[U-Boot] [PATCH V4 1/3] fs: delete unused Makefile
fs/Makefile is unused. The top-level Makefile sets LIBS-y += fs/xxx and hence causes make to directly descend two directory levels into each individual filesystem, and it never descends into fs/ itself.
So, delete this useless file.
Signed-off-by: Stephen Warren swarren@nvidia.com Reviewed-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Acked-by: Simon Glass sjg@chromium.org --- v4: No change. v3: No change. v2: No change. --- fs/Makefile | 42 ------------------------------------------ 1 files changed, 0 insertions(+), 42 deletions(-) delete mode 100644 fs/Makefile
diff --git a/fs/Makefile b/fs/Makefile deleted file mode 100644 index 901e189..0000000 --- a/fs/Makefile +++ /dev/null @@ -1,42 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -# - -subdirs-$(CONFIG_CMD_CRAMFS) := cramfs -subdirs-$(CONFIG_CMD_EXT4) += ext4 -ifndef CONFIG_CMD_EXT4 -subdirs-$(CONFIG_CMD_EXT2) += ext4 -endif -subdirs-$(CONFIG_CMD_FAT) += fat -subdirs-$(CONFIG_CMD_FDOS) += fdos -subdirs-$(CONFIG_CMD_JFFS2) += jffs2 -subdirs-$(CONFIG_CMD_REISER) += reiserfs -subdirs-$(CONFIG_YAFFS2) += yaffs2 -subdirs-$(CONFIG_CMD_UBIFS) += ubifs -subdirs-$(CONFIG_CMD_ZFS) += zfs - -SUBDIRS := $(subdirs-y) - -$(obj).depend all: - @for dir in $(SUBDIRS) ; do \ - $(MAKE) -C $$dir $@ ; done
This makes the FAT and ext4 filesystem implementations build if CONFIG_FS_{FAT,EXT4} are defined, rather than basing the build on whether CONFIG_CMD_{FAT,EXT*} are defined. This will allow the filesystems to be built separately from the filesystem-specific commands that use them. This paves the way for the creation of filesystem-generic commands that used the filesystems, without requiring the filesystem- specific commands.
Minor documentation changes are made for this change.
The new config options are automatically selected by the old config options to retain backwards-compatibility.
Signed-off-by: Stephen Warren swarren@nvidia.com Reviewed-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- v4: No change. v3: No change. v2: New patch. --- README | 4 +++- doc/README.ext4 | 13 +++++++++++++ fs/ext4/Makefile | 7 ++----- fs/ext4/ext4_common.c | 2 +- fs/ext4/ext4_common.h | 4 ++-- fs/ext4/ext4fs.c | 2 +- fs/fat/Makefile | 4 ++-- include/config_fallbacks.h | 13 +++++++++++++ include/ext4fs.h | 2 +- 9 files changed, 38 insertions(+), 13 deletions(-)
diff --git a/README b/README index 9804cea..f22ed1b 100644 --- a/README +++ b/README @@ -801,9 +801,11 @@ The following options need to be configured: CONFIG_CMD_EEPROM * EEPROM read/write support CONFIG_CMD_ELF * bootelf, bootvx CONFIG_CMD_EXPORTENV * export the environment + CONFIG_CMD_EXT2 * ext2 command support + CONFIG_CMD_EXT4 * ext4 command support CONFIG_CMD_SAVEENV saveenv CONFIG_CMD_FDC * Floppy Disk Support - CONFIG_CMD_FAT * FAT partition support + CONFIG_CMD_FAT * FAT command support CONFIG_CMD_FDOS * Dos diskette Support CONFIG_CMD_FLASH flinfo, erase, protect CONFIG_CMD_FPGA FPGA device initialization support diff --git a/doc/README.ext4 b/doc/README.ext4 index b3ea8b7..b7d0ad3 100644 --- a/doc/README.ext4 +++ b/doc/README.ext4 @@ -1,15 +1,28 @@ This patch series adds support for ext4 ls,load and write features in uboot Journaling is supported for write feature.
+To enable support for the ext4 (and ext2) filesystem implementation, +#define CONFIG_FS_EXT4 + +If you want write support, +#define CONFIG_EXT4_WRITE + To Enable ext2 ls and load commands, modify the board specific config file with #define CONFIG_CMD_EXT2 +This automatically defines CONFIG_FS_EXT4 for you.
To Enable ext4 ls and load commands, modify the board specific config file with #define CONFIG_CMD_EXT4 +This automatically defines CONFIG_FS_EXT4 for you.
To enable ext4 write command, modify the board specific config file with #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE +These automatically define CONFIG_FS_EXT4 and CONFIG_EXT4_WRITE for you. + +Also relevant are the generic filesystem commands, +#define CONFIG_CMD_FS_GENERIC +This does not automatically enable EXT4 support for you.
