[U-Boot] How to enable 2 FCC Ports while booting using CONFIG_NET_MULTI
Dear All, please let me know how to enable two Ethernet Ports in U-boot for MPC8280 at booting time. After booting i should be able to ping the two ports i.e. FCC1 and FCC2 only by connecting the ethernet cable to the repective port (FCC1 & FCC2.
currently i have enabled one port FCC2 as ethact port, can i change this depending by which port i want to ping.
i came to know about CONFIG_NET_MULTI whether this will be the solution for using two ports at a time.
With Thanks and Regards, Gurumurthy
Dear "Gurumurthy Gowdar",
In message 20091027063046.45327.qmail@f4mail-235-243.rediffmail.com you wrote:
You don't. You don;t do this at all.
U-Boot does not enable any peripherals "at booting time". This is a design principle, see http://www.denx.de/wiki/view/U-Boot/DesignPrinciples#2_Keep_it_Fast
Ethernet ininitlization is only done when U-Boot attempts to perform a network command, and then only that single interface gets initialized which U-Boot is going to use.
Yes, you can toggle between several ports. But keep in mind that only one of them will be active at any time, if any at all.
You cannot use two ports at the same time, only one or the other. But it is possible to switch at runtime (either automatically when a download fails or manually by setting the "ethact" environment variable accordingly).
Gurumurthy Gowdar
