[U-Boot-Users] Error reading environment with fw_printenv
I'm running fw_printenv tools on the target (ARM9 running Linux 2.6.9-rc2). MTD partitions work fine (tried to read some bytes with dd). I encounter the following problem. When the function flash_io (fw_env.c) tries to read the CRC and the flags, the function read reads just one byte instead of 5 as specified by len parameter ((line 538)):
if (read (fd, &environment, len) != len) { fprintf (stderr, "CRC read error on %s: %s\n", DEVNAME (curdev), strerror (errno)); return (-1); }
So the function quits even if errno==0.
Is it correct to assume that the read actually reads the specified number of bytes?
Regards,
llandre
DAVE Electronics System House - R&D Department web: http://www.dave-tech.it email: r&d2@dave-tech.it
Can you read the envrionment sector (use a combination of bs+ and skip= options with "dd" to get the right offset) ?
You mean the return code of read() is 1? Can you show me the strace output for this?
On a MTD device it should, unless it encounteres EOF. Are yoiu sure your configuration is OK?
I had an error in the fw_env.h file. I fixed it and now the environment is read correctly.
Thanks for your help,
llandre
llandre
