale/ls2080a/Kconfig +++ b/board/freescale/ls2080a/Kconfig @@ -1,3 +1,21 @@ +if TARGET_LS2080ARDB + +config SYS_BOARD + default "ls2080a" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "ls2080ardb" + +source "board/freescale/common/Kconfig" + +endif + if TARGET_LS2080A_SIMU
config SYS_BOARD
Remove LS2080A_SIMU as it was pre-silicon board and is no longer Maintained.
arch/arm/Kconfig | 12 --- arch/arm/cpu/armv8/Kconfig | 2 +- board/freescale/ls2080a/Kconfig | 17 ---- board/freescale/ls2080a/MAINTAINERS | 2 - configs/ls2080a_simu_defconfig | 45 --------- drivers/i2c/Kconfig | 2 - include/configs/ls2080a_simu.h | 147 ---------------------------- 7 files changed, 1 insertion(+), 226 deletions(-) delete mode 100644 configs/ls2080a_simu_defconfig delete mode 100644 include/configs/ls2080a_simu.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index e4b29e92c8..108c22b597 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1134,18 +1134,6 @@ config TARGET_VEXPRESS64_JUNO select ARM64 select PL01X_SERIAL
-config TARGET_LS2080A_SIMU - bool "Support ls2080a_simu" - select ARCH_LS2080A - select ARM64 - select ARMV8_MULTIENTRY - select BOARD_LATE_INIT - help - Support for Freescale LS2080A_SIMU platform. - The LS2080A Development System (QDS) is a pre silicon - development platform that supports the QorIQ LS2080A - Layerscape Architecture processor. - config TARGET_LS1088AQDS bool "Support ls1088aqds" select ARCH_LS1088A diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 006453921e..bbed71be43 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -98,7 +98,7 @@ config PSCI_RESET default y select ARM_SMCCC if OF_CONTROL depends on !ARCH_EXYNOS7 && !ARCH_BCM283X && \ - !TARGET_LS2080A_SIMU && !TARGET_LS2080AQDS && \ + !TARGET_LS2080AQDS && \ !TARGET_LS2080ARDB && \ !TARGET_LS1088ARDB && !TARGET_LS1088AQDS && \ !TARGET_LS1012ARDB && !TARGET_LS1012AFRDM && \ diff --git a/board/freescale/ls2080a/Kconfig b/board/freescale/ls2080a/Kconfig index f85c547b61..b756548179 100644 --- a/board/freescale/ls2080a/Kconfig +++ b/board/freescale/ls2080a/Kconfig @@ -16,20 +16,3 @@ source "board/freescale/common/Kconfig"
endif
-if TARGET_LS2080A_SIMU - -config SYS_BOARD - default "ls2080a" - -config SYS_VENDOR - default "freescale" - -config SYS_SOC - default "fsl-layerscape" - -config SYS_CONFIG_NAME - default "ls2080a_simu" - -source "board/freescale/common/Kconfig" - -endif diff --git a/board/freescale/ls2080a/MAINTAINERS b/board/freescale/ls2080a/MAINTAINERS index 3afaab9c77..b228f4dd59 100644 --- a/board/freescale/ls2080a/MAINTAINERS +++ b/board/freescale/ls2080a/MAINTAINERS @@ -3,5 +3,3 @@ M: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com M: Priyanka Jain priyanka.jain@nxp.com S: Maintained F: board/freescale/ls2080a/ -F: include/configs/ls2080a_simu.h -F: configs/ls2080a_simu_defconfig diff --git a/configs/ls2080a_simu_defconfig b/configs/ls2080a_simu_defconfig deleted file mode 100644 index ccf71179e0..0000000000 --- a/configs/ls2080a_simu_defconfig +++ /dev/null @@ -1,45 +0,0 @@ -CONFIG_ARM=y -CONFIG_TARGET_LS2080A_SIMU=y -CONFIG_SYS_TEXT_BASE=0x30100000 -CONFIG_ENV_SIZE=0x1000 -CONFIG_NR_DRAM_BANKS=3 -CONFIG_IDENT_STRING=" LS2080A-SIMU" -CONFIG_FIT=y -CONFIG_FIT_VERBOSE=y -CONFIG_OF_BOARD_SETUP=y -CONFIG_OF_STDOUT_VIA_ALIAS=y -CONFIG_SYS_EXTRA_OPTIONS="SIMU" -CONFIG_BOOTDELAY=10 -CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" -# CONFIG_USE_BOOTCOMMAND is not set -# CONFIG_DISPLAY_BOARDINFO is not set -# CONFIG_CMD_CONSOLE is not set -# CONFIG_CMD_XIMG is not set -# CONFIG_CMD_EDITENV is not set -CONFIG_CMD_GREPENV=y -CONFIG_CMD_I2C=y -# CONFIG_CMD_LOADS is not set -CONFIG_CMD_MMC=y -CONFIG_CMD_NAND=y -# CONFIG_CMD_ITEST is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set -CONFIG_CMD_CACHE=y -# CONFIG_CMD_MISC is not set -CONFIG_MP=y -# CONFIG_ISO_PARTITION is not set -# CONFIG_EFI_PARTITION is not set -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_FSL_CAAM=y -CONFIG_FSL_ESDHC=y -CONFIG_MTD=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_CFI_DRIVER=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_MTD_RAW_NAND=y -CONFIG_SYS_NS16550=y -CONFIG_OF_LIBFDT=y -CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 02a74eb136..b981d47e67 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -214,7 +214,6 @@ endif if SYS_I2C_MXC_I2C1 config SYS_MXC_I2C1_SPEED int "I2C Channel 1 speed" - default 40000000 if TARGET_LS2080A_SIMU default 100000 help MXC I2C Channel 1 speed @@ -229,7 +228,6 @@ endif if SYS_I2C_MXC_I2C2 config SYS_MXC_I2C2_SPEED int "I2C Channel 2 speed" - default 40000000 if TARGET_LS2080A_SIMU default 100000 help MXC I2C Channel 2 speed diff --git a/include/configs/ls2080a_simu.h b/include/configs/ls2080a_simu.h deleted file mode 