Steps to test:
diff --git a/fs/ext4/Makefile b/fs/ext4/Makefile index 82cd9ae..bb801f9 100644 --- a/fs/ext4/Makefile +++ b/fs/ext4/Makefile @@ -30,11 +30,8 @@ include $(TOPDIR)/config.mk LIB = $(obj)libext4fs.o
AOBJS = -COBJS-$(CONFIG_CMD_EXT4) := ext4fs.o ext4_common.o dev.o -ifndef CONFIG_CMD_EXT4 -COBJS-$(CONFIG_CMD_EXT2) := ext4fs.o ext4_common.o dev.o -endif -COBJS-$(CONFIG_CMD_EXT4_WRITE) += ext4_journal.o crc16.o +COBJS-$(CONFIG_FS_EXT4) := ext4fs.o ext4_common.o dev.o +COBJS-$(CONFIG_EXT4_WRITE) += ext4_journal.o crc16.o
SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) diff --git a/fs/ext4/ext4_common.c b/fs/ext4/ext4_common.c index d6d55b9..323875f 100644 --- a/fs/ext4/ext4_common.c +++ b/fs/ext4/ext4_common.c @@ -56,7 +56,7 @@ int ext4fs_indir3_blkno = -1; struct ext2_inode *g_parent_inode; static int symlinknest;
-#if defined(CONFIG_CMD_EXT4_WRITE) +#if defined(CONFIG_EXT4_WRITE) uint32_t ext4fs_div_roundup(uint32_t size, uint32_t n) { uint32_t res = size / n; diff --git a/fs/ext4/ext4_common.h b/fs/ext4/ext4_common.h index f728134..87cab16 100644 --- a/fs/ext4/ext4_common.h +++ b/fs/ext4/ext4_common.h @@ -37,7 +37,7 @@ #include <ext4fs.h> #include <malloc.h> #include <asm/errno.h> -#if defined(CONFIG_CMD_EXT4_WRITE) +#if defined(CONFIG_EXT4_WRITE) #include "ext4_journal.h" #include "crc16.h" #endif @@ -71,7 +71,7 @@ int ext4fs_find_file(const char *path, struct ext2fs_node *rootnode, int ext4fs_iterate_dir(struct ext2fs_node *dir, char *name, struct ext2fs_node **fnode, int *ftype);
-#if defined(CONFIG_CMD_EXT4_WRITE) +#if defined(CONFIG_EXT4_WRITE) uint32_t ext4fs_div_roundup(uint32_t size, uint32_t n); int ext4fs_checksum_update(unsigned int i); int ext4fs_get_parent_inode_num(const char *dirname, char *dname, int flags); diff --git a/fs/ext4/ext4fs.c b/fs/ext4/ext4fs.c index 3a5ef20..06536ba 100644 --- a/fs/ext4/ext4fs.c +++ b/fs/ext4/ext4fs.c @@ -196,7 +196,7 @@ int ext4fs_read(char *buf, unsigned len) return ext4fs_read_file(ext4fs_file, 0, len, buf); }
-#if defined(CONFIG_CMD_EXT4_WRITE) +#if defined(CONFIG_EXT4_WRITE) static void ext4fs_update(void) { short i; diff --git a/fs/fat/Makefile b/fs/fat/Makefile index 9635d36..3e33e38 100644 --- a/fs/fat/Makefile +++ b/fs/fat/Makefile @@ -24,11 +24,11 @@ include $(TOPDIR)/config.mk LIB = $(obj)libfat.o
AOBJS = -COBJS-$(CONFIG_CMD_FAT) := fat.o +COBJS-$(CONFIG_FS_FAT) := fat.o COBJS-$(CONFIG_FAT_WRITE):= fat_write.o
ifndef CONFIG_SPL_BUILD -COBJS-$(CONFIG_CMD_FAT) += file.o +COBJS-$(CONFIG_FS_FAT) += file.o endif
SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index 430890c..bfb9680 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -13,4 +13,17 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } #endif
+#if defined(CONFIG_CMD_FAT) && !defined(CONFIG_FS_FAT) +#define CONFIG_FS_FAT +#endif + +#if (defined(CONFIG_CMD_EXT4) || defined(CONFIG_CMD_EXT2)) && \ + !defined(CONFIG_FS_EXT4) +#define CONFIG_FS_EXT4 +#endif + +#if defined(CONFIG_CMD_EXT4_WRITE) && !defined(CONFIG_EXT4_WRITE) +#define CONFIG_EXT4_WRITE +#endif + #endif /* __CONFIG_FALLBACKS_H */ diff --git a/include/ext4fs.h b/include/ext4fs.h index 23298fc..3b59d15 100644 --- a/include/ext4fs.h +++ b/include/ext4fs.h @@ -116,7 +116,7 @@ struct ext_filesystem { extern struct ext2_data *ext4fs_root; extern struct ext2fs_node *ext4fs_file;
-#if defined(CONFIG_CMD_EXT4_WRITE) +#if defined(CONFIG_EXT4_WRITE) extern struct ext2_inode *g_parent_inode; extern int gd_index; extern int gindex;
Implement "ls" and "fsload" commands that act like {fat,ext2}{ls,load}, and transparently handle either file-system. This scheme could easily be extended to other filesystem types; I only didn't do it for zfs because I don't have any filesystems of that type to test with.
Replace the implementation of {fat,ext[24]}{ls,load} with this new code too.
