[U-Boot] [PATCH] IXP425: make cmd_go handle caches correctly Part 1/1
This patch adds icache_invalidate() and dcache_flush() to cpu/ixp/cpu.c.
Also it adds do_go_exec() which is called from do_go(). This private implementation performs cache handling before jumping into the code.
Without this cache handling, you will jump into stale code if you download a program several times.
The patch is against "latest" u-boot git-repository
Please (still) be patient if style of submission or patches are offending.
Signed-off-by: Stefan Althoefer stefan.althoefer@web.de ----
diff -uprN u-boot-orig//cpu/ixp/cpu.c u-boot/cpu/ixp/cpu.c --- u-boot-orig//cpu/ixp/cpu.c 2008-12-02 17:25:31.000000000 +0100 +++ u-boot/cpu/ixp/cpu.c 2008-12-03 11:35:37.000000000 +0100 @@ -171,6 +207,22 @@ int icache_status (void) return (i & 0x1000); }
+void icache_invalidate (void) +{ + register u32 i; + + /* FIXME: Required to check if icache is enabled before we do this? */ + + /* invalidate I-cache (i is ignored)*/ + i = 0; + asm ("mcr p15, 0, %0, c7, c5, 0": :"r" (i)); + + /* cpwait */ + asm ("mrc p15,0,%0,c2,c0,0;\ + mov %0,%0;\ + sub pc,pc,#4" : : "r" (i) ); +} + /* we will never enable dcache, because we have to setup MMU first */ void dcache_enable (void) { @@ -187,6 +239,11 @@ int dcache_status (void) return 0; /* always off */ }
+void dcache_flush (void) +{ + return; +} + /* FIXME */ /* void pci_init(void) @@ -195,6 +252,17 @@ void pci_init(void) } */
+/* With IXP (and ARM generally) we need to handle caches to avoid + stale data. */ +unsigned long do_go_exec (ulong (*entry)(int, char *[]), int argc, char *argv[]) +{ + dcache_flush(); + icache_invalidate(); + + return entry (argc, argv); +} + + #ifdef CONFIG_BOOTCOUNT_LIMIT
void bootcount_store (ulong a)
Dear Stefan Althoefer,
Coding style: please use TABs for indentation.
And move such comments below th e"---" line, please.
Sorry for the spaces.
BTW: In function calls: Is the space between function name are opening bracket desired or not? Seems this is handled very inconsistent.
-- Stefan
cpu/ixp/cpu.c | 32 ++++++++++++++++++++++++++++++++ 1 files changed, 32 insertions(+), 0 deletions(-)
diff --git a/cpu/ixp/cpu.c b/cpu/ixp/cpu.c index 27872fb..9035d98 100644 --- a/cpu/ixp/cpu.c +++ b/cpu/ixp/cpu.c @@ -171,6 +171,22 @@ int icache_status (void) return (i & 0x1000); }
+void icache_invalidate (void) +{ + register u32 i; + + /* FIXME: Required to check if icache is enabled before we do this? */ + + /* invalidate I-cache (i is ignored)*/ + i = 0; + asm ("mcr p15, 0, %0, c7, c5, 0": :"r" (i)); + + /* cpwait */ + asm ("mrc p15,0,%0,c2,c0,0;\ + mov %0,%0;\ + sub pc,pc,#4" : : "r" (i) ); +} + /* we will never enable dcache, because we have to setup MMU first */ void dcache_enable (void) { @@ -187,6 +203,11 @@ int dcache_status (void) return 0; /* always off */ }
+void dcache_flush (void) +{ + return; +} + /* FIXME */ /* void pci_init(void) @@ -195,6 +216,17 @@ void pci_init(void) } */
+/* With IXP (and ARM generally) we need to handle caches to avoid + stale data. */ +unsigned long do_go_exec (ulong (*entry)(int, char *[]), int argc, char *argv[]) +{ + dcache_flush (); + icache_invalidate (); + + return entry (argc, argv); +} + + #ifdef CONFIG_BOOTCOUNT_LIMIT
- register u32 i;
why do you need it?
- /* FIXME: Required to check if icache is enabled before we do this? */
- /* invalidate I-cache (i is ignored)*/
- i = 0;
- asm ("mcr p15, 0, %0, c7, c5, 0": :"r" (i));
- /* cpwait */
- asm ("mrc p15,0,%0,c2,c0,0;\
mov %0,%0;\
- return;
general arm function need to be in the lib_arm
- stale data. */
- dcache_flush ();
- icache_invalidate ();
- return entry (argc, argv);
Best Regards, J.
Jean-Christophe PLAGNIOL-VILLARD
Stefan Althoefer