100644 index ab46df7600..0000000000 --- a/include/configs/ls2080a_simu.h +++ /dev/null @@ -1,147 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2014 Freescale Semiconductor - */ - -#ifndef __LS2_SIMU_H -#define __LS2_SIMU_H - -#include "ls2080a_common.h" - -#define CONFIG_SYS_CLK_FREQ 100000000 -#define CONFIG_DDR_CLK_FREQ 133333333 - -#define CONFIG_DIMM_SLOTS_PER_CTLR 1 -#define CONFIG_CHIP_SELECTS_PER_CTRL 4 -#ifdef CONFIG_SYS_FSL_HAS_DP_DDR -#define CONFIG_DP_DDR_DIMM_SLOTS_PER_CTLR 1 -#endif - -/* SMSC 91C111 ethernet configuration */ -#define CONFIG_SMC91111 -#define CONFIG_SMC91111_BASE (0x2210000) - -#define CONFIG_SYS_NOR0_CSPR_EXT (0x0) -#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) - -#ifdef CONFIG_MTD_NOR_FLASH -#define CONFIG_SYS_FLASH_QUIET_TEST -#endif - -/* - * NOR Flash Timing Params - */ -#define CONFIG_SYS_NOR0_CSPR \ - (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ - CSPR_PORT_SIZE_16 | \ - CSPR_MSEL_NOR | \ - CSPR_V) -#define CONFIG_SYS_NOR0_CSPR_EARLY \ - (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS_EARLY) | \ - CSPR_PORT_SIZE_16 | \ - CSPR_MSEL_NOR | \ - CSPR_V) -#define CONFIG_SYS_NOR_CSOR CSOR_NOR_ADM_SHIFT(12) -#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x1) | \ - FTIM0_NOR_TEADC(0x1) | \ - FTIM0_NOR_TEAHC(0x1)) -#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x1) | \ - FTIM1_NOR_TRAD_NOR(0x1)) -#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x0) | \ - FTIM2_NOR_TCH(0x0) | \ - FTIM2_NOR_TWP(0x1)) -#define CONFIG_SYS_NOR_FTIM3 0x04000000 -#define CONFIG_SYS_IFC_CCR 0x01000000 - -#ifdef CONFIG_MTD_NOR_FLASH -#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ - -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ - -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } -#endif - -#define CONFIG_NAND_FSL_IFC -#define CONFIG_SYS_NAND_MAX_ECCPOS 256 -#define CONFIG_SYS_NAND_MAX_OOBFREE 2 - -#define CONFIG_SYS_NAND_CSPR_EXT (0x0) -#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ - | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ - | CSPR_MSEL_NAND /* MSEL = NAND */ \ - | CSPR_V) -#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64 * 1024) - -#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ - | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ - | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ - | CSOR_NAND_RAL_3 /* RAL = 2Byes */ \ - | CSOR_NAND_PGS_2K /* Page Size = 2K */ \ - | CSOR_NAND_SPRZ_64/* Spare size = 64 */ \ - | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ - -#define CONFIG_SYS_NAND_ONFI_DETECTION - -/* ONFI NAND Flash mode0 Timing Params */ -#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ - FTIM0_NAND_TWP(0x18) | \ - FTIM0_NAND_TWCHT(0x07) | \ - FTIM0_NAND_TWH(0x0a)) -#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ - FTIM1_NAND_TWBE(0x39) | \ - FTIM1_NAND_TRR(0x0e) | \ - FTIM1_NAND_TRP(0x18)) -#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \ - FTIM2_NAND_TREH(0x0a) | \ - FTIM2_NAND_TWHRE(0x1e)) -#define CONFIG_SYS_NAND_FTIM3 0x0 - -#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_MTD_NAND_VERIFY_WRITE - -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) - -#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT -#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR_EARLY -#define CONFIG_SYS_CSPR0_FINAL CONFIG_SYS_NOR0_CSPR -#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK -#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR -#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 -#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 -#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 -#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 -#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NAND_CSPR_EXT -#define CONFIG_SYS_CSPR1 CONFIG_SYS_NAND_CSPR -#define CONFIG_SYS_AMASK1 CONFIG_SYS_NAND_AMASK -#define CONFIG_SYS_CSOR1 CONFIG_SYS_NAND_CSOR -#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NAND_FTIM0 -#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NAND_FTIM1 -#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NAND_FTIM2 -#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NAND_FTIM3 - -/* MMC */ -#ifdef CONFIG_MMC -#define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 -#endif - -/* Debug Server firmware */ -#define CONFIG_SYS_DEBUG_SERVER_FW_IN_NOR -#define CONFIG_SYS_DEBUG_SERVER_FW_ADDR 0x580C00000ULL - -/* MC firmware */ -#define CONFIG_SYS_LS_MC_DPL_IN_NOR -#define CONFIG_SYS_LS_MC_DPL_ADDR 0x5806C0000ULL - -#define CONFIG_SYS_LS_MC_DPC_IN_NOR -#define CONFIG_SYS_LS_MC_DPC_ADDR 0x5806F8000ULL - -#define CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS 200000 - -/* Store environment at top of flash */ - -#endif /* __LS2_SIMU_H */
Priyanka Jain