Signed-off-by: Stephen Warren swarren@nvidia.com --- v4: * Use FS_TYPE_* everywhere, rather than separate FS_* and FS_TYPE_*. * Make fs_set_blk_dev() loop over a table of filesystems. v3: * Updated the implementation of the new commands to be suitable for use as the body of {fat,ext[24]}{ls,load} too. * Enhanced the implementation to make more fsload parameters optional (load address, filename); they can now come from environment variables like ext2load supported. * Moved implementation into fs.c. * Removed cmd_ext_common.c. * s/partition/filesystem/ in patch subject. v2: * Build cmd_fs.c when CONFIG_CMD_FS_GENERIC not always. * Use new CONFIG_FS_{FAT,EXT4} rather than CONFIG_CMD_{FAT,EXT2}. * Implemented fs_close() and call it from the tail of fs_ls() and fs_read(). This ensures that any other usage of e.g. the ext4 library between fs_*() calls, then the two usages won't interfere. * Re-organized fs.c to reduce the number of ifdef blocks. * Added argc checking to do_ls(). --- Makefile | 3 +- common/Makefile | 6 +- common/cmd_ext2.c | 13 +-- common/cmd_ext4.c | 12 +-- common/cmd_ext_common.c | 197 ------------------------------ common/cmd_fat.c | 76 +----------- common/cmd_fs.c | 51 ++++++++ fs/Makefile | 47 +++++++ fs/fs.c | 308 +++++++++++++++++++++++++++++++++++++++++++++++ include/ext_common.h | 3 - include/fs.h | 65 ++++++++++ 11 files changed, 483 insertions(+), 298 deletions(-) delete mode 100644 common/cmd_ext_common.c create mode 100644 common/cmd_fs.c create mode 100644 fs/Makefile create mode 100644 fs/fs.c create mode 100644 include/fs.h
diff --git a/Makefile b/Makefile index ab34fa7..b92e2af 100644 --- a/Makefile +++ b/Makefile @@ -260,7 +260,8 @@ LIBS-y += drivers/net/npe/libnpe.o endif LIBS-$(CONFIG_OF_EMBED) += dts/libdts.o LIBS-y += arch/$(ARCH)/lib/lib$(ARCH).o -LIBS-y += fs/cramfs/libcramfs.o \ +LIBS-y += fs/libfs.o \ + fs/cramfs/libcramfs.o \ fs/ext4/libext4fs.o \ fs/fat/libfat.o \ fs/fdos/libfdos.o \ diff --git a/common/Makefile b/common/Makefile index a4eb477..cc22c52 100644 --- a/common/Makefile +++ b/common/Makefile @@ -88,11 +88,6 @@ COBJS-$(CONFIG_CMD_ELF) += cmd_elf.o COBJS-$(CONFIG_SYS_HUSH_PARSER) += cmd_exit.o COBJS-$(CONFIG_CMD_EXT4) += cmd_ext4.o COBJS-$(CONFIG_CMD_EXT2) += cmd_ext2.o -ifdef CONFIG_CMD_EXT4 -COBJS-y += cmd_ext_common.o -else -COBJS-$(CONFIG_CMD_EXT2) += cmd_ext_common.o -endif COBJS-$(CONFIG_CMD_FAT) += cmd_fat.o COBJS-$(CONFIG_CMD_FDC)$(CONFIG_CMD_FDOS) += cmd_fdc.o COBJS-$(CONFIG_OF_LIBFDT) += cmd_fdt.o fdt_support.o @@ -102,6 +97,7 @@ COBJS-$(CONFIG_CMD_FLASH) += cmd_flash.o ifdef CONFIG_FPGA COBJS-$(CONFIG_CMD_FPGA) += cmd_fpga.o endif +COBJS-$(CONFIG_CMD_FS_GENERIC) += cmd_fs.o COBJS-$(CONFIG_CMD_GPIO) += cmd_gpio.o COBJS-$(CONFIG_CMD_I2C) += cmd_i2c.o COBJS-$(CONFIG_CMD_IDE) += cmd_ide.o diff --git a/common/cmd_ext2.c b/common/cmd_ext2.c index c27d9c7..06d0234 100644 --- a/common/cmd_ext2.c +++ b/common/cmd_ext2.c @@ -37,15 +37,11 @@ /* * Ext2fs support */ -#include <common.h> -#include <ext_common.h> +#include <fs.h>
int do_ext2ls (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - if (do_ext_ls(cmdtp, flag, argc, argv)) - return -1; - - return 0; + return do_ls(cmdtp, flag, argc, argv, FS_TYPE_EXT); }
/****************************************************************************** @@ -53,10 +49,7 @@ int do_ext2ls (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) */ int do_ext2load (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - if (do_ext_load(cmdtp, flag, argc, argv)) - return -1; - - return 0; + return do_fsload(cmdtp, flag, argc, argv, FS_TYPE_EXT); }
U_BOOT_CMD( diff --git a/common/cmd_ext4.c b/common/cmd_ext4.c index ca46561..237bc19 100644 --- a/common/cmd_ext4.c +++ b/common/cmd_ext4.c @@ -47,10 +47,10 @@ #include <image.h> #include <linux/ctype.h> #include <asm/byteorder.h> -#include <ext_common.h> #include <ext4fs.h> #include <linux/stat.h> #include <malloc.h> +#include <fs.h>
#if defined(CONFIG_CMD_USB) && defined(CONFIG_USB_STORAGE) #include <usb.h> @@ -59,18 +59,12 @@ int do_ext4_load(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) { - if (do_ext_load(cmdtp, flag, argc, argv)) - return -1; - - return 0; + return do_fsload(cmdtp, flag, argc, argv, FS_TYPE_EXT); }
int do_ext4_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) { - if (do_ext_ls(cmdtp, flag, argc, argv)) - return -1; - - return 0; + return do_ls(cmdtp, flag, argc, argv, FS_TYPE_EXT); }
#if defined(CONFIG_CMD_EXT4_WRITE) diff --git a/common/cmd_ext_common.c b/common/cmd_ext_common.c deleted file mode 100644 index 1952f4d..0000000 --- a/common/cmd_ext_common.c +++ /dev/null @@ -1,197 +0,0 @@ -/* - * (C) Copyright 2011 - 2012 Samsung Electronics - * EXT2/4 filesystem implementation in Uboot by - * Uma Shankar uma.shankar@samsung.com - * Manjunatha C Achar a.manjunatha@samsung.com - * - * Ext4fs support - * made from existing cmd_ext2.c file of Uboot - * - * (C) Copyright 2004 - * esd gmbh <www.esd-electronics.com> - * Reinhard Arlt reinhard.arlt@esd-electronics.com - * - * made from cmd_reiserfs by - * - * (C) Copyright 2003 - 2004 - * Sysgo Real-Time Solutions, AG <www.elinos.com> - * Pavel Bartusek pba@sysgo.com - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - * - */ - -/* - * Changelog: - * 0.1 - Newly created file for ext4fs support. Taken from cmd_ext2.c - * file in uboot. Added ext4fs ls load and write support. - */ - -#include <common.h> -#include <part.h> -#include <config.h> -#include <command.h> -#include <image.h> -#include <linux/ctype.h> -#include <asm/byteorder.h> -#include <ext_common.h> -#include <ext4fs.h> -#include <linux/stat.h> -#include <malloc.h> - -#if defined(CONFIG_CMD_USB) && defined(CONFIG_USB_STORAGE) -#include <usb.h> -#endif - -#if !defined(CONFIG_DOS_PARTITION) && !defined(CONFIG_EFI_PARTITION) -#error DOS or EFI partition support must be selected -#endif - -#define DOS_PART_MAGIC_OFFSET 0x1fe -#define DOS_FS_TYPE_OFFSET 0x36 -#define DOS_FS32_TYPE_OFFSET 0x52 - -int do_ext_load(cmd_tbl_t *cmdtp, int flag, int argc, - char *const argv[]) -{ - char *filename = NULL; - int dev, part; - ulong addr = 0; - int filelen; - disk_partition_t info; - block_dev_desc_t *dev_desc; - char buf[12]; - unsigned long count; - const char *addr_str; - - count = 0; - addr = simple_strtoul(argv[3], NULL, 16); - filename = getenv("bootfile"); - switch (argc) { - case 3: - addr_str = getenv("loadaddr"); - if (addr_str != NULL) - addr = simple_strtoul(addr_str, NULL, 16); - else - addr = CONFIG_SYS_LOAD_ADDR; - - break; - case 4: - break; - case 5: - filename = argv[4]; - break; - case 6: - filename = argv[4]; - count = simple_strtoul(argv[5], NULL, 16); - break; - - default: - return cmd_usage(cmdtp); - } - - if (!filename) { - puts("** No boot file defined **\n"); - return 1; - } - - part = get_device_and_partition(argv[1], argv[2], &dev_desc, &info, 1); - if (part < 0) - return 1; - - dev = dev_desc->dev; - printf("Loading file "%s" from %s device %d%c%c\n", - filename, argv[1], dev, - part ? ':' : ' ', part ? part + '0' : ' '); - - ext4fs_set_blk_dev(dev_desc, &info); - - if (!ext4fs_mount(info.size)) { - printf("** Bad ext2 partition or disk - %s %d:%d **\n", - argv[1], dev, part); - ext4fs_close(); - goto fail; - } - - filelen = ext4fs_open(filename); - if (filelen < 0) { - printf("** File not found %s\n", filename); - ext4fs_close(); - goto fail; - } - if ((count < filelen) && (count != 0)) - filelen = count; - - if (ext4fs_read((char *)addr, filelen) != filelen) { - printf("** Unable to read "%s" from %s %d:%d **\n", - filename, argv[1], dev, part); - ext4fs_close(); - goto fail; - } - - ext4fs_close(); - /* Loading ok, update default load address */ - load_addr = addr; - - printf("%d bytes read\n", filelen); - sprintf(buf, "%X", filelen); - setenv("filesize", buf); - - return 0; -fail: - return 1; -} - -int do_ext_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) -{ - const char *filename = "/"; - int dev; - int part; - block_dev_desc_t *dev_desc; - disk_partition_t info; - - if (argc < 2) - return cmd_usage(cmdtp); - - part = get_device_and_partition(argv[1], argv[2], &dev_desc, &info, 1); - if (part < 0) - return 1; - - if (argc == 4) - filename = argv[3]; - - dev = dev_desc->dev; - ext4fs_set_blk_dev(dev_desc, &info); - - if (!ext4fs_mount(info.size)) { - printf("** Bad ext2 partition or disk - %s %d:%d **\n", - argv[1], dev, part); - ext4fs_close(); - goto fail; - } - - if (ext4fs_ls(filename)) { - printf("** Error extfs_ls() **\n"); - ext4fs_close(); - goto fail; - }; - - ext4fs_close(); - return 0; - -fail: - return 1; -} diff --git a/common/cmd_fat.c b/common/cmd_fat.c index c38302d..c865d6d 100644 --- a/common/cmd_fat.c +++ b/common/cmd_fat.c @@ -31,54 +31,11 @@ #include <ata.h> #include <part.h> #include <fat.h> - +#include <fs.h>
int do_fat_fsload (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - long size; - unsigned long offset; - unsigned long count = 0; - unsigned long pos = 0; - char buf [12]; - block_dev_desc_t *dev_desc=NULL; - disk_partition_t info; - int part, dev; - - if (argc < 5) { - printf("usage: fatload <interface> [<dev[:part]>] " - "<addr> <filename> [bytes [pos]]\n"); - return 1; - } - - part = get_device_and_partition(argv[1], argv[2], &dev_desc, &info, 1); - if (part < 0) - return 1; - - dev = dev_desc->dev; - if (fat_set_blk_dev(dev_desc, &info) != 0) { - printf("\n** Unable to use %s %d:%d for fatload **\n", - argv[1], dev, part); - return 1; - } - offset = simple_strtoul(argv[3], NULL, 16); - if (argc >= 6) - count = simple_strtoul(argv[5], NULL, 16); - if (argc >= 7) - pos = simple_strtoul(argv[6], NULL, 16); - size = file_fat_read_at(argv[4], pos, (unsigned char *)offset, count); - - if(size==-1) { - printf("\n** Unable to read "%s" from %s %d:%d **\n", - argv[4], argv[1], dev, part); - return 1; - } - - printf("\n%ld bytes read\n", size); - - sprintf(buf, "%lX", size); - setenv("filesize", buf); - - return 0; + return do_fsload(cmdtp, flag, argc, argv, FS_TYPE_FAT); }
@@ -96,34 +53,7 @@ U_BOOT_CMD(
int do_fat_ls (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - char *filename = "/"; - int ret, dev, part; - block_dev_desc_t *dev_desc=NULL; - disk_partition_t info; - - if (argc < 2) { - printf("usage: fatls <interface> [<dev[:part]>] [directory]\n"); - return 0; - } - - part = get_device_and_partition(argv[1], argv[2], &dev_desc, &info, 1); - if (part < 0) - return 1; - - dev = dev_desc->dev; - if (fat_set_blk_dev(dev_desc, &info) != 0) { - printf("\n** Unable to use %s %d:%d for fatls **\n", - argv[1], dev, part); - return 1; - } - if (argc == 4) - ret = file_fat_ls(argv[3]); - else - ret = file_fat_ls(filename); - - if(ret!=0) - printf("No Fat FS detected\n"); - return ret; + return do_ls(cmdtp, flag, argc, argv, FS_TYPE_FAT); }
