[PULL] u-boot-riscv/master
Hi Tom,
The following changes since commit 9a0cf3993f71043ba08c315572c54622de42d447:
Merge branch '2023-10-17-spl-test-some-load-methods' (2023-10-18 08:28:00 -0400)
https://source.denx.de/u-boot/custodians/u-boot-riscv.git
for you to fetch changes up to bc5a50452bd42029d6587e1596b44ff235655e90:
riscv: Add Zbb support for building U-Boot (2023-10-19 17:29:50 +0800)
CI result shows no issue: https://source.denx.de/u-boot/custodians/u-boot-riscv/-/pipelines/18215 ----------------------------------------------------------------
+ riscv: Add Zbb support + riscv: Add preliminary RISC-V falcon mode support + riscv: Remove dram_init_banksize() + andes: rearrange PLICSW scheme + visionfive2: enable bootstage configs
---------------------------------------------------------------- Chanho Park (1): configs: visionfive2: enable bootstage configs
Heinrich Schuchardt (1): riscv: remove dram_init_banksize()
Mayuresh Chitale (1): riscv: binman: Fix compilation error
Randolph (8): riscv: andes: Rearrange Andes PLICSW to single-bit-per-hart strategy spl: riscv: opensbi: change the default os_type as varible riscv: kconfig: introduce SPL_LOAD_FIT_OPENSBI_OS_BOOT symbol riscv: dts: binman: add condition for opensbi os boot Makefile: delete file *.itb when make clean spl: riscv: add os type for next booting stage andes: config: add riscv falcon mode for ae350 platform riscv: spl: andes: Move the DTB in front of kernel
Yu Chien Peter Lin (1): riscv: Add Zbb support for building U-Boot
Makefile | 2 +- arch/riscv/Kconfig | 99 +++++++++++++++++++++++++++++++ arch/riscv/Makefile | 5 +- arch/riscv/cpu/generic/dram.c | 16 ----- arch/riscv/dts/binman.dtsi | 38 ++++++++++-- arch/riscv/include/asm/string.h | 18 ++++++ arch/riscv/lib/Makefile | 3 + arch/riscv/lib/andes_plicsw.c | 24 ++++---- arch/riscv/lib/strcmp_zbb.S | 81 +++++++++++++++++++++++++ arch/riscv/lib/strlen_zbb.S | 101 ++++++++++++++++++++++++++++++++ arch/riscv/lib/strncmp_zbb.S | 94 +++++++++++++++++++++++++++++ board/AndesTech/ae350/ae350.c | 25 ++++++++ common/spl/spl_fit.c | 3 +- common/spl/spl_opensbi.c | 31 ++++++---- configs/ae350_rv32_falcon_defconfig | 60 +++++++++++++++++++ configs/ae350_rv32_falcon_xip_defconfig | 61 +++++++++++++++++++ configs/ae350_rv64_falcon_defconfig | 60 +++++++++++++++++++ configs/ae350_rv64_falcon_xip_defconfig | 61 +++++++++++++++++++ configs/starfive_visionfive2_defconfig | 2 + 19 files changed, 738 insertions(+), 46 deletions(-) create mode 100644 arch/riscv/lib/strcmp_zbb.S create mode 100644 arch/riscv/lib/strlen_zbb.S create mode 100644 arch/riscv/lib/strncmp_zbb.S create mode 100644 configs/ae350_rv32_falcon_defconfig create mode 100644 configs/ae350_rv32_falcon_xip_defconfig create mode 100644 configs/ae350_rv64_falcon_defconfig create mode 100644 configs/ae350_rv64_falcon_xip_defconfig
Best regards, Leo
On Thu, Oct 19, 2023 at 07:41:24PM +0800, Leo Liang wrote:
Hi Tom,
Leo Liang
