[U-Boot] [PATCH][v1] muas3001: remove BRG clock node fixup to use common mpc8260 code.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@noser.com --- board/muas3001/muas3001.c | 16 ---------------- 1 files changed, 0 insertions(+), 16 deletions(-)
diff --git a/board/muas3001/muas3001.c b/board/muas3001/muas3001.c index 8f83dd9..bf4ccb6 100644 --- a/board/muas3001/muas3001.c +++ b/board/muas3001/muas3001.c @@ -310,7 +310,6 @@ void ft_blob_update (void *blob, bd_t *bd) int ret, nodeoffset = 0; ulong memory_data[2] = {0}; ulong flash_data[4] = {0}; - ulong freq = 0; ulong speed = 0;
memory_data[0] = cpu_to_be32 (bd->bi_memstart); @@ -359,21 +358,6 @@ void ft_blob_update (void *blob, bd_t *bd) "err:%s\n", fdt_strerror (nodeoffset)); }
- /* brg clock */ - nodeoffset = fdt_path_offset (blob, "/soc/cpm/brg"); - if (nodeoffset >= 0) { - freq = cpu_to_be32 (bd->bi_brgfreq); - ret = fdt_setprop (blob, nodeoffset, "clock-frequency", &freq, - sizeof (unsigned long)); - if (ret < 0) - printf ("ft_blob_update): cannot set /soc/cpm/brg/clock-frequency " - "property err:%s\n", fdt_strerror (ret)); - } else { - /* memory node is required in dts */ - printf ("ft_blob_update(): cannot find /soc/cpm/brg/clock-frequency node " - "err:%s\n", fdt_strerror (nodeoffset)); - } - /* baudrate */ nodeoffset = fdt_path_offset (blob, "/soc/cpm/serial"); if (nodeoffset >= 0) {
Hello Marcel,
Unfortunately, I don;t have anymore access to this board, but your patch looks good to me, so:
Acked-by: Heiko Schocher hs@denx.de
bye Heiko
Signed-off-by: Marcel Ziswiler marcel.ziswiler@noser.com Acked-by: Heiko Schocher hs@denx.de --- Changes since v1: - Added Heiko's ack
Dear Marcel Ziswiler,
Changes since v1:
- Added Heiko's ack
Applied, thanks.
Heiko Schocher
Marcel Ziswiler