U_BOOT_CMD( diff --git a/common/cmd_fs.c b/common/cmd_fs.c new file mode 100644 index 0000000..296124b --- /dev/null +++ b/common/cmd_fs.c @@ -0,0 +1,51 @@ +/* + * Copyright (c) 2012, NVIDIA CORPORATION. All rights reserved. + * + * Inspired by cmd_ext_common.c, cmd_fat.c. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#include <common.h> +#include <command.h> +#include <fs.h> + +int do_fsload_wrapper(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + return do_fsload(cmdtp, flag, argc, argv, FS_TYPE_ANY); +} + +U_BOOT_CMD( + fsload, 7, 0, do_fsload_wrapper, + "load binary file from a filesystem", + "<interface> [<dev[:part]> [<addr> [<filename> [bytes [pos]]]]]\n" + " - Load binary file 'filename' from partition 'part' on device\n" + " type 'interface' instance 'dev' to address 'addr' in memory.\n" + " 'bytes' gives the size to load in bytes.\n" + " If 'bytes' is 0 or omitted, the file is read until the end.\n" + " 'pos' gives the file byte position to start reading from.\n" + " If 'pos' is 0 or omitted, the file is read from the start." +); + +int do_ls_wrapper(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + return do_ls(cmdtp, flag, argc, argv, FS_TYPE_ANY); +} + +U_BOOT_CMD( + ls, 4, 1, do_ls_wrapper, + "list files in a directory (default /)", + "<interface> [<dev[:part]> [directory]]\n" + " - List files in directory 'directory' of partition 'part' on\n" + " device type 'interface' instance 'dev'." +); diff --git a/fs/Makefile b/fs/Makefile new file mode 100644 index 0000000..d0ab3ae --- /dev/null +++ b/fs/Makefile @@ -0,0 +1,47 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# Copyright (c) 2012, NVIDIA CORPORATION. All rights reserved. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)libfs.o + +COBJS-y += fs.o + +COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(LIB) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/fs/fs.c b/fs/fs.c new file mode 100644 index 0000000..23ffa25 --- /dev/null +++ b/fs/fs.c @@ -0,0 +1,308 @@ +/* + * Copyright (c) 2012, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#include <config.h> +#include <common.h> +#include <part.h> +#include <ext4fs.h> +#include <fat.h> +#include <fs.h> + +static block_dev_desc_t *fs_dev_desc; +static disk_partition_t fs_partition; +static int fs_type = FS_TYPE_ANY; + +static inline int fs_ls_unsupported(const char *dirname) +{ + printf("** Unrecognized filesystem type **\n"); + return -1; +} + +static inline int fs_read_unsupported(const char *filename, ulong addr, + int offset, int len) +{ + printf("** Unrecognized filesystem type **\n"); + return -1; +} + +#ifdef CONFIG_FS_FAT +static int fs_probe_fat(void) +{ + return fat_set_blk_dev(fs_dev_desc, &fs_partition); +} + +static void fs_close_fat(void) +{ +} + +#define fs_ls_fat file_fat_ls + +static int fs_read_fat(const char *filename, ulong addr, int offset, int len) +{ + int len_read; + + len_read = file_fat_read_at(filename, offset, + (unsigned char *)addr, len); + if (len_read == -1) { + printf("** Unable to read file %s **\n", filename); + return -1; + } + + return len_read; +} +#else +static inline int fs_probe_fat(void) +{ + return -1; +} + +static inline void fs_close_fat(void) +{ +} + +#define fs_ls_fat fs_ls_unsupported +#define fs_read_fat fs_read_unsupported +#endif + +#ifdef CONFIG_FS_EXT4 +static int fs_probe_ext(void) +{ + ext4fs_set_blk_dev(fs_dev_desc, &fs_partition); + + if (!ext4fs_mount(fs_partition.size)) { + ext4fs_close(); + return -1; + } + + return 0; +} + +static void fs_close_ext(void) +{ + ext4fs_close(); +} + +#define fs_ls_ext ext4fs_ls + +static int fs_read_ext(const char *filename, ulong addr, int offset, int len) +{ + int file_len; + int len_read; + + if (offset != 0) { + printf("** Cannot support non-zero offset **\n"); + return -1; + } + + file_len = ext4fs_open(filename); + if (file_len < 0) { + printf("** File not found %s **\n", filename); + ext4fs_close(); + return -1; + } + + if (len == 0) + len = file_len; + + len_read = ext4fs_read((char *)addr, len); + ext4fs_close(); + + if (len_read != len) { + printf("** Unable to read file %s **\n", filename); + return -1; + } + + return len_read; +} +#else +static inline int fs_probe_ext(void) +{ + return -1; +} + +static inline void fs_close_ext(void) +{ +} + +#define fs_ls_ext fs_ls_unsupported +#define fs_read_ext fs_read_unsupported +#endif + +static const struct { + int fstype; + int (*probe)(void); +} fstypes[] = { + { + .fstype = FS_TYPE_FAT, + .probe = fs_probe_fat, + }, + { + .fstype = FS_TYPE_EXT, + .probe = fs_probe_ext, + }, +}; + +int fs_set_blk_dev(const char *ifname, const char *dev_part_str, int fstype) +{ + int part, i; + + part = get_device_and_partition(ifname, dev_part_str, &fs_dev_desc, + &fs_partition, 1); + if (part < 0) + return -1; + + for (i = 0; i < ARRAY_SIZE(fstypes); i++) { + if ((fstype != FS_TYPE_ANY) && (fstype != fstypes[i].fstype)) + continue; + + if (!fstypes[i].probe()) { + fs_type = fstypes[i].fstype; + return 0; + } + } + + printf("** Unrecognized filesystem type **\n"); + return -1; +} + +static void fs_close(void) +{ + switch (fs_type) { + case FS_TYPE_FAT: + fs_close_fat(); + break; + case FS_TYPE_EXT: + fs_close_ext(); + break; + default: + break; + } + + fs_type = FS_TYPE_ANY; +} + +int fs_ls(const char *dirname) +{ + int ret; + + switch (fs_type) { + case FS_TYPE_FAT: + ret = fs_ls_fat(dirname); + break; + case FS_TYPE_EXT: + ret = fs_ls_ext(dirname); + break; + default: + ret = fs_ls_unsupported(dirname); + break; + } + + fs_close(); + + return ret; +} + +int fs_read(const char *filename, ulong addr, int offset, int len) +{ + int ret; + + switch (fs_type) { + case FS_TYPE_FAT: + ret = fs_read_fat(filename, addr, offset, len); + break; + case FS_TYPE_EXT: + ret = fs_read_ext(filename, addr, offset, len); + break; + default: + ret = fs_read_unsupported(filename, addr, offset, len); + break; + } + + fs_close(); + + return ret; +} + +int do_fsload(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], + int fstype) +{ + unsigned long addr; + const char *addr_str; + const char *filename; + unsigned long bytes; + unsigned long pos; + int len_read; + char buf[12]; + + if (argc < 5) + return CMD_RET_USAGE; + + if (fs_set_blk_dev(argv[1], argv[2], fstype)) + return 1; + + if (argc >= 4) { + addr = simple_strtoul(argv[3], NULL, 0); + } else { + addr_str = getenv("loadaddr"); + if (addr_str != NULL) + addr = simple_strtoul(addr_str, NULL, 16); + else + addr = CONFIG_SYS_LOAD_ADDR; + } + if (argc >= 5) { + filename = argv[4]; + } else { + filename = getenv("bootfile"); + if (!filename) { + puts("** No boot file defined **\n"); + return 1; + } + } + if (argc >= 6) + bytes = simple_strtoul(argv[5], NULL, 0); + else + bytes = 0; + if (argc >= 7) + pos = simple_strtoul(argv[6], NULL, 0); + else + pos = 0; + + len_read = fs_read(filename, addr, pos, bytes); + if (len_read <= 0) + return 1; + + printf("%d bytes read\n", len_read); + + sprintf(buf, "0x%x", len_read); + setenv("filesize", buf); + + return 0; +} + +int do_ls(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], + int fstype) +{ + if (argc < 2) + return CMD_RET_USAGE; + + if (fs_set_blk_dev(argv[1], (argc >= 3) ? argv[2] : NULL, fstype)) + return 1; + + if (fs_ls(argc == 4 ? argv[3] : "/")) + return 1; + + return 0; +} diff --git a/include/ext_common.h b/include/ext_common.h index ce73857..86373a6 100644 --- a/include/ext_common.h +++ b/include/ext_common.h @@ -195,7 +195,4 @@ int do_ext4_load(cmd_tbl_t *cmdtp, int flag, int argc, int do_ext4_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]); int do_ext4_write(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]); -int do_ext_load(cmd_tbl_t *cmdtp, int flag, int argc, - char *const argv[]); -int do_ext_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]); #endif diff --git a/include/fs.h b/include/fs.h new file mode 100644 index 0000000..f396d84 --- /dev/null +++ b/include/fs.h @@ -0,0 +1,65 @@ +/* + * Copyright (c) 2012, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ +#ifndef _FS_H +#define _FS_H + +#include <common.h> + +#define FS_TYPE_ANY 0 +#define FS_TYPE_FAT 1 +#define FS_TYPE_EXT 2 + +/* + * Tell the fs layer which block device an partition to use for future + * commands. This also internally identifies the filesystem that is present + * within the partition. The identification process may be limited to a + * specific filesystem type by passing FS_* in the fstype parameter. + * + * Returns 0 on success. + * Returns non-zero if there is an error accessing the disk or partition, or + * no known filesystem type could be recognized on it. + */ +int fs_set_blk_dev(const char *ifname, const char *dev_part_str, int fstype); + +/* + * Print the list of files on the partition previously set by fs_set_blk_dev(), + * in directory "dirname". + * + * Returns 0 on success. Returns non-zero on error. + */ +int fs_ls(const char *dirname); + +/* + * Read file "filename" from the partition previously set by fs_set_blk_dev(), + * to address "addr", starting at byte offset "offset", and reading "len" + * bytes. "offset" may be 0 to read from the start of the file. "len" may be + * 0 to read the entire file. Note that not all filesystem types support + * either/both offset!=0 or len!=0. + * + * Returns number of bytes read on success. Returns <= 0 on error. + */ +int fs_read(const char *filename, ulong addr, int offset, int len); + +/* + * Common implementation for various filesystem commands, optionally limited + * to a specific filesystem type via the fstype parameter. + */ +int do_fsload(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], + int fstype); +int do_ls(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], + int fstype); + +#endif /* _FS_H */
Dear all,
this patch (namely 045fa1e1142552799ad3203e9e0bc22a11e866ea) seems to break avr32 on runtime. It seems there is a new array introduced (the fstypes array in fs/fs.c) which do not provide a relocation method (CONFIG_NEEDS_MANUAL_RELOC). This is currently only a weak assumption, but has any other requiring manual relocation m86k, mips, nds32m sparc) also encountered this problem?
<snip>
<snip>
- int fstype;
- int (*probe)(void);
+} fstypes[] = {
I currently think this should be manually relocated for those arches which need the manual relocation.
- int part, i;
- part = get_device_and_partition(ifname, dev_part_str, &fs_dev_desc,
&fs_partition, 1);
- if (part < 0)
return -1;
- for (i = 0; i < ARRAY_SIZE(fstypes); i++) {
continue;
- printf("** Unrecognized filesystem type **\n");
- return -1;
Best regards
Andreas Bießmann
On Tue, Oct 30, 2012 at 12:05:37PM +0100, Andreas Bie?mann wrote:
Dear all,
Urk, sorry. Can you prepare and test a patch? Thanks!
Commit 045fa1e1142552799ad3203e9e0bc22a11e866ea introduce an array with filesystem accessors. On arches which need manual reloc this is broken cause the function pointers still pointing to the privious location, fix it.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Cc: swarren@wwwdotorg.org Cc: trini@ti.com --- fs/fs.c | 16 +++++++++++++++- 1 file changed, 15 insertions(+), 1 deletion(-)
diff --git a/fs/fs.c b/fs/fs.c index 23ffa25..66feb30 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -21,6 +21,8 @@ #include <fat.h> #include <fs.h>
+DECLARE_GLOBAL_DATA_PTR; + static block_dev_desc_t *fs_dev_desc; static disk_partition_t fs_partition; static int fs_type = FS_TYPE_ANY; @@ -141,7 +143,7 @@ static inline void fs_close_ext(void) #define fs_read_ext fs_read_unsupported #endif
-static const struct { +static struct { int fstype; int (*probe)(void); } fstypes[] = { @@ -158,6 +160,18 @@ static const struct { int fs_set_blk_dev(const char *ifname, const char *dev_part_str, int fstype) { int part, i; +#ifdef CONFIG_NEEDS_MANUAL_RELOC + static int relocated = 0; + + /* relocate fstypes[].probe */ + if (!relocated) { + int i; + for (i = 0; i < ARRAY_SIZE(fstypes); i++) + if (fstypes[i].probe != NULL) + fstypes[i].probe += gd->reloc_off; + relocated = 1; + } +#endif
part = get_device_and_partition(ifname, dev_part_str, &fs_dev_desc, &fs_partition, 1);
We found the same code to copy:-)
- static int relocated = 0;
checkpatch bitches about the "= 0" there. I assume BSS initialization isn't also broken when CONFIG_NEEDS_MANUAL_RELOC is enabled?
The only other example of relocation this way also does an inital assignment to 0. Andreas, can you run-time test? Thanks.
Dear Stephen Warren,
we did ;)
For AVR32 BSS initialization is working correctly, I do not know how the other arches behave, but I think it is Ok to remove the '0' here. Also the check for fstypes[i].probe != NULL in my patch seems to be not necessary. So I would favor using your patch then.
Best regards
Andreas Bießmann
Without this, fstypes[].probe points at the wrong place, so calling the function results in undefined behaviour.
Signed-off-by: Stephen Warren swarren@nvidia.com --- Note: I have compile-tested this with the relocation code forcibly enabled, but have no way of actually testing the result. --- fs/fs.c | 13 ++++++++++++- 1 files changed, 12 insertions(+), 1 deletions(-)
diff --git a/fs/fs.c b/fs/fs.c index 23ffa25..e148a07 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -21,6 +21,8 @@ #include <fat.h> #include <fs.h>
-static const struct { +static struct { int fstype; int (*probe)(void); } fstypes[] = { @@ -158,6 +160,15 @@ static const struct { int fs_set_blk_dev(const char *ifname, const char *dev_part_str, int fstype) { int part, i; +#ifdef CONFIG_NEEDS_MANUAL_RELOC + static int relocated; + + if (!relocated) { + for (i = 0; i < ARRAY_SIZE(fstypes); i++) + fstypes[i].probe += gd->reloc_off; + relocated = 1; + } +#endif
Tested on AVR32 (atstk1002)
Tested-by: Andreas Bießmann andreas.devel@googlemail.com
Best regards
Andreas Bießmann
Tested-by: Andreas Bie?mann andreas.devel@googlemail.com
Hi Stephen,
Sorry to come after this has been applied. I've been ultra busy lately.
[--snip--]
[--snip--]
int fstype)
- unsigned long addr;
- const char *filename;
- unsigned long bytes;
- unsigned long pos;
- int len_read;
- char buf[12];
- if (argc < 5)
With the arguments now made optional, this should rather be: + if (argc < 2)
- if (fs_set_blk_dev(argv[1], argv[2], fstype))
With <dev[:part]> being optional, this should rather be: + if (fs_set_blk_dev(argv[1], (argc >= 3) ? argv[2] : NULL, fstype))
return 1;
- if (argc >= 4) {
0 is just natural here. However, this raises the issue of the users of the legacy fat and ext commands, which used 16 here. So should we use 0 because it is cleaner, or 16 in order not to break compatibility for existing users?
- } else {
Ditto.
else
- if (argc >= 5) {
filename = argv[4];
- } else {
if (!filename) {
return 1;
- if (argc >= 6)
Ditto.
- else
bytes = 0;
- if (argc >= 7)
Ditto.
- else
pos = 0;
- len_read = fs_read(filename, addr, pos, bytes);
- if (len_read <= 0)
return 1;
- printf("%d bytes read\n", len_read);
- sprintf(buf, "0x%x", len_read);
- int fstype)
- if (argc < 2)
- if (fs_set_blk_dev(argv[1], (argc >= 3) ? argv[2] : NULL, fstype))
return 1;
- if (fs_ls(argc == 4 ? argv[3] : "/"))
IMHO, it would be better to just ignore the possible extra arguments, like in: + if (fs_ls(argc >= 4 ? argv[3] : "/"))
return 1;
[--snip--]
Best regards, Benoît
On 10/30/2012 02:23 PM, Benoît Thébaudeau wrote:
Hi Stephen,
return 1;
- if (argc >= 4) {
Oh yes, that is a problem.
I think we should use 0 here for the new commands at least; it has always annoyed me that U-Boot assumes that clearly non-hex values (since there is no 0x) are actually hex. I often have to manually convert values because of this (e.g. host-based ls decimal output to U-Boot command input expecting hex without leading 0x.)
However, we do need to fix this for the existing legacy commands. I suggest we either:
a) Add a new parameter to do_fsload() indicating which base to use.
or:
b) Assume base 0 if fstype==FS_TYPE_ANY, otherwise use 16.
(a) is probably cleaner.
For the environment variables, I suppose we need to continue to explicitly request base 16 conversion, since those variables could be used with either the old or the new commands.
- int fstype)
- if (argc < 2)
return 1;
- if (fs_ls(argc >= 4 ? argv[3] : "/"))
Here I don't agree. If the command expects a certain set of arguments, we should validate that the user provided exactly that set, and no more. If we allow arbitrary cruft, then if we need to add new arguments later, we won't be able to guarantee that handling those extra arguments won't break some existing broken usage of the command.
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Hi Stephen,
I feel I should be donning a brown paper bag here as well.
I feel your pain (and have gotten in the habit of doing lots of printf + shell math) but don't like changing expectations on the users, even if they are seemingly odd (since they've gotten used to them too).
or:
I agree with (a) along with adding to the help which parts are read in as decimal at the cli.
- -- Tom
- int fstype)
- if (argc < 2)
fstype))
return 1;
My comment was misleading. Actually, with the current code, do_ls() can not be called (except directly) if there are more than 4 arguments, because of the way the ls command is declared through U_BOOT_CMD(). Hence, if ">=" is used, arguments can be added later without changing existing lines.
And if we consider a direct call to do_ls() skipping the command system, then this function should return CMD_RET_USAGE if argc > 4.
- int fstype)
- if (argc < 2)
fstype))
return 1;
Ah OK, that makes sense.
True.
v4:
- Use FS_TYPE_* everywhere, rather than separate FS_* and FS_TYPE_*.
- Make fs_set_blk_dev() loop over a table of filesystems.
v3:
- Updated the implementation of the new commands to be suitable for use as the body of {fat,ext[24]}{ls,load} too.
- Enhanced the implementation to make more fsload parameters optional (load address, filename); they can now come from environment variables like ext2load supported.
- Moved implementation into fs.c.
- Removed cmd_ext_common.c.
- s/partition/filesystem/ in patch subject.
v2:
- Build cmd_fs.c when CONFIG_CMD_FS_GENERIC not always.
- Use new CONFIG_FS_{FAT,EXT4} rather than CONFIG_CMD_{FAT,EXT2}.
- Implemented fs_close() and call it from the tail of fs_ls() and fs_read(). This ensures that any other usage of e.g. the ext4 library between fs_*() calls, then the two usages won't interfere.
- Re-organized fs.c to reduce the number of ifdef blocks.
- Added argc checking to do_ls().
<snip>
- Copyright (c) 2012, NVIDIA CORPORATION. All rights reserved.
- Inspired by cmd_ext_common.c, cmd_fat.c.
- This program is free software; you can redistribute it and/or modify it
- under the terms and conditions of the GNU General Public License,
- version 2, as published by the Free Software Foundation.
- This program is distributed in the hope it will be useful, but WITHOUT
- ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
- FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
- more details.
- along with this program. If not, see http://www.gnu.org/licenses/.
- return do_fsload(cmdtp, flag, argc, argv, FS_TYPE_ANY);
+U_BOOT_CMD(
- fsload, 7, 0, do_fsload_wrapper,
I just realized that cmd_jffs2.c also defines a U_BOOT_CMD fsload ... this may also be a problem for users of the old command!
However if one defines CONFIG_CMD_JFFS2 _and_ CONFIG_CMD_FS_GENERIC the linker will throw following warning:
---8<--- /tmp/build_avr32/common/cmd_jffs2.o:(.u_boot_list.cmd.fsload+0x0): multiple definition of `_u_boot_list_cmd_fsload' /tmp/build_avr32/common/cmd_fs.o:(.u_boot_list.cmd.fsload+0x0): first defined here /tmp/build_avr32/common/cmd_jffs2.o:(.u_boot_list.cmd.ls+0x0): multiple definition of `_u_boot_list_cmd_ls' /tmp/build_avr32/common/cmd_fs.o:(.u_boot_list.cmd.ls+0x0): first defined here --->8---
Was this intended?
Best regards
Andreas Bießmann
v4:
v3:
v2:
<snip>
- more details.
+U_BOOT_CMD(
Was this intended?
No, this is certainly a problem. I guess we need to rename the new command.
I had originally thought about calling it plain "load" rather than "fsload" (just like it's "ls" not "fsls"). However, that seemed far too generic. However, given this conflict, and the fact that I don't think there's any existing "load" command, perhaps we have no choice but to s/fsload/load/, unless anyone has any better ideas? "fileload"?
Signed-off-by: Stephen Warren swarren@nvidia.com Reviewed-by: Beno??t Th??baudeau benoit.thebaudeau@advansee.com Acked-by: Simon Glass sjg@chromium.org
This, and the series, now applied to u-boot/master, thanks!
Andreas Bießmann
Benoît Thébaudeau
Stephen Warren